RTEMS 6.1-rc4
#define __HAL_RCC_CRS_FREQ_ERROR_COUNTER_ENABLE()   SET_BIT(CRS->CR, CRS_CR_CEN)
 Enable the oscillator clock for frequency error counter.
#define __HAL_RCC_CRS_FREQ_ERROR_COUNTER_DISABLE()   CLEAR_BIT(CRS->CR, CRS_CR_CEN)
 Disable the oscillator clock for frequency error counter.
#define __HAL_RCC_CRS_AUTOMATIC_CALIB_ENABLE()   SET_BIT(CRS->CR, CRS_CR_AUTOTRIMEN)
 Enable the automatic hardware adjustment of TRIM bits.
#define __HAL_RCC_CRS_AUTOMATIC_CALIB_DISABLE()   CLEAR_BIT(CRS->CR, CRS_CR_AUTOTRIMEN)
 Enable or disable the automatic hardware adjustment of TRIM bits.
#define __HAL_RCC_CRS_RELOADVALUE_CALCULATE(__FTARGET__, __FSYNC__)   (((__FTARGET__) / (__FSYNC__)) - 1U)
 Macro to calculate reload value to be set in CRS register according to target and sync frequencies.
◆ __HAL_RCC_CRS_AUTOMATIC_CALIB_DISABLE
#define __HAL_RCC_CRS_AUTOMATIC_CALIB_DISABLE ( )    CLEAR_BIT(CRS->CR, CRS_CR_AUTOTRIMEN)
Return values
None
◆ __HAL_RCC_CRS_AUTOMATIC_CALIB_ENABLE
#define __HAL_RCC_CRS_AUTOMATIC_CALIB_ENABLE ( )    SET_BIT(CRS->CR, CRS_CR_AUTOTRIMEN)
Note
When the AUTOTRIMEN bit is set the CRS_CFGR register becomes write-protected.
Return values
None
◆ __HAL_RCC_CRS_FREQ_ERROR_COUNTER_DISABLE
#define __HAL_RCC_CRS_FREQ_ERROR_COUNTER_DISABLE ( )    CLEAR_BIT(CRS->CR, CRS_CR_CEN)
Return values
None
◆ __HAL_RCC_CRS_FREQ_ERROR_COUNTER_ENABLE
#define __HAL_RCC_CRS_FREQ_ERROR_COUNTER_ENABLE ( )    SET_BIT(CRS->CR, CRS_CR_CEN)
Note
when the CEN bit is set the CRS_CFGR register becomes write-protected.
Return values
None
◆ __HAL_RCC_CRS_RELOADVALUE_CALCULATE
#define __HAL_RCC_CRS_RELOADVALUE_CALCULATE (   __FTARGET__,
  __FSYNC__
Note
The RELOAD value should be selected according to the ratio between the target frequency and the frequency of the synchronization source after pre-scaling. It is then decreased by one in order to reach the expected synchronization on the zero value. The formula is the following: RELOAD = (fTARGET / fSYNC) -1
Parameters
__FTARGET__Target frequency (value in Hz)
__FSYNC__Synchronization signal frequency (value in Hz)
Return values
None
