RTEMS 6.1-rc4
Files | Functions
I2C Support. More...
file  i2c.c
 I2C support implementation.
file  i2c.h
 I2C support API.
rtems_status_code lpc32xx_i2c_init (volatile lpc32xx_i2c *i2c, unsigned clock_in_hz)
 Initializes the I2C module i2c.
void lpc32xx_i2c_reset (volatile lpc32xx_i2c *i2c)
 Resets the I2C module i2c.
rtems_status_code lpc32xx_i2c_clock (volatile lpc32xx_i2c *i2c, unsigned clock_in_hz)
 Sets the I2C module i2c clock.
rtems_status_code lpc32xx_i2c_write_start (volatile lpc32xx_i2c *i2c, unsigned addr)
 Starts a write transaction on the I2C module i2c.
rtems_status_code lpc32xx_i2c_write_with_optional_stop (volatile lpc32xx_i2c *i2c, const uint8_t *out, size_t n, bool stop)
 Writes data via the I2C module i2c with optional stop.
rtems_status_code lpc32xx_i2c_read_start (volatile lpc32xx_i2c *i2c, unsigned addr)
 Starts a read transaction on the I2C module i2c.
rtems_status_code lpc32xx_i2c_read_with_optional_stop (volatile lpc32xx_i2c *i2c, uint8_t *in, size_t n, bool stop)
 Reads data via the I2C module i2c with optional stop.
rtems_status_code lpc32xx_i2c_write_and_read (volatile lpc32xx_i2c *i2c, unsigned addr, const uint8_t *out, size_t out_size, uint8_t *in, size_t in_size)
 Writes and reads data via the I2C module i2c.
I2C Clock Control Register (I2CCLK_CTRL)
#define I2CCLK_1_EN   BSP_BIT32(0)
#define I2CCLK_2_EN   BSP_BIT32(1)
#define I2CCLK_1_HIGH_DRIVE   BSP_BIT32(2)
#define I2CCLK_2_HIGH_DRIVE   BSP_BIT32(3)
#define I2CCLK_USB_HIGH_DRIVE   BSP_BIT32(4)
I2C TX Data FIFO Register (I2Cn_TX)
#define I2C_TX_READ   BSP_BIT32(0)
#define I2C_TX_ADDR(val)   BSP_FLD32(val, 1, 7)
#define I2C_TX_START   BSP_BIT32(8)
#define I2C_TX_STOP   BSP_BIT32(9)
I2C Status Register (I2Cn_STAT)
#define I2C_STAT_TDI   BSP_BIT32(0)
#define I2C_STAT_AFI   BSP_BIT32(1)
#define I2C_STAT_NAI   BSP_BIT32(2)
#define I2C_STAT_DRMI   BSP_BIT32(3)
#define I2C_STAT_DRSI   BSP_BIT32(4)
#define I2C_STAT_ACTIVE   BSP_BIT32(5)
#define I2C_STAT_SCL   BSP_BIT32(6)
#define I2C_STAT_SDA   BSP_BIT32(7)
#define I2C_STAT_RFF   BSP_BIT32(8)
#define I2C_STAT_RFE   BSP_BIT32(9)
#define I2C_STAT_TFF   BSP_BIT32(10)
#define I2C_STAT_TFE   BSP_BIT32(11)
#define I2C_STAT_TFFS   BSP_BIT32(12)
#define I2C_STAT_TFES   BSP_BIT32(13)
I2C Control Register (I2Cn_CTRL)
#define I2C_CTRL_TDIE   BSP_BIT32(0)
#define I2C_CTRL_AFIE   BSP_BIT32(1)
#define I2C_CTRL_NAIE   BSP_BIT32(2)
#define I2C_CTRL_DRMIE   BSP_BIT32(3)
#define I2C_CTRL_DRSIE   BSP_BIT32(4)
#define I2C_CTRL_RFFIE   BSP_BIT32(5)
#define I2C_CTRL_RFDAIE   BSP_BIT32(6)
#define I2C_CTRL_TFFIO   BSP_BIT32(7)
#define I2C_CTRL_RESET   BSP_BIT32(8)
#define I2C_CTRL_SEVEN   BSP_BIT32(9)
#define I2C_CTRL_TFFSIE   BSP_BIT32(10)
I2C Support.
All writes and reads will be performed in master mode. Exclusive bus access will be assumed.
◆ lpc32xx_i2c_clock()
rtems_status_code lpc32xx_i2c_clock ( volatile lpc32xx_i2c i2c,
Valid clock_in_hz values are 100000 and 400000.
Return values
RTEMS_SUCCESSFULSuccessful operation.
RTEMS_INVALID_CLOCKInvalid clock_in_hz value.
◆ lpc32xx_i2c_init()
rtems_status_code lpc32xx_i2c_init ( volatile lpc32xx_i2c i2c,
Return values
RTEMS_INVALID_IDInvalid i2c value.
◆ lpc32xx_i2c_read_start()
rtems_status_code lpc32xx_i2c_read_start ( volatile lpc32xx_i2c i2c,
unsigned  addr
The address parameter addr must not contain the read/write bit.
The error status may be delayed to the next lpc32xx_i2c_read_with_optional_stop() due to controller flaws.
Return values
RTEMS_IO_ERRORReceived a NACK from the slave.
◆ lpc32xx_i2c_read_with_optional_stop()
rtems_status_code lpc32xx_i2c_read_with_optional_stop ( volatile lpc32xx_i2c i2c,
uint8_t *  in,
size_t  n,
bool  stop
Return values
RTEMS_NOT_IMPLEMENTEDStop is false.
◆ lpc32xx_i2c_write_and_read()
rtems_status_code lpc32xx_i2c_write_and_read ( volatile lpc32xx_i2c i2c,
unsigned  addr,
const uint8_t *  out,
size_t  out_size,
uint8_t *  in,
size_t  in_size
This will be one bus transaction.
Return values
◆ lpc32xx_i2c_write_start()
rtems_status_code lpc32xx_i2c_write_start ( volatile lpc32xx_i2c i2c,
unsigned  addr
The error status may be delayed to the next lpc32xx_i2c_write_with_optional_stop() due to controller flaws.
Return values
◆ lpc32xx_i2c_write_with_optional_stop()
rtems_status_code lpc32xx_i2c_write_with_optional_stop ( volatile lpc32xx_i2c i2c,
size_t  n,
bool  stop
Return values
