RTEMS 6.1-rc4
Files | Data Structures | Typedefs | Enumerations | Functions
spec:/rtems/intr/req/vector-is-enabled
file  tc-intr-vector-is-enabled.c
struct  RtemsIntrReqVectorIsEnabled_Entry
struct  RtemsIntrReqVectorIsEnabled_Context
 Test context for spec:/rtems/intr/req/vector-is-enabled test case. More...
typedef RtemsIntrReqVectorIsEnabled_Context Context
enum  RtemsIntrReqVectorIsEnabled_Pre_Vector { RtemsIntrReqVectorIsEnabled_Pre_Vector_Valid , RtemsIntrReqVectorIsEnabled_Pre_Vector_Invalid , RtemsIntrReqVectorIsEnabled_Pre_Vector_NA }
enum  RtemsIntrReqVectorIsEnabled_Pre_Enabled { RtemsIntrReqVectorIsEnabled_Pre_Enabled_Obj , RtemsIntrReqVectorIsEnabled_Pre_Enabled_Null , RtemsIntrReqVectorIsEnabled_Pre_Enabled_NA }
enum  RtemsIntrReqVectorIsEnabled_Pre_IsEnabled { RtemsIntrReqVectorIsEnabled_Pre_IsEnabled_Yes , RtemsIntrReqVectorIsEnabled_Pre_IsEnabled_No , RtemsIntrReqVectorIsEnabled_Pre_IsEnabled_NA }
enum  RtemsIntrReqVectorIsEnabled_Post_Status { RtemsIntrReqVectorIsEnabled_Post_Status_Ok , RtemsIntrReqVectorIsEnabled_Post_Status_InvAddr , RtemsIntrReqVectorIsEnabled_Post_Status_InvId , RtemsIntrReqVectorIsEnabled_Post_Status_NA }
enum  RtemsIntrReqVectorIsEnabled_Post_IsEnabled { RtemsIntrReqVectorIsEnabled_Post_IsEnabled_Nop , RtemsIntrReqVectorIsEnabled_Post_IsEnabled_Yes , RtemsIntrReqVectorIsEnabled_Post_IsEnabled_No , RtemsIntrReqVectorIsEnabled_Post_IsEnabled_NA }
 T_TEST_CASE_FIXTURE (RtemsIntrReqVectorIsEnabled, &RtemsIntrReqVectorIsEnabled_Fixture)
