RTEMS 6.1-rc4
Port control 2, ports > 0 (PCTRL2)
This group contains register bit definitions. More...
#define GRSPWROUTER_PCTRL2_SM_SHIFT   24
#define GRSPWROUTER_PCTRL2_SM_MASK   0xff000000U
#define GRSPWROUTER_PCTRL2_SM_GET(_reg)
#define GRSPWROUTER_PCTRL2_SM_SET(_reg, _val)
#define GRSPWROUTER_PCTRL2_SM(_val)
#define GRSPWROUTER_PCTRL2_SV_SHIFT   16
#define GRSPWROUTER_PCTRL2_SV_MASK   0xff0000U
#define GRSPWROUTER_PCTRL2_SV_GET(_reg)
#define GRSPWROUTER_PCTRL2_SV_SET(_reg, _val)
#define GRSPWROUTER_PCTRL2_SV(_val)
#define GRSPWROUTER_PCTRL2_OR   0x8000U
#define GRSPWROUTER_PCTRL2_UR   0x4000U
#define GRSPWROUTER_PCTRL2_R   0x2000U
#define GRSPWROUTER_PCTRL2_AT   0x1000U
#define GRSPWROUTER_PCTRL2_AR   0x800U
#define GRSPWROUTER_PCTRL2_IT   0x400U
#define GRSPWROUTER_PCTRL2_IR   0x200U
#define GRSPWROUTER_PCTRL2_SD_SHIFT   1
#define GRSPWROUTER_PCTRL2_SD_MASK   0x3eU
#define GRSPWROUTER_PCTRL2_SD_GET(_reg)
#define GRSPWROUTER_PCTRL2_SD_SET(_reg, _val)
#define GRSPWROUTER_PCTRL2_SD(_val)
#define GRSPWROUTER_PCTRL2_SC   0x1U
◆ GRSPWROUTER_PCTRL2_SD
#define GRSPWROUTER_PCTRL2_SD (   _val)
Value:
( ( ( _val ) << GRSPWROUTER_PCTRL2_SD_SHIFT ) & \
GRSPWROUTER_PCTRL2_SD_MASK )
◆ GRSPWROUTER_PCTRL2_SD_GET
#define GRSPWROUTER_PCTRL2_SD_GET (   _reg)
Value:
( ( ( _reg ) & GRSPWROUTER_PCTRL2_SD_MASK ) >> \
◆ GRSPWROUTER_PCTRL2_SD_SET
#define GRSPWROUTER_PCTRL2_SD_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GRSPWROUTER_PCTRL2_SD_MASK ) | \
GRSPWROUTER_PCTRL2_SD_MASK ) )
◆ GRSPWROUTER_PCTRL2_SM
#define GRSPWROUTER_PCTRL2_SM (   _val)
Value:
( ( ( _val ) << GRSPWROUTER_PCTRL2_SM_SHIFT ) & \
GRSPWROUTER_PCTRL2_SM_MASK )
◆ GRSPWROUTER_PCTRL2_SM_GET
#define GRSPWROUTER_PCTRL2_SM_GET (   _reg)
Value:
( ( ( _reg ) & GRSPWROUTER_PCTRL2_SM_MASK ) >> \
◆ GRSPWROUTER_PCTRL2_SM_SET
#define GRSPWROUTER_PCTRL2_SM_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GRSPWROUTER_PCTRL2_SM_MASK ) | \
GRSPWROUTER_PCTRL2_SM_MASK ) )
◆ GRSPWROUTER_PCTRL2_SV
#define GRSPWROUTER_PCTRL2_SV (   _val)
Value:
( ( ( _val ) << GRSPWROUTER_PCTRL2_SV_SHIFT ) & \
GRSPWROUTER_PCTRL2_SV_MASK )
◆ GRSPWROUTER_PCTRL2_SV_GET
#define GRSPWROUTER_PCTRL2_SV_GET (   _reg)
Value:
( ( ( _reg ) & GRSPWROUTER_PCTRL2_SV_MASK ) >> \
◆ GRSPWROUTER_PCTRL2_SV_SET
#define GRSPWROUTER_PCTRL2_SV_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GRSPWROUTER_PCTRL2_SV_MASK ) | \
GRSPWROUTER_PCTRL2_SV_MASK ) )
