RTEMS 6.1-rc4
#define USB_ENDPTCTRL_COUNT   (7U)
ID - Identification register
#define USB_ID_ID_MASK   (0x3FU)
#define USB_ID_ID_SHIFT   (0U)
#define USB_ID_ID(x)   (((uint32_t)(((uint32_t)(x)) << USB_ID_ID_SHIFT)) & USB_ID_ID_MASK)
#define USB_ID_NID_MASK   (0x3F00U)
#define USB_ID_NID_SHIFT   (8U)
#define USB_ID_NID(x)   (((uint32_t)(((uint32_t)(x)) << USB_ID_NID_SHIFT)) & USB_ID_NID_MASK)
#define USB_ID_REVISION_MASK   (0xFF0000U)
#define USB_ID_REVISION_SHIFT   (16U)
#define USB_ID_REVISION(x)   (((uint32_t)(((uint32_t)(x)) << USB_ID_REVISION_SHIFT)) & USB_ID_REVISION_MASK)
HWGENERAL - Hardware General
#define USB_HWGENERAL_PHYW_MASK   (0x30U)
#define USB_HWGENERAL_PHYW_SHIFT   (4U)
#define USB_HWGENERAL_PHYW(x)   (((uint32_t)(((uint32_t)(x)) << USB_HWGENERAL_PHYW_SHIFT)) & USB_HWGENERAL_PHYW_MASK)
#define USB_HWGENERAL_PHYM_MASK   (0x1C0U)
#define USB_HWGENERAL_PHYM_SHIFT   (6U)
#define USB_HWGENERAL_PHYM(x)   (((uint32_t)(((uint32_t)(x)) << USB_HWGENERAL_PHYM_SHIFT)) & USB_HWGENERAL_PHYM_MASK)
#define USB_HWGENERAL_SM_MASK   (0x600U)
#define USB_HWGENERAL_SM_SHIFT   (9U)
#define USB_HWGENERAL_SM(x)   (((uint32_t)(((uint32_t)(x)) << USB_HWGENERAL_SM_SHIFT)) & USB_HWGENERAL_SM_MASK)
HWHOST - Host Hardware Parameters
#define USB_HWHOST_HC_MASK   (0x1U)
#define USB_HWHOST_HC_SHIFT   (0U)
#define USB_HWHOST_HC(x)   (((uint32_t)(((uint32_t)(x)) << USB_HWHOST_HC_SHIFT)) & USB_HWHOST_HC_MASK)
#define USB_HWHOST_NPORT_MASK   (0xEU)
#define USB_HWHOST_NPORT_SHIFT   (1U)
#define USB_HWHOST_NPORT(x)   (((uint32_t)(((uint32_t)(x)) << USB_HWHOST_NPORT_SHIFT)) & USB_HWHOST_NPORT_MASK)
HWDEVICE - Device Hardware Parameters
#define USB_HWDEVICE_DC_MASK   (0x1U)
#define USB_HWDEVICE_DC_SHIFT   (0U)
#define USB_HWDEVICE_DC(x)   (((uint32_t)(((uint32_t)(x)) << USB_HWDEVICE_DC_SHIFT)) & USB_HWDEVICE_DC_MASK)
#define USB_HWDEVICE_DEVEP_MASK   (0x3EU)
#define USB_HWDEVICE_DEVEP_SHIFT   (1U)
#define USB_HWDEVICE_DEVEP(x)   (((uint32_t)(((uint32_t)(x)) << USB_HWDEVICE_DEVEP_SHIFT)) & USB_HWDEVICE_DEVEP_MASK)
HWTXBUF - TX Buffer Hardware Parameters
#define USB_HWTXBUF_TXBURST_MASK   (0xFFU)
#define USB_HWTXBUF_TXBURST_SHIFT   (0U)
#define USB_HWTXBUF_TXBURST(x)   (((uint32_t)(((uint32_t)(x)) << USB_HWTXBUF_TXBURST_SHIFT)) & USB_HWTXBUF_TXBURST_MASK)
#define USB_HWTXBUF_TXCHANADD_MASK   (0xFF0000U)
#define USB_HWTXBUF_TXCHANADD_SHIFT   (16U)
#define USB_HWTXBUF_TXCHANADD(x)   (((uint32_t)(((uint32_t)(x)) << USB_HWTXBUF_TXCHANADD_SHIFT)) & USB_HWTXBUF_TXCHANADD_MASK)
HWRXBUF - RX Buffer Hardware Parameters
#define USB_HWRXBUF_RXBURST_MASK   (0xFFU)
#define USB_HWRXBUF_RXBURST_SHIFT   (0U)
#define USB_HWRXBUF_RXBURST(x)   (((uint32_t)(((uint32_t)(x)) << USB_HWRXBUF_RXBURST_SHIFT)) & USB_HWRXBUF_RXBURST_MASK)
#define USB_HWRXBUF_RXADD_MASK   (0xFF00U)
#define USB_HWRXBUF_RXADD_SHIFT   (8U)
#define USB_HWRXBUF_RXADD(x)   (((uint32_t)(((uint32_t)(x)) << USB_HWRXBUF_RXADD_SHIFT)) & USB_HWRXBUF_RXADD_MASK)
GPTIMER0LD - General Purpose Timer #0 Load
#define USB_GPTIMER0LD_GPTLD_MASK   (0xFFFFFFU)
#define USB_GPTIMER0LD_GPTLD_SHIFT   (0U)
#define USB_GPTIMER0LD_GPTLD(x)   (((uint32_t)(((uint32_t)(x)) << USB_GPTIMER0LD_GPTLD_SHIFT)) & USB_GPTIMER0LD_GPTLD_MASK)
GPTIMER0CTRL - General Purpose Timer #0 Controller
#define USB_GPTIMER0CTRL_GPTCNT_MASK   (0xFFFFFFU)
#define USB_GPTIMER0CTRL_GPTCNT_SHIFT   (0U)
#define USB_GPTIMER0CTRL_GPTCNT(x)   (((uint32_t)(((uint32_t)(x)) << USB_GPTIMER0CTRL_GPTCNT_SHIFT)) & USB_GPTIMER0CTRL_GPTCNT_MASK)
#define USB_GPTIMER0CTRL_GPTMODE_MASK   (0x1000000U)
#define USB_GPTIMER0CTRL_GPTMODE_SHIFT   (24U)
#define USB_GPTIMER0CTRL_GPTMODE(x)   (((uint32_t)(((uint32_t)(x)) << USB_GPTIMER0CTRL_GPTMODE_SHIFT)) & USB_GPTIMER0CTRL_GPTMODE_MASK)
#define USB_GPTIMER0CTRL_GPTRST_MASK   (0x40000000U)
#define USB_GPTIMER0CTRL_GPTRST_SHIFT   (30U)
#define USB_GPTIMER0CTRL_GPTRST(x)   (((uint32_t)(((uint32_t)(x)) << USB_GPTIMER0CTRL_GPTRST_SHIFT)) & USB_GPTIMER0CTRL_GPTRST_MASK)
#define USB_GPTIMER0CTRL_GPTRUN_MASK   (0x80000000U)
#define USB_GPTIMER0CTRL_GPTRUN_SHIFT   (31U)
#define USB_GPTIMER0CTRL_GPTRUN(x)   (((uint32_t)(((uint32_t)(x)) << USB_GPTIMER0CTRL_GPTRUN_SHIFT)) & USB_GPTIMER0CTRL_GPTRUN_MASK)
GPTIMER1LD - General Purpose Timer #1 Load
#define USB_GPTIMER1LD_GPTLD_MASK   (0xFFFFFFU)
#define USB_GPTIMER1LD_GPTLD_SHIFT   (0U)
#define USB_GPTIMER1LD_GPTLD(x)   (((uint32_t)(((uint32_t)(x)) << USB_GPTIMER1LD_GPTLD_SHIFT)) & USB_GPTIMER1LD_GPTLD_MASK)
GPTIMER1CTRL - General Purpose Timer #1 Controller
#define USB_GPTIMER1CTRL_GPTCNT_MASK   (0xFFFFFFU)
#define USB_GPTIMER1CTRL_GPTCNT_SHIFT   (0U)
#define USB_GPTIMER1CTRL_GPTCNT(x)   (((uint32_t)(((uint32_t)(x)) << USB_GPTIMER1CTRL_GPTCNT_SHIFT)) & USB_GPTIMER1CTRL_GPTCNT_MASK)
#define USB_GPTIMER1CTRL_GPTMODE_MASK   (0x1000000U)
#define USB_GPTIMER1CTRL_GPTMODE_SHIFT   (24U)
#define USB_GPTIMER1CTRL_GPTMODE(x)   (((uint32_t)(((uint32_t)(x)) << USB_GPTIMER1CTRL_GPTMODE_SHIFT)) & USB_GPTIMER1CTRL_GPTMODE_MASK)
#define USB_GPTIMER1CTRL_GPTRST_MASK   (0x40000000U)
#define USB_GPTIMER1CTRL_GPTRST_SHIFT   (30U)
#define USB_GPTIMER1CTRL_GPTRST(x)   (((uint32_t)(((uint32_t)(x)) << USB_GPTIMER1CTRL_GPTRST_SHIFT)) & USB_GPTIMER1CTRL_GPTRST_MASK)
#define USB_GPTIMER1CTRL_GPTRUN_MASK   (0x80000000U)
#define USB_GPTIMER1CTRL_GPTRUN_SHIFT   (31U)
#define USB_GPTIMER1CTRL_GPTRUN(x)   (((uint32_t)(((uint32_t)(x)) << USB_GPTIMER1CTRL_GPTRUN_SHIFT)) & USB_GPTIMER1CTRL_GPTRUN_MASK)
SBUSCFG - System Bus Config
#define USB_SBUSCFG_AHBBRST_MASK   (0x7U)
#define USB_SBUSCFG_AHBBRST_SHIFT   (0U)
#define USB_SBUSCFG_AHBBRST(x)   (((uint32_t)(((uint32_t)(x)) << USB_SBUSCFG_AHBBRST_SHIFT)) & USB_SBUSCFG_AHBBRST_MASK)
CAPLENGTH - Capability Registers Length
#define USB_CAPLENGTH_CAPLENGTH_MASK   (0xFFU)
#define USB_CAPLENGTH_CAPLENGTH_SHIFT   (0U)
#define USB_CAPLENGTH_CAPLENGTH(x)   (((uint8_t)(((uint8_t)(x)) << USB_CAPLENGTH_CAPLENGTH_SHIFT)) & USB_CAPLENGTH_CAPLENGTH_MASK)
HCIVERSION - Host Controller Interface Version
#define USB_HCIVERSION_HCIVERSION_MASK   (0xFFFFU)
#define USB_HCIVERSION_HCIVERSION_SHIFT   (0U)
#define USB_HCIVERSION_HCIVERSION(x)   (((uint16_t)(((uint16_t)(x)) << USB_HCIVERSION_HCIVERSION_SHIFT)) & USB_HCIVERSION_HCIVERSION_MASK)
HCSPARAMS - Host Controller Structural Parameters
#define USB_HCSPARAMS_N_PORTS_MASK   (0xFU)
#define USB_HCSPARAMS_N_PORTS_SHIFT   (0U)
#define USB_HCSPARAMS_N_PORTS(x)   (((uint32_t)(((uint32_t)(x)) << USB_HCSPARAMS_N_PORTS_SHIFT)) & USB_HCSPARAMS_N_PORTS_MASK)
#define USB_HCSPARAMS_PPC_MASK   (0x10U)
#define USB_HCSPARAMS_PPC_SHIFT   (4U)
#define USB_HCSPARAMS_PPC(x)   (((uint32_t)(((uint32_t)(x)) << USB_HCSPARAMS_PPC_SHIFT)) & USB_HCSPARAMS_PPC_MASK)
#define USB_HCSPARAMS_N_PCC_MASK   (0xF00U)
#define USB_HCSPARAMS_N_PCC_SHIFT   (8U)
#define USB_HCSPARAMS_N_PCC(x)   (((uint32_t)(((uint32_t)(x)) << USB_HCSPARAMS_N_PCC_SHIFT)) & USB_HCSPARAMS_N_PCC_MASK)
#define USB_HCSPARAMS_N_CC_MASK   (0xF000U)
#define USB_HCSPARAMS_N_CC_SHIFT   (12U)
#define USB_HCSPARAMS_N_CC(x)   (((uint32_t)(((uint32_t)(x)) << USB_HCSPARAMS_N_CC_SHIFT)) & USB_HCSPARAMS_N_CC_MASK)
#define USB_HCSPARAMS_PI_MASK   (0x10000U)
#define USB_HCSPARAMS_PI_SHIFT   (16U)
#define USB_HCSPARAMS_PI(x)   (((uint32_t)(((uint32_t)(x)) << USB_HCSPARAMS_PI_SHIFT)) & USB_HCSPARAMS_PI_MASK)
#define USB_HCSPARAMS_N_PTT_MASK   (0xF00000U)
#define USB_HCSPARAMS_N_PTT_SHIFT   (20U)
#define USB_HCSPARAMS_N_PTT(x)   (((uint32_t)(((uint32_t)(x)) << USB_HCSPARAMS_N_PTT_SHIFT)) & USB_HCSPARAMS_N_PTT_MASK)
#define USB_HCSPARAMS_N_TT_MASK   (0xF000000U)
#define USB_HCSPARAMS_N_TT_SHIFT   (24U)
#define USB_HCSPARAMS_N_TT(x)   (((uint32_t)(((uint32_t)(x)) << USB_HCSPARAMS_N_TT_SHIFT)) & USB_HCSPARAMS_N_TT_MASK)
HCCPARAMS - Host Controller Capability Parameters
#define USB_HCCPARAMS_ADC_MASK   (0x1U)
#define USB_HCCPARAMS_ADC_SHIFT   (0U)
#define USB_HCCPARAMS_ADC(x)   (((uint32_t)(((uint32_t)(x)) << USB_HCCPARAMS_ADC_SHIFT)) & USB_HCCPARAMS_ADC_MASK)
#define USB_HCCPARAMS_PFL_MASK   (0x2U)
#define USB_HCCPARAMS_PFL_SHIFT   (1U)
#define USB_HCCPARAMS_PFL(x)   (((uint32_t)(((uint32_t)(x)) << USB_HCCPARAMS_PFL_SHIFT)) & USB_HCCPARAMS_PFL_MASK)
#define USB_HCCPARAMS_ASP_MASK   (0x4U)
#define USB_HCCPARAMS_ASP_SHIFT   (2U)
#define USB_HCCPARAMS_ASP(x)   (((uint32_t)(((uint32_t)(x)) << USB_HCCPARAMS_ASP_SHIFT)) & USB_HCCPARAMS_ASP_MASK)
#define USB_HCCPARAMS_IST_MASK   (0xF0U)
#define USB_HCCPARAMS_IST_SHIFT   (4U)
#define USB_HCCPARAMS_IST(x)   (((uint32_t)(((uint32_t)(x)) << USB_HCCPARAMS_IST_SHIFT)) & USB_HCCPARAMS_IST_MASK)
#define USB_HCCPARAMS_EECP_MASK   (0xFF00U)
#define USB_HCCPARAMS_EECP_SHIFT   (8U)
#define USB_HCCPARAMS_EECP(x)   (((uint32_t)(((uint32_t)(x)) << USB_HCCPARAMS_EECP_SHIFT)) & USB_HCCPARAMS_EECP_MASK)
DCIVERSION - Device Controller Interface Version
#define USB_DCIVERSION_DCIVERSION_MASK   (0xFFFFU)
#define USB_DCIVERSION_DCIVERSION_SHIFT   (0U)
#define USB_DCIVERSION_DCIVERSION(x)   (((uint16_t)(((uint16_t)(x)) << USB_DCIVERSION_DCIVERSION_SHIFT)) & USB_DCIVERSION_DCIVERSION_MASK)
DCCPARAMS - Device Controller Capability Parameters
#define USB_DCCPARAMS_DEN_MASK   (0x1FU)
#define USB_DCCPARAMS_DEN_SHIFT   (0U)
#define USB_DCCPARAMS_DEN(x)   (((uint32_t)(((uint32_t)(x)) << USB_DCCPARAMS_DEN_SHIFT)) & USB_DCCPARAMS_DEN_MASK)
#define USB_DCCPARAMS_DC_MASK   (0x80U)
#define USB_DCCPARAMS_DC_SHIFT   (7U)
#define USB_DCCPARAMS_DC(x)   (((uint32_t)(((uint32_t)(x)) << USB_DCCPARAMS_DC_SHIFT)) & USB_DCCPARAMS_DC_MASK)
#define USB_DCCPARAMS_HC_MASK   (0x100U)
#define USB_DCCPARAMS_HC_SHIFT   (8U)
#define USB_DCCPARAMS_HC(x)   (((uint32_t)(((uint32_t)(x)) << USB_DCCPARAMS_HC_SHIFT)) & USB_DCCPARAMS_HC_MASK)
USBCMD - USB Command Register
#define USB_USBCMD_RS_MASK   (0x1U)
#define USB_USBCMD_RS_SHIFT   (0U)
#define USB_USBCMD_RS(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBCMD_RS_SHIFT)) & USB_USBCMD_RS_MASK)
#define USB_USBCMD_RST_MASK   (0x2U)
#define USB_USBCMD_RST_SHIFT   (1U)
#define USB_USBCMD_RST(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBCMD_RST_SHIFT)) & USB_USBCMD_RST_MASK)
#define USB_USBCMD_FS_1_MASK   (0xCU)
#define USB_USBCMD_FS_1_SHIFT   (2U)
#define USB_USBCMD_FS_1(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBCMD_FS_1_SHIFT)) & USB_USBCMD_FS_1_MASK)
#define USB_USBCMD_PSE_MASK   (0x10U)
#define USB_USBCMD_PSE_SHIFT   (4U)
#define USB_USBCMD_PSE(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBCMD_PSE_SHIFT)) & USB_USBCMD_PSE_MASK)
#define USB_USBCMD_ASE_MASK   (0x20U)
#define USB_USBCMD_ASE_SHIFT   (5U)
#define USB_USBCMD_ASE(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBCMD_ASE_SHIFT)) & USB_USBCMD_ASE_MASK)
#define USB_USBCMD_IAA_MASK   (0x40U)
#define USB_USBCMD_IAA_SHIFT   (6U)
#define USB_USBCMD_IAA(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBCMD_IAA_SHIFT)) & USB_USBCMD_IAA_MASK)
#define USB_USBCMD_ASP_MASK   (0x300U)
#define USB_USBCMD_ASP_SHIFT   (8U)
#define USB_USBCMD_ASP(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBCMD_ASP_SHIFT)) & USB_USBCMD_ASP_MASK)
#define USB_USBCMD_ASPE_MASK   (0x800U)
#define USB_USBCMD_ASPE_SHIFT   (11U)
#define USB_USBCMD_ASPE(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBCMD_ASPE_SHIFT)) & USB_USBCMD_ASPE_MASK)
#define USB_USBCMD_SUTW_MASK   (0x2000U)
#define USB_USBCMD_SUTW_SHIFT   (13U)
#define USB_USBCMD_SUTW(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBCMD_SUTW_SHIFT)) & USB_USBCMD_SUTW_MASK)
#define USB_USBCMD_ATDTW_MASK   (0x4000U)
#define USB_USBCMD_ATDTW_SHIFT   (14U)
#define USB_USBCMD_ATDTW(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBCMD_ATDTW_SHIFT)) & USB_USBCMD_ATDTW_MASK)
#define USB_USBCMD_FS_2_MASK   (0x8000U)
#define USB_USBCMD_FS_2_SHIFT   (15U)
#define USB_USBCMD_FS_2(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBCMD_FS_2_SHIFT)) & USB_USBCMD_FS_2_MASK)
#define USB_USBCMD_ITC_MASK   (0xFF0000U)
#define USB_USBCMD_ITC_SHIFT   (16U)
#define USB_USBCMD_ITC(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBCMD_ITC_SHIFT)) & USB_USBCMD_ITC_MASK)
USBSTS - USB Status Register
#define USB_USBSTS_UI_MASK   (0x1U)
#define USB_USBSTS_UI_SHIFT   (0U)
#define USB_USBSTS_UI(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_UI_SHIFT)) & USB_USBSTS_UI_MASK)
#define USB_USBSTS_UEI_MASK   (0x2U)
#define USB_USBSTS_UEI_SHIFT   (1U)
#define USB_USBSTS_UEI(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_UEI_SHIFT)) & USB_USBSTS_UEI_MASK)
#define USB_USBSTS_PCI_MASK   (0x4U)
#define USB_USBSTS_PCI_SHIFT   (2U)
#define USB_USBSTS_PCI(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_PCI_SHIFT)) & USB_USBSTS_PCI_MASK)
#define USB_USBSTS_FRI_MASK   (0x8U)
#define USB_USBSTS_FRI_SHIFT   (3U)
#define USB_USBSTS_FRI(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_FRI_SHIFT)) & USB_USBSTS_FRI_MASK)
#define USB_USBSTS_SEI_MASK   (0x10U)
#define USB_USBSTS_SEI_SHIFT   (4U)
#define USB_USBSTS_SEI(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_SEI_SHIFT)) & USB_USBSTS_SEI_MASK)
#define USB_USBSTS_AAI_MASK   (0x20U)
#define USB_USBSTS_AAI_SHIFT   (5U)
#define USB_USBSTS_AAI(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_AAI_SHIFT)) & USB_USBSTS_AAI_MASK)
#define USB_USBSTS_URI_MASK   (0x40U)
#define USB_USBSTS_URI_SHIFT   (6U)
#define USB_USBSTS_URI(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_URI_SHIFT)) & USB_USBSTS_URI_MASK)
#define USB_USBSTS_SRI_MASK   (0x80U)
#define USB_USBSTS_SRI_SHIFT   (7U)
#define USB_USBSTS_SRI(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_SRI_SHIFT)) & USB_USBSTS_SRI_MASK)
#define USB_USBSTS_SLI_MASK   (0x100U)
#define USB_USBSTS_SLI_SHIFT   (8U)
#define USB_USBSTS_SLI(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_SLI_SHIFT)) & USB_USBSTS_SLI_MASK)
#define USB_USBSTS_ULPII_MASK   (0x400U)
#define USB_USBSTS_ULPII_SHIFT   (10U)
#define USB_USBSTS_ULPII(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_ULPII_SHIFT)) & USB_USBSTS_ULPII_MASK)
#define USB_USBSTS_HCH_MASK   (0x1000U)
#define USB_USBSTS_HCH_SHIFT   (12U)
#define USB_USBSTS_HCH(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_HCH_SHIFT)) & USB_USBSTS_HCH_MASK)
#define USB_USBSTS_RCL_MASK   (0x2000U)
#define USB_USBSTS_RCL_SHIFT   (13U)
#define USB_USBSTS_RCL(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_RCL_SHIFT)) & USB_USBSTS_RCL_MASK)
#define USB_USBSTS_PS_MASK   (0x4000U)
#define USB_USBSTS_PS_SHIFT   (14U)
#define USB_USBSTS_PS(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_PS_SHIFT)) & USB_USBSTS_PS_MASK)
#define USB_USBSTS_AS_MASK   (0x8000U)
#define USB_USBSTS_AS_SHIFT   (15U)
#define USB_USBSTS_AS(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_AS_SHIFT)) & USB_USBSTS_AS_MASK)
#define USB_USBSTS_NAKI_MASK   (0x10000U)
#define USB_USBSTS_NAKI_SHIFT   (16U)
#define USB_USBSTS_NAKI(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_NAKI_SHIFT)) & USB_USBSTS_NAKI_MASK)
#define USB_USBSTS_TI0_MASK   (0x1000000U)
#define USB_USBSTS_TI0_SHIFT   (24U)
#define USB_USBSTS_TI0(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_TI0_SHIFT)) & USB_USBSTS_TI0_MASK)
#define USB_USBSTS_TI1_MASK   (0x2000000U)
#define USB_USBSTS_TI1_SHIFT   (25U)
#define USB_USBSTS_TI1(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_TI1_SHIFT)) & USB_USBSTS_TI1_MASK)
USBINTR - Interrupt Enable Register
#define USB_USBINTR_UE_MASK   (0x1U)
#define USB_USBINTR_UE_SHIFT   (0U)
#define USB_USBINTR_UE(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_UE_SHIFT)) & USB_USBINTR_UE_MASK)
#define USB_USBINTR_UEE_MASK   (0x2U)
#define USB_USBINTR_UEE_SHIFT   (1U)
#define USB_USBINTR_UEE(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_UEE_SHIFT)) & USB_USBINTR_UEE_MASK)
#define USB_USBINTR_PCE_MASK   (0x4U)
#define USB_USBINTR_PCE_SHIFT   (2U)
#define USB_USBINTR_PCE(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_PCE_SHIFT)) & USB_USBINTR_PCE_MASK)
#define USB_USBINTR_FRE_MASK   (0x8U)
#define USB_USBINTR_FRE_SHIFT   (3U)
#define USB_USBINTR_FRE(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_FRE_SHIFT)) & USB_USBINTR_FRE_MASK)
#define USB_USBINTR_SEE_MASK   (0x10U)
#define USB_USBINTR_SEE_SHIFT   (4U)
#define USB_USBINTR_SEE(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_SEE_SHIFT)) & USB_USBINTR_SEE_MASK)
#define USB_USBINTR_AAE_MASK   (0x20U)
#define USB_USBINTR_AAE_SHIFT   (5U)
#define USB_USBINTR_AAE(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_AAE_SHIFT)) & USB_USBINTR_AAE_MASK)
#define USB_USBINTR_URE_MASK   (0x40U)
#define USB_USBINTR_URE_SHIFT   (6U)
#define USB_USBINTR_URE(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_URE_SHIFT)) & USB_USBINTR_URE_MASK)
#define USB_USBINTR_SRE_MASK   (0x80U)
#define USB_USBINTR_SRE_SHIFT   (7U)
#define USB_USBINTR_SRE(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_SRE_SHIFT)) & USB_USBINTR_SRE_MASK)
#define USB_USBINTR_SLE_MASK   (0x100U)
#define USB_USBINTR_SLE_SHIFT   (8U)
#define USB_USBINTR_SLE(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_SLE_SHIFT)) & USB_USBINTR_SLE_MASK)
#define USB_USBINTR_ULPIE_MASK   (0x400U)
#define USB_USBINTR_ULPIE_SHIFT   (10U)
#define USB_USBINTR_ULPIE(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_ULPIE_SHIFT)) & USB_USBINTR_ULPIE_MASK)
#define USB_USBINTR_NAKE_MASK   (0x10000U)
#define USB_USBINTR_NAKE_SHIFT   (16U)
#define USB_USBINTR_NAKE(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_NAKE_SHIFT)) & USB_USBINTR_NAKE_MASK)
#define USB_USBINTR_UAIE_MASK   (0x40000U)
#define USB_USBINTR_UAIE_SHIFT   (18U)
#define USB_USBINTR_UAIE(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_UAIE_SHIFT)) & USB_USBINTR_UAIE_MASK)
#define USB_USBINTR_UPIE_MASK   (0x80000U)
#define USB_USBINTR_UPIE_SHIFT   (19U)
#define USB_USBINTR_UPIE(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_UPIE_SHIFT)) & USB_USBINTR_UPIE_MASK)
#define USB_USBINTR_TIE0_MASK   (0x1000000U)
#define USB_USBINTR_TIE0_SHIFT   (24U)
#define USB_USBINTR_TIE0(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_TIE0_SHIFT)) & USB_USBINTR_TIE0_MASK)
#define USB_USBINTR_TIE1_MASK   (0x2000000U)
#define USB_USBINTR_TIE1_SHIFT   (25U)
#define USB_USBINTR_TIE1(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_TIE1_SHIFT)) & USB_USBINTR_TIE1_MASK)
FRINDEX - USB Frame Index
#define USB_FRINDEX_FRINDEX_MASK   (0x3FFFU)
#define USB_FRINDEX_FRINDEX_SHIFT   (0U)
#define USB_FRINDEX_FRINDEX(x)   (((uint32_t)(((uint32_t)(x)) << USB_FRINDEX_FRINDEX_SHIFT)) & USB_FRINDEX_FRINDEX_MASK)
DEVICEADDR - Device Address
#define USB_DEVICEADDR_USBADRA_MASK   (0x1000000U)
#define USB_DEVICEADDR_USBADRA_SHIFT   (24U)
#define USB_DEVICEADDR_USBADRA(x)   (((uint32_t)(((uint32_t)(x)) << USB_DEVICEADDR_USBADRA_SHIFT)) & USB_DEVICEADDR_USBADRA_MASK)
#define USB_DEVICEADDR_USBADR_MASK   (0xFE000000U)
#define USB_DEVICEADDR_USBADR_SHIFT   (25U)
#define USB_DEVICEADDR_USBADR(x)   (((uint32_t)(((uint32_t)(x)) << USB_DEVICEADDR_USBADR_SHIFT)) & USB_DEVICEADDR_USBADR_MASK)
PERIODICLISTBASE - Frame List Base Address
#define USB_PERIODICLISTBASE_BASEADR_MASK   (0xFFFFF000U)
#define USB_PERIODICLISTBASE_BASEADR_SHIFT   (12U)
#define USB_PERIODICLISTBASE_BASEADR(x)   (((uint32_t)(((uint32_t)(x)) << USB_PERIODICLISTBASE_BASEADR_SHIFT)) & USB_PERIODICLISTBASE_BASEADR_MASK)
ASYNCLISTADDR - Next Asynch. Address
#define USB_ASYNCLISTADDR_ASYBASE_MASK   (0xFFFFFFE0U)
#define USB_ASYNCLISTADDR_ASYBASE_SHIFT   (5U)
#define USB_ASYNCLISTADDR_ASYBASE(x)   (((uint32_t)(((uint32_t)(x)) << USB_ASYNCLISTADDR_ASYBASE_SHIFT)) & USB_ASYNCLISTADDR_ASYBASE_MASK)
ENDPTLISTADDR - Endpoint List Address
#define USB_ENDPTLISTADDR_EPBASE_MASK   (0xFFFFF800U)
#define USB_ENDPTLISTADDR_EPBASE_SHIFT   (11U)
#define USB_ENDPTLISTADDR_EPBASE(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTLISTADDR_EPBASE_SHIFT)) & USB_ENDPTLISTADDR_EPBASE_MASK)
BURSTSIZE - Programmable Burst Size
#define USB_BURSTSIZE_RXPBURST_MASK   (0xFFU)
#define USB_BURSTSIZE_RXPBURST_SHIFT   (0U)
#define USB_BURSTSIZE_RXPBURST(x)   (((uint32_t)(((uint32_t)(x)) << USB_BURSTSIZE_RXPBURST_SHIFT)) & USB_BURSTSIZE_RXPBURST_MASK)
#define USB_BURSTSIZE_TXPBURST_MASK   (0x1FF00U)
#define USB_BURSTSIZE_TXPBURST_SHIFT   (8U)
#define USB_BURSTSIZE_TXPBURST(x)   (((uint32_t)(((uint32_t)(x)) << USB_BURSTSIZE_TXPBURST_SHIFT)) & USB_BURSTSIZE_TXPBURST_MASK)
TXFILLTUNING - TX FIFO Fill Tuning
#define USB_TXFILLTUNING_TXSCHOH_MASK   (0xFFU)
#define USB_TXFILLTUNING_TXSCHOH_SHIFT   (0U)
#define USB_TXFILLTUNING_TXSCHOH(x)   (((uint32_t)(((uint32_t)(x)) << USB_TXFILLTUNING_TXSCHOH_SHIFT)) & USB_TXFILLTUNING_TXSCHOH_MASK)
#define USB_TXFILLTUNING_TXSCHHEALTH_MASK   (0x1F00U)
#define USB_TXFILLTUNING_TXSCHHEALTH_SHIFT   (8U)
#define USB_TXFILLTUNING_TXSCHHEALTH(x)   (((uint32_t)(((uint32_t)(x)) << USB_TXFILLTUNING_TXSCHHEALTH_SHIFT)) & USB_TXFILLTUNING_TXSCHHEALTH_MASK)
#define USB_TXFILLTUNING_TXFIFOTHRES_MASK   (0x3F0000U)
#define USB_TXFILLTUNING_TXFIFOTHRES_SHIFT   (16U)
#define USB_TXFILLTUNING_TXFIFOTHRES(x)   (((uint32_t)(((uint32_t)(x)) << USB_TXFILLTUNING_TXFIFOTHRES_SHIFT)) & USB_TXFILLTUNING_TXFIFOTHRES_MASK)
ENDPTNAK - Endpoint NAK
#define USB_ENDPTNAK_EPRN_MASK   (0xFFU)
#define USB_ENDPTNAK_EPRN_SHIFT   (0U)
#define USB_ENDPTNAK_EPRN(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTNAK_EPRN_SHIFT)) & USB_ENDPTNAK_EPRN_MASK)
#define USB_ENDPTNAK_EPTN_MASK   (0xFF0000U)
#define USB_ENDPTNAK_EPTN_SHIFT   (16U)
#define USB_ENDPTNAK_EPTN(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTNAK_EPTN_SHIFT)) & USB_ENDPTNAK_EPTN_MASK)
ENDPTNAKEN - Endpoint NAK Enable
#define USB_ENDPTNAKEN_EPRNE_MASK   (0xFFU)
#define USB_ENDPTNAKEN_EPRNE_SHIFT   (0U)
#define USB_ENDPTNAKEN_EPRNE(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTNAKEN_EPRNE_SHIFT)) & USB_ENDPTNAKEN_EPRNE_MASK)
#define USB_ENDPTNAKEN_EPTNE_MASK   (0xFF0000U)
#define USB_ENDPTNAKEN_EPTNE_SHIFT   (16U)
#define USB_ENDPTNAKEN_EPTNE(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTNAKEN_EPTNE_SHIFT)) & USB_ENDPTNAKEN_EPTNE_MASK)
CONFIGFLAG - Configure Flag Register
#define USB_CONFIGFLAG_CF_MASK   (0x1U)
#define USB_CONFIGFLAG_CF_SHIFT   (0U)
#define USB_CONFIGFLAG_CF(x)   (((uint32_t)(((uint32_t)(x)) << USB_CONFIGFLAG_CF_SHIFT)) & USB_CONFIGFLAG_CF_MASK)
PORTSC1 - Port Status & Control
#define USB_PORTSC1_CCS_MASK   (0x1U)
#define USB_PORTSC1_CCS_SHIFT   (0U)
#define USB_PORTSC1_CCS(x)   (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_CCS_SHIFT)) & USB_PORTSC1_CCS_MASK)
#define USB_PORTSC1_CSC_MASK   (0x2U)
#define USB_PORTSC1_CSC_SHIFT   (1U)
#define USB_PORTSC1_CSC(x)   (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_CSC_SHIFT)) & USB_PORTSC1_CSC_MASK)
#define USB_PORTSC1_PE_MASK   (0x4U)
#define USB_PORTSC1_PE_SHIFT   (2U)
#define USB_PORTSC1_PE(x)   (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PE_SHIFT)) & USB_PORTSC1_PE_MASK)
#define USB_PORTSC1_PEC_MASK   (0x8U)
#define USB_PORTSC1_PEC_SHIFT   (3U)
#define USB_PORTSC1_PEC(x)   (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PEC_SHIFT)) & USB_PORTSC1_PEC_MASK)
#define USB_PORTSC1_OCA_MASK   (0x10U)
#define USB_PORTSC1_OCA_SHIFT   (4U)
#define USB_PORTSC1_OCA(x)   (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_OCA_SHIFT)) & USB_PORTSC1_OCA_MASK)
#define USB_PORTSC1_OCC_MASK   (0x20U)
#define USB_PORTSC1_OCC_SHIFT   (5U)
#define USB_PORTSC1_OCC(x)   (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_OCC_SHIFT)) & USB_PORTSC1_OCC_MASK)
#define USB_PORTSC1_FPR_MASK   (0x40U)
#define USB_PORTSC1_FPR_SHIFT   (6U)
#define USB_PORTSC1_FPR(x)   (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_FPR_SHIFT)) & USB_PORTSC1_FPR_MASK)
#define USB_PORTSC1_SUSP_MASK   (0x80U)
#define USB_PORTSC1_SUSP_SHIFT   (7U)
#define USB_PORTSC1_SUSP(x)   (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_SUSP_SHIFT)) & USB_PORTSC1_SUSP_MASK)
#define USB_PORTSC1_PR_MASK   (0x100U)
#define USB_PORTSC1_PR_SHIFT   (8U)
#define USB_PORTSC1_PR(x)   (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PR_SHIFT)) & USB_PORTSC1_PR_MASK)
#define USB_PORTSC1_HSP_MASK   (0x200U)
#define USB_PORTSC1_HSP_SHIFT   (9U)
#define USB_PORTSC1_HSP(x)   (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_HSP_SHIFT)) & USB_PORTSC1_HSP_MASK)
#define USB_PORTSC1_LS_MASK   (0xC00U)
#define USB_PORTSC1_LS_SHIFT   (10U)
#define USB_PORTSC1_LS(x)   (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_LS_SHIFT)) & USB_PORTSC1_LS_MASK)
#define USB_PORTSC1_PP_MASK   (0x1000U)
#define USB_PORTSC1_PP_SHIFT   (12U)
#define USB_PORTSC1_PP(x)   (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PP_SHIFT)) & USB_PORTSC1_PP_MASK)
#define USB_PORTSC1_PO_MASK   (0x2000U)
#define USB_PORTSC1_PO_SHIFT   (13U)
#define USB_PORTSC1_PO(x)   (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PO_SHIFT)) & USB_PORTSC1_PO_MASK)
#define USB_PORTSC1_PIC_MASK   (0xC000U)
#define USB_PORTSC1_PIC_SHIFT   (14U)
#define USB_PORTSC1_PIC(x)   (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PIC_SHIFT)) & USB_PORTSC1_PIC_MASK)
#define USB_PORTSC1_PTC_MASK   (0xF0000U)
#define USB_PORTSC1_PTC_SHIFT   (16U)
#define USB_PORTSC1_PTC(x)   (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PTC_SHIFT)) & USB_PORTSC1_PTC_MASK)
#define USB_PORTSC1_WKCN_MASK   (0x100000U)
#define USB_PORTSC1_WKCN_SHIFT   (20U)
#define USB_PORTSC1_WKCN(x)   (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_WKCN_SHIFT)) & USB_PORTSC1_WKCN_MASK)
#define USB_PORTSC1_WKDC_MASK   (0x200000U)
#define USB_PORTSC1_WKDC_SHIFT   (21U)
#define USB_PORTSC1_WKDC(x)   (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_WKDC_SHIFT)) & USB_PORTSC1_WKDC_MASK)
#define USB_PORTSC1_WKOC_MASK   (0x400000U)
#define USB_PORTSC1_WKOC_SHIFT   (22U)
#define USB_PORTSC1_WKOC(x)   (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_WKOC_SHIFT)) & USB_PORTSC1_WKOC_MASK)
#define USB_PORTSC1_PHCD_MASK   (0x800000U)
#define USB_PORTSC1_PHCD_SHIFT   (23U)
#define USB_PORTSC1_PHCD(x)   (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PHCD_SHIFT)) & USB_PORTSC1_PHCD_MASK)
#define USB_PORTSC1_PFSC_MASK   (0x1000000U)
#define USB_PORTSC1_PFSC_SHIFT   (24U)
#define USB_PORTSC1_PFSC(x)   (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PFSC_SHIFT)) & USB_PORTSC1_PFSC_MASK)
#define USB_PORTSC1_PTS_2_MASK   (0x2000000U)
#define USB_PORTSC1_PTS_2_SHIFT   (25U)
#define USB_PORTSC1_PTS_2(x)   (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PTS_2_SHIFT)) & USB_PORTSC1_PTS_2_MASK)
#define USB_PORTSC1_PSPD_MASK   (0xC000000U)
#define USB_PORTSC1_PSPD_SHIFT   (26U)
#define USB_PORTSC1_PSPD(x)   (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PSPD_SHIFT)) & USB_PORTSC1_PSPD_MASK)
#define USB_PORTSC1_PTW_MASK   (0x10000000U)
#define USB_PORTSC1_PTW_SHIFT   (28U)
#define USB_PORTSC1_PTW(x)   (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PTW_SHIFT)) & USB_PORTSC1_PTW_MASK)
#define USB_PORTSC1_STS_MASK   (0x20000000U)
#define USB_PORTSC1_STS_SHIFT   (29U)
#define USB_PORTSC1_STS(x)   (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_STS_SHIFT)) & USB_PORTSC1_STS_MASK)
#define USB_PORTSC1_PTS_1_MASK   (0xC0000000U)
#define USB_PORTSC1_PTS_1_SHIFT   (30U)
#define USB_PORTSC1_PTS_1(x)   (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PTS_1_SHIFT)) & USB_PORTSC1_PTS_1_MASK)
OTGSC - On-The-Go Status & control
#define USB_OTGSC_VD_MASK   (0x1U)
#define USB_OTGSC_VD_SHIFT   (0U)
#define USB_OTGSC_VD(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_VD_SHIFT)) & USB_OTGSC_VD_MASK)
#define USB_OTGSC_VC_MASK   (0x2U)
#define USB_OTGSC_VC_SHIFT   (1U)
#define USB_OTGSC_VC(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_VC_SHIFT)) & USB_OTGSC_VC_MASK)
#define USB_OTGSC_OT_MASK   (0x8U)
#define USB_OTGSC_OT_SHIFT   (3U)
#define USB_OTGSC_OT(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_OT_SHIFT)) & USB_OTGSC_OT_MASK)
#define USB_OTGSC_DP_MASK   (0x10U)
#define USB_OTGSC_DP_SHIFT   (4U)
#define USB_OTGSC_DP(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_DP_SHIFT)) & USB_OTGSC_DP_MASK)
#define USB_OTGSC_IDPU_MASK   (0x20U)
#define USB_OTGSC_IDPU_SHIFT   (5U)
#define USB_OTGSC_IDPU(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_IDPU_SHIFT)) & USB_OTGSC_IDPU_MASK)
#define USB_OTGSC_ID_MASK   (0x100U)
#define USB_OTGSC_ID_SHIFT   (8U)
#define USB_OTGSC_ID(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_ID_SHIFT)) & USB_OTGSC_ID_MASK)
#define USB_OTGSC_AVV_MASK   (0x200U)
#define USB_OTGSC_AVV_SHIFT   (9U)
#define USB_OTGSC_AVV(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_AVV_SHIFT)) & USB_OTGSC_AVV_MASK)
#define USB_OTGSC_ASV_MASK   (0x400U)
#define USB_OTGSC_ASV_SHIFT   (10U)
#define USB_OTGSC_ASV(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_ASV_SHIFT)) & USB_OTGSC_ASV_MASK)
#define USB_OTGSC_BSV_MASK   (0x800U)
#define USB_OTGSC_BSV_SHIFT   (11U)
#define USB_OTGSC_BSV(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_BSV_SHIFT)) & USB_OTGSC_BSV_MASK)
#define USB_OTGSC_BSE_MASK   (0x1000U)
#define USB_OTGSC_BSE_SHIFT   (12U)
#define USB_OTGSC_BSE(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_BSE_SHIFT)) & USB_OTGSC_BSE_MASK)
#define USB_OTGSC_TOG_1MS_MASK   (0x2000U)
#define USB_OTGSC_TOG_1MS_SHIFT   (13U)
#define USB_OTGSC_TOG_1MS(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_TOG_1MS_SHIFT)) & USB_OTGSC_TOG_1MS_MASK)
#define USB_OTGSC_DPS_MASK   (0x4000U)
#define USB_OTGSC_DPS_SHIFT   (14U)
#define USB_OTGSC_DPS(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_DPS_SHIFT)) & USB_OTGSC_DPS_MASK)
#define USB_OTGSC_IDIS_MASK   (0x10000U)
#define USB_OTGSC_IDIS_SHIFT   (16U)
#define USB_OTGSC_IDIS(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_IDIS_SHIFT)) & USB_OTGSC_IDIS_MASK)
#define USB_OTGSC_AVVIS_MASK   (0x20000U)
#define USB_OTGSC_AVVIS_SHIFT   (17U)
#define USB_OTGSC_AVVIS(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_AVVIS_SHIFT)) & USB_OTGSC_AVVIS_MASK)
#define USB_OTGSC_ASVIS_MASK   (0x40000U)
#define USB_OTGSC_ASVIS_SHIFT   (18U)
#define USB_OTGSC_ASVIS(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_ASVIS_SHIFT)) & USB_OTGSC_ASVIS_MASK)
#define USB_OTGSC_BSVIS_MASK   (0x80000U)
#define USB_OTGSC_BSVIS_SHIFT   (19U)
#define USB_OTGSC_BSVIS(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_BSVIS_SHIFT)) & USB_OTGSC_BSVIS_MASK)
#define USB_OTGSC_BSEIS_MASK   (0x100000U)
#define USB_OTGSC_BSEIS_SHIFT   (20U)
#define USB_OTGSC_BSEIS(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_BSEIS_SHIFT)) & USB_OTGSC_BSEIS_MASK)
#define USB_OTGSC_STATUS_1MS_MASK   (0x200000U)
#define USB_OTGSC_STATUS_1MS_SHIFT   (21U)
#define USB_OTGSC_STATUS_1MS(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_STATUS_1MS_SHIFT)) & USB_OTGSC_STATUS_1MS_MASK)
#define USB_OTGSC_DPIS_MASK   (0x400000U)
#define USB_OTGSC_DPIS_SHIFT   (22U)
#define USB_OTGSC_DPIS(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_DPIS_SHIFT)) & USB_OTGSC_DPIS_MASK)
#define USB_OTGSC_IDIE_MASK   (0x1000000U)
#define USB_OTGSC_IDIE_SHIFT   (24U)
#define USB_OTGSC_IDIE(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_IDIE_SHIFT)) & USB_OTGSC_IDIE_MASK)
#define USB_OTGSC_AVVIE_MASK   (0x2000000U)
#define USB_OTGSC_AVVIE_SHIFT   (25U)
#define USB_OTGSC_AVVIE(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_AVVIE_SHIFT)) & USB_OTGSC_AVVIE_MASK)
#define USB_OTGSC_ASVIE_MASK   (0x4000000U)
#define USB_OTGSC_ASVIE_SHIFT   (26U)
#define USB_OTGSC_ASVIE(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_ASVIE_SHIFT)) & USB_OTGSC_ASVIE_MASK)
#define USB_OTGSC_BSVIE_MASK   (0x8000000U)
#define USB_OTGSC_BSVIE_SHIFT   (27U)
#define USB_OTGSC_BSVIE(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_BSVIE_SHIFT)) & USB_OTGSC_BSVIE_MASK)
#define USB_OTGSC_BSEIE_MASK   (0x10000000U)
#define USB_OTGSC_BSEIE_SHIFT   (28U)
#define USB_OTGSC_BSEIE(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_BSEIE_SHIFT)) & USB_OTGSC_BSEIE_MASK)
#define USB_OTGSC_EN_1MS_MASK   (0x20000000U)
#define USB_OTGSC_EN_1MS_SHIFT   (29U)
#define USB_OTGSC_EN_1MS(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_EN_1MS_SHIFT)) & USB_OTGSC_EN_1MS_MASK)
#define USB_OTGSC_DPIE_MASK   (0x40000000U)
#define USB_OTGSC_DPIE_SHIFT   (30U)
#define USB_OTGSC_DPIE(x)   (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_DPIE_SHIFT)) & USB_OTGSC_DPIE_MASK)
USBMODE - USB Device Mode
#define USB_USBMODE_CM_MASK   (0x3U)
#define USB_USBMODE_CM_SHIFT   (0U)
#define USB_USBMODE_CM(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBMODE_CM_SHIFT)) & USB_USBMODE_CM_MASK)
#define USB_USBMODE_ES_MASK   (0x4U)
#define USB_USBMODE_ES_SHIFT   (2U)
#define USB_USBMODE_ES(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBMODE_ES_SHIFT)) & USB_USBMODE_ES_MASK)
#define USB_USBMODE_SLOM_MASK   (0x8U)
#define USB_USBMODE_SLOM_SHIFT   (3U)
#define USB_USBMODE_SLOM(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBMODE_SLOM_SHIFT)) & USB_USBMODE_SLOM_MASK)
#define USB_USBMODE_SDIS_MASK   (0x10U)
#define USB_USBMODE_SDIS_SHIFT   (4U)
#define USB_USBMODE_SDIS(x)   (((uint32_t)(((uint32_t)(x)) << USB_USBMODE_SDIS_SHIFT)) & USB_USBMODE_SDIS_MASK)
ENDPTSETUPSTAT - Endpoint Setup Status
#define USB_ENDPTSETUPSTAT_ENDPTSETUPSTAT_MASK   (0xFFFFU)
#define USB_ENDPTSETUPSTAT_ENDPTSETUPSTAT_SHIFT   (0U)
#define USB_ENDPTSETUPSTAT_ENDPTSETUPSTAT(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTSETUPSTAT_ENDPTSETUPSTAT_SHIFT)) & USB_ENDPTSETUPSTAT_ENDPTSETUPSTAT_MASK)
ENDPTPRIME - Endpoint Prime
#define USB_ENDPTPRIME_PERB_MASK   (0xFFU)
#define USB_ENDPTPRIME_PERB_SHIFT   (0U)
#define USB_ENDPTPRIME_PERB(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTPRIME_PERB_SHIFT)) & USB_ENDPTPRIME_PERB_MASK)
#define USB_ENDPTPRIME_PETB_MASK   (0xFF0000U)
#define USB_ENDPTPRIME_PETB_SHIFT   (16U)
#define USB_ENDPTPRIME_PETB(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTPRIME_PETB_SHIFT)) & USB_ENDPTPRIME_PETB_MASK)
ENDPTFLUSH - Endpoint Flush
#define USB_ENDPTFLUSH_FERB_MASK   (0xFFU)
#define USB_ENDPTFLUSH_FERB_SHIFT   (0U)
#define USB_ENDPTFLUSH_FERB(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTFLUSH_FERB_SHIFT)) & USB_ENDPTFLUSH_FERB_MASK)
#define USB_ENDPTFLUSH_FETB_MASK   (0xFF0000U)
#define USB_ENDPTFLUSH_FETB_SHIFT   (16U)
#define USB_ENDPTFLUSH_FETB(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTFLUSH_FETB_SHIFT)) & USB_ENDPTFLUSH_FETB_MASK)
ENDPTSTAT - Endpoint Status
#define USB_ENDPTSTAT_ERBR_MASK   (0xFFU)
#define USB_ENDPTSTAT_ERBR_SHIFT   (0U)
#define USB_ENDPTSTAT_ERBR(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTSTAT_ERBR_SHIFT)) & USB_ENDPTSTAT_ERBR_MASK)
#define USB_ENDPTSTAT_ETBR_MASK   (0xFF0000U)
#define USB_ENDPTSTAT_ETBR_SHIFT   (16U)
#define USB_ENDPTSTAT_ETBR(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTSTAT_ETBR_SHIFT)) & USB_ENDPTSTAT_ETBR_MASK)
ENDPTCOMPLETE - Endpoint Complete
#define USB_ENDPTCOMPLETE_ERCE_MASK   (0xFFU)
#define USB_ENDPTCOMPLETE_ERCE_SHIFT   (0U)
#define USB_ENDPTCOMPLETE_ERCE(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCOMPLETE_ERCE_SHIFT)) & USB_ENDPTCOMPLETE_ERCE_MASK)
#define USB_ENDPTCOMPLETE_ETCE_MASK   (0xFF0000U)
#define USB_ENDPTCOMPLETE_ETCE_SHIFT   (16U)
#define USB_ENDPTCOMPLETE_ETCE(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCOMPLETE_ETCE_SHIFT)) & USB_ENDPTCOMPLETE_ETCE_MASK)
ENDPTCTRL0 - Endpoint Control0
#define USB_ENDPTCTRL0_RXS_MASK   (0x1U)
#define USB_ENDPTCTRL0_RXS_SHIFT   (0U)
#define USB_ENDPTCTRL0_RXS(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL0_RXS_SHIFT)) & USB_ENDPTCTRL0_RXS_MASK)
#define USB_ENDPTCTRL0_RXT_MASK   (0xCU)
#define USB_ENDPTCTRL0_RXT_SHIFT   (2U)
#define USB_ENDPTCTRL0_RXT(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL0_RXT_SHIFT)) & USB_ENDPTCTRL0_RXT_MASK)
#define USB_ENDPTCTRL0_RXE_MASK   (0x80U)
#define USB_ENDPTCTRL0_RXE_SHIFT   (7U)
#define USB_ENDPTCTRL0_RXE(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL0_RXE_SHIFT)) & USB_ENDPTCTRL0_RXE_MASK)
#define USB_ENDPTCTRL0_TXS_MASK   (0x10000U)
#define USB_ENDPTCTRL0_TXS_SHIFT   (16U)
#define USB_ENDPTCTRL0_TXS(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL0_TXS_SHIFT)) & USB_ENDPTCTRL0_TXS_MASK)
#define USB_ENDPTCTRL0_TXT_MASK   (0xC0000U)
#define USB_ENDPTCTRL0_TXT_SHIFT   (18U)
#define USB_ENDPTCTRL0_TXT(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL0_TXT_SHIFT)) & USB_ENDPTCTRL0_TXT_MASK)
#define USB_ENDPTCTRL0_TXE_MASK   (0x800000U)
#define USB_ENDPTCTRL0_TXE_SHIFT   (23U)
#define USB_ENDPTCTRL0_TXE(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL0_TXE_SHIFT)) & USB_ENDPTCTRL0_TXE_MASK)
ENDPTCTRL - Endpoint Control 1..Endpoint Control 7
#define USB_ENDPTCTRL_RXS_MASK   (0x1U)
#define USB_ENDPTCTRL_RXS_SHIFT   (0U)
#define USB_ENDPTCTRL_RXS(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL_RXS_SHIFT)) & USB_ENDPTCTRL_RXS_MASK)
#define USB_ENDPTCTRL_RXD_MASK   (0x2U)
#define USB_ENDPTCTRL_RXD_SHIFT   (1U)
#define USB_ENDPTCTRL_RXD(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL_RXD_SHIFT)) & USB_ENDPTCTRL_RXD_MASK)
#define USB_ENDPTCTRL_RXT_MASK   (0xCU)
#define USB_ENDPTCTRL_RXT_SHIFT   (2U)
#define USB_ENDPTCTRL_RXT(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL_RXT_SHIFT)) & USB_ENDPTCTRL_RXT_MASK)
#define USB_ENDPTCTRL_RXI_MASK   (0x20U)
#define USB_ENDPTCTRL_RXI_SHIFT   (5U)
#define USB_ENDPTCTRL_RXI(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL_RXI_SHIFT)) & USB_ENDPTCTRL_RXI_MASK)
#define USB_ENDPTCTRL_RXR_MASK   (0x40U)
#define USB_ENDPTCTRL_RXR_SHIFT   (6U)
#define USB_ENDPTCTRL_RXR(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL_RXR_SHIFT)) & USB_ENDPTCTRL_RXR_MASK)
#define USB_ENDPTCTRL_RXE_MASK   (0x80U)
#define USB_ENDPTCTRL_RXE_SHIFT   (7U)
#define USB_ENDPTCTRL_RXE(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL_RXE_SHIFT)) & USB_ENDPTCTRL_RXE_MASK)
#define USB_ENDPTCTRL_TXS_MASK   (0x10000U)
#define USB_ENDPTCTRL_TXS_SHIFT   (16U)
#define USB_ENDPTCTRL_TXS(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL_TXS_SHIFT)) & USB_ENDPTCTRL_TXS_MASK)
#define USB_ENDPTCTRL_TXD_MASK   (0x20000U)
#define USB_ENDPTCTRL_TXD_SHIFT   (17U)
#define USB_ENDPTCTRL_TXD(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL_TXD_SHIFT)) & USB_ENDPTCTRL_TXD_MASK)
#define USB_ENDPTCTRL_TXT_MASK   (0xC0000U)
#define USB_ENDPTCTRL_TXT_SHIFT   (18U)
#define USB_ENDPTCTRL_TXT(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL_TXT_SHIFT)) & USB_ENDPTCTRL_TXT_MASK)
#define USB_ENDPTCTRL_TXI_MASK   (0x200000U)
#define USB_ENDPTCTRL_TXI_SHIFT   (21U)
#define USB_ENDPTCTRL_TXI(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL_TXI_SHIFT)) & USB_ENDPTCTRL_TXI_MASK)
#define USB_ENDPTCTRL_TXR_MASK   (0x400000U)
#define USB_ENDPTCTRL_TXR_SHIFT   (22U)
#define USB_ENDPTCTRL_TXR(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL_TXR_SHIFT)) & USB_ENDPTCTRL_TXR_MASK)
#define USB_ENDPTCTRL_TXE_MASK   (0x800000U)
#define USB_ENDPTCTRL_TXE_SHIFT   (23U)
#define USB_ENDPTCTRL_TXE(x)   (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL_TXE_SHIFT)) & USB_ENDPTCTRL_TXE_MASK)
◆ USB_ASYNCLISTADDR_ASYBASE [1/2]
#define USB_ASYNCLISTADDR_ASYBASE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ASYNCLISTADDR_ASYBASE_SHIFT)) & USB_ASYNCLISTADDR_ASYBASE_MASK)
ASYBASE - ASYBASE
◆ USB_ASYNCLISTADDR_ASYBASE [2/2]
ASYBASE - ASYBASE
◆ USB_BURSTSIZE_RXPBURST [1/2]
#define USB_BURSTSIZE_RXPBURST (   x)    (((uint32_t)(((uint32_t)(x)) << USB_BURSTSIZE_RXPBURST_SHIFT)) & USB_BURSTSIZE_RXPBURST_MASK)
RXPBURST - RXPBURST
◆ USB_BURSTSIZE_RXPBURST [2/2]
RXPBURST - RXPBURST
◆ USB_BURSTSIZE_TXPBURST [1/2]
#define USB_BURSTSIZE_TXPBURST (   x)    (((uint32_t)(((uint32_t)(x)) << USB_BURSTSIZE_TXPBURST_SHIFT)) & USB_BURSTSIZE_TXPBURST_MASK)
TXPBURST - TXPBURST
◆ USB_BURSTSIZE_TXPBURST [2/2]
TXPBURST - TXPBURST
◆ USB_CAPLENGTH_CAPLENGTH [1/2]
#define USB_CAPLENGTH_CAPLENGTH (   x)    (((uint8_t)(((uint8_t)(x)) << USB_CAPLENGTH_CAPLENGTH_SHIFT)) & USB_CAPLENGTH_CAPLENGTH_MASK)
CAPLENGTH - CAPLENGTH
◆ USB_CAPLENGTH_CAPLENGTH [2/2]
◆ USB_CONFIGFLAG_CF [1/3]
#define USB_CONFIGFLAG_CF (   x)    (((uint32_t)(((uint32_t)(x)) << USB_CONFIGFLAG_CF_SHIFT)) & USB_CONFIGFLAG_CF_MASK)
CF 0b0..Port routing control logic default-routes each port to an implementation dependent classic host controller. 0b1..Port routing control logic default-routes all ports to this host controller.
◆ USB_CONFIGFLAG_CF [2/3]
CF - CF 0b0..Port routing control logic default-routes each port to an implementation dependent classic host controller. 0b1..Port routing control logic default-routes all ports to this host controller.
◆ USB_CONFIGFLAG_CF [3/3]
◆ USB_DCCPARAMS_DC [1/2]
#define USB_DCCPARAMS_DC (   x)    (((uint32_t)(((uint32_t)(x)) << USB_DCCPARAMS_DC_SHIFT)) & USB_DCCPARAMS_DC_MASK)
DC - DC
◆ USB_DCCPARAMS_DC [2/2]
DC - DC
◆ USB_DCCPARAMS_DEN [1/2]
#define USB_DCCPARAMS_DEN (   x)    (((uint32_t)(((uint32_t)(x)) << USB_DCCPARAMS_DEN_SHIFT)) & USB_DCCPARAMS_DEN_MASK)
DEN - DEN
◆ USB_DCCPARAMS_DEN [2/2]
DEN - DEN
◆ USB_DCCPARAMS_HC [1/2]
#define USB_DCCPARAMS_HC (   x)    (((uint32_t)(((uint32_t)(x)) << USB_DCCPARAMS_HC_SHIFT)) & USB_DCCPARAMS_HC_MASK)
HC - HC
◆ USB_DCCPARAMS_HC [2/2]
HC - HC
◆ USB_DCIVERSION_DCIVERSION [1/2]
#define USB_DCIVERSION_DCIVERSION (   x)    (((uint16_t)(((uint16_t)(x)) << USB_DCIVERSION_DCIVERSION_SHIFT)) & USB_DCIVERSION_DCIVERSION_MASK)
DCIVERSION - DCIVERSION
◆ USB_DCIVERSION_DCIVERSION [2/2]
◆ USB_DEVICEADDR_USBADR [1/2]
#define USB_DEVICEADDR_USBADR (   x)    (((uint32_t)(((uint32_t)(x)) << USB_DEVICEADDR_USBADR_SHIFT)) & USB_DEVICEADDR_USBADR_MASK)
USBADR - USBADR
◆ USB_DEVICEADDR_USBADR [2/2]
USBADR - USBADR
◆ USB_DEVICEADDR_USBADRA [1/2]
#define USB_DEVICEADDR_USBADRA (   x)    (((uint32_t)(((uint32_t)(x)) << USB_DEVICEADDR_USBADRA_SHIFT)) & USB_DEVICEADDR_USBADRA_MASK)
USBADRA - USBADRA
◆ USB_DEVICEADDR_USBADRA [2/2]
USBADRA - USBADRA
◆ USB_ENDPTCOMPLETE_ERCE [1/2]
#define USB_ENDPTCOMPLETE_ERCE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCOMPLETE_ERCE_SHIFT)) & USB_ENDPTCOMPLETE_ERCE_MASK)
ERCE - ERCE
◆ USB_ENDPTCOMPLETE_ERCE [2/2]
ERCE - ERCE
◆ USB_ENDPTCOMPLETE_ETCE [1/2]
#define USB_ENDPTCOMPLETE_ETCE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCOMPLETE_ETCE_SHIFT)) & USB_ENDPTCOMPLETE_ETCE_MASK)
ETCE - ETCE
◆ USB_ENDPTCOMPLETE_ETCE [2/2]
ETCE - ETCE
◆ USB_ENDPTCTRL0_RXE [1/2]
#define USB_ENDPTCTRL0_RXE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL0_RXE_SHIFT)) & USB_ENDPTCTRL0_RXE_MASK)
RXE - RXE
◆ USB_ENDPTCTRL0_RXE [2/2]
RXE - RXE
◆ USB_ENDPTCTRL0_RXS [1/2]
#define USB_ENDPTCTRL0_RXS (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL0_RXS_SHIFT)) & USB_ENDPTCTRL0_RXS_MASK)
RXS - RXS
◆ USB_ENDPTCTRL0_RXS [2/2]
RXS - RXS
◆ USB_ENDPTCTRL0_RXT [1/2]
#define USB_ENDPTCTRL0_RXT (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL0_RXT_SHIFT)) & USB_ENDPTCTRL0_RXT_MASK)
RXT - RXT
◆ USB_ENDPTCTRL0_RXT [2/2]
RXT - RXT
◆ USB_ENDPTCTRL0_TXE [1/2]
#define USB_ENDPTCTRL0_TXE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL0_TXE_SHIFT)) & USB_ENDPTCTRL0_TXE_MASK)
TXE - TXE
◆ USB_ENDPTCTRL0_TXE [2/2]
TXE - TXE
◆ USB_ENDPTCTRL0_TXS [1/2]
#define USB_ENDPTCTRL0_TXS (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL0_TXS_SHIFT)) & USB_ENDPTCTRL0_TXS_MASK)
TXS - TXS
◆ USB_ENDPTCTRL0_TXS [2/2]
TXS - TXS
◆ USB_ENDPTCTRL0_TXT [1/2]
#define USB_ENDPTCTRL0_TXT (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL0_TXT_SHIFT)) & USB_ENDPTCTRL0_TXT_MASK)
TXT - TXT
◆ USB_ENDPTCTRL0_TXT [2/2]
TXT - TXT
◆ USB_ENDPTCTRL_RXD [1/2]
#define USB_ENDPTCTRL_RXD (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL_RXD_SHIFT)) & USB_ENDPTCTRL_RXD_MASK)
RXD - RXD
◆ USB_ENDPTCTRL_RXD [2/2]
RXD - RXD
◆ USB_ENDPTCTRL_RXE [1/2]
#define USB_ENDPTCTRL_RXE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL_RXE_SHIFT)) & USB_ENDPTCTRL_RXE_MASK)
RXE - RXE
◆ USB_ENDPTCTRL_RXE [2/2]
RXE - RXE
◆ USB_ENDPTCTRL_RXI [1/2]
#define USB_ENDPTCTRL_RXI (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL_RXI_SHIFT)) & USB_ENDPTCTRL_RXI_MASK)
RXI - RXI
◆ USB_ENDPTCTRL_RXI [2/2]
RXI - RXI
◆ USB_ENDPTCTRL_RXR [1/2]
#define USB_ENDPTCTRL_RXR (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL_RXR_SHIFT)) & USB_ENDPTCTRL_RXR_MASK)
RXR - RXR
◆ USB_ENDPTCTRL_RXR [2/2]
RXR - RXR
◆ USB_ENDPTCTRL_RXS [1/2]
#define USB_ENDPTCTRL_RXS (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL_RXS_SHIFT)) & USB_ENDPTCTRL_RXS_MASK)
RXS - RXS
◆ USB_ENDPTCTRL_RXS [2/2]
RXS - RXS
◆ USB_ENDPTCTRL_RXT [1/2]
#define USB_ENDPTCTRL_RXT (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL_RXT_SHIFT)) & USB_ENDPTCTRL_RXT_MASK)
RXT - RXT
◆ USB_ENDPTCTRL_RXT [2/2]
RXT - RXT
◆ USB_ENDPTCTRL_TXD [1/2]
#define USB_ENDPTCTRL_TXD (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL_TXD_SHIFT)) & USB_ENDPTCTRL_TXD_MASK)
TXD - TXD
◆ USB_ENDPTCTRL_TXD [2/2]
TXD - TXD
◆ USB_ENDPTCTRL_TXE [1/2]
#define USB_ENDPTCTRL_TXE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL_TXE_SHIFT)) & USB_ENDPTCTRL_TXE_MASK)
TXE - TXE
◆ USB_ENDPTCTRL_TXE [2/2]
TXE - TXE
◆ USB_ENDPTCTRL_TXI [1/2]
#define USB_ENDPTCTRL_TXI (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL_TXI_SHIFT)) & USB_ENDPTCTRL_TXI_MASK)
TXI - TXI
◆ USB_ENDPTCTRL_TXI [2/2]
TXI - TXI
◆ USB_ENDPTCTRL_TXR [1/2]
#define USB_ENDPTCTRL_TXR (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL_TXR_SHIFT)) & USB_ENDPTCTRL_TXR_MASK)
TXR - TXR
◆ USB_ENDPTCTRL_TXR [2/2]
TXR - TXR
◆ USB_ENDPTCTRL_TXS [1/2]
#define USB_ENDPTCTRL_TXS (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL_TXS_SHIFT)) & USB_ENDPTCTRL_TXS_MASK)
TXS - TXS
◆ USB_ENDPTCTRL_TXS [2/2]
TXS - TXS
◆ USB_ENDPTCTRL_TXT [1/2]
#define USB_ENDPTCTRL_TXT (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTCTRL_TXT_SHIFT)) & USB_ENDPTCTRL_TXT_MASK)
TXT - TXT
◆ USB_ENDPTCTRL_TXT [2/2]
TXT - TXT
◆ USB_ENDPTFLUSH_FERB [1/2]
#define USB_ENDPTFLUSH_FERB (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTFLUSH_FERB_SHIFT)) & USB_ENDPTFLUSH_FERB_MASK)
FERB - FERB
◆ USB_ENDPTFLUSH_FERB [2/2]
FERB - FERB
◆ USB_ENDPTFLUSH_FETB [1/2]
#define USB_ENDPTFLUSH_FETB (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTFLUSH_FETB_SHIFT)) & USB_ENDPTFLUSH_FETB_MASK)
FETB - FETB
◆ USB_ENDPTFLUSH_FETB [2/2]
FETB - FETB
◆ USB_ENDPTLISTADDR_EPBASE [1/2]
#define USB_ENDPTLISTADDR_EPBASE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTLISTADDR_EPBASE_SHIFT)) & USB_ENDPTLISTADDR_EPBASE_MASK)
EPBASE - EPBASE
◆ USB_ENDPTLISTADDR_EPBASE [2/2]
EPBASE - EPBASE
◆ USB_ENDPTNAK_EPRN [1/2]
#define USB_ENDPTNAK_EPRN (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTNAK_EPRN_SHIFT)) & USB_ENDPTNAK_EPRN_MASK)
EPRN - EPRN
◆ USB_ENDPTNAK_EPRN [2/2]
EPRN - EPRN
◆ USB_ENDPTNAK_EPTN [1/2]
#define USB_ENDPTNAK_EPTN (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTNAK_EPTN_SHIFT)) & USB_ENDPTNAK_EPTN_MASK)
EPTN - EPTN
◆ USB_ENDPTNAK_EPTN [2/2]
EPTN - EPTN
◆ USB_ENDPTNAKEN_EPRNE [1/2]
#define USB_ENDPTNAKEN_EPRNE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTNAKEN_EPRNE_SHIFT)) & USB_ENDPTNAKEN_EPRNE_MASK)
EPRNE - EPRNE
◆ USB_ENDPTNAKEN_EPRNE [2/2]
EPRNE - EPRNE
◆ USB_ENDPTNAKEN_EPTNE [1/2]
#define USB_ENDPTNAKEN_EPTNE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTNAKEN_EPTNE_SHIFT)) & USB_ENDPTNAKEN_EPTNE_MASK)
EPTNE - EPTNE
◆ USB_ENDPTNAKEN_EPTNE [2/2]
EPTNE - EPTNE
◆ USB_ENDPTPRIME_PERB [1/2]
#define USB_ENDPTPRIME_PERB (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTPRIME_PERB_SHIFT)) & USB_ENDPTPRIME_PERB_MASK)
PERB - PERB
◆ USB_ENDPTPRIME_PERB [2/2]
PERB - PERB
◆ USB_ENDPTPRIME_PETB [1/2]
#define USB_ENDPTPRIME_PETB (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTPRIME_PETB_SHIFT)) & USB_ENDPTPRIME_PETB_MASK)
PETB - PETB
◆ USB_ENDPTPRIME_PETB [2/2]
PETB - PETB
◆ USB_ENDPTSETUPSTAT_ENDPTSETUPSTAT [1/2]
#define USB_ENDPTSETUPSTAT_ENDPTSETUPSTAT (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTSETUPSTAT_ENDPTSETUPSTAT_SHIFT)) & USB_ENDPTSETUPSTAT_ENDPTSETUPSTAT_MASK)
ENDPTSETUPSTAT - ENDPTSETUPSTAT
◆ USB_ENDPTSETUPSTAT_ENDPTSETUPSTAT [2/2]
◆ USB_ENDPTSTAT_ERBR [1/2]
#define USB_ENDPTSTAT_ERBR (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTSTAT_ERBR_SHIFT)) & USB_ENDPTSTAT_ERBR_MASK)
ERBR - ERBR
◆ USB_ENDPTSTAT_ERBR [2/2]
ERBR - ERBR
◆ USB_ENDPTSTAT_ETBR [1/2]
#define USB_ENDPTSTAT_ETBR (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ENDPTSTAT_ETBR_SHIFT)) & USB_ENDPTSTAT_ETBR_MASK)
ETBR - ETBR
◆ USB_ENDPTSTAT_ETBR [2/2]
ETBR - ETBR
◆ USB_FRINDEX_FRINDEX [1/3]
#define USB_FRINDEX_FRINDEX (   x)    (((uint32_t)(((uint32_t)(x)) << USB_FRINDEX_FRINDEX_SHIFT)) & USB_FRINDEX_FRINDEX_MASK)
FRINDEX 0b00000000000000..(1024) 12 0b00000000000001..(512) 11 0b00000000000010..(256) 10 0b00000000000011..(128) 9 0b00000000000100..(64) 8 0b00000000000101..(32) 7 0b00000000000110..(16) 6 0b00000000000111..(8) 5
◆ USB_FRINDEX_FRINDEX [2/3]
FRINDEX - FRINDEX 0b00000000000000..(1024) 12 0b00000000000001..(512) 11 0b00000000000010..(256) 10 0b00000000000011..(128) 9 0b00000000000100..(64) 8 0b00000000000101..(32) 7 0b00000000000110..(16) 6 0b00000000000111..(8) 5
◆ USB_FRINDEX_FRINDEX [3/3]
◆ USB_GPTIMER0CTRL_GPTCNT [1/2]
#define USB_GPTIMER0CTRL_GPTCNT (   x)    (((uint32_t)(((uint32_t)(x)) << USB_GPTIMER0CTRL_GPTCNT_SHIFT)) & USB_GPTIMER0CTRL_GPTCNT_MASK)
GPTCNT - GPTCNT
◆ USB_GPTIMER0CTRL_GPTCNT [2/2]
GPTCNT - GPTCNT
◆ USB_GPTIMER0CTRL_GPTMODE [1/3]
#define USB_GPTIMER0CTRL_GPTMODE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_GPTIMER0CTRL_GPTMODE_SHIFT)) & USB_GPTIMER0CTRL_GPTMODE_MASK)
GPTMODE 0b0..One Shot Mode 0b1..Repeat Mode
◆ USB_GPTIMER0CTRL_GPTMODE [2/3]
GPTMODE - GPTMODE 0b0..One Shot Mode 0b1..Repeat Mode
◆ USB_GPTIMER0CTRL_GPTMODE [3/3]
◆ USB_GPTIMER0CTRL_GPTRST [1/3]
#define USB_GPTIMER0CTRL_GPTRST (   x)    (((uint32_t)(((uint32_t)(x)) << USB_GPTIMER0CTRL_GPTRST_SHIFT)) & USB_GPTIMER0CTRL_GPTRST_MASK)
GPTRST 0b0..No action 0b1..Load counter value from GPTLD bits in n_GPTIMER0LD
◆ USB_GPTIMER0CTRL_GPTRST [2/3]
GPTRST - GPTRST 0b0..No action 0b1..Load counter value from GPTLD bits in n_GPTIMER0LD
◆ USB_GPTIMER0CTRL_GPTRST [3/3]
◆ USB_GPTIMER0CTRL_GPTRUN [1/3]
#define USB_GPTIMER0CTRL_GPTRUN (   x)    (((uint32_t)(((uint32_t)(x)) << USB_GPTIMER0CTRL_GPTRUN_SHIFT)) & USB_GPTIMER0CTRL_GPTRUN_MASK)
GPTRUN 0b0..Stop counting 0b1..Run
◆ USB_GPTIMER0CTRL_GPTRUN [2/3]
GPTRUN - GPTRUN 0b0..Stop counting 0b1..Run
◆ USB_GPTIMER0CTRL_GPTRUN [3/3]
◆ USB_GPTIMER0LD_GPTLD [1/2]
#define USB_GPTIMER0LD_GPTLD (   x)    (((uint32_t)(((uint32_t)(x)) << USB_GPTIMER0LD_GPTLD_SHIFT)) & USB_GPTIMER0LD_GPTLD_MASK)
GPTLD - GPTLD
◆ USB_GPTIMER0LD_GPTLD [2/2]
GPTLD - GPTLD
◆ USB_GPTIMER1CTRL_GPTCNT [1/2]
#define USB_GPTIMER1CTRL_GPTCNT (   x)    (((uint32_t)(((uint32_t)(x)) << USB_GPTIMER1CTRL_GPTCNT_SHIFT)) & USB_GPTIMER1CTRL_GPTCNT_MASK)
GPTCNT - GPTCNT
◆ USB_GPTIMER1CTRL_GPTCNT [2/2]
GPTCNT - GPTCNT
◆ USB_GPTIMER1CTRL_GPTMODE [1/3]
#define USB_GPTIMER1CTRL_GPTMODE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_GPTIMER1CTRL_GPTMODE_SHIFT)) & USB_GPTIMER1CTRL_GPTMODE_MASK)
◆ USB_GPTIMER1CTRL_GPTMODE [2/3]
◆ USB_GPTIMER1CTRL_GPTMODE [3/3]
◆ USB_GPTIMER1CTRL_GPTRST [1/3]
#define USB_GPTIMER1CTRL_GPTRST (   x)    (((uint32_t)(((uint32_t)(x)) << USB_GPTIMER1CTRL_GPTRST_SHIFT)) & USB_GPTIMER1CTRL_GPTRST_MASK)
GPTRST 0b0..No action 0b1..Load counter value from GPTLD bits in USB_n_GPTIMER0LD
◆ USB_GPTIMER1CTRL_GPTRST [2/3]
GPTRST - GPTRST 0b0..No action 0b1..Load counter value from GPTLD bits in USB_n_GPTIMER0LD
◆ USB_GPTIMER1CTRL_GPTRST [3/3]
◆ USB_GPTIMER1CTRL_GPTRUN [1/3]
#define USB_GPTIMER1CTRL_GPTRUN (   x)    (((uint32_t)(((uint32_t)(x)) << USB_GPTIMER1CTRL_GPTRUN_SHIFT)) & USB_GPTIMER1CTRL_GPTRUN_MASK)
◆ USB_GPTIMER1CTRL_GPTRUN [2/3]
◆ USB_GPTIMER1CTRL_GPTRUN [3/3]
◆ USB_GPTIMER1LD_GPTLD [1/2]
#define USB_GPTIMER1LD_GPTLD (   x)    (((uint32_t)(((uint32_t)(x)) << USB_GPTIMER1LD_GPTLD_SHIFT)) & USB_GPTIMER1LD_GPTLD_MASK)
GPTLD - GPTLD
◆ USB_GPTIMER1LD_GPTLD [2/2]
GPTLD - GPTLD
◆ USB_HCCPARAMS_ADC [1/2]
#define USB_HCCPARAMS_ADC (   x)    (((uint32_t)(((uint32_t)(x)) << USB_HCCPARAMS_ADC_SHIFT)) & USB_HCCPARAMS_ADC_MASK)
ADC - ADC
◆ USB_HCCPARAMS_ADC [2/2]
ADC - ADC
◆ USB_HCCPARAMS_ASP [1/2]
#define USB_HCCPARAMS_ASP (   x)    (((uint32_t)(((uint32_t)(x)) << USB_HCCPARAMS_ASP_SHIFT)) & USB_HCCPARAMS_ASP_MASK)
ASP - ASP
◆ USB_HCCPARAMS_ASP [2/2]
ASP - ASP
◆ USB_HCCPARAMS_EECP [1/2]
#define USB_HCCPARAMS_EECP (   x)    (((uint32_t)(((uint32_t)(x)) << USB_HCCPARAMS_EECP_SHIFT)) & USB_HCCPARAMS_EECP_MASK)
EECP - EECP
◆ USB_HCCPARAMS_EECP [2/2]
EECP - EECP
◆ USB_HCCPARAMS_IST [1/2]
#define USB_HCCPARAMS_IST (   x)    (((uint32_t)(((uint32_t)(x)) << USB_HCCPARAMS_IST_SHIFT)) & USB_HCCPARAMS_IST_MASK)
IST - IST
◆ USB_HCCPARAMS_IST [2/2]
IST - IST
◆ USB_HCCPARAMS_PFL [1/2]
#define USB_HCCPARAMS_PFL (   x)    (((uint32_t)(((uint32_t)(x)) << USB_HCCPARAMS_PFL_SHIFT)) & USB_HCCPARAMS_PFL_MASK)
PFL - PFL
◆ USB_HCCPARAMS_PFL [2/2]
PFL - PFL
◆ USB_HCIVERSION_HCIVERSION [1/2]
#define USB_HCIVERSION_HCIVERSION (   x)    (((uint16_t)(((uint16_t)(x)) << USB_HCIVERSION_HCIVERSION_SHIFT)) & USB_HCIVERSION_HCIVERSION_MASK)
HCIVERSION - HCIVERSION
◆ USB_HCIVERSION_HCIVERSION [2/2]
◆ USB_HCSPARAMS_N_CC [1/3]
#define USB_HCSPARAMS_N_CC (   x)    (((uint32_t)(((uint32_t)(x)) << USB_HCSPARAMS_N_CC_SHIFT)) & USB_HCSPARAMS_N_CC_MASK)
N_CC 0b0000..There is no internal Companion Controller and port-ownership hand-off is not supported. 0b0001..There are internal companion controller(s) and port-ownership hand-offs is supported.
◆ USB_HCSPARAMS_N_CC [2/3]
N_CC - N_CC 0b0000..There is no internal Companion Controller and port-ownership hand-off is not supported. 0b0001..There are internal companion controller(s) and port-ownership hand-offs is supported.
◆ USB_HCSPARAMS_N_CC [3/3]
◆ USB_HCSPARAMS_N_PCC [1/2]
#define USB_HCSPARAMS_N_PCC (   x)    (((uint32_t)(((uint32_t)(x)) << USB_HCSPARAMS_N_PCC_SHIFT)) & USB_HCSPARAMS_N_PCC_MASK)
N_PCC - N_PCC
◆ USB_HCSPARAMS_N_PCC [2/2]
N_PCC - N_PCC
◆ USB_HCSPARAMS_N_PORTS [1/2]
#define USB_HCSPARAMS_N_PORTS (   x)    (((uint32_t)(((uint32_t)(x)) << USB_HCSPARAMS_N_PORTS_SHIFT)) & USB_HCSPARAMS_N_PORTS_MASK)
N_PORTS - N_PORTS
◆ USB_HCSPARAMS_N_PORTS [2/2]
N_PORTS - N_PORTS
◆ USB_HCSPARAMS_N_PTT [1/2]
#define USB_HCSPARAMS_N_PTT (   x)    (((uint32_t)(((uint32_t)(x)) << USB_HCSPARAMS_N_PTT_SHIFT)) & USB_HCSPARAMS_N_PTT_MASK)
N_PTT - N_PTT
◆ USB_HCSPARAMS_N_PTT [2/2]
N_PTT - N_PTT
◆ USB_HCSPARAMS_N_TT [1/2]
#define USB_HCSPARAMS_N_TT (   x)    (((uint32_t)(((uint32_t)(x)) << USB_HCSPARAMS_N_TT_SHIFT)) & USB_HCSPARAMS_N_TT_MASK)
N_TT - N_TT
◆ USB_HCSPARAMS_N_TT [2/2]
N_TT - N_TT
◆ USB_HCSPARAMS_PI [1/2]
#define USB_HCSPARAMS_PI (   x)    (((uint32_t)(((uint32_t)(x)) << USB_HCSPARAMS_PI_SHIFT)) & USB_HCSPARAMS_PI_MASK)
PI - PI
◆ USB_HCSPARAMS_PI [2/2]
PI - PI
◆ USB_HCSPARAMS_PPC [1/2]
#define USB_HCSPARAMS_PPC (   x)    (((uint32_t)(((uint32_t)(x)) << USB_HCSPARAMS_PPC_SHIFT)) & USB_HCSPARAMS_PPC_MASK)
PPC - PPC
◆ USB_HCSPARAMS_PPC [2/2]
PPC - PPC
◆ USB_HWDEVICE_DC [1/3]
#define USB_HWDEVICE_DC (   x)    (((uint32_t)(((uint32_t)(x)) << USB_HWDEVICE_DC_SHIFT)) & USB_HWDEVICE_DC_MASK)
DC 0b1..Supported 0b0..Not supported
◆ USB_HWDEVICE_DC [2/3]
DC - DC 0b1..Supported 0b0..Not supported
◆ USB_HWDEVICE_DC [3/3]
◆ USB_HWDEVICE_DEVEP [1/2]
#define USB_HWDEVICE_DEVEP (   x)    (((uint32_t)(((uint32_t)(x)) << USB_HWDEVICE_DEVEP_SHIFT)) & USB_HWDEVICE_DEVEP_MASK)
DEVEP - DEVEP
◆ USB_HWDEVICE_DEVEP [2/2]
DEVEP - DEVEP
◆ USB_HWGENERAL_PHYM [1/3]
#define USB_HWGENERAL_PHYM (   x)    (((uint32_t)(((uint32_t)(x)) << USB_HWGENERAL_PHYM_SHIFT)) & USB_HWGENERAL_PHYM_MASK)
PHYM 0b000..UTMI/UMTI+ 0b001..ULPI DDR 0b010..ULPI 0b011..Serial Only 0b100..Software programmable - reset to UTMI/UTMI+ 0b101..Software programmable - reset to ULPI DDR 0b110..Software programmable - reset to ULPI 0b111..Software programmable - reset to Serial
◆ USB_HWGENERAL_PHYM [2/3]
PHYM - PHYM 0b000..UTMI/UMTI+ 0b001..ULPI DDR 0b010..ULPI 0b011..Serial Only 0b100..Software programmable - reset to UTMI/UTMI+ 0b101..Software programmable - reset to ULPI DDR 0b110..Software programmable - reset to ULPI 0b111..Software programmable - reset to Serial
◆ USB_HWGENERAL_PHYM [3/3]
◆ USB_HWGENERAL_PHYW [1/3]
#define USB_HWGENERAL_PHYW (   x)    (((uint32_t)(((uint32_t)(x)) << USB_HWGENERAL_PHYW_SHIFT)) & USB_HWGENERAL_PHYW_MASK)
PHYW 0b00..8 bit wide data bus Software non-programmable 0b01..16 bit wide data bus Software non-programmable 0b10..Reset to 8 bit wide data bus Software programmable 0b11..Reset to 16 bit wide data bus Software programmable
◆ USB_HWGENERAL_PHYW [2/3]
PHYW - PHYW 0b00..8 bit wide data bus (Software non-programmable) 0b01..16 bit wide data bus (Software non-programmable) 0b10..Reset to 8 bit wide data bus (Software programmable) 0b11..Reset to 16 bit wide data bus (Software programmable)
◆ USB_HWGENERAL_PHYW [3/3]
◆ USB_HWGENERAL_SM [1/3]
#define USB_HWGENERAL_SM (   x)    (((uint32_t)(((uint32_t)(x)) << USB_HWGENERAL_SM_SHIFT)) & USB_HWGENERAL_SM_MASK)
SM 0b00..No Serial Engine, always use parallel signalling. 0b01..Serial Engine present, always use serial signalling for FS/LS. 0b10..Software programmable - Reset to use parallel signalling for FS/LS 0b11..Software programmable - Reset to use serial signalling for FS/LS
◆ USB_HWGENERAL_SM [2/3]
SM - SM 0b00..No Serial Engine, always use parallel signalling. 0b01..Serial Engine present, always use serial signalling for FS/LS. 0b10..Software programmable - Reset to use parallel signalling for FS/LS 0b11..Software programmable - Reset to use serial signalling for FS/LS
◆ USB_HWGENERAL_SM [3/3]
◆ USB_HWHOST_HC [1/3]
#define USB_HWHOST_HC (   x)    (((uint32_t)(((uint32_t)(x)) << USB_HWHOST_HC_SHIFT)) & USB_HWHOST_HC_MASK)
HC 0b1..Supported 0b0..Not supported
◆ USB_HWHOST_HC [2/3]
HC - HC 0b1..Supported 0b0..Not supported
◆ USB_HWHOST_HC [3/3]
◆ USB_HWHOST_NPORT [1/2]
#define USB_HWHOST_NPORT (   x)    (((uint32_t)(((uint32_t)(x)) << USB_HWHOST_NPORT_SHIFT)) & USB_HWHOST_NPORT_MASK)
NPORT - NPORT
◆ USB_HWHOST_NPORT [2/2]
NPORT - NPORT
◆ USB_HWRXBUF_RXADD [1/2]
#define USB_HWRXBUF_RXADD (   x)    (((uint32_t)(((uint32_t)(x)) << USB_HWRXBUF_RXADD_SHIFT)) & USB_HWRXBUF_RXADD_MASK)
RXADD - RXADD
◆ USB_HWRXBUF_RXADD [2/2]
RXADD - RXADD
◆ USB_HWRXBUF_RXBURST [1/2]
#define USB_HWRXBUF_RXBURST (   x)    (((uint32_t)(((uint32_t)(x)) << USB_HWRXBUF_RXBURST_SHIFT)) & USB_HWRXBUF_RXBURST_MASK)
RXBURST - RXBURST
◆ USB_HWRXBUF_RXBURST [2/2]
RXBURST - RXBURST
◆ USB_HWTXBUF_TXBURST [1/2]
#define USB_HWTXBUF_TXBURST (   x)    (((uint32_t)(((uint32_t)(x)) << USB_HWTXBUF_TXBURST_SHIFT)) & USB_HWTXBUF_TXBURST_MASK)
TXBURST - TXBURST
◆ USB_HWTXBUF_TXBURST [2/2]
TXBURST - TXBURST
◆ USB_HWTXBUF_TXCHANADD [1/2]
#define USB_HWTXBUF_TXCHANADD (   x)    (((uint32_t)(((uint32_t)(x)) << USB_HWTXBUF_TXCHANADD_SHIFT)) & USB_HWTXBUF_TXCHANADD_MASK)
TXCHANADD - TXCHANADD
◆ USB_HWTXBUF_TXCHANADD [2/2]
◆ USB_ID_ID [1/2]
#define USB_ID_ID (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ID_ID_SHIFT)) & USB_ID_ID_MASK)
ID - ID
◆ USB_ID_ID [2/2]
ID - ID
◆ USB_ID_NID [1/2]
#define USB_ID_NID (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ID_NID_SHIFT)) & USB_ID_NID_MASK)
NID - NID
◆ USB_ID_NID [2/2]
NID - NID
◆ USB_ID_REVISION [1/2]
#define USB_ID_REVISION (   x)    (((uint32_t)(((uint32_t)(x)) << USB_ID_REVISION_SHIFT)) & USB_ID_REVISION_MASK)
REVISION - REVISION
◆ USB_ID_REVISION [2/2]
REVISION - REVISION
◆ USB_OTGSC_ASV [1/2]
#define USB_OTGSC_ASV (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_ASV_SHIFT)) & USB_OTGSC_ASV_MASK)
ASV - ASV
◆ USB_OTGSC_ASV [2/2]
ASV - ASV
◆ USB_OTGSC_ASVIE [1/2]
#define USB_OTGSC_ASVIE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_ASVIE_SHIFT)) & USB_OTGSC_ASVIE_MASK)
ASVIE - ASVIE
◆ USB_OTGSC_ASVIE [2/2]
ASVIE - ASVIE
◆ USB_OTGSC_ASVIS [1/2]
#define USB_OTGSC_ASVIS (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_ASVIS_SHIFT)) & USB_OTGSC_ASVIS_MASK)
ASVIS - ASVIS
◆ USB_OTGSC_ASVIS [2/2]
ASVIS - ASVIS
◆ USB_OTGSC_AVV [1/2]
#define USB_OTGSC_AVV (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_AVV_SHIFT)) & USB_OTGSC_AVV_MASK)
AVV - AVV
◆ USB_OTGSC_AVV [2/2]
AVV - AVV
◆ USB_OTGSC_AVVIE [1/2]
#define USB_OTGSC_AVVIE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_AVVIE_SHIFT)) & USB_OTGSC_AVVIE_MASK)
AVVIE - AVVIE
◆ USB_OTGSC_AVVIE [2/2]
AVVIE - AVVIE
◆ USB_OTGSC_AVVIS [1/2]
#define USB_OTGSC_AVVIS (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_AVVIS_SHIFT)) & USB_OTGSC_AVVIS_MASK)
AVVIS - AVVIS
◆ USB_OTGSC_AVVIS [2/2]
AVVIS - AVVIS
◆ USB_OTGSC_BSE [1/2]
#define USB_OTGSC_BSE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_BSE_SHIFT)) & USB_OTGSC_BSE_MASK)
BSE - BSE
◆ USB_OTGSC_BSE [2/2]
BSE - BSE
◆ USB_OTGSC_BSEIE [1/2]
#define USB_OTGSC_BSEIE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_BSEIE_SHIFT)) & USB_OTGSC_BSEIE_MASK)
BSEIE - BSEIE
◆ USB_OTGSC_BSEIE [2/2]
BSEIE - BSEIE
◆ USB_OTGSC_BSEIS [1/2]
#define USB_OTGSC_BSEIS (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_BSEIS_SHIFT)) & USB_OTGSC_BSEIS_MASK)
BSEIS - BSEIS
◆ USB_OTGSC_BSEIS [2/2]
BSEIS - BSEIS
◆ USB_OTGSC_BSV [1/2]
#define USB_OTGSC_BSV (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_BSV_SHIFT)) & USB_OTGSC_BSV_MASK)
BSV - BSV
◆ USB_OTGSC_BSV [2/2]
BSV - BSV
◆ USB_OTGSC_BSVIE [1/2]
#define USB_OTGSC_BSVIE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_BSVIE_SHIFT)) & USB_OTGSC_BSVIE_MASK)
BSVIE - BSVIE
◆ USB_OTGSC_BSVIE [2/2]
BSVIE - BSVIE
◆ USB_OTGSC_BSVIS [1/2]
#define USB_OTGSC_BSVIS (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_BSVIS_SHIFT)) & USB_OTGSC_BSVIS_MASK)
BSVIS - BSVIS
◆ USB_OTGSC_BSVIS [2/2]
BSVIS - BSVIS
◆ USB_OTGSC_DP [1/2]
#define USB_OTGSC_DP (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_DP_SHIFT)) & USB_OTGSC_DP_MASK)
DP - DP
◆ USB_OTGSC_DP [2/2]
DP - DP
◆ USB_OTGSC_DPIE [1/2]
#define USB_OTGSC_DPIE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_DPIE_SHIFT)) & USB_OTGSC_DPIE_MASK)
DPIE - DPIE
◆ USB_OTGSC_DPIE [2/2]
DPIE - DPIE
◆ USB_OTGSC_DPIS [1/2]
#define USB_OTGSC_DPIS (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_DPIS_SHIFT)) & USB_OTGSC_DPIS_MASK)
DPIS - DPIS
◆ USB_OTGSC_DPIS [2/2]
DPIS - DPIS
◆ USB_OTGSC_DPS [1/2]
#define USB_OTGSC_DPS (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_DPS_SHIFT)) & USB_OTGSC_DPS_MASK)
DPS - DPS
◆ USB_OTGSC_DPS [2/2]
DPS - DPS
◆ USB_OTGSC_EN_1MS [1/2]
#define USB_OTGSC_EN_1MS (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_EN_1MS_SHIFT)) & USB_OTGSC_EN_1MS_MASK)
EN_1MS - EN_1MS
◆ USB_OTGSC_EN_1MS [2/2]
EN_1MS - EN_1MS
◆ USB_OTGSC_ID [1/2]
#define USB_OTGSC_ID (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_ID_SHIFT)) & USB_OTGSC_ID_MASK)
ID - ID
◆ USB_OTGSC_ID [2/2]
ID - ID
◆ USB_OTGSC_IDIE [1/2]
#define USB_OTGSC_IDIE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_IDIE_SHIFT)) & USB_OTGSC_IDIE_MASK)
IDIE - IDIE
◆ USB_OTGSC_IDIE [2/2]
IDIE - IDIE
◆ USB_OTGSC_IDIS [1/2]
#define USB_OTGSC_IDIS (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_IDIS_SHIFT)) & USB_OTGSC_IDIS_MASK)
IDIS - IDIS
◆ USB_OTGSC_IDIS [2/2]
IDIS - IDIS
◆ USB_OTGSC_IDPU [1/2]
#define USB_OTGSC_IDPU (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_IDPU_SHIFT)) & USB_OTGSC_IDPU_MASK)
IDPU - IDPU
◆ USB_OTGSC_IDPU [2/2]
IDPU - IDPU
◆ USB_OTGSC_OT [1/2]
#define USB_OTGSC_OT (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_OT_SHIFT)) & USB_OTGSC_OT_MASK)
OT - OT
◆ USB_OTGSC_OT [2/2]
OT - OT
◆ USB_OTGSC_STATUS_1MS [1/2]
#define USB_OTGSC_STATUS_1MS (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_STATUS_1MS_SHIFT)) & USB_OTGSC_STATUS_1MS_MASK)
STATUS_1MS - STATUS_1MS
◆ USB_OTGSC_STATUS_1MS [2/2]
◆ USB_OTGSC_TOG_1MS [1/2]
#define USB_OTGSC_TOG_1MS (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_TOG_1MS_SHIFT)) & USB_OTGSC_TOG_1MS_MASK)
TOG_1MS - TOG_1MS
◆ USB_OTGSC_TOG_1MS [2/2]
TOG_1MS - TOG_1MS
◆ USB_OTGSC_VC [1/2]
#define USB_OTGSC_VC (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_VC_SHIFT)) & USB_OTGSC_VC_MASK)
VC - VC
◆ USB_OTGSC_VC [2/2]
VC - VC
◆ USB_OTGSC_VD [1/2]
#define USB_OTGSC_VD (   x)    (((uint32_t)(((uint32_t)(x)) << USB_OTGSC_VD_SHIFT)) & USB_OTGSC_VD_MASK)
VD - VD
◆ USB_OTGSC_VD [2/2]
VD - VD
◆ USB_PERIODICLISTBASE_BASEADR [1/2]
#define USB_PERIODICLISTBASE_BASEADR (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PERIODICLISTBASE_BASEADR_SHIFT)) & USB_PERIODICLISTBASE_BASEADR_MASK)
BASEADR - BASEADR
◆ USB_PERIODICLISTBASE_BASEADR [2/2]
BASEADR - BASEADR
◆ USB_PORTSC1_CCS [1/2]
#define USB_PORTSC1_CCS (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_CCS_SHIFT)) & USB_PORTSC1_CCS_MASK)
CCS - CCS
◆ USB_PORTSC1_CCS [2/2]
CCS - CCS
◆ USB_PORTSC1_CSC [1/2]
#define USB_PORTSC1_CSC (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_CSC_SHIFT)) & USB_PORTSC1_CSC_MASK)
CSC - CSC
◆ USB_PORTSC1_CSC [2/2]
CSC - CSC
◆ USB_PORTSC1_FPR [1/2]
#define USB_PORTSC1_FPR (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_FPR_SHIFT)) & USB_PORTSC1_FPR_MASK)
FPR - FPR
◆ USB_PORTSC1_FPR [2/2]
FPR - FPR
◆ USB_PORTSC1_HSP [1/2]
#define USB_PORTSC1_HSP (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_HSP_SHIFT)) & USB_PORTSC1_HSP_MASK)
HSP - HSP
◆ USB_PORTSC1_HSP [2/2]
HSP - HSP
◆ USB_PORTSC1_LS [1/3]
#define USB_PORTSC1_LS (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_LS_SHIFT)) & USB_PORTSC1_LS_MASK)
LS 0b00..SE0 0b10..J-state 0b01..K-state 0b11..Undefined
◆ USB_PORTSC1_LS [2/3]
LS - LS 0b00..SE0 0b10..J-state 0b01..K-state 0b11..Undefined
◆ USB_PORTSC1_LS [3/3]
◆ USB_PORTSC1_OCA [1/3]
#define USB_PORTSC1_OCA (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_OCA_SHIFT)) & USB_PORTSC1_OCA_MASK)
OCA 0b1..This port currently has an over-current condition 0b0..This port does not have an over-current condition.
◆ USB_PORTSC1_OCA [2/3]
OCA - OCA 0b1..This port currently has an over-current condition 0b0..This port does not have an over-current condition.
◆ USB_PORTSC1_OCA [3/3]
◆ USB_PORTSC1_OCC [1/2]
#define USB_PORTSC1_OCC (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_OCC_SHIFT)) & USB_PORTSC1_OCC_MASK)
OCC - OCC
◆ USB_PORTSC1_OCC [2/2]
OCC - OCC
◆ USB_PORTSC1_PE [1/2]
#define USB_PORTSC1_PE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PE_SHIFT)) & USB_PORTSC1_PE_MASK)
PE - PE
◆ USB_PORTSC1_PE [2/2]
PE - PE
◆ USB_PORTSC1_PEC [1/2]
#define USB_PORTSC1_PEC (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PEC_SHIFT)) & USB_PORTSC1_PEC_MASK)
PEC - PEC
◆ USB_PORTSC1_PEC [2/2]
PEC - PEC
◆ USB_PORTSC1_PFSC [1/3]
#define USB_PORTSC1_PFSC (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PFSC_SHIFT)) & USB_PORTSC1_PFSC_MASK)
PFSC 0b1..Forced to full speed 0b0..Normal operation
◆ USB_PORTSC1_PFSC [2/3]
PFSC - PFSC 0b1..Forced to full speed 0b0..Normal operation
◆ USB_PORTSC1_PFSC [3/3]
◆ USB_PORTSC1_PHCD [1/3]
#define USB_PORTSC1_PHCD (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PHCD_SHIFT)) & USB_PORTSC1_PHCD_MASK)
PHCD 0b1..Disable PHY clock 0b0..Enable PHY clock
◆ USB_PORTSC1_PHCD [2/3]
PHCD - PHCD 0b1..Disable PHY clock 0b0..Enable PHY clock
◆ USB_PORTSC1_PHCD [3/3]
◆ USB_PORTSC1_PIC [1/3]
#define USB_PORTSC1_PIC (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PIC_SHIFT)) & USB_PORTSC1_PIC_MASK)
PIC 0b00..Port indicators are off 0b01..Amber 0b10..Green 0b11..Undefined
◆ USB_PORTSC1_PIC [2/3]
PIC - PIC 0b00..Port indicators are off 0b01..Amber 0b10..Green 0b11..Undefined
◆ USB_PORTSC1_PIC [3/3]
◆ USB_PORTSC1_PO [1/2]
#define USB_PORTSC1_PO (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PO_SHIFT)) & USB_PORTSC1_PO_MASK)
PO - PO
◆ USB_PORTSC1_PO [2/2]
PO - PO
◆ USB_PORTSC1_PP [1/2]
#define USB_PORTSC1_PP (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PP_SHIFT)) & USB_PORTSC1_PP_MASK)
PP - PP
◆ USB_PORTSC1_PP [2/2]
PP - PP
◆ USB_PORTSC1_PR [1/2]
#define USB_PORTSC1_PR (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PR_SHIFT)) & USB_PORTSC1_PR_MASK)
PR - PR
◆ USB_PORTSC1_PR [2/2]
PR - PR
◆ USB_PORTSC1_PSPD [1/3]
#define USB_PORTSC1_PSPD (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PSPD_SHIFT)) & USB_PORTSC1_PSPD_MASK)
PSPD 0b00..Full Speed 0b01..Low Speed 0b10..High Speed 0b11..Undefined
◆ USB_PORTSC1_PSPD [2/3]
PSPD - PSPD 0b00..Full Speed 0b01..Low Speed 0b10..High Speed 0b11..Undefined
◆ USB_PORTSC1_PSPD [3/3]
◆ USB_PORTSC1_PTC [1/3]
#define USB_PORTSC1_PTC (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PTC_SHIFT)) & USB_PORTSC1_PTC_MASK)
PTC 0b0000..TEST_MODE_DISABLE 0b0001..J_STATE 0b0010..K_STATE 0b0011..SE0 (host) / NAK (device) 0b0100..Packet 0b0101..FORCE_ENABLE_HS 0b0110..FORCE_ENABLE_FS 0b0111..FORCE_ENABLE_LS 0b1000-0b1111..Reserved
◆ USB_PORTSC1_PTC [2/3]
PTC - PTC 0b0000..TEST_MODE_DISABLE 0b0001..J_STATE 0b0010..K_STATE 0b0011..SE0 (host) / NAK (device) 0b0100..Packet 0b0101..FORCE_ENABLE_HS 0b0110..FORCE_ENABLE_FS 0b0111..FORCE_ENABLE_LS 0b1000-0b1111..Reserved
◆ USB_PORTSC1_PTC [3/3]
◆ USB_PORTSC1_PTS_1 [1/2]
#define USB_PORTSC1_PTS_1 (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PTS_1_SHIFT)) & USB_PORTSC1_PTS_1_MASK)
PTS_1 - PTS_1
◆ USB_PORTSC1_PTS_1 [2/2]
PTS_1 - PTS_1
◆ USB_PORTSC1_PTS_2 [1/2]
#define USB_PORTSC1_PTS_2 (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PTS_2_SHIFT)) & USB_PORTSC1_PTS_2_MASK)
PTS_2 - PTS_2
◆ USB_PORTSC1_PTS_2 [2/2]
PTS_2 - PTS_2
◆ USB_PORTSC1_PTW [1/3]
#define USB_PORTSC1_PTW (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_PTW_SHIFT)) & USB_PORTSC1_PTW_MASK)
PTW 0b0..Select the 8-bit UTMI interface [60MHz] 0b1..Select the 16-bit UTMI interface [30MHz]
◆ USB_PORTSC1_PTW [2/3]
PTW - PTW 0b0..Select the 8-bit UTMI interface [60MHz] 0b1..Select the 16-bit UTMI interface [30MHz]
◆ USB_PORTSC1_PTW [3/3]
◆ USB_PORTSC1_STS [1/2]
#define USB_PORTSC1_STS (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_STS_SHIFT)) & USB_PORTSC1_STS_MASK)
STS - STS
◆ USB_PORTSC1_STS [2/2]
STS - STS
◆ USB_PORTSC1_SUSP [1/2]
#define USB_PORTSC1_SUSP (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_SUSP_SHIFT)) & USB_PORTSC1_SUSP_MASK)
SUSP - SUSP
◆ USB_PORTSC1_SUSP [2/2]
SUSP - SUSP
◆ USB_PORTSC1_WKCN [1/2]
#define USB_PORTSC1_WKCN (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_WKCN_SHIFT)) & USB_PORTSC1_WKCN_MASK)
WKCN - WKCN
◆ USB_PORTSC1_WKCN [2/2]
WKCN - WKCN
◆ USB_PORTSC1_WKDC [1/2]
#define USB_PORTSC1_WKDC (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_WKDC_SHIFT)) & USB_PORTSC1_WKDC_MASK)
WKDC - WKDC
◆ USB_PORTSC1_WKDC [2/2]
WKDC - WKDC
◆ USB_PORTSC1_WKOC [1/2]
#define USB_PORTSC1_WKOC (   x)    (((uint32_t)(((uint32_t)(x)) << USB_PORTSC1_WKOC_SHIFT)) & USB_PORTSC1_WKOC_MASK)
WKOC - WKOC
◆ USB_PORTSC1_WKOC [2/2]
WKOC - WKOC
◆ USB_SBUSCFG_AHBBRST [1/3]
#define USB_SBUSCFG_AHBBRST (   x)    (((uint32_t)(((uint32_t)(x)) << USB_SBUSCFG_AHBBRST_SHIFT)) & USB_SBUSCFG_AHBBRST_MASK)
AHBBRST 0b000..Incremental burst of unspecified length only 0b001..INCR4 burst, then single transfer 0b010..INCR8 burst, INCR4 burst, then single transfer 0b011..INCR16 burst, INCR8 burst, INCR4 burst, then single transfer 0b100..Reserved, don't use 0b101..INCR4 burst, then incremental burst of unspecified length 0b110..INCR8 burst, INCR4 burst, then incremental burst of unspecified length 0b111..INCR16 burst, INCR8 burst, INCR4 burst, then incremental burst of unspecified length
◆ USB_SBUSCFG_AHBBRST [2/3]
AHBBRST - AHBBRST 0b000..Incremental burst of unspecified length only 0b001..INCR4 burst, then single transfer 0b010..INCR8 burst, INCR4 burst, then single transfer 0b011..INCR16 burst, INCR8 burst, INCR4 burst, then single transfer 0b100..Reserved, don't use 0b101..INCR4 burst, then incremental burst of unspecified length 0b110..INCR8 burst, INCR4 burst, then incremental burst of unspecified length 0b111..INCR16 burst, INCR8 burst, INCR4 burst, then incremental burst of unspecified length
◆ USB_SBUSCFG_AHBBRST [3/3]
◆ USB_TXFILLTUNING_TXFIFOTHRES [1/2]
#define USB_TXFILLTUNING_TXFIFOTHRES (   x)    (((uint32_t)(((uint32_t)(x)) << USB_TXFILLTUNING_TXFIFOTHRES_SHIFT)) & USB_TXFILLTUNING_TXFIFOTHRES_MASK)
TXFIFOTHRES - TXFIFOTHRES
◆ USB_TXFILLTUNING_TXFIFOTHRES [2/2]
◆ USB_TXFILLTUNING_TXSCHHEALTH [1/2]
#define USB_TXFILLTUNING_TXSCHHEALTH (   x)    (((uint32_t)(((uint32_t)(x)) << USB_TXFILLTUNING_TXSCHHEALTH_SHIFT)) & USB_TXFILLTUNING_TXSCHHEALTH_MASK)
TXSCHHEALTH - TXSCHHEALTH
◆ USB_TXFILLTUNING_TXSCHHEALTH [2/2]
◆ USB_TXFILLTUNING_TXSCHOH [1/2]
#define USB_TXFILLTUNING_TXSCHOH (   x)    (((uint32_t)(((uint32_t)(x)) << USB_TXFILLTUNING_TXSCHOH_SHIFT)) & USB_TXFILLTUNING_TXSCHOH_MASK)
TXSCHOH - TXSCHOH
◆ USB_TXFILLTUNING_TXSCHOH [2/2]
TXSCHOH - TXSCHOH
◆ USB_USBCMD_ASE [1/3]
#define USB_USBCMD_ASE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBCMD_ASE_SHIFT)) & USB_USBCMD_ASE_MASK)
ASE 0b0..Do not process the Asynchronous Schedule. 0b1..Use the ASYNCLISTADDR register to access the Asynchronous Schedule.
◆ USB_USBCMD_ASE [2/3]
ASE - ASE 0b0..Do not process the Asynchronous Schedule. 0b1..Use the ASYNCLISTADDR register to access the Asynchronous Schedule.
◆ USB_USBCMD_ASE [3/3]
◆ USB_USBCMD_ASP [1/2]
#define USB_USBCMD_ASP (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBCMD_ASP_SHIFT)) & USB_USBCMD_ASP_MASK)
ASP - ASP
◆ USB_USBCMD_ASP [2/2]
ASP - ASP
◆ USB_USBCMD_ASPE [1/2]
#define USB_USBCMD_ASPE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBCMD_ASPE_SHIFT)) & USB_USBCMD_ASPE_MASK)
ASPE - ASPE
◆ USB_USBCMD_ASPE [2/2]
ASPE - ASPE
◆ USB_USBCMD_ATDTW [1/2]
#define USB_USBCMD_ATDTW (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBCMD_ATDTW_SHIFT)) & USB_USBCMD_ATDTW_MASK)
ATDTW - ATDTW
◆ USB_USBCMD_ATDTW [2/2]
ATDTW - ATDTW
◆ USB_USBCMD_FS_1 [1/2]
#define USB_USBCMD_FS_1 (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBCMD_FS_1_SHIFT)) & USB_USBCMD_FS_1_MASK)
FS_1 - FS_1
◆ USB_USBCMD_FS_1 [2/2]
FS_1 - FS_1
◆ USB_USBCMD_FS_2 [1/3]
#define USB_USBCMD_FS_2 (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBCMD_FS_2_SHIFT)) & USB_USBCMD_FS_2_MASK)
FS_2 0b0..1024 elements (4096 bytes) Default value 0b1..512 elements (2048 bytes)
◆ USB_USBCMD_FS_2 [2/3]
FS_2 - FS_2
◆ USB_USBCMD_FS_2 [3/3]
FS_2 - FS_2
◆ USB_USBCMD_IAA [1/2]
#define USB_USBCMD_IAA (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBCMD_IAA_SHIFT)) & USB_USBCMD_IAA_MASK)
IAA - IAA
◆ USB_USBCMD_IAA [2/2]
IAA - IAA
◆ USB_USBCMD_ITC [1/3]
#define USB_USBCMD_ITC (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBCMD_ITC_SHIFT)) & USB_USBCMD_ITC_MASK)
ITC 0b00000000..Immediate (no threshold) 0b00000001..1 micro-frame 0b00000010..2 micro-frames 0b00000100..4 micro-frames 0b00001000..8 micro-frames 0b00010000..16 micro-frames 0b00100000..32 micro-frames 0b01000000..64 micro-frames
◆ USB_USBCMD_ITC [2/3]
ITC - ITC 0b00000000..Immediate (no threshold) 0b00000001..1 micro-frame 0b00000010..2 micro-frames 0b00000100..4 micro-frames 0b00001000..8 micro-frames 0b00010000..16 micro-frames 0b00100000..32 micro-frames 0b01000000..64 micro-frames
◆ USB_USBCMD_ITC [3/3]
◆ USB_USBCMD_PSE [1/3]
#define USB_USBCMD_PSE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBCMD_PSE_SHIFT)) & USB_USBCMD_PSE_MASK)
PSE 0b0..Do not process the Periodic Schedule 0b1..Use the PERIODICLISTBASE register to access the Periodic Schedule.
◆ USB_USBCMD_PSE [2/3]
PSE - PSE 0b0..Do not process the Periodic Schedule 0b1..Use the PERIODICLISTBASE register to access the Periodic Schedule.
◆ USB_USBCMD_PSE [3/3]
◆ USB_USBCMD_RS [1/2]
#define USB_USBCMD_RS (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBCMD_RS_SHIFT)) & USB_USBCMD_RS_MASK)
RS - RS
◆ USB_USBCMD_RS [2/2]
RS - RS
◆ USB_USBCMD_RST [1/2]
#define USB_USBCMD_RST (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBCMD_RST_SHIFT)) & USB_USBCMD_RST_MASK)
RST - RST
◆ USB_USBCMD_RST [2/2]
RST - RST
◆ USB_USBCMD_SUTW [1/2]
#define USB_USBCMD_SUTW (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBCMD_SUTW_SHIFT)) & USB_USBCMD_SUTW_MASK)
SUTW - SUTW
◆ USB_USBCMD_SUTW [2/2]
SUTW - SUTW
◆ USB_USBINTR_AAE [1/2]
#define USB_USBINTR_AAE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_AAE_SHIFT)) & USB_USBINTR_AAE_MASK)
AAE - AAE
◆ USB_USBINTR_AAE [2/2]
AAE - AAE
◆ USB_USBINTR_FRE [1/2]
#define USB_USBINTR_FRE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_FRE_SHIFT)) & USB_USBINTR_FRE_MASK)
FRE - FRE
◆ USB_USBINTR_FRE [2/2]
FRE - FRE
◆ USB_USBINTR_NAKE [1/2]
#define USB_USBINTR_NAKE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_NAKE_SHIFT)) & USB_USBINTR_NAKE_MASK)
NAKE - NAKE
◆ USB_USBINTR_NAKE [2/2]
NAKE - NAKE
◆ USB_USBINTR_PCE [1/2]
#define USB_USBINTR_PCE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_PCE_SHIFT)) & USB_USBINTR_PCE_MASK)
PCE - PCE
◆ USB_USBINTR_PCE [2/2]
PCE - PCE
◆ USB_USBINTR_SEE [1/2]
#define USB_USBINTR_SEE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_SEE_SHIFT)) & USB_USBINTR_SEE_MASK)
SEE - SEE
◆ USB_USBINTR_SEE [2/2]
SEE - SEE
◆ USB_USBINTR_SLE [1/2]
#define USB_USBINTR_SLE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_SLE_SHIFT)) & USB_USBINTR_SLE_MASK)
SLE - SLE
◆ USB_USBINTR_SLE [2/2]
SLE - SLE
◆ USB_USBINTR_SRE [1/2]
#define USB_USBINTR_SRE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_SRE_SHIFT)) & USB_USBINTR_SRE_MASK)
SRE - SRE
◆ USB_USBINTR_SRE [2/2]
SRE - SRE
◆ USB_USBINTR_TIE0 [1/2]
#define USB_USBINTR_TIE0 (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_TIE0_SHIFT)) & USB_USBINTR_TIE0_MASK)
TIE0 - TIE0
◆ USB_USBINTR_TIE0 [2/2]
TIE0 - TIE0
◆ USB_USBINTR_TIE1 [1/2]
#define USB_USBINTR_TIE1 (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_TIE1_SHIFT)) & USB_USBINTR_TIE1_MASK)
TIE1 - TIE1
◆ USB_USBINTR_TIE1 [2/2]
TIE1 - TIE1
◆ USB_USBINTR_UAIE [1/2]
#define USB_USBINTR_UAIE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_UAIE_SHIFT)) & USB_USBINTR_UAIE_MASK)
UAIE - UAIE
◆ USB_USBINTR_UAIE [2/2]
UAIE - UAIE
◆ USB_USBINTR_UE [1/2]
#define USB_USBINTR_UE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_UE_SHIFT)) & USB_USBINTR_UE_MASK)
UE - UE
◆ USB_USBINTR_UE [2/2]
UE - UE
◆ USB_USBINTR_UEE [1/2]
#define USB_USBINTR_UEE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_UEE_SHIFT)) & USB_USBINTR_UEE_MASK)
UEE - UEE
◆ USB_USBINTR_UEE [2/2]
UEE - UEE
◆ USB_USBINTR_ULPIE [1/2]
#define USB_USBINTR_ULPIE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_ULPIE_SHIFT)) & USB_USBINTR_ULPIE_MASK)
ULPIE - ULPIE
◆ USB_USBINTR_ULPIE [2/2]
ULPIE - ULPIE
◆ USB_USBINTR_UPIE [1/2]
#define USB_USBINTR_UPIE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_UPIE_SHIFT)) & USB_USBINTR_UPIE_MASK)
UPIE - UPIE
◆ USB_USBINTR_UPIE [2/2]
UPIE - UPIE
◆ USB_USBINTR_URE [1/2]
#define USB_USBINTR_URE (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBINTR_URE_SHIFT)) & USB_USBINTR_URE_MASK)
URE - URE
◆ USB_USBINTR_URE [2/2]
URE - URE
◆ USB_USBMODE_CM [1/3]
#define USB_USBMODE_CM (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBMODE_CM_SHIFT)) & USB_USBMODE_CM_MASK)
CM 0b00..Idle [Default for combination host/device] 0b01..Reserved 0b10..Device Controller [Default for device only controller] 0b11..Host Controller [Default for host only controller]
◆ USB_USBMODE_CM [2/3]
CM - CM 0b00..Idle [Default for combination host/device] 0b01..Reserved 0b10..Device Controller [Default for device only controller] 0b11..Host Controller [Default for host only controller]
◆ USB_USBMODE_CM [3/3]
◆ USB_USBMODE_ES [1/3]
#define USB_USBMODE_ES (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBMODE_ES_SHIFT)) & USB_USBMODE_ES_MASK)
ES 0b0..Little Endian [Default] 0b1..Big Endian
◆ USB_USBMODE_ES [2/3]
ES - ES 0b0..Little Endian [Default] 0b1..Big Endian
◆ USB_USBMODE_ES [3/3]
◆ USB_USBMODE_SDIS [1/2]
#define USB_USBMODE_SDIS (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBMODE_SDIS_SHIFT)) & USB_USBMODE_SDIS_MASK)
SDIS - SDIS
◆ USB_USBMODE_SDIS [2/2]
SDIS - SDIS
◆ USB_USBMODE_SLOM [1/3]
#define USB_USBMODE_SLOM (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBMODE_SLOM_SHIFT)) & USB_USBMODE_SLOM_MASK)
SLOM 0b0..Setup Lockouts On (default); 0b1..Setup Lockouts Off (DCD requires use of Setup Data Buffer Tripwire in USBCMDUSB Command Register .
◆ USB_USBMODE_SLOM [2/3]
SLOM - SLOM 0b0..Setup Lockouts On (default); 0b1..Setup Lockouts Off
◆ USB_USBMODE_SLOM [3/3]
◆ USB_USBSTS_AAI [1/2]
#define USB_USBSTS_AAI (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_AAI_SHIFT)) & USB_USBSTS_AAI_MASK)
AAI - AAI
◆ USB_USBSTS_AAI [2/2]
AAI - AAI
◆ USB_USBSTS_AS [1/2]
#define USB_USBSTS_AS (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_AS_SHIFT)) & USB_USBSTS_AS_MASK)
AS - AS
◆ USB_USBSTS_AS [2/2]
AS - AS
◆ USB_USBSTS_FRI [1/2]
#define USB_USBSTS_FRI (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_FRI_SHIFT)) & USB_USBSTS_FRI_MASK)
FRI - FRI
◆ USB_USBSTS_FRI [2/2]
FRI - FRI
◆ USB_USBSTS_HCH [1/2]
#define USB_USBSTS_HCH (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_HCH_SHIFT)) & USB_USBSTS_HCH_MASK)
HCH - HCH
◆ USB_USBSTS_HCH [2/2]
HCH - HCH
◆ USB_USBSTS_NAKI [1/2]
#define USB_USBSTS_NAKI (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_NAKI_SHIFT)) & USB_USBSTS_NAKI_MASK)
NAKI - NAKI
◆ USB_USBSTS_NAKI [2/2]
NAKI - NAKI
◆ USB_USBSTS_PCI [1/2]
#define USB_USBSTS_PCI (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_PCI_SHIFT)) & USB_USBSTS_PCI_MASK)
PCI - PCI
◆ USB_USBSTS_PCI [2/2]
PCI - PCI
◆ USB_USBSTS_PS [1/2]
#define USB_USBSTS_PS (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_PS_SHIFT)) & USB_USBSTS_PS_MASK)
PS - PS
◆ USB_USBSTS_PS [2/2]
PS - PS
◆ USB_USBSTS_RCL [1/2]
#define USB_USBSTS_RCL (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_RCL_SHIFT)) & USB_USBSTS_RCL_MASK)
RCL - RCL
◆ USB_USBSTS_RCL [2/2]
RCL - RCL
◆ USB_USBSTS_SEI [1/2]
#define USB_USBSTS_SEI (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_SEI_SHIFT)) & USB_USBSTS_SEI_MASK)
SEI - SEI
◆ USB_USBSTS_SEI [2/2]
SEI - SEI
◆ USB_USBSTS_SLI [1/2]
#define USB_USBSTS_SLI (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_SLI_SHIFT)) & USB_USBSTS_SLI_MASK)
SLI - SLI
◆ USB_USBSTS_SLI [2/2]
SLI - SLI
◆ USB_USBSTS_SRI [1/2]
#define USB_USBSTS_SRI (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_SRI_SHIFT)) & USB_USBSTS_SRI_MASK)
SRI - SRI
◆ USB_USBSTS_SRI [2/2]
SRI - SRI
◆ USB_USBSTS_TI0 [1/2]
#define USB_USBSTS_TI0 (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_TI0_SHIFT)) & USB_USBSTS_TI0_MASK)
TI0 - TI0
◆ USB_USBSTS_TI0 [2/2]
TI0 - TI0
◆ USB_USBSTS_TI1 [1/2]
#define USB_USBSTS_TI1 (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_TI1_SHIFT)) & USB_USBSTS_TI1_MASK)
TI1 - TI1
◆ USB_USBSTS_TI1 [2/2]
TI1 - TI1
◆ USB_USBSTS_UEI [1/2]
#define USB_USBSTS_UEI (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_UEI_SHIFT)) & USB_USBSTS_UEI_MASK)
UEI - UEI
◆ USB_USBSTS_UEI [2/2]
UEI - UEI
◆ USB_USBSTS_UI [1/2]
#define USB_USBSTS_UI (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_UI_SHIFT)) & USB_USBSTS_UI_MASK)
UI - UI
◆ USB_USBSTS_UI [2/2]
UI - UI
◆ USB_USBSTS_ULPII [1/2]
#define USB_USBSTS_ULPII (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_ULPII_SHIFT)) & USB_USBSTS_ULPII_MASK)
ULPII - ULPII
◆ USB_USBSTS_ULPII [2/2]
ULPII - ULPII
◆ USB_USBSTS_URI [1/2]
#define USB_USBSTS_URI (   x)    (((uint32_t)(((uint32_t)(x)) << USB_USBSTS_URI_SHIFT)) & USB_USBSTS_URI_MASK)
URI - URI
◆ USB_USBSTS_URI [2/2]
URI - URI
