RTEMS 6.1-rc4
#define | IS_TIM_CLEARINPUT_SOURCE(__MODE__) |
#define | IS_TIM_DMA_BASE(__BASE__) |
#define | IS_TIM_EVENT_SOURCE(__SOURCE__) ((((__SOURCE__) & 0xFFFFFE00U) == 0x00000000U) && ((__SOURCE__) != 0x00000000U)) |
#define | IS_TIM_COUNTER_MODE(__MODE__) |
#define | IS_TIM_UIFREMAP_MODE(__MODE__) |
#define | IS_TIM_CLOCKDIVISION_DIV(__DIV__) |
#define | IS_TIM_AUTORELOAD_PRELOAD(PRELOAD) |
#define | IS_TIM_FAST_STATE(__STATE__) |
#define | IS_TIM_OC_POLARITY(__POLARITY__) |
#define | IS_TIM_OCN_POLARITY(__POLARITY__) |
#define | IS_TIM_OCIDLE_STATE(__STATE__) |
#define | IS_TIM_OCNIDLE_STATE(__STATE__) |
#define | IS_TIM_ENCODERINPUT_POLARITY(__POLARITY__) |
#define | IS_TIM_IC_POLARITY(__POLARITY__) |
#define | IS_TIM_IC_SELECTION(__SELECTION__) |
#define | IS_TIM_IC_PRESCALER(__PRESCALER__) |
#define | IS_TIM_CCX_CHANNEL(__INSTANCE__, __CHANNEL__) |
#define | IS_TIM_OPM_MODE(__MODE__) |
#define | IS_TIM_ENCODER_MODE(__MODE__) |
#define | IS_TIM_DMA_SOURCE(__SOURCE__) ((((__SOURCE__) & 0xFFFF80FFU) == 0x00000000U) && ((__SOURCE__) != 0x00000000U)) |
#define | IS_TIM_CHANNELS(__CHANNEL__) |
#define | IS_TIM_OPM_CHANNELS(__CHANNEL__) |
#define | IS_TIM_PERIOD(__HANDLE__, __PERIOD__) |
#define | IS_TIM_COMPLEMENTARY_CHANNELS(__CHANNEL__) |
#define | IS_TIM_CLOCKSOURCE(__CLOCK__) |
#define | IS_TIM_CLOCKPOLARITY(__POLARITY__) |
#define | IS_TIM_CLOCKPRESCALER(__PRESCALER__) |
#define | IS_TIM_CLOCKFILTER(__ICFILTER__) ((__ICFILTER__) <= 0xFU) |
#define | IS_TIM_CLEARINPUT_POLARITY(__POLARITY__) |
#define | IS_TIM_CLEARINPUT_PRESCALER(__PRESCALER__) |
#define | IS_TIM_CLEARINPUT_FILTER(__ICFILTER__) ((__ICFILTER__) <= 0xFU) |
#define | IS_TIM_OSSR_STATE(__STATE__) |
#define | IS_TIM_OSSI_STATE(__STATE__) |
#define | IS_TIM_LOCK_LEVEL(__LEVEL__) |
#define | IS_TIM_BREAK_FILTER(__BRKFILTER__) ((__BRKFILTER__) <= 0xFUL) |
#define | IS_TIM_BREAK_STATE(__STATE__) |
#define | IS_TIM_BREAK_POLARITY(__POLARITY__) |
#define | IS_TIM_BREAK2_STATE(__STATE__) |
#define | IS_TIM_BREAK2_POLARITY(__POLARITY__) |
#define | IS_TIM_AUTOMATIC_OUTPUT_STATE(__STATE__) |
#define | IS_TIM_GROUPCH5(__OCREF__) ((((__OCREF__) & 0x1FFFFFFFU) == 0x00000000U)) |
#define | IS_TIM_TRGO_SOURCE(__SOURCE__) |
#define | IS_TIM_TRGO2_SOURCE(__SOURCE__) |
#define | IS_TIM_MSM_STATE(__STATE__) |
#define | IS_TIM_SLAVE_MODE(__MODE__) |
#define | IS_TIM_PWM_MODE(__MODE__) |
#define | IS_TIM_OC_MODE(__MODE__) |
#define | IS_TIM_TRIGGER_SELECTION(__SELECTION__) |
#define | IS_TIM_INTERNAL_TRIGGEREVENT_SELECTION(__SELECTION__) |
#define | IS_TIM_TRIGGERPOLARITY(__POLARITY__) |
#define | IS_TIM_TRIGGERPRESCALER(__PRESCALER__) |
#define | IS_TIM_TRIGGERFILTER(__ICFILTER__) ((__ICFILTER__) <= 0xFU) |
#define | IS_TIM_TI1SELECTION(__TI1SELECTION__) |
#define | IS_TIM_DMA_LENGTH(__LENGTH__) |
#define | IS_TIM_DMA_DATA_LENGTH(LENGTH) (((LENGTH) >= 0x1U) && ((LENGTH) < 0x10000U)) |
#define | IS_TIM_IC_FILTER(__ICFILTER__) ((__ICFILTER__) <= 0xFU) |
#define | IS_TIM_DEADTIME(__DEADTIME__) ((__DEADTIME__) <= 0xFFU) |
#define | IS_TIM_BREAK_SYSTEM(__CONFIG__) |
#define | IS_TIM_SLAVEMODE_TRIGGER_ENABLED(__TRIGGER__) |
#define | TIM_SET_ICPRESCALERVALUE(__HANDLE__, __CHANNEL__, __ICPSC__) |
#define | TIM_RESET_ICPRESCALERVALUE(__HANDLE__, __CHANNEL__) |
#define | TIM_SET_CAPTUREPOLARITY(__HANDLE__, __CHANNEL__, __POLARITY__) |
#define | TIM_RESET_CAPTUREPOLARITY(__HANDLE__, __CHANNEL__) |
#define | TIM_CHANNEL_STATE_GET(__HANDLE__, __CHANNEL__) |
#define | TIM_CHANNEL_STATE_SET(__HANDLE__, __CHANNEL__, __CHANNEL_STATE__) |
#define | TIM_CHANNEL_STATE_SET_ALL(__HANDLE__, __CHANNEL_STATE__) |
#define | TIM_CHANNEL_N_STATE_GET(__HANDLE__, __CHANNEL__) |
#define | TIM_CHANNEL_N_STATE_SET(__HANDLE__, __CHANNEL__, __CHANNEL_STATE__) |
#define | TIM_CHANNEL_N_STATE_SET_ALL(__HANDLE__, __CHANNEL_STATE__) |
#define IS_TIM_AUTOMATIC_OUTPUT_STATE | ( | __STATE__ | ) |
#define IS_TIM_AUTORELOAD_PRELOAD | ( | PRELOAD | ) |
#define IS_TIM_BREAK2_POLARITY | ( | __POLARITY__ | ) |
#define IS_TIM_BREAK2_STATE | ( | __STATE__ | ) |
#define IS_TIM_BREAK_POLARITY | ( | __POLARITY__ | ) |
#define IS_TIM_BREAK_STATE | ( | __STATE__ | ) |
#define IS_TIM_BREAK_SYSTEM | ( | __CONFIG__ | ) |
#define IS_TIM_CCX_CHANNEL | ( | __INSTANCE__, | |
__CHANNEL__ | |||
#define IS_TIM_CHANNELS | ( | __CHANNEL__ | ) |
#define IS_TIM_CLEARINPUT_POLARITY | ( | __POLARITY__ | ) |
#define IS_TIM_CLEARINPUT_PRESCALER | ( | __PRESCALER__ | ) |
#define IS_TIM_CLEARINPUT_SOURCE | ( | __MODE__ | ) |
#define IS_TIM_CLOCKDIVISION_DIV | ( | __DIV__ | ) |
#define IS_TIM_CLOCKPOLARITY | ( | __POLARITY__ | ) |
#define IS_TIM_CLOCKPRESCALER | ( | __PRESCALER__ | ) |
#define IS_TIM_CLOCKSOURCE | ( | __CLOCK__ | ) |
#define IS_TIM_COMPLEMENTARY_CHANNELS | ( | __CHANNEL__ | ) |
#define IS_TIM_COUNTER_MODE | ( | __MODE__ | ) |
#define IS_TIM_DMA_BASE | ( | __BASE__ | ) |
#define IS_TIM_DMA_LENGTH | ( | __LENGTH__ | ) |
#define IS_TIM_ENCODER_MODE | ( | __MODE__ | ) |
#define IS_TIM_ENCODERINPUT_POLARITY | ( | __POLARITY__ | ) |
#define IS_TIM_FAST_STATE | ( | __STATE__ | ) |
#define IS_TIM_IC_POLARITY | ( | __POLARITY__ | ) |
#define IS_TIM_IC_PRESCALER | ( | __PRESCALER__ | ) |
#define IS_TIM_IC_SELECTION | ( | __SELECTION__ | ) |
#define IS_TIM_INTERNAL_TRIGGEREVENT_SELECTION | ( | __SELECTION__ | ) |
#define IS_TIM_LOCK_LEVEL | ( | __LEVEL__ | ) |
#define IS_TIM_MSM_STATE | ( | __STATE__ | ) |
#define IS_TIM_OC_MODE | ( | __MODE__ | ) |
#define IS_TIM_OC_POLARITY | ( | __POLARITY__ | ) |
#define IS_TIM_OCIDLE_STATE | ( | __STATE__ | ) |
#define IS_TIM_OCN_POLARITY | ( | __POLARITY__ | ) |
#define IS_TIM_OCNIDLE_STATE | ( | __STATE__ | ) |
#define IS_TIM_OPM_CHANNELS | ( | __CHANNEL__ | ) |
#define IS_TIM_OPM_MODE | ( | __MODE__ | ) |
#define IS_TIM_OSSI_STATE | ( | __STATE__ | ) |
#define IS_TIM_OSSR_STATE | ( | __STATE__ | ) |
#define IS_TIM_PERIOD | ( | __HANDLE__, | |
__PERIOD__ | |||
#define IS_TIM_PWM_MODE | ( | __MODE__ | ) |
#define IS_TIM_SLAVE_MODE | ( | __MODE__ | ) |
#define IS_TIM_SLAVEMODE_TRIGGER_ENABLED | ( | __TRIGGER__ | ) |
#define IS_TIM_TI1SELECTION | ( | __TI1SELECTION__ | ) |
#define IS_TIM_TRGO2_SOURCE | ( | __SOURCE__ | ) |
#define IS_TIM_TRGO_SOURCE | ( | __SOURCE__ | ) |
#define IS_TIM_TRIGGER_SELECTION | ( | __SELECTION__ | ) |
#define IS_TIM_TRIGGERPOLARITY | ( | __POLARITY__ | ) |
#define IS_TIM_TRIGGERPRESCALER | ( | __PRESCALER__ | ) |
#define IS_TIM_UIFREMAP_MODE | ( | __MODE__ | ) |
#define TIM_CHANNEL_N_STATE_GET | ( | __HANDLE__, | |
__CHANNEL__ | |||
#define TIM_CHANNEL_N_STATE_SET | ( | __HANDLE__, | |
__CHANNEL__, | |||
__CHANNEL_STATE__ | |||
#define TIM_CHANNEL_N_STATE_SET_ALL | ( | __HANDLE__, | |
#define TIM_CHANNEL_STATE_GET | ( | __HANDLE__, | |
__CHANNEL__ | |||
#define TIM_CHANNEL_STATE_SET | ( | __HANDLE__, | |
__CHANNEL__, | |||
#define TIM_CHANNEL_STATE_SET_ALL | ( | __HANDLE__, | |
#define TIM_RESET_CAPTUREPOLARITY | ( | __HANDLE__, | |
__CHANNEL__ | |||
#define TIM_RESET_ICPRESCALERVALUE | ( | __HANDLE__, | |
__CHANNEL__ | |||
#define TIM_SET_CAPTUREPOLARITY | ( | __HANDLE__, | |
__CHANNEL__, | |||
__POLARITY__ | |||
#define TIM_SET_ICPRESCALERVALUE | ( | __HANDLE__, | |
__CHANNEL__, | |||
__ICPSC__ | |||
