RTEMS 6.1-rc4
Modules | Files | Macros | Functions | Variables
NXP MPC55XX and MPC56XX
NXP MPC55XX and MPC56XX Board Support Package. More...
 Configuration files
 Deserial Serial Peripheral Interface (DSPI)
file  clock-config.c
 Clock driver configuration.
file  bsp.h
 Global BSP definitions.
file  irq.h
 IRQ.
file  mpc55xx-config.h
 Low-level configuration.
file  smsc9218i.h
 SMSC - LAN9218i.
file  edma.h
 Enhanced Direct Memory Access (eDMA).
file  emios.h
 Enhanced Modular Input Output Subsystem (eMIOS).
file  mpc55xx.h
 Documentation for this file.
file  reg-defs.h
 Register definitions.
file  regs-edma.h
file  regs-mmu.h
file  regs.h
 Register definitions for the MPC55xx and MPC56xx microcontroller family.
file  siu.h
 System Integration Unit Access (SIU).
file  watchdog.h
 Header file for the watchdog timer.
file  bspgetworkarea.c
 This source file contains the powerpc/mpc55xxevb implementation of _Memory_Get().
file  bspreset.c
 BSP reset.
file  bspstart.c
 BSP startup code.
file  edma.c
file  emios.c
file  flash_support.c
 MPC55XX flash memory support.
file  get-system-clock.c
 System clock calculation.
file  idle-thread.c
 bsp_idle_thread() implementation.
file  irq.c
 Source file for MPC55XX interrupt support.
file  sd-card-init.c
 SD Card initialization code.
file  siu.c
file  start-clock.c
 Clock and FMPLL initialization code.
file  start-config-clock.c
 Clock and FMPLL configuration.
file  start-config-ebi-cs-cal.c
 EBI calibration chip-select configuration.
file  start-config-ebi-cs.c
 EBI chip-select configuration.
file  start-config-ebi.c
 EBI configuration.
file  start-config-mmu-early.c
 MMU early configuration.
file  start-config-mmu.c
 MMU configuration.
file  start-config-siu-pcr.c
 SIU PCR configuration.
file  start-early.c
 Early initialization code.
file  start-prologue.c
 Start prologue.
file  start-watchdog.c
 Watchdog initialization code.
#define BSP_FEATURE_IRQ_EXTENSION
#define MPC55XX_PERIPHERAL_CLOCK    (MPC55XX_SYSTEM_CLOCK / MPC55XX_SYSTEM_CLOCK_DIVIDER)
#define BSP_Convert_decrementer(_value)    (((unsigned long long) (_value)) / ((unsigned long long)bsp_clicks_per_usec))
 Convert Decrementer ticks to microseconds.
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH   smsc9218i_attach_detach
#define RTEMS_BSP_NETWORK_DRIVER_NAME   "eth0"
#define BSP_IDLE_TASK_BODY   bsp_idle_thread
#define BSP_DSRAM_SECTION   __attribute__((section(".bsp_dsram")))
#define BSP_SYSRAM_SECTION   __attribute__((section(".bsp_sysram")))
rtems_status_code mpc55xx_sd_card_init (bool mount)
int smsc9218i_attach_detach (struct rtems_bsdnet_ifconfig *config, int attaching)
rtems_status_code bsp_register_i2c (void)
void bsp_restart (void *addr)
void * bsp_idle_thread (uintptr_t arg)
 Optimized idle task.
unsigned int bsp_clock_speed
 System clock frequency.
uint32_t bsp_clicks_per_usec
 Time base clicks per micro second.
◆ bsp_idle_thread()
void * bsp_idle_thread ( uintptr_t  ignored)
This BSP provides its own IDLE thread to override the RTEMS one.
This idle task sets the power mode to idle. This causes the processor clock to be stopped, while on-chip peripherals remain active. Any enabled interrupt from a peripheral or an external interrupt source will cause the processor to resume execution.
To enable the idle task use the following in the system configuration:
#include <bsp.h>
#define CONFIGURE_INIT
#define CONFIGURE_IDLE_TASK_BODY bsp_idle_thread
#include <confdefs.h>
This header file evaluates the application configuration options defined by the application.
The MSR[POW] bit is set to put the CPU into the low power mode defined in HID0. HID0 is set during starup in start.S.
#include <bsp.h>
