RTEMS 6.1-rc4
Files | Data Structures | Typedefs | Enumerations | Functions
spec:/bsp/req/interrupt-handler-dispatch-unchecked
file  tc-bsp-interrupt-handler-dispatch-unchecked.c
struct  BspReqInterruptHandlerDispatchUnchecked_Entry
struct  BspReqInterruptHandlerDispatchUnchecked_Context
 Test context for spec:/bsp/req/interrupt-handler-dispatch-unchecked test case. More...
typedef BspReqInterruptHandlerDispatchUnchecked_Context Context
enum  BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirst { BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirst_Null , BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirst_Entry , BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirst_NA }
enum  BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirstAgain { BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirstAgain_Null , BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirstAgain_Entry , BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirstAgain_NA }
enum  BspReqInterruptHandlerDispatchUnchecked_Post_Result { BspReqInterruptHandlerDispatchUnchecked_Post_Result_FatalError , BspReqInterruptHandlerDispatchUnchecked_Post_Result_Dispatch , BspReqInterruptHandlerDispatchUnchecked_Post_Result_NA }
enum  BspReqInterruptHandlerDispatchUnchecked_Post_FatalSource { BspReqInterruptHandlerDispatchUnchecked_Post_FatalSource_SpuriousInterrupt , BspReqInterruptHandlerDispatchUnchecked_Post_FatalSource_NA }
enum  BspReqInterruptHandlerDispatchUnchecked_Post_FatalCode { BspReqInterruptHandlerDispatchUnchecked_Post_FatalCode_Vector , BspReqInterruptHandlerDispatchUnchecked_Post_FatalCode_NA }
void __real_bsp_interrupt_handler_default (rtems_vector_number vector)
void __wrap_bsp_interrupt_handler_default (rtems_vector_number vector)
 T_TEST_CASE_FIXTURE (BspReqInterruptHandlerDispatchUnchecked, &BspReqInterruptHandlerDispatchUnchecked_Fixture)
