RTEMS 6.1-rc4
STM32H7 Board Support Package. More...
Files | |
file | spi2-cfg.c |
This source file contains the SPI2 pin configuration. | |
file | spi-support.c |
This source file contains the shared SPI support code. | |
file | spi1.c |
This source file contains the shared SPI1 peripheral configuration. | |
file | spi2.c |
This source file contains the shared SPI2 peripheral configuration. | |
file | spi3.c |
This source file contains the shared SPI3 peripheral configuration. | |
file | spi4.c |
This source file contains the shared SPI4 peripheral configuration. | |
file | spi5.c |
This source file contains the shared SPI5 peripheral configuration. | |
file | spi6.c |
This source file contains the shared SPI6 peripheral configuration. | |
file | stm32h7-hal-spi.c |
This source file contains the SPI MSP initialization implementation. | |
uint32_t | stm32h7_systick_frequency (void) |
void | stm32h7_init_power (void) |
void | stm32h7_init_oscillator (void) |
void | stm32h7_init_clocks (void) |
void | stm32h7_init_peripheral_clocks (void) |
void | stm32h7_init_qspi (void) |
void | SystemInit_ExtMemCtl (void) |
Setup the external memory controller. Called in startup_stm32h7xx.s before jump to main. This function configures the external memories (SRAM/SDRAM) This SRAM/SDRAM will be used as program data memory (including heap and stack). | |
void | stm32h7_register_spi_devices (void) |
Register SPI interfaces. | |
void stm32h7_register_spi_devices | ( | void | ) |
This initializes and registers the configured SPI devices with the RTEMS SPI framework. SPI devices are configured at BSP build time.
void SystemInit_ExtMemCtl | ( | void | ) |
None |
None |
