RTEMS 6.1-rc4
Modules | |
Ssarc_mapping | |
Typedefs | |
typedef enum _iomuxc_lpsr_sw_mux_ctl_pad | iomuxc_lpsr_sw_mux_ctl_pad_t |
Enumeration for the IOMUXC_LPSR SW_MUX_CTL_PAD. | |
typedef enum _iomuxc_lpsr_sw_pad_ctl_pad | iomuxc_lpsr_sw_pad_ctl_pad_t |
Enumeration for the IOMUXC_LPSR SW_PAD_CTL_PAD. | |
typedef enum _iomuxc_lpsr_select_input | iomuxc_lpsr_select_input_t |
Enumeration for the IOMUXC_LPSR select input. | |
typedef enum _iomuxc_lpsr_select_input iomuxc_lpsr_select_input_t |
Defines the enumeration for the IOMUXC_LPSR select input collections.
typedef enum _iomuxc_lpsr_sw_mux_ctl_pad iomuxc_lpsr_sw_mux_ctl_pad_t |
Defines the enumeration for the IOMUXC_LPSR SW_MUX_CTL_PAD collections.
typedef enum _iomuxc_lpsr_sw_pad_ctl_pad iomuxc_lpsr_sw_pad_ctl_pad_t |
Defines the enumeration for the IOMUXC_LPSR SW_PAD_CTL_PAD collections.
