RTEMS 6.1-rc4
REG_1P1 - Regulator 1P1 Register
#define PMU_REG_1P1_ENABLE_LINREG_MASK   (0x1U)
#define PMU_REG_1P1_ENABLE_LINREG_SHIFT   (0U)
#define PMU_REG_1P1_ENABLE_LINREG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_ENABLE_LINREG_SHIFT)) & PMU_REG_1P1_ENABLE_LINREG_MASK)
#define PMU_REG_1P1_ENABLE_BO_MASK   (0x2U)
#define PMU_REG_1P1_ENABLE_BO_SHIFT   (1U)
#define PMU_REG_1P1_ENABLE_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_ENABLE_BO_SHIFT)) & PMU_REG_1P1_ENABLE_BO_MASK)
#define PMU_REG_1P1_ENABLE_ILIMIT_MASK   (0x4U)
#define PMU_REG_1P1_ENABLE_ILIMIT_SHIFT   (2U)
#define PMU_REG_1P1_ENABLE_ILIMIT(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_ENABLE_ILIMIT_SHIFT)) & PMU_REG_1P1_ENABLE_ILIMIT_MASK)
#define PMU_REG_1P1_ENABLE_PULLDOWN_MASK   (0x8U)
#define PMU_REG_1P1_ENABLE_PULLDOWN_SHIFT   (3U)
#define PMU_REG_1P1_ENABLE_PULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_ENABLE_PULLDOWN_SHIFT)) & PMU_REG_1P1_ENABLE_PULLDOWN_MASK)
#define PMU_REG_1P1_BO_OFFSET_MASK   (0x70U)
#define PMU_REG_1P1_BO_OFFSET_SHIFT   (4U)
#define PMU_REG_1P1_BO_OFFSET(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_BO_OFFSET_SHIFT)) & PMU_REG_1P1_BO_OFFSET_MASK)
#define PMU_REG_1P1_OUTPUT_TRG_MASK   (0x1F00U)
#define PMU_REG_1P1_OUTPUT_TRG_SHIFT   (8U)
#define PMU_REG_1P1_OUTPUT_TRG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_OUTPUT_TRG_SHIFT)) & PMU_REG_1P1_OUTPUT_TRG_MASK)
#define PMU_REG_1P1_BO_VDD1P1_MASK   (0x10000U)
#define PMU_REG_1P1_BO_VDD1P1_SHIFT   (16U)
#define PMU_REG_1P1_BO_VDD1P1(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_BO_VDD1P1_SHIFT)) & PMU_REG_1P1_BO_VDD1P1_MASK)
#define PMU_REG_1P1_OK_VDD1P1_MASK   (0x20000U)
#define PMU_REG_1P1_OK_VDD1P1_SHIFT   (17U)
#define PMU_REG_1P1_OK_VDD1P1(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_OK_VDD1P1_SHIFT)) & PMU_REG_1P1_OK_VDD1P1_MASK)
#define PMU_REG_1P1_ENABLE_WEAK_LINREG_MASK   (0x40000U)
#define PMU_REG_1P1_ENABLE_WEAK_LINREG_SHIFT   (18U)
#define PMU_REG_1P1_ENABLE_WEAK_LINREG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_ENABLE_WEAK_LINREG_SHIFT)) & PMU_REG_1P1_ENABLE_WEAK_LINREG_MASK)
#define PMU_REG_1P1_SELREF_WEAK_LINREG_MASK   (0x80000U)
#define PMU_REG_1P1_SELREF_WEAK_LINREG_SHIFT   (19U)
#define PMU_REG_1P1_SELREF_WEAK_LINREG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_SELREF_WEAK_LINREG_SHIFT)) & PMU_REG_1P1_SELREF_WEAK_LINREG_MASK)
REG_1P1_SET - Regulator 1P1 Register
#define PMU_REG_1P1_SET_ENABLE_LINREG_MASK   (0x1U)
#define PMU_REG_1P1_SET_ENABLE_LINREG_SHIFT   (0U)
#define PMU_REG_1P1_SET_ENABLE_LINREG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_SET_ENABLE_LINREG_SHIFT)) & PMU_REG_1P1_SET_ENABLE_LINREG_MASK)
#define PMU_REG_1P1_SET_ENABLE_BO_MASK   (0x2U)
#define PMU_REG_1P1_SET_ENABLE_BO_SHIFT   (1U)
#define PMU_REG_1P1_SET_ENABLE_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_SET_ENABLE_BO_SHIFT)) & PMU_REG_1P1_SET_ENABLE_BO_MASK)
#define PMU_REG_1P1_SET_ENABLE_ILIMIT_MASK   (0x4U)
#define PMU_REG_1P1_SET_ENABLE_ILIMIT_SHIFT   (2U)
#define PMU_REG_1P1_SET_ENABLE_ILIMIT(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_SET_ENABLE_ILIMIT_SHIFT)) & PMU_REG_1P1_SET_ENABLE_ILIMIT_MASK)
#define PMU_REG_1P1_SET_ENABLE_PULLDOWN_MASK   (0x8U)
#define PMU_REG_1P1_SET_ENABLE_PULLDOWN_SHIFT   (3U)
#define PMU_REG_1P1_SET_ENABLE_PULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_SET_ENABLE_PULLDOWN_SHIFT)) & PMU_REG_1P1_SET_ENABLE_PULLDOWN_MASK)
#define PMU_REG_1P1_SET_BO_OFFSET_MASK   (0x70U)
#define PMU_REG_1P1_SET_BO_OFFSET_SHIFT   (4U)
#define PMU_REG_1P1_SET_BO_OFFSET(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_SET_BO_OFFSET_SHIFT)) & PMU_REG_1P1_SET_BO_OFFSET_MASK)
#define PMU_REG_1P1_SET_OUTPUT_TRG_MASK   (0x1F00U)
#define PMU_REG_1P1_SET_OUTPUT_TRG_SHIFT   (8U)
#define PMU_REG_1P1_SET_OUTPUT_TRG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_SET_OUTPUT_TRG_SHIFT)) & PMU_REG_1P1_SET_OUTPUT_TRG_MASK)
#define PMU_REG_1P1_SET_BO_VDD1P1_MASK   (0x10000U)
#define PMU_REG_1P1_SET_BO_VDD1P1_SHIFT   (16U)
#define PMU_REG_1P1_SET_BO_VDD1P1(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_SET_BO_VDD1P1_SHIFT)) & PMU_REG_1P1_SET_BO_VDD1P1_MASK)
#define PMU_REG_1P1_SET_OK_VDD1P1_MASK   (0x20000U)
#define PMU_REG_1P1_SET_OK_VDD1P1_SHIFT   (17U)
#define PMU_REG_1P1_SET_OK_VDD1P1(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_SET_OK_VDD1P1_SHIFT)) & PMU_REG_1P1_SET_OK_VDD1P1_MASK)
#define PMU_REG_1P1_SET_ENABLE_WEAK_LINREG_MASK   (0x40000U)
#define PMU_REG_1P1_SET_ENABLE_WEAK_LINREG_SHIFT   (18U)
#define PMU_REG_1P1_SET_ENABLE_WEAK_LINREG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_SET_ENABLE_WEAK_LINREG_SHIFT)) & PMU_REG_1P1_SET_ENABLE_WEAK_LINREG_MASK)
#define PMU_REG_1P1_SET_SELREF_WEAK_LINREG_MASK   (0x80000U)
#define PMU_REG_1P1_SET_SELREF_WEAK_LINREG_SHIFT   (19U)
#define PMU_REG_1P1_SET_SELREF_WEAK_LINREG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_SET_SELREF_WEAK_LINREG_SHIFT)) & PMU_REG_1P1_SET_SELREF_WEAK_LINREG_MASK)
REG_1P1_CLR - Regulator 1P1 Register
#define PMU_REG_1P1_CLR_ENABLE_LINREG_MASK   (0x1U)
#define PMU_REG_1P1_CLR_ENABLE_LINREG_SHIFT   (0U)
#define PMU_REG_1P1_CLR_ENABLE_LINREG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_CLR_ENABLE_LINREG_SHIFT)) & PMU_REG_1P1_CLR_ENABLE_LINREG_MASK)
#define PMU_REG_1P1_CLR_ENABLE_BO_MASK   (0x2U)
#define PMU_REG_1P1_CLR_ENABLE_BO_SHIFT   (1U)
#define PMU_REG_1P1_CLR_ENABLE_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_CLR_ENABLE_BO_SHIFT)) & PMU_REG_1P1_CLR_ENABLE_BO_MASK)
#define PMU_REG_1P1_CLR_ENABLE_ILIMIT_MASK   (0x4U)
#define PMU_REG_1P1_CLR_ENABLE_ILIMIT_SHIFT   (2U)
#define PMU_REG_1P1_CLR_ENABLE_ILIMIT(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_CLR_ENABLE_ILIMIT_SHIFT)) & PMU_REG_1P1_CLR_ENABLE_ILIMIT_MASK)
#define PMU_REG_1P1_CLR_ENABLE_PULLDOWN_MASK   (0x8U)
#define PMU_REG_1P1_CLR_ENABLE_PULLDOWN_SHIFT   (3U)
#define PMU_REG_1P1_CLR_ENABLE_PULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_CLR_ENABLE_PULLDOWN_SHIFT)) & PMU_REG_1P1_CLR_ENABLE_PULLDOWN_MASK)
#define PMU_REG_1P1_CLR_BO_OFFSET_MASK   (0x70U)
#define PMU_REG_1P1_CLR_BO_OFFSET_SHIFT   (4U)
#define PMU_REG_1P1_CLR_BO_OFFSET(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_CLR_BO_OFFSET_SHIFT)) & PMU_REG_1P1_CLR_BO_OFFSET_MASK)
#define PMU_REG_1P1_CLR_OUTPUT_TRG_MASK   (0x1F00U)
#define PMU_REG_1P1_CLR_OUTPUT_TRG_SHIFT   (8U)
#define PMU_REG_1P1_CLR_OUTPUT_TRG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_CLR_OUTPUT_TRG_SHIFT)) & PMU_REG_1P1_CLR_OUTPUT_TRG_MASK)
#define PMU_REG_1P1_CLR_BO_VDD1P1_MASK   (0x10000U)
#define PMU_REG_1P1_CLR_BO_VDD1P1_SHIFT   (16U)
#define PMU_REG_1P1_CLR_BO_VDD1P1(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_CLR_BO_VDD1P1_SHIFT)) & PMU_REG_1P1_CLR_BO_VDD1P1_MASK)
#define PMU_REG_1P1_CLR_OK_VDD1P1_MASK   (0x20000U)
#define PMU_REG_1P1_CLR_OK_VDD1P1_SHIFT   (17U)
#define PMU_REG_1P1_CLR_OK_VDD1P1(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_CLR_OK_VDD1P1_SHIFT)) & PMU_REG_1P1_CLR_OK_VDD1P1_MASK)
#define PMU_REG_1P1_CLR_ENABLE_WEAK_LINREG_MASK   (0x40000U)
#define PMU_REG_1P1_CLR_ENABLE_WEAK_LINREG_SHIFT   (18U)
#define PMU_REG_1P1_CLR_ENABLE_WEAK_LINREG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_CLR_ENABLE_WEAK_LINREG_SHIFT)) & PMU_REG_1P1_CLR_ENABLE_WEAK_LINREG_MASK)
#define PMU_REG_1P1_CLR_SELREF_WEAK_LINREG_MASK   (0x80000U)
#define PMU_REG_1P1_CLR_SELREF_WEAK_LINREG_SHIFT   (19U)
#define PMU_REG_1P1_CLR_SELREF_WEAK_LINREG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_CLR_SELREF_WEAK_LINREG_SHIFT)) & PMU_REG_1P1_CLR_SELREF_WEAK_LINREG_MASK)
REG_1P1_TOG - Regulator 1P1 Register
#define PMU_REG_1P1_TOG_ENABLE_LINREG_MASK   (0x1U)
#define PMU_REG_1P1_TOG_ENABLE_LINREG_SHIFT   (0U)
#define PMU_REG_1P1_TOG_ENABLE_LINREG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_TOG_ENABLE_LINREG_SHIFT)) & PMU_REG_1P1_TOG_ENABLE_LINREG_MASK)
#define PMU_REG_1P1_TOG_ENABLE_BO_MASK   (0x2U)
#define PMU_REG_1P1_TOG_ENABLE_BO_SHIFT   (1U)
#define PMU_REG_1P1_TOG_ENABLE_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_TOG_ENABLE_BO_SHIFT)) & PMU_REG_1P1_TOG_ENABLE_BO_MASK)
#define PMU_REG_1P1_TOG_ENABLE_ILIMIT_MASK   (0x4U)
#define PMU_REG_1P1_TOG_ENABLE_ILIMIT_SHIFT   (2U)
#define PMU_REG_1P1_TOG_ENABLE_ILIMIT(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_TOG_ENABLE_ILIMIT_SHIFT)) & PMU_REG_1P1_TOG_ENABLE_ILIMIT_MASK)
#define PMU_REG_1P1_TOG_ENABLE_PULLDOWN_MASK   (0x8U)
#define PMU_REG_1P1_TOG_ENABLE_PULLDOWN_SHIFT   (3U)
#define PMU_REG_1P1_TOG_ENABLE_PULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_TOG_ENABLE_PULLDOWN_SHIFT)) & PMU_REG_1P1_TOG_ENABLE_PULLDOWN_MASK)
#define PMU_REG_1P1_TOG_BO_OFFSET_MASK   (0x70U)
#define PMU_REG_1P1_TOG_BO_OFFSET_SHIFT   (4U)
#define PMU_REG_1P1_TOG_BO_OFFSET(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_TOG_BO_OFFSET_SHIFT)) & PMU_REG_1P1_TOG_BO_OFFSET_MASK)
#define PMU_REG_1P1_TOG_OUTPUT_TRG_MASK   (0x1F00U)
#define PMU_REG_1P1_TOG_OUTPUT_TRG_SHIFT   (8U)
#define PMU_REG_1P1_TOG_OUTPUT_TRG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_TOG_OUTPUT_TRG_SHIFT)) & PMU_REG_1P1_TOG_OUTPUT_TRG_MASK)
#define PMU_REG_1P1_TOG_BO_VDD1P1_MASK   (0x10000U)
#define PMU_REG_1P1_TOG_BO_VDD1P1_SHIFT   (16U)
#define PMU_REG_1P1_TOG_BO_VDD1P1(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_TOG_BO_VDD1P1_SHIFT)) & PMU_REG_1P1_TOG_BO_VDD1P1_MASK)
#define PMU_REG_1P1_TOG_OK_VDD1P1_MASK   (0x20000U)
#define PMU_REG_1P1_TOG_OK_VDD1P1_SHIFT   (17U)
#define PMU_REG_1P1_TOG_OK_VDD1P1(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_TOG_OK_VDD1P1_SHIFT)) & PMU_REG_1P1_TOG_OK_VDD1P1_MASK)
#define PMU_REG_1P1_TOG_ENABLE_WEAK_LINREG_MASK   (0x40000U)
#define PMU_REG_1P1_TOG_ENABLE_WEAK_LINREG_SHIFT   (18U)
#define PMU_REG_1P1_TOG_ENABLE_WEAK_LINREG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_TOG_ENABLE_WEAK_LINREG_SHIFT)) & PMU_REG_1P1_TOG_ENABLE_WEAK_LINREG_MASK)
#define PMU_REG_1P1_TOG_SELREF_WEAK_LINREG_MASK   (0x80000U)
#define PMU_REG_1P1_TOG_SELREF_WEAK_LINREG_SHIFT   (19U)
#define PMU_REG_1P1_TOG_SELREF_WEAK_LINREG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_TOG_SELREF_WEAK_LINREG_SHIFT)) & PMU_REG_1P1_TOG_SELREF_WEAK_LINREG_MASK)
REG_3P0 - Regulator 3P0 Register
#define PMU_REG_3P0_ENABLE_LINREG_MASK   (0x1U)
#define PMU_REG_3P0_ENABLE_LINREG_SHIFT   (0U)
#define PMU_REG_3P0_ENABLE_LINREG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_ENABLE_LINREG_SHIFT)) & PMU_REG_3P0_ENABLE_LINREG_MASK)
#define PMU_REG_3P0_ENABLE_BO_MASK   (0x2U)
#define PMU_REG_3P0_ENABLE_BO_SHIFT   (1U)
#define PMU_REG_3P0_ENABLE_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_ENABLE_BO_SHIFT)) & PMU_REG_3P0_ENABLE_BO_MASK)
#define PMU_REG_3P0_ENABLE_ILIMIT_MASK   (0x4U)
#define PMU_REG_3P0_ENABLE_ILIMIT_SHIFT   (2U)
#define PMU_REG_3P0_ENABLE_ILIMIT(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_ENABLE_ILIMIT_SHIFT)) & PMU_REG_3P0_ENABLE_ILIMIT_MASK)
#define PMU_REG_3P0_BO_OFFSET_MASK   (0x70U)
#define PMU_REG_3P0_BO_OFFSET_SHIFT   (4U)
#define PMU_REG_3P0_BO_OFFSET(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_BO_OFFSET_SHIFT)) & PMU_REG_3P0_BO_OFFSET_MASK)
#define PMU_REG_3P0_VBUS_SEL_MASK   (0x80U)
#define PMU_REG_3P0_VBUS_SEL_SHIFT   (7U)
#define PMU_REG_3P0_VBUS_SEL(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_VBUS_SEL_SHIFT)) & PMU_REG_3P0_VBUS_SEL_MASK)
#define PMU_REG_3P0_OUTPUT_TRG_MASK   (0x1F00U)
#define PMU_REG_3P0_OUTPUT_TRG_SHIFT   (8U)
#define PMU_REG_3P0_OUTPUT_TRG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_OUTPUT_TRG_SHIFT)) & PMU_REG_3P0_OUTPUT_TRG_MASK)
#define PMU_REG_3P0_BO_VDD3P0_MASK   (0x10000U)
#define PMU_REG_3P0_BO_VDD3P0_SHIFT   (16U)
#define PMU_REG_3P0_BO_VDD3P0(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_BO_VDD3P0_SHIFT)) & PMU_REG_3P0_BO_VDD3P0_MASK)
#define PMU_REG_3P0_OK_VDD3P0_MASK   (0x20000U)
#define PMU_REG_3P0_OK_VDD3P0_SHIFT   (17U)
#define PMU_REG_3P0_OK_VDD3P0(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_OK_VDD3P0_SHIFT)) & PMU_REG_3P0_OK_VDD3P0_MASK)
REG_3P0_SET - Regulator 3P0 Register
#define PMU_REG_3P0_SET_ENABLE_LINREG_MASK   (0x1U)
#define PMU_REG_3P0_SET_ENABLE_LINREG_SHIFT   (0U)
#define PMU_REG_3P0_SET_ENABLE_LINREG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_SET_ENABLE_LINREG_SHIFT)) & PMU_REG_3P0_SET_ENABLE_LINREG_MASK)
#define PMU_REG_3P0_SET_ENABLE_BO_MASK   (0x2U)
#define PMU_REG_3P0_SET_ENABLE_BO_SHIFT   (1U)
#define PMU_REG_3P0_SET_ENABLE_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_SET_ENABLE_BO_SHIFT)) & PMU_REG_3P0_SET_ENABLE_BO_MASK)
#define PMU_REG_3P0_SET_ENABLE_ILIMIT_MASK   (0x4U)
#define PMU_REG_3P0_SET_ENABLE_ILIMIT_SHIFT   (2U)
#define PMU_REG_3P0_SET_ENABLE_ILIMIT(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_SET_ENABLE_ILIMIT_SHIFT)) & PMU_REG_3P0_SET_ENABLE_ILIMIT_MASK)
#define PMU_REG_3P0_SET_BO_OFFSET_MASK   (0x70U)
#define PMU_REG_3P0_SET_BO_OFFSET_SHIFT   (4U)
#define PMU_REG_3P0_SET_BO_OFFSET(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_SET_BO_OFFSET_SHIFT)) & PMU_REG_3P0_SET_BO_OFFSET_MASK)
#define PMU_REG_3P0_SET_VBUS_SEL_MASK   (0x80U)
#define PMU_REG_3P0_SET_VBUS_SEL_SHIFT   (7U)
#define PMU_REG_3P0_SET_VBUS_SEL(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_SET_VBUS_SEL_SHIFT)) & PMU_REG_3P0_SET_VBUS_SEL_MASK)
#define PMU_REG_3P0_SET_OUTPUT_TRG_MASK   (0x1F00U)
#define PMU_REG_3P0_SET_OUTPUT_TRG_SHIFT   (8U)
#define PMU_REG_3P0_SET_OUTPUT_TRG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_SET_OUTPUT_TRG_SHIFT)) & PMU_REG_3P0_SET_OUTPUT_TRG_MASK)
#define PMU_REG_3P0_SET_BO_VDD3P0_MASK   (0x10000U)
#define PMU_REG_3P0_SET_BO_VDD3P0_SHIFT   (16U)
#define PMU_REG_3P0_SET_BO_VDD3P0(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_SET_BO_VDD3P0_SHIFT)) & PMU_REG_3P0_SET_BO_VDD3P0_MASK)
#define PMU_REG_3P0_SET_OK_VDD3P0_MASK   (0x20000U)
#define PMU_REG_3P0_SET_OK_VDD3P0_SHIFT   (17U)
#define PMU_REG_3P0_SET_OK_VDD3P0(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_SET_OK_VDD3P0_SHIFT)) & PMU_REG_3P0_SET_OK_VDD3P0_MASK)
REG_3P0_CLR - Regulator 3P0 Register
#define PMU_REG_3P0_CLR_ENABLE_LINREG_MASK   (0x1U)
#define PMU_REG_3P0_CLR_ENABLE_LINREG_SHIFT   (0U)
#define PMU_REG_3P0_CLR_ENABLE_LINREG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_CLR_ENABLE_LINREG_SHIFT)) & PMU_REG_3P0_CLR_ENABLE_LINREG_MASK)
#define PMU_REG_3P0_CLR_ENABLE_BO_MASK   (0x2U)
#define PMU_REG_3P0_CLR_ENABLE_BO_SHIFT   (1U)
#define PMU_REG_3P0_CLR_ENABLE_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_CLR_ENABLE_BO_SHIFT)) & PMU_REG_3P0_CLR_ENABLE_BO_MASK)
#define PMU_REG_3P0_CLR_ENABLE_ILIMIT_MASK   (0x4U)
#define PMU_REG_3P0_CLR_ENABLE_ILIMIT_SHIFT   (2U)
#define PMU_REG_3P0_CLR_ENABLE_ILIMIT(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_CLR_ENABLE_ILIMIT_SHIFT)) & PMU_REG_3P0_CLR_ENABLE_ILIMIT_MASK)
#define PMU_REG_3P0_CLR_BO_OFFSET_MASK   (0x70U)
#define PMU_REG_3P0_CLR_BO_OFFSET_SHIFT   (4U)
#define PMU_REG_3P0_CLR_BO_OFFSET(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_CLR_BO_OFFSET_SHIFT)) & PMU_REG_3P0_CLR_BO_OFFSET_MASK)
#define PMU_REG_3P0_CLR_VBUS_SEL_MASK   (0x80U)
#define PMU_REG_3P0_CLR_VBUS_SEL_SHIFT   (7U)
#define PMU_REG_3P0_CLR_VBUS_SEL(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_CLR_VBUS_SEL_SHIFT)) & PMU_REG_3P0_CLR_VBUS_SEL_MASK)
#define PMU_REG_3P0_CLR_OUTPUT_TRG_MASK   (0x1F00U)
#define PMU_REG_3P0_CLR_OUTPUT_TRG_SHIFT   (8U)
#define PMU_REG_3P0_CLR_OUTPUT_TRG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_CLR_OUTPUT_TRG_SHIFT)) & PMU_REG_3P0_CLR_OUTPUT_TRG_MASK)
#define PMU_REG_3P0_CLR_BO_VDD3P0_MASK   (0x10000U)
#define PMU_REG_3P0_CLR_BO_VDD3P0_SHIFT   (16U)
#define PMU_REG_3P0_CLR_BO_VDD3P0(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_CLR_BO_VDD3P0_SHIFT)) & PMU_REG_3P0_CLR_BO_VDD3P0_MASK)
#define PMU_REG_3P0_CLR_OK_VDD3P0_MASK   (0x20000U)
#define PMU_REG_3P0_CLR_OK_VDD3P0_SHIFT   (17U)
#define PMU_REG_3P0_CLR_OK_VDD3P0(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_CLR_OK_VDD3P0_SHIFT)) & PMU_REG_3P0_CLR_OK_VDD3P0_MASK)
REG_3P0_TOG - Regulator 3P0 Register
#define PMU_REG_3P0_TOG_ENABLE_LINREG_MASK   (0x1U)
#define PMU_REG_3P0_TOG_ENABLE_LINREG_SHIFT   (0U)
#define PMU_REG_3P0_TOG_ENABLE_LINREG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_TOG_ENABLE_LINREG_SHIFT)) & PMU_REG_3P0_TOG_ENABLE_LINREG_MASK)
#define PMU_REG_3P0_TOG_ENABLE_BO_MASK   (0x2U)
#define PMU_REG_3P0_TOG_ENABLE_BO_SHIFT   (1U)
#define PMU_REG_3P0_TOG_ENABLE_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_TOG_ENABLE_BO_SHIFT)) & PMU_REG_3P0_TOG_ENABLE_BO_MASK)
#define PMU_REG_3P0_TOG_ENABLE_ILIMIT_MASK   (0x4U)
#define PMU_REG_3P0_TOG_ENABLE_ILIMIT_SHIFT   (2U)
#define PMU_REG_3P0_TOG_ENABLE_ILIMIT(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_TOG_ENABLE_ILIMIT_SHIFT)) & PMU_REG_3P0_TOG_ENABLE_ILIMIT_MASK)
#define PMU_REG_3P0_TOG_BO_OFFSET_MASK   (0x70U)
#define PMU_REG_3P0_TOG_BO_OFFSET_SHIFT   (4U)
#define PMU_REG_3P0_TOG_BO_OFFSET(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_TOG_BO_OFFSET_SHIFT)) & PMU_REG_3P0_TOG_BO_OFFSET_MASK)
#define PMU_REG_3P0_TOG_VBUS_SEL_MASK   (0x80U)
#define PMU_REG_3P0_TOG_VBUS_SEL_SHIFT   (7U)
#define PMU_REG_3P0_TOG_VBUS_SEL(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_TOG_VBUS_SEL_SHIFT)) & PMU_REG_3P0_TOG_VBUS_SEL_MASK)
#define PMU_REG_3P0_TOG_OUTPUT_TRG_MASK   (0x1F00U)
#define PMU_REG_3P0_TOG_OUTPUT_TRG_SHIFT   (8U)
#define PMU_REG_3P0_TOG_OUTPUT_TRG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_TOG_OUTPUT_TRG_SHIFT)) & PMU_REG_3P0_TOG_OUTPUT_TRG_MASK)
#define PMU_REG_3P0_TOG_BO_VDD3P0_MASK   (0x10000U)
#define PMU_REG_3P0_TOG_BO_VDD3P0_SHIFT   (16U)
#define PMU_REG_3P0_TOG_BO_VDD3P0(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_TOG_BO_VDD3P0_SHIFT)) & PMU_REG_3P0_TOG_BO_VDD3P0_MASK)
#define PMU_REG_3P0_TOG_OK_VDD3P0_MASK   (0x20000U)
#define PMU_REG_3P0_TOG_OK_VDD3P0_SHIFT   (17U)
#define PMU_REG_3P0_TOG_OK_VDD3P0(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_TOG_OK_VDD3P0_SHIFT)) & PMU_REG_3P0_TOG_OK_VDD3P0_MASK)
REG_2P5 - Regulator 2P5 Register
#define PMU_REG_2P5_ENABLE_LINREG_MASK   (0x1U)
#define PMU_REG_2P5_ENABLE_LINREG_SHIFT   (0U)
#define PMU_REG_2P5_ENABLE_LINREG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_ENABLE_LINREG_SHIFT)) & PMU_REG_2P5_ENABLE_LINREG_MASK)
#define PMU_REG_2P5_ENABLE_BO_MASK   (0x2U)
#define PMU_REG_2P5_ENABLE_BO_SHIFT   (1U)
#define PMU_REG_2P5_ENABLE_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_ENABLE_BO_SHIFT)) & PMU_REG_2P5_ENABLE_BO_MASK)
#define PMU_REG_2P5_ENABLE_ILIMIT_MASK   (0x4U)
#define PMU_REG_2P5_ENABLE_ILIMIT_SHIFT   (2U)
#define PMU_REG_2P5_ENABLE_ILIMIT(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_ENABLE_ILIMIT_SHIFT)) & PMU_REG_2P5_ENABLE_ILIMIT_MASK)
#define PMU_REG_2P5_ENABLE_PULLDOWN_MASK   (0x8U)
#define PMU_REG_2P5_ENABLE_PULLDOWN_SHIFT   (3U)
#define PMU_REG_2P5_ENABLE_PULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_ENABLE_PULLDOWN_SHIFT)) & PMU_REG_2P5_ENABLE_PULLDOWN_MASK)
#define PMU_REG_2P5_BO_OFFSET_MASK   (0x70U)
#define PMU_REG_2P5_BO_OFFSET_SHIFT   (4U)
#define PMU_REG_2P5_BO_OFFSET(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_BO_OFFSET_SHIFT)) & PMU_REG_2P5_BO_OFFSET_MASK)
#define PMU_REG_2P5_OUTPUT_TRG_MASK   (0x1F00U)
#define PMU_REG_2P5_OUTPUT_TRG_SHIFT   (8U)
#define PMU_REG_2P5_OUTPUT_TRG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_OUTPUT_TRG_SHIFT)) & PMU_REG_2P5_OUTPUT_TRG_MASK)
#define PMU_REG_2P5_BO_VDD2P5_MASK   (0x10000U)
#define PMU_REG_2P5_BO_VDD2P5_SHIFT   (16U)
#define PMU_REG_2P5_BO_VDD2P5(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_BO_VDD2P5_SHIFT)) & PMU_REG_2P5_BO_VDD2P5_MASK)
#define PMU_REG_2P5_OK_VDD2P5_MASK   (0x20000U)
#define PMU_REG_2P5_OK_VDD2P5_SHIFT   (17U)
#define PMU_REG_2P5_OK_VDD2P5(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_OK_VDD2P5_SHIFT)) & PMU_REG_2P5_OK_VDD2P5_MASK)
#define PMU_REG_2P5_ENABLE_WEAK_LINREG_MASK   (0x40000U)
#define PMU_REG_2P5_ENABLE_WEAK_LINREG_SHIFT   (18U)
#define PMU_REG_2P5_ENABLE_WEAK_LINREG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_ENABLE_WEAK_LINREG_SHIFT)) & PMU_REG_2P5_ENABLE_WEAK_LINREG_MASK)
REG_2P5_SET - Regulator 2P5 Register
#define PMU_REG_2P5_SET_ENABLE_LINREG_MASK   (0x1U)
#define PMU_REG_2P5_SET_ENABLE_LINREG_SHIFT   (0U)
#define PMU_REG_2P5_SET_ENABLE_LINREG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_SET_ENABLE_LINREG_SHIFT)) & PMU_REG_2P5_SET_ENABLE_LINREG_MASK)
#define PMU_REG_2P5_SET_ENABLE_BO_MASK   (0x2U)
#define PMU_REG_2P5_SET_ENABLE_BO_SHIFT   (1U)
#define PMU_REG_2P5_SET_ENABLE_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_SET_ENABLE_BO_SHIFT)) & PMU_REG_2P5_SET_ENABLE_BO_MASK)
#define PMU_REG_2P5_SET_ENABLE_ILIMIT_MASK   (0x4U)
#define PMU_REG_2P5_SET_ENABLE_ILIMIT_SHIFT   (2U)
#define PMU_REG_2P5_SET_ENABLE_ILIMIT(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_SET_ENABLE_ILIMIT_SHIFT)) & PMU_REG_2P5_SET_ENABLE_ILIMIT_MASK)
#define PMU_REG_2P5_SET_ENABLE_PULLDOWN_MASK   (0x8U)
#define PMU_REG_2P5_SET_ENABLE_PULLDOWN_SHIFT   (3U)
#define PMU_REG_2P5_SET_ENABLE_PULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_SET_ENABLE_PULLDOWN_SHIFT)) & PMU_REG_2P5_SET_ENABLE_PULLDOWN_MASK)
#define PMU_REG_2P5_SET_BO_OFFSET_MASK   (0x70U)
#define PMU_REG_2P5_SET_BO_OFFSET_SHIFT   (4U)
#define PMU_REG_2P5_SET_BO_OFFSET(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_SET_BO_OFFSET_SHIFT)) & PMU_REG_2P5_SET_BO_OFFSET_MASK)
#define PMU_REG_2P5_SET_OUTPUT_TRG_MASK   (0x1F00U)
#define PMU_REG_2P5_SET_OUTPUT_TRG_SHIFT   (8U)
#define PMU_REG_2P5_SET_OUTPUT_TRG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_SET_OUTPUT_TRG_SHIFT)) & PMU_REG_2P5_SET_OUTPUT_TRG_MASK)
#define PMU_REG_2P5_SET_BO_VDD2P5_MASK   (0x10000U)
#define PMU_REG_2P5_SET_BO_VDD2P5_SHIFT   (16U)
#define PMU_REG_2P5_SET_BO_VDD2P5(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_SET_BO_VDD2P5_SHIFT)) & PMU_REG_2P5_SET_BO_VDD2P5_MASK)
#define PMU_REG_2P5_SET_OK_VDD2P5_MASK   (0x20000U)
#define PMU_REG_2P5_SET_OK_VDD2P5_SHIFT   (17U)
#define PMU_REG_2P5_SET_OK_VDD2P5(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_SET_OK_VDD2P5_SHIFT)) & PMU_REG_2P5_SET_OK_VDD2P5_MASK)
#define PMU_REG_2P5_SET_ENABLE_WEAK_LINREG_MASK   (0x40000U)
#define PMU_REG_2P5_SET_ENABLE_WEAK_LINREG_SHIFT   (18U)
#define PMU_REG_2P5_SET_ENABLE_WEAK_LINREG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_SET_ENABLE_WEAK_LINREG_SHIFT)) & PMU_REG_2P5_SET_ENABLE_WEAK_LINREG_MASK)
REG_2P5_CLR - Regulator 2P5 Register
#define PMU_REG_2P5_CLR_ENABLE_LINREG_MASK   (0x1U)
#define PMU_REG_2P5_CLR_ENABLE_LINREG_SHIFT   (0U)
#define PMU_REG_2P5_CLR_ENABLE_LINREG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_CLR_ENABLE_LINREG_SHIFT)) & PMU_REG_2P5_CLR_ENABLE_LINREG_MASK)
#define PMU_REG_2P5_CLR_ENABLE_BO_MASK   (0x2U)
#define PMU_REG_2P5_CLR_ENABLE_BO_SHIFT   (1U)
#define PMU_REG_2P5_CLR_ENABLE_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_CLR_ENABLE_BO_SHIFT)) & PMU_REG_2P5_CLR_ENABLE_BO_MASK)
#define PMU_REG_2P5_CLR_ENABLE_ILIMIT_MASK   (0x4U)
#define PMU_REG_2P5_CLR_ENABLE_ILIMIT_SHIFT   (2U)
#define PMU_REG_2P5_CLR_ENABLE_ILIMIT(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_CLR_ENABLE_ILIMIT_SHIFT)) & PMU_REG_2P5_CLR_ENABLE_ILIMIT_MASK)
#define PMU_REG_2P5_CLR_ENABLE_PULLDOWN_MASK   (0x8U)
#define PMU_REG_2P5_CLR_ENABLE_PULLDOWN_SHIFT   (3U)
#define PMU_REG_2P5_CLR_ENABLE_PULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_CLR_ENABLE_PULLDOWN_SHIFT)) & PMU_REG_2P5_CLR_ENABLE_PULLDOWN_MASK)
#define PMU_REG_2P5_CLR_BO_OFFSET_MASK   (0x70U)
#define PMU_REG_2P5_CLR_BO_OFFSET_SHIFT   (4U)
#define PMU_REG_2P5_CLR_BO_OFFSET(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_CLR_BO_OFFSET_SHIFT)) & PMU_REG_2P5_CLR_BO_OFFSET_MASK)
#define PMU_REG_2P5_CLR_OUTPUT_TRG_MASK   (0x1F00U)
#define PMU_REG_2P5_CLR_OUTPUT_TRG_SHIFT   (8U)
#define PMU_REG_2P5_CLR_OUTPUT_TRG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_CLR_OUTPUT_TRG_SHIFT)) & PMU_REG_2P5_CLR_OUTPUT_TRG_MASK)
#define PMU_REG_2P5_CLR_BO_VDD2P5_MASK   (0x10000U)
#define PMU_REG_2P5_CLR_BO_VDD2P5_SHIFT   (16U)
#define PMU_REG_2P5_CLR_BO_VDD2P5(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_CLR_BO_VDD2P5_SHIFT)) & PMU_REG_2P5_CLR_BO_VDD2P5_MASK)
#define PMU_REG_2P5_CLR_OK_VDD2P5_MASK   (0x20000U)
#define PMU_REG_2P5_CLR_OK_VDD2P5_SHIFT   (17U)
#define PMU_REG_2P5_CLR_OK_VDD2P5(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_CLR_OK_VDD2P5_SHIFT)) & PMU_REG_2P5_CLR_OK_VDD2P5_MASK)
#define PMU_REG_2P5_CLR_ENABLE_WEAK_LINREG_MASK   (0x40000U)
#define PMU_REG_2P5_CLR_ENABLE_WEAK_LINREG_SHIFT   (18U)
#define PMU_REG_2P5_CLR_ENABLE_WEAK_LINREG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_CLR_ENABLE_WEAK_LINREG_SHIFT)) & PMU_REG_2P5_CLR_ENABLE_WEAK_LINREG_MASK)
REG_2P5_TOG - Regulator 2P5 Register
#define PMU_REG_2P5_TOG_ENABLE_LINREG_MASK   (0x1U)
#define PMU_REG_2P5_TOG_ENABLE_LINREG_SHIFT   (0U)
#define PMU_REG_2P5_TOG_ENABLE_LINREG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_TOG_ENABLE_LINREG_SHIFT)) & PMU_REG_2P5_TOG_ENABLE_LINREG_MASK)
#define PMU_REG_2P5_TOG_ENABLE_BO_MASK   (0x2U)
#define PMU_REG_2P5_TOG_ENABLE_BO_SHIFT   (1U)
#define PMU_REG_2P5_TOG_ENABLE_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_TOG_ENABLE_BO_SHIFT)) & PMU_REG_2P5_TOG_ENABLE_BO_MASK)
#define PMU_REG_2P5_TOG_ENABLE_ILIMIT_MASK   (0x4U)
#define PMU_REG_2P5_TOG_ENABLE_ILIMIT_SHIFT   (2U)
#define PMU_REG_2P5_TOG_ENABLE_ILIMIT(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_TOG_ENABLE_ILIMIT_SHIFT)) & PMU_REG_2P5_TOG_ENABLE_ILIMIT_MASK)
#define PMU_REG_2P5_TOG_ENABLE_PULLDOWN_MASK   (0x8U)
#define PMU_REG_2P5_TOG_ENABLE_PULLDOWN_SHIFT   (3U)
#define PMU_REG_2P5_TOG_ENABLE_PULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_TOG_ENABLE_PULLDOWN_SHIFT)) & PMU_REG_2P5_TOG_ENABLE_PULLDOWN_MASK)
#define PMU_REG_2P5_TOG_BO_OFFSET_MASK   (0x70U)
#define PMU_REG_2P5_TOG_BO_OFFSET_SHIFT   (4U)
#define PMU_REG_2P5_TOG_BO_OFFSET(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_TOG_BO_OFFSET_SHIFT)) & PMU_REG_2P5_TOG_BO_OFFSET_MASK)
#define PMU_REG_2P5_TOG_OUTPUT_TRG_MASK   (0x1F00U)
#define PMU_REG_2P5_TOG_OUTPUT_TRG_SHIFT   (8U)
#define PMU_REG_2P5_TOG_OUTPUT_TRG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_TOG_OUTPUT_TRG_SHIFT)) & PMU_REG_2P5_TOG_OUTPUT_TRG_MASK)
#define PMU_REG_2P5_TOG_BO_VDD2P5_MASK   (0x10000U)
#define PMU_REG_2P5_TOG_BO_VDD2P5_SHIFT   (16U)
#define PMU_REG_2P5_TOG_BO_VDD2P5(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_TOG_BO_VDD2P5_SHIFT)) & PMU_REG_2P5_TOG_BO_VDD2P5_MASK)
#define PMU_REG_2P5_TOG_OK_VDD2P5_MASK   (0x20000U)
#define PMU_REG_2P5_TOG_OK_VDD2P5_SHIFT   (17U)
#define PMU_REG_2P5_TOG_OK_VDD2P5(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_TOG_OK_VDD2P5_SHIFT)) & PMU_REG_2P5_TOG_OK_VDD2P5_MASK)
#define PMU_REG_2P5_TOG_ENABLE_WEAK_LINREG_MASK   (0x40000U)
#define PMU_REG_2P5_TOG_ENABLE_WEAK_LINREG_SHIFT   (18U)
#define PMU_REG_2P5_TOG_ENABLE_WEAK_LINREG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_TOG_ENABLE_WEAK_LINREG_SHIFT)) & PMU_REG_2P5_TOG_ENABLE_WEAK_LINREG_MASK)
REG_CORE - Digital Regulator Core Register
#define PMU_REG_CORE_REG0_TARG_MASK   (0x1FU)
#define PMU_REG_CORE_REG0_TARG_SHIFT   (0U)
#define PMU_REG_CORE_REG0_TARG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_REG0_TARG_SHIFT)) & PMU_REG_CORE_REG0_TARG_MASK)
#define PMU_REG_CORE_REG0_ADJ_MASK   (0x1E0U)
#define PMU_REG_CORE_REG0_ADJ_SHIFT   (5U)
#define PMU_REG_CORE_REG0_ADJ(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_REG0_ADJ_SHIFT)) & PMU_REG_CORE_REG0_ADJ_MASK)
#define PMU_REG_CORE_REG1_TARG_MASK   (0x3E00U)
#define PMU_REG_CORE_REG1_TARG_SHIFT   (9U)
#define PMU_REG_CORE_REG1_TARG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_REG1_TARG_SHIFT)) & PMU_REG_CORE_REG1_TARG_MASK)
#define PMU_REG_CORE_REG1_ADJ_MASK   (0x3C000U)
#define PMU_REG_CORE_REG1_ADJ_SHIFT   (14U)
#define PMU_REG_CORE_REG1_ADJ(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_REG1_ADJ_SHIFT)) & PMU_REG_CORE_REG1_ADJ_MASK)
#define PMU_REG_CORE_REG2_TARG_MASK   (0x7C0000U)
#define PMU_REG_CORE_REG2_TARG_SHIFT   (18U)
#define PMU_REG_CORE_REG2_TARG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_REG2_TARG_SHIFT)) & PMU_REG_CORE_REG2_TARG_MASK)
#define PMU_REG_CORE_REG2_ADJ_MASK   (0x7800000U)
#define PMU_REG_CORE_REG2_ADJ_SHIFT   (23U)
#define PMU_REG_CORE_REG2_ADJ(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_REG2_ADJ_SHIFT)) & PMU_REG_CORE_REG2_ADJ_MASK)
#define PMU_REG_CORE_RAMP_RATE_MASK   (0x18000000U)
#define PMU_REG_CORE_RAMP_RATE_SHIFT   (27U)
#define PMU_REG_CORE_RAMP_RATE(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_RAMP_RATE_SHIFT)) & PMU_REG_CORE_RAMP_RATE_MASK)
#define PMU_REG_CORE_FET_ODRIVE_MASK   (0x20000000U)
#define PMU_REG_CORE_FET_ODRIVE_SHIFT   (29U)
#define PMU_REG_CORE_FET_ODRIVE(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_FET_ODRIVE_SHIFT)) & PMU_REG_CORE_FET_ODRIVE_MASK)
REG_CORE_SET - Digital Regulator Core Register
#define PMU_REG_CORE_SET_REG0_TARG_MASK   (0x1FU)
#define PMU_REG_CORE_SET_REG0_TARG_SHIFT   (0U)
#define PMU_REG_CORE_SET_REG0_TARG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_SET_REG0_TARG_SHIFT)) & PMU_REG_CORE_SET_REG0_TARG_MASK)
#define PMU_REG_CORE_SET_REG0_ADJ_MASK   (0x1E0U)
#define PMU_REG_CORE_SET_REG0_ADJ_SHIFT   (5U)
#define PMU_REG_CORE_SET_REG0_ADJ(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_SET_REG0_ADJ_SHIFT)) & PMU_REG_CORE_SET_REG0_ADJ_MASK)
#define PMU_REG_CORE_SET_REG1_TARG_MASK   (0x3E00U)
#define PMU_REG_CORE_SET_REG1_TARG_SHIFT   (9U)
#define PMU_REG_CORE_SET_REG1_TARG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_SET_REG1_TARG_SHIFT)) & PMU_REG_CORE_SET_REG1_TARG_MASK)
#define PMU_REG_CORE_SET_REG1_ADJ_MASK   (0x3C000U)
#define PMU_REG_CORE_SET_REG1_ADJ_SHIFT   (14U)
#define PMU_REG_CORE_SET_REG1_ADJ(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_SET_REG1_ADJ_SHIFT)) & PMU_REG_CORE_SET_REG1_ADJ_MASK)
#define PMU_REG_CORE_SET_REG2_TARG_MASK   (0x7C0000U)
#define PMU_REG_CORE_SET_REG2_TARG_SHIFT   (18U)
#define PMU_REG_CORE_SET_REG2_TARG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_SET_REG2_TARG_SHIFT)) & PMU_REG_CORE_SET_REG2_TARG_MASK)
#define PMU_REG_CORE_SET_REG2_ADJ_MASK   (0x7800000U)
#define PMU_REG_CORE_SET_REG2_ADJ_SHIFT   (23U)
#define PMU_REG_CORE_SET_REG2_ADJ(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_SET_REG2_ADJ_SHIFT)) & PMU_REG_CORE_SET_REG2_ADJ_MASK)
#define PMU_REG_CORE_SET_RAMP_RATE_MASK   (0x18000000U)
#define PMU_REG_CORE_SET_RAMP_RATE_SHIFT   (27U)
#define PMU_REG_CORE_SET_RAMP_RATE(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_SET_RAMP_RATE_SHIFT)) & PMU_REG_CORE_SET_RAMP_RATE_MASK)
#define PMU_REG_CORE_SET_FET_ODRIVE_MASK   (0x20000000U)
#define PMU_REG_CORE_SET_FET_ODRIVE_SHIFT   (29U)
#define PMU_REG_CORE_SET_FET_ODRIVE(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_SET_FET_ODRIVE_SHIFT)) & PMU_REG_CORE_SET_FET_ODRIVE_MASK)
REG_CORE_CLR - Digital Regulator Core Register
#define PMU_REG_CORE_CLR_REG0_TARG_MASK   (0x1FU)
#define PMU_REG_CORE_CLR_REG0_TARG_SHIFT   (0U)
#define PMU_REG_CORE_CLR_REG0_TARG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_CLR_REG0_TARG_SHIFT)) & PMU_REG_CORE_CLR_REG0_TARG_MASK)
#define PMU_REG_CORE_CLR_REG0_ADJ_MASK   (0x1E0U)
#define PMU_REG_CORE_CLR_REG0_ADJ_SHIFT   (5U)
#define PMU_REG_CORE_CLR_REG0_ADJ(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_CLR_REG0_ADJ_SHIFT)) & PMU_REG_CORE_CLR_REG0_ADJ_MASK)
#define PMU_REG_CORE_CLR_REG1_TARG_MASK   (0x3E00U)
#define PMU_REG_CORE_CLR_REG1_TARG_SHIFT   (9U)
#define PMU_REG_CORE_CLR_REG1_TARG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_CLR_REG1_TARG_SHIFT)) & PMU_REG_CORE_CLR_REG1_TARG_MASK)
#define PMU_REG_CORE_CLR_REG1_ADJ_MASK   (0x3C000U)
#define PMU_REG_CORE_CLR_REG1_ADJ_SHIFT   (14U)
#define PMU_REG_CORE_CLR_REG1_ADJ(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_CLR_REG1_ADJ_SHIFT)) & PMU_REG_CORE_CLR_REG1_ADJ_MASK)
#define PMU_REG_CORE_CLR_REG2_TARG_MASK   (0x7C0000U)
#define PMU_REG_CORE_CLR_REG2_TARG_SHIFT   (18U)
#define PMU_REG_CORE_CLR_REG2_TARG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_CLR_REG2_TARG_SHIFT)) & PMU_REG_CORE_CLR_REG2_TARG_MASK)
#define PMU_REG_CORE_CLR_REG2_ADJ_MASK   (0x7800000U)
#define PMU_REG_CORE_CLR_REG2_ADJ_SHIFT   (23U)
#define PMU_REG_CORE_CLR_REG2_ADJ(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_CLR_REG2_ADJ_SHIFT)) & PMU_REG_CORE_CLR_REG2_ADJ_MASK)
#define PMU_REG_CORE_CLR_RAMP_RATE_MASK   (0x18000000U)
#define PMU_REG_CORE_CLR_RAMP_RATE_SHIFT   (27U)
#define PMU_REG_CORE_CLR_RAMP_RATE(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_CLR_RAMP_RATE_SHIFT)) & PMU_REG_CORE_CLR_RAMP_RATE_MASK)
#define PMU_REG_CORE_CLR_FET_ODRIVE_MASK   (0x20000000U)
#define PMU_REG_CORE_CLR_FET_ODRIVE_SHIFT   (29U)
#define PMU_REG_CORE_CLR_FET_ODRIVE(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_CLR_FET_ODRIVE_SHIFT)) & PMU_REG_CORE_CLR_FET_ODRIVE_MASK)
REG_CORE_TOG - Digital Regulator Core Register
#define PMU_REG_CORE_TOG_REG0_TARG_MASK   (0x1FU)
#define PMU_REG_CORE_TOG_REG0_TARG_SHIFT   (0U)
#define PMU_REG_CORE_TOG_REG0_TARG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_TOG_REG0_TARG_SHIFT)) & PMU_REG_CORE_TOG_REG0_TARG_MASK)
#define PMU_REG_CORE_TOG_REG0_ADJ_MASK   (0x1E0U)
#define PMU_REG_CORE_TOG_REG0_ADJ_SHIFT   (5U)
#define PMU_REG_CORE_TOG_REG0_ADJ(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_TOG_REG0_ADJ_SHIFT)) & PMU_REG_CORE_TOG_REG0_ADJ_MASK)
#define PMU_REG_CORE_TOG_REG1_TARG_MASK   (0x3E00U)
#define PMU_REG_CORE_TOG_REG1_TARG_SHIFT   (9U)
#define PMU_REG_CORE_TOG_REG1_TARG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_TOG_REG1_TARG_SHIFT)) & PMU_REG_CORE_TOG_REG1_TARG_MASK)
#define PMU_REG_CORE_TOG_REG1_ADJ_MASK   (0x3C000U)
#define PMU_REG_CORE_TOG_REG1_ADJ_SHIFT   (14U)
#define PMU_REG_CORE_TOG_REG1_ADJ(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_TOG_REG1_ADJ_SHIFT)) & PMU_REG_CORE_TOG_REG1_ADJ_MASK)
#define PMU_REG_CORE_TOG_REG2_TARG_MASK   (0x7C0000U)
#define PMU_REG_CORE_TOG_REG2_TARG_SHIFT   (18U)
#define PMU_REG_CORE_TOG_REG2_TARG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_TOG_REG2_TARG_SHIFT)) & PMU_REG_CORE_TOG_REG2_TARG_MASK)
#define PMU_REG_CORE_TOG_REG2_ADJ_MASK   (0x7800000U)
#define PMU_REG_CORE_TOG_REG2_ADJ_SHIFT   (23U)
#define PMU_REG_CORE_TOG_REG2_ADJ(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_TOG_REG2_ADJ_SHIFT)) & PMU_REG_CORE_TOG_REG2_ADJ_MASK)
#define PMU_REG_CORE_TOG_RAMP_RATE_MASK   (0x18000000U)
#define PMU_REG_CORE_TOG_RAMP_RATE_SHIFT   (27U)
#define PMU_REG_CORE_TOG_RAMP_RATE(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_TOG_RAMP_RATE_SHIFT)) & PMU_REG_CORE_TOG_RAMP_RATE_MASK)
#define PMU_REG_CORE_TOG_FET_ODRIVE_MASK   (0x20000000U)
#define PMU_REG_CORE_TOG_FET_ODRIVE_SHIFT   (29U)
#define PMU_REG_CORE_TOG_FET_ODRIVE(x)   (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_TOG_FET_ODRIVE_SHIFT)) & PMU_REG_CORE_TOG_FET_ODRIVE_MASK)
MISC0 - Miscellaneous Register 0
#define PMU_MISC0_REFTOP_PWD_MASK   (0x1U)
#define PMU_MISC0_REFTOP_PWD_SHIFT   (0U)
#define PMU_MISC0_REFTOP_PWD(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_REFTOP_PWD_SHIFT)) & PMU_MISC0_REFTOP_PWD_MASK)
#define PMU_MISC0_REFTOP_PWDVBGUP_MASK   (0x2U)
#define PMU_MISC0_REFTOP_PWDVBGUP_SHIFT   (1U)
#define PMU_MISC0_REFTOP_PWDVBGUP(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_REFTOP_PWDVBGUP_SHIFT)) & PMU_MISC0_REFTOP_PWDVBGUP_MASK)
#define PMU_MISC0_REFTOP_LOWPOWER_MASK   (0x4U)
#define PMU_MISC0_REFTOP_LOWPOWER_SHIFT   (2U)
#define PMU_MISC0_REFTOP_LOWPOWER(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_REFTOP_LOWPOWER_SHIFT)) & PMU_MISC0_REFTOP_LOWPOWER_MASK)
#define PMU_MISC0_REFTOP_SELFBIASOFF_MASK   (0x8U)
#define PMU_MISC0_REFTOP_SELFBIASOFF_SHIFT   (3U)
#define PMU_MISC0_REFTOP_SELFBIASOFF(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_REFTOP_SELFBIASOFF_SHIFT)) & PMU_MISC0_REFTOP_SELFBIASOFF_MASK)
#define PMU_MISC0_REFTOP_VBGADJ_MASK   (0x70U)
#define PMU_MISC0_REFTOP_VBGADJ_SHIFT   (4U)
#define PMU_MISC0_REFTOP_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_REFTOP_VBGADJ_SHIFT)) & PMU_MISC0_REFTOP_VBGADJ_MASK)
#define PMU_MISC0_REFTOP_VBGUP_MASK   (0x80U)
#define PMU_MISC0_REFTOP_VBGUP_SHIFT   (7U)
#define PMU_MISC0_REFTOP_VBGUP(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_REFTOP_VBGUP_SHIFT)) & PMU_MISC0_REFTOP_VBGUP_MASK)
#define PMU_MISC0_STOP_MODE_CONFIG_MASK   (0xC00U)
#define PMU_MISC0_STOP_MODE_CONFIG_SHIFT   (10U)
#define PMU_MISC0_STOP_MODE_CONFIG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_STOP_MODE_CONFIG_SHIFT)) & PMU_MISC0_STOP_MODE_CONFIG_MASK)
#define PMU_MISC0_DISCON_HIGH_SNVS_MASK   (0x1000U)
#define PMU_MISC0_DISCON_HIGH_SNVS_SHIFT   (12U)
#define PMU_MISC0_DISCON_HIGH_SNVS(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_DISCON_HIGH_SNVS_SHIFT)) & PMU_MISC0_DISCON_HIGH_SNVS_MASK)
#define PMU_MISC0_OSC_I_MASK   (0x6000U)
#define PMU_MISC0_OSC_I_SHIFT   (13U)
#define PMU_MISC0_OSC_I(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_OSC_I_SHIFT)) & PMU_MISC0_OSC_I_MASK)
#define PMU_MISC0_OSC_XTALOK_MASK   (0x8000U)
#define PMU_MISC0_OSC_XTALOK_SHIFT   (15U)
#define PMU_MISC0_OSC_XTALOK(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_OSC_XTALOK_SHIFT)) & PMU_MISC0_OSC_XTALOK_MASK)
#define PMU_MISC0_OSC_XTALOK_EN_MASK   (0x10000U)
#define PMU_MISC0_OSC_XTALOK_EN_SHIFT   (16U)
#define PMU_MISC0_OSC_XTALOK_EN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_OSC_XTALOK_EN_SHIFT)) & PMU_MISC0_OSC_XTALOK_EN_MASK)
#define PMU_MISC0_CLKGATE_CTRL_MASK   (0x2000000U)
#define PMU_MISC0_CLKGATE_CTRL_SHIFT   (25U)
#define PMU_MISC0_CLKGATE_CTRL(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLKGATE_CTRL_SHIFT)) & PMU_MISC0_CLKGATE_CTRL_MASK)
#define PMU_MISC0_CLKGATE_DELAY_MASK   (0x1C000000U)
#define PMU_MISC0_CLKGATE_DELAY_SHIFT   (26U)
#define PMU_MISC0_CLKGATE_DELAY(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLKGATE_DELAY_SHIFT)) & PMU_MISC0_CLKGATE_DELAY_MASK)
#define PMU_MISC0_RTC_XTAL_SOURCE_MASK   (0x20000000U)
#define PMU_MISC0_RTC_XTAL_SOURCE_SHIFT   (29U)
#define PMU_MISC0_RTC_XTAL_SOURCE(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_RTC_XTAL_SOURCE_SHIFT)) & PMU_MISC0_RTC_XTAL_SOURCE_MASK)
#define PMU_MISC0_XTAL_24M_PWD_MASK   (0x40000000U)
#define PMU_MISC0_XTAL_24M_PWD_SHIFT   (30U)
#define PMU_MISC0_XTAL_24M_PWD(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_XTAL_24M_PWD_SHIFT)) & PMU_MISC0_XTAL_24M_PWD_MASK)
#define PMU_MISC0_VID_PLL_PREDIV_MASK   (0x80000000U)
#define PMU_MISC0_VID_PLL_PREDIV_SHIFT   (31U)
#define PMU_MISC0_VID_PLL_PREDIV(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_VID_PLL_PREDIV_SHIFT)) & PMU_MISC0_VID_PLL_PREDIV_MASK)
MISC0_SET - Miscellaneous Register 0
#define PMU_MISC0_SET_REFTOP_PWD_MASK   (0x1U)
#define PMU_MISC0_SET_REFTOP_PWD_SHIFT   (0U)
#define PMU_MISC0_SET_REFTOP_PWD(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_SET_REFTOP_PWD_SHIFT)) & PMU_MISC0_SET_REFTOP_PWD_MASK)
#define PMU_MISC0_SET_REFTOP_PWDVBGUP_MASK   (0x2U)
#define PMU_MISC0_SET_REFTOP_PWDVBGUP_SHIFT   (1U)
#define PMU_MISC0_SET_REFTOP_PWDVBGUP(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_SET_REFTOP_PWDVBGUP_SHIFT)) & PMU_MISC0_SET_REFTOP_PWDVBGUP_MASK)
#define PMU_MISC0_SET_REFTOP_LOWPOWER_MASK   (0x4U)
#define PMU_MISC0_SET_REFTOP_LOWPOWER_SHIFT   (2U)
#define PMU_MISC0_SET_REFTOP_LOWPOWER(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_SET_REFTOP_LOWPOWER_SHIFT)) & PMU_MISC0_SET_REFTOP_LOWPOWER_MASK)
#define PMU_MISC0_SET_REFTOP_SELFBIASOFF_MASK   (0x8U)
#define PMU_MISC0_SET_REFTOP_SELFBIASOFF_SHIFT   (3U)
#define PMU_MISC0_SET_REFTOP_SELFBIASOFF(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_SET_REFTOP_SELFBIASOFF_SHIFT)) & PMU_MISC0_SET_REFTOP_SELFBIASOFF_MASK)
#define PMU_MISC0_SET_REFTOP_VBGADJ_MASK   (0x70U)
#define PMU_MISC0_SET_REFTOP_VBGADJ_SHIFT   (4U)
#define PMU_MISC0_SET_REFTOP_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_SET_REFTOP_VBGADJ_SHIFT)) & PMU_MISC0_SET_REFTOP_VBGADJ_MASK)
#define PMU_MISC0_SET_REFTOP_VBGUP_MASK   (0x80U)
#define PMU_MISC0_SET_REFTOP_VBGUP_SHIFT   (7U)
#define PMU_MISC0_SET_REFTOP_VBGUP(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_SET_REFTOP_VBGUP_SHIFT)) & PMU_MISC0_SET_REFTOP_VBGUP_MASK)
#define PMU_MISC0_SET_STOP_MODE_CONFIG_MASK   (0xC00U)
#define PMU_MISC0_SET_STOP_MODE_CONFIG_SHIFT   (10U)
#define PMU_MISC0_SET_STOP_MODE_CONFIG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_SET_STOP_MODE_CONFIG_SHIFT)) & PMU_MISC0_SET_STOP_MODE_CONFIG_MASK)
#define PMU_MISC0_SET_DISCON_HIGH_SNVS_MASK   (0x1000U)
#define PMU_MISC0_SET_DISCON_HIGH_SNVS_SHIFT   (12U)
#define PMU_MISC0_SET_DISCON_HIGH_SNVS(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_SET_DISCON_HIGH_SNVS_SHIFT)) & PMU_MISC0_SET_DISCON_HIGH_SNVS_MASK)
#define PMU_MISC0_SET_OSC_I_MASK   (0x6000U)
#define PMU_MISC0_SET_OSC_I_SHIFT   (13U)
#define PMU_MISC0_SET_OSC_I(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_SET_OSC_I_SHIFT)) & PMU_MISC0_SET_OSC_I_MASK)
#define PMU_MISC0_SET_OSC_XTALOK_MASK   (0x8000U)
#define PMU_MISC0_SET_OSC_XTALOK_SHIFT   (15U)
#define PMU_MISC0_SET_OSC_XTALOK(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_SET_OSC_XTALOK_SHIFT)) & PMU_MISC0_SET_OSC_XTALOK_MASK)
#define PMU_MISC0_SET_OSC_XTALOK_EN_MASK   (0x10000U)
#define PMU_MISC0_SET_OSC_XTALOK_EN_SHIFT   (16U)
#define PMU_MISC0_SET_OSC_XTALOK_EN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_SET_OSC_XTALOK_EN_SHIFT)) & PMU_MISC0_SET_OSC_XTALOK_EN_MASK)
#define PMU_MISC0_SET_CLKGATE_CTRL_MASK   (0x2000000U)
#define PMU_MISC0_SET_CLKGATE_CTRL_SHIFT   (25U)
#define PMU_MISC0_SET_CLKGATE_CTRL(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_SET_CLKGATE_CTRL_SHIFT)) & PMU_MISC0_SET_CLKGATE_CTRL_MASK)
#define PMU_MISC0_SET_CLKGATE_DELAY_MASK   (0x1C000000U)
#define PMU_MISC0_SET_CLKGATE_DELAY_SHIFT   (26U)
#define PMU_MISC0_SET_CLKGATE_DELAY(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_SET_CLKGATE_DELAY_SHIFT)) & PMU_MISC0_SET_CLKGATE_DELAY_MASK)
#define PMU_MISC0_SET_RTC_XTAL_SOURCE_MASK   (0x20000000U)
#define PMU_MISC0_SET_RTC_XTAL_SOURCE_SHIFT   (29U)
#define PMU_MISC0_SET_RTC_XTAL_SOURCE(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_SET_RTC_XTAL_SOURCE_SHIFT)) & PMU_MISC0_SET_RTC_XTAL_SOURCE_MASK)
#define PMU_MISC0_SET_XTAL_24M_PWD_MASK   (0x40000000U)
#define PMU_MISC0_SET_XTAL_24M_PWD_SHIFT   (30U)
#define PMU_MISC0_SET_XTAL_24M_PWD(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_SET_XTAL_24M_PWD_SHIFT)) & PMU_MISC0_SET_XTAL_24M_PWD_MASK)
#define PMU_MISC0_SET_VID_PLL_PREDIV_MASK   (0x80000000U)
#define PMU_MISC0_SET_VID_PLL_PREDIV_SHIFT   (31U)
#define PMU_MISC0_SET_VID_PLL_PREDIV(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_SET_VID_PLL_PREDIV_SHIFT)) & PMU_MISC0_SET_VID_PLL_PREDIV_MASK)
MISC0_CLR - Miscellaneous Register 0
#define PMU_MISC0_CLR_REFTOP_PWD_MASK   (0x1U)
#define PMU_MISC0_CLR_REFTOP_PWD_SHIFT   (0U)
#define PMU_MISC0_CLR_REFTOP_PWD(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLR_REFTOP_PWD_SHIFT)) & PMU_MISC0_CLR_REFTOP_PWD_MASK)
#define PMU_MISC0_CLR_REFTOP_PWDVBGUP_MASK   (0x2U)
#define PMU_MISC0_CLR_REFTOP_PWDVBGUP_SHIFT   (1U)
#define PMU_MISC0_CLR_REFTOP_PWDVBGUP(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLR_REFTOP_PWDVBGUP_SHIFT)) & PMU_MISC0_CLR_REFTOP_PWDVBGUP_MASK)
#define PMU_MISC0_CLR_REFTOP_LOWPOWER_MASK   (0x4U)
#define PMU_MISC0_CLR_REFTOP_LOWPOWER_SHIFT   (2U)
#define PMU_MISC0_CLR_REFTOP_LOWPOWER(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLR_REFTOP_LOWPOWER_SHIFT)) & PMU_MISC0_CLR_REFTOP_LOWPOWER_MASK)
#define PMU_MISC0_CLR_REFTOP_SELFBIASOFF_MASK   (0x8U)
#define PMU_MISC0_CLR_REFTOP_SELFBIASOFF_SHIFT   (3U)
#define PMU_MISC0_CLR_REFTOP_SELFBIASOFF(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLR_REFTOP_SELFBIASOFF_SHIFT)) & PMU_MISC0_CLR_REFTOP_SELFBIASOFF_MASK)
#define PMU_MISC0_CLR_REFTOP_VBGADJ_MASK   (0x70U)
#define PMU_MISC0_CLR_REFTOP_VBGADJ_SHIFT   (4U)
#define PMU_MISC0_CLR_REFTOP_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLR_REFTOP_VBGADJ_SHIFT)) & PMU_MISC0_CLR_REFTOP_VBGADJ_MASK)
#define PMU_MISC0_CLR_REFTOP_VBGUP_MASK   (0x80U)
#define PMU_MISC0_CLR_REFTOP_VBGUP_SHIFT   (7U)
#define PMU_MISC0_CLR_REFTOP_VBGUP(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLR_REFTOP_VBGUP_SHIFT)) & PMU_MISC0_CLR_REFTOP_VBGUP_MASK)
#define PMU_MISC0_CLR_STOP_MODE_CONFIG_MASK   (0xC00U)
#define PMU_MISC0_CLR_STOP_MODE_CONFIG_SHIFT   (10U)
#define PMU_MISC0_CLR_STOP_MODE_CONFIG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLR_STOP_MODE_CONFIG_SHIFT)) & PMU_MISC0_CLR_STOP_MODE_CONFIG_MASK)
#define PMU_MISC0_CLR_DISCON_HIGH_SNVS_MASK   (0x1000U)
#define PMU_MISC0_CLR_DISCON_HIGH_SNVS_SHIFT   (12U)
#define PMU_MISC0_CLR_DISCON_HIGH_SNVS(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLR_DISCON_HIGH_SNVS_SHIFT)) & PMU_MISC0_CLR_DISCON_HIGH_SNVS_MASK)
#define PMU_MISC0_CLR_OSC_I_MASK   (0x6000U)
#define PMU_MISC0_CLR_OSC_I_SHIFT   (13U)
#define PMU_MISC0_CLR_OSC_I(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLR_OSC_I_SHIFT)) & PMU_MISC0_CLR_OSC_I_MASK)
#define PMU_MISC0_CLR_OSC_XTALOK_MASK   (0x8000U)
#define PMU_MISC0_CLR_OSC_XTALOK_SHIFT   (15U)
#define PMU_MISC0_CLR_OSC_XTALOK(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLR_OSC_XTALOK_SHIFT)) & PMU_MISC0_CLR_OSC_XTALOK_MASK)
#define PMU_MISC0_CLR_OSC_XTALOK_EN_MASK   (0x10000U)
#define PMU_MISC0_CLR_OSC_XTALOK_EN_SHIFT   (16U)
#define PMU_MISC0_CLR_OSC_XTALOK_EN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLR_OSC_XTALOK_EN_SHIFT)) & PMU_MISC0_CLR_OSC_XTALOK_EN_MASK)
#define PMU_MISC0_CLR_CLKGATE_CTRL_MASK   (0x2000000U)
#define PMU_MISC0_CLR_CLKGATE_CTRL_SHIFT   (25U)
#define PMU_MISC0_CLR_CLKGATE_CTRL(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLR_CLKGATE_CTRL_SHIFT)) & PMU_MISC0_CLR_CLKGATE_CTRL_MASK)
#define PMU_MISC0_CLR_CLKGATE_DELAY_MASK   (0x1C000000U)
#define PMU_MISC0_CLR_CLKGATE_DELAY_SHIFT   (26U)
#define PMU_MISC0_CLR_CLKGATE_DELAY(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLR_CLKGATE_DELAY_SHIFT)) & PMU_MISC0_CLR_CLKGATE_DELAY_MASK)
#define PMU_MISC0_CLR_RTC_XTAL_SOURCE_MASK   (0x20000000U)
#define PMU_MISC0_CLR_RTC_XTAL_SOURCE_SHIFT   (29U)
#define PMU_MISC0_CLR_RTC_XTAL_SOURCE(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLR_RTC_XTAL_SOURCE_SHIFT)) & PMU_MISC0_CLR_RTC_XTAL_SOURCE_MASK)
#define PMU_MISC0_CLR_XTAL_24M_PWD_MASK   (0x40000000U)
#define PMU_MISC0_CLR_XTAL_24M_PWD_SHIFT   (30U)
#define PMU_MISC0_CLR_XTAL_24M_PWD(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLR_XTAL_24M_PWD_SHIFT)) & PMU_MISC0_CLR_XTAL_24M_PWD_MASK)
#define PMU_MISC0_CLR_VID_PLL_PREDIV_MASK   (0x80000000U)
#define PMU_MISC0_CLR_VID_PLL_PREDIV_SHIFT   (31U)
#define PMU_MISC0_CLR_VID_PLL_PREDIV(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLR_VID_PLL_PREDIV_SHIFT)) & PMU_MISC0_CLR_VID_PLL_PREDIV_MASK)
MISC0_TOG - Miscellaneous Register 0
#define PMU_MISC0_TOG_REFTOP_PWD_MASK   (0x1U)
#define PMU_MISC0_TOG_REFTOP_PWD_SHIFT   (0U)
#define PMU_MISC0_TOG_REFTOP_PWD(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_TOG_REFTOP_PWD_SHIFT)) & PMU_MISC0_TOG_REFTOP_PWD_MASK)
#define PMU_MISC0_TOG_REFTOP_PWDVBGUP_MASK   (0x2U)
#define PMU_MISC0_TOG_REFTOP_PWDVBGUP_SHIFT   (1U)
#define PMU_MISC0_TOG_REFTOP_PWDVBGUP(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_TOG_REFTOP_PWDVBGUP_SHIFT)) & PMU_MISC0_TOG_REFTOP_PWDVBGUP_MASK)
#define PMU_MISC0_TOG_REFTOP_LOWPOWER_MASK   (0x4U)
#define PMU_MISC0_TOG_REFTOP_LOWPOWER_SHIFT   (2U)
#define PMU_MISC0_TOG_REFTOP_LOWPOWER(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_TOG_REFTOP_LOWPOWER_SHIFT)) & PMU_MISC0_TOG_REFTOP_LOWPOWER_MASK)
#define PMU_MISC0_TOG_REFTOP_SELFBIASOFF_MASK   (0x8U)
#define PMU_MISC0_TOG_REFTOP_SELFBIASOFF_SHIFT   (3U)
#define PMU_MISC0_TOG_REFTOP_SELFBIASOFF(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_TOG_REFTOP_SELFBIASOFF_SHIFT)) & PMU_MISC0_TOG_REFTOP_SELFBIASOFF_MASK)
#define PMU_MISC0_TOG_REFTOP_VBGADJ_MASK   (0x70U)
#define PMU_MISC0_TOG_REFTOP_VBGADJ_SHIFT   (4U)
#define PMU_MISC0_TOG_REFTOP_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_TOG_REFTOP_VBGADJ_SHIFT)) & PMU_MISC0_TOG_REFTOP_VBGADJ_MASK)
#define PMU_MISC0_TOG_REFTOP_VBGUP_MASK   (0x80U)
#define PMU_MISC0_TOG_REFTOP_VBGUP_SHIFT   (7U)
#define PMU_MISC0_TOG_REFTOP_VBGUP(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_TOG_REFTOP_VBGUP_SHIFT)) & PMU_MISC0_TOG_REFTOP_VBGUP_MASK)
#define PMU_MISC0_TOG_STOP_MODE_CONFIG_MASK   (0xC00U)
#define PMU_MISC0_TOG_STOP_MODE_CONFIG_SHIFT   (10U)
#define PMU_MISC0_TOG_STOP_MODE_CONFIG(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_TOG_STOP_MODE_CONFIG_SHIFT)) & PMU_MISC0_TOG_STOP_MODE_CONFIG_MASK)
#define PMU_MISC0_TOG_DISCON_HIGH_SNVS_MASK   (0x1000U)
#define PMU_MISC0_TOG_DISCON_HIGH_SNVS_SHIFT   (12U)
#define PMU_MISC0_TOG_DISCON_HIGH_SNVS(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_TOG_DISCON_HIGH_SNVS_SHIFT)) & PMU_MISC0_TOG_DISCON_HIGH_SNVS_MASK)
#define PMU_MISC0_TOG_OSC_I_MASK   (0x6000U)
#define PMU_MISC0_TOG_OSC_I_SHIFT   (13U)
#define PMU_MISC0_TOG_OSC_I(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_TOG_OSC_I_SHIFT)) & PMU_MISC0_TOG_OSC_I_MASK)
#define PMU_MISC0_TOG_OSC_XTALOK_MASK   (0x8000U)
#define PMU_MISC0_TOG_OSC_XTALOK_SHIFT   (15U)
#define PMU_MISC0_TOG_OSC_XTALOK(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_TOG_OSC_XTALOK_SHIFT)) & PMU_MISC0_TOG_OSC_XTALOK_MASK)
#define PMU_MISC0_TOG_OSC_XTALOK_EN_MASK   (0x10000U)
#define PMU_MISC0_TOG_OSC_XTALOK_EN_SHIFT   (16U)
#define PMU_MISC0_TOG_OSC_XTALOK_EN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_TOG_OSC_XTALOK_EN_SHIFT)) & PMU_MISC0_TOG_OSC_XTALOK_EN_MASK)
#define PMU_MISC0_TOG_CLKGATE_CTRL_MASK   (0x2000000U)
#define PMU_MISC0_TOG_CLKGATE_CTRL_SHIFT   (25U)
#define PMU_MISC0_TOG_CLKGATE_CTRL(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_TOG_CLKGATE_CTRL_SHIFT)) & PMU_MISC0_TOG_CLKGATE_CTRL_MASK)
#define PMU_MISC0_TOG_CLKGATE_DELAY_MASK   (0x1C000000U)
#define PMU_MISC0_TOG_CLKGATE_DELAY_SHIFT   (26U)
#define PMU_MISC0_TOG_CLKGATE_DELAY(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_TOG_CLKGATE_DELAY_SHIFT)) & PMU_MISC0_TOG_CLKGATE_DELAY_MASK)
#define PMU_MISC0_TOG_RTC_XTAL_SOURCE_MASK   (0x20000000U)
#define PMU_MISC0_TOG_RTC_XTAL_SOURCE_SHIFT   (29U)
#define PMU_MISC0_TOG_RTC_XTAL_SOURCE(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_TOG_RTC_XTAL_SOURCE_SHIFT)) & PMU_MISC0_TOG_RTC_XTAL_SOURCE_MASK)
#define PMU_MISC0_TOG_XTAL_24M_PWD_MASK   (0x40000000U)
#define PMU_MISC0_TOG_XTAL_24M_PWD_SHIFT   (30U)
#define PMU_MISC0_TOG_XTAL_24M_PWD(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_TOG_XTAL_24M_PWD_SHIFT)) & PMU_MISC0_TOG_XTAL_24M_PWD_MASK)
#define PMU_MISC0_TOG_VID_PLL_PREDIV_MASK   (0x80000000U)
#define PMU_MISC0_TOG_VID_PLL_PREDIV_SHIFT   (31U)
#define PMU_MISC0_TOG_VID_PLL_PREDIV(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_TOG_VID_PLL_PREDIV_SHIFT)) & PMU_MISC0_TOG_VID_PLL_PREDIV_MASK)
MISC1 - Miscellaneous Register 1
#define PMU_MISC1_LVDS1_CLK_SEL_MASK   (0x1FU)
#define PMU_MISC1_LVDS1_CLK_SEL_SHIFT   (0U)
#define PMU_MISC1_LVDS1_CLK_SEL(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_LVDS1_CLK_SEL_SHIFT)) & PMU_MISC1_LVDS1_CLK_SEL_MASK)
#define PMU_MISC1_LVDS2_CLK_SEL_MASK   (0x3E0U)
#define PMU_MISC1_LVDS2_CLK_SEL_SHIFT   (5U)
#define PMU_MISC1_LVDS2_CLK_SEL(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_LVDS2_CLK_SEL_SHIFT)) & PMU_MISC1_LVDS2_CLK_SEL_MASK)
#define PMU_MISC1_LVDSCLK1_OBEN_MASK   (0x400U)
#define PMU_MISC1_LVDSCLK1_OBEN_SHIFT   (10U)
#define PMU_MISC1_LVDSCLK1_OBEN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_LVDSCLK1_OBEN_SHIFT)) & PMU_MISC1_LVDSCLK1_OBEN_MASK)
#define PMU_MISC1_LVDSCLK2_OBEN_MASK   (0x800U)
#define PMU_MISC1_LVDSCLK2_OBEN_SHIFT   (11U)
#define PMU_MISC1_LVDSCLK2_OBEN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_LVDSCLK2_OBEN_SHIFT)) & PMU_MISC1_LVDSCLK2_OBEN_MASK)
#define PMU_MISC1_LVDSCLK1_IBEN_MASK   (0x1000U)
#define PMU_MISC1_LVDSCLK1_IBEN_SHIFT   (12U)
#define PMU_MISC1_LVDSCLK1_IBEN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_LVDSCLK1_IBEN_SHIFT)) & PMU_MISC1_LVDSCLK1_IBEN_MASK)
#define PMU_MISC1_LVDSCLK2_IBEN_MASK   (0x2000U)
#define PMU_MISC1_LVDSCLK2_IBEN_SHIFT   (13U)
#define PMU_MISC1_LVDSCLK2_IBEN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_LVDSCLK2_IBEN_SHIFT)) & PMU_MISC1_LVDSCLK2_IBEN_MASK)
#define PMU_MISC1_PFD_480_AUTOGATE_EN_MASK   (0x10000U)
#define PMU_MISC1_PFD_480_AUTOGATE_EN_SHIFT   (16U)
#define PMU_MISC1_PFD_480_AUTOGATE_EN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_PFD_480_AUTOGATE_EN_SHIFT)) & PMU_MISC1_PFD_480_AUTOGATE_EN_MASK)
#define PMU_MISC1_PFD_528_AUTOGATE_EN_MASK   (0x20000U)
#define PMU_MISC1_PFD_528_AUTOGATE_EN_SHIFT   (17U)
#define PMU_MISC1_PFD_528_AUTOGATE_EN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_PFD_528_AUTOGATE_EN_SHIFT)) & PMU_MISC1_PFD_528_AUTOGATE_EN_MASK)
#define PMU_MISC1_IRQ_TEMPPANIC_MASK   (0x8000000U)
#define PMU_MISC1_IRQ_TEMPPANIC_SHIFT   (27U)
#define PMU_MISC1_IRQ_TEMPPANIC(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_IRQ_TEMPPANIC_SHIFT)) & PMU_MISC1_IRQ_TEMPPANIC_MASK)
#define PMU_MISC1_IRQ_TEMPLOW_MASK   (0x10000000U)
#define PMU_MISC1_IRQ_TEMPLOW_SHIFT   (28U)
#define PMU_MISC1_IRQ_TEMPLOW(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_IRQ_TEMPLOW_SHIFT)) & PMU_MISC1_IRQ_TEMPLOW_MASK)
#define PMU_MISC1_IRQ_TEMPHIGH_MASK   (0x20000000U)
#define PMU_MISC1_IRQ_TEMPHIGH_SHIFT   (29U)
#define PMU_MISC1_IRQ_TEMPHIGH(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_IRQ_TEMPHIGH_SHIFT)) & PMU_MISC1_IRQ_TEMPHIGH_MASK)
#define PMU_MISC1_IRQ_ANA_BO_MASK   (0x40000000U)
#define PMU_MISC1_IRQ_ANA_BO_SHIFT   (30U)
#define PMU_MISC1_IRQ_ANA_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_IRQ_ANA_BO_SHIFT)) & PMU_MISC1_IRQ_ANA_BO_MASK)
#define PMU_MISC1_IRQ_DIG_BO_MASK   (0x80000000U)
#define PMU_MISC1_IRQ_DIG_BO_SHIFT   (31U)
#define PMU_MISC1_IRQ_DIG_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_IRQ_DIG_BO_SHIFT)) & PMU_MISC1_IRQ_DIG_BO_MASK)
MISC1_SET - Miscellaneous Register 1
#define PMU_MISC1_SET_LVDS1_CLK_SEL_MASK   (0x1FU)
#define PMU_MISC1_SET_LVDS1_CLK_SEL_SHIFT   (0U)
#define PMU_MISC1_SET_LVDS1_CLK_SEL(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_SET_LVDS1_CLK_SEL_SHIFT)) & PMU_MISC1_SET_LVDS1_CLK_SEL_MASK)
#define PMU_MISC1_SET_LVDS2_CLK_SEL_MASK   (0x3E0U)
#define PMU_MISC1_SET_LVDS2_CLK_SEL_SHIFT   (5U)
#define PMU_MISC1_SET_LVDS2_CLK_SEL(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_SET_LVDS2_CLK_SEL_SHIFT)) & PMU_MISC1_SET_LVDS2_CLK_SEL_MASK)
#define PMU_MISC1_SET_LVDSCLK1_OBEN_MASK   (0x400U)
#define PMU_MISC1_SET_LVDSCLK1_OBEN_SHIFT   (10U)
#define PMU_MISC1_SET_LVDSCLK1_OBEN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_SET_LVDSCLK1_OBEN_SHIFT)) & PMU_MISC1_SET_LVDSCLK1_OBEN_MASK)
#define PMU_MISC1_SET_LVDSCLK2_OBEN_MASK   (0x800U)
#define PMU_MISC1_SET_LVDSCLK2_OBEN_SHIFT   (11U)
#define PMU_MISC1_SET_LVDSCLK2_OBEN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_SET_LVDSCLK2_OBEN_SHIFT)) & PMU_MISC1_SET_LVDSCLK2_OBEN_MASK)
#define PMU_MISC1_SET_LVDSCLK1_IBEN_MASK   (0x1000U)
#define PMU_MISC1_SET_LVDSCLK1_IBEN_SHIFT   (12U)
#define PMU_MISC1_SET_LVDSCLK1_IBEN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_SET_LVDSCLK1_IBEN_SHIFT)) & PMU_MISC1_SET_LVDSCLK1_IBEN_MASK)
#define PMU_MISC1_SET_LVDSCLK2_IBEN_MASK   (0x2000U)
#define PMU_MISC1_SET_LVDSCLK2_IBEN_SHIFT   (13U)
#define PMU_MISC1_SET_LVDSCLK2_IBEN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_SET_LVDSCLK2_IBEN_SHIFT)) & PMU_MISC1_SET_LVDSCLK2_IBEN_MASK)
#define PMU_MISC1_SET_PFD_480_AUTOGATE_EN_MASK   (0x10000U)
#define PMU_MISC1_SET_PFD_480_AUTOGATE_EN_SHIFT   (16U)
#define PMU_MISC1_SET_PFD_480_AUTOGATE_EN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_SET_PFD_480_AUTOGATE_EN_SHIFT)) & PMU_MISC1_SET_PFD_480_AUTOGATE_EN_MASK)
#define PMU_MISC1_SET_PFD_528_AUTOGATE_EN_MASK   (0x20000U)
#define PMU_MISC1_SET_PFD_528_AUTOGATE_EN_SHIFT   (17U)
#define PMU_MISC1_SET_PFD_528_AUTOGATE_EN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_SET_PFD_528_AUTOGATE_EN_SHIFT)) & PMU_MISC1_SET_PFD_528_AUTOGATE_EN_MASK)
#define PMU_MISC1_SET_IRQ_TEMPPANIC_MASK   (0x8000000U)
#define PMU_MISC1_SET_IRQ_TEMPPANIC_SHIFT   (27U)
#define PMU_MISC1_SET_IRQ_TEMPPANIC(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_SET_IRQ_TEMPPANIC_SHIFT)) & PMU_MISC1_SET_IRQ_TEMPPANIC_MASK)
#define PMU_MISC1_SET_IRQ_TEMPLOW_MASK   (0x10000000U)
#define PMU_MISC1_SET_IRQ_TEMPLOW_SHIFT   (28U)
#define PMU_MISC1_SET_IRQ_TEMPLOW(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_SET_IRQ_TEMPLOW_SHIFT)) & PMU_MISC1_SET_IRQ_TEMPLOW_MASK)
#define PMU_MISC1_SET_IRQ_TEMPHIGH_MASK   (0x20000000U)
#define PMU_MISC1_SET_IRQ_TEMPHIGH_SHIFT   (29U)
#define PMU_MISC1_SET_IRQ_TEMPHIGH(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_SET_IRQ_TEMPHIGH_SHIFT)) & PMU_MISC1_SET_IRQ_TEMPHIGH_MASK)
#define PMU_MISC1_SET_IRQ_ANA_BO_MASK   (0x40000000U)
#define PMU_MISC1_SET_IRQ_ANA_BO_SHIFT   (30U)
#define PMU_MISC1_SET_IRQ_ANA_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_SET_IRQ_ANA_BO_SHIFT)) & PMU_MISC1_SET_IRQ_ANA_BO_MASK)
#define PMU_MISC1_SET_IRQ_DIG_BO_MASK   (0x80000000U)
#define PMU_MISC1_SET_IRQ_DIG_BO_SHIFT   (31U)
#define PMU_MISC1_SET_IRQ_DIG_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_SET_IRQ_DIG_BO_SHIFT)) & PMU_MISC1_SET_IRQ_DIG_BO_MASK)
MISC1_CLR - Miscellaneous Register 1
#define PMU_MISC1_CLR_LVDS1_CLK_SEL_MASK   (0x1FU)
#define PMU_MISC1_CLR_LVDS1_CLK_SEL_SHIFT   (0U)
#define PMU_MISC1_CLR_LVDS1_CLK_SEL(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_CLR_LVDS1_CLK_SEL_SHIFT)) & PMU_MISC1_CLR_LVDS1_CLK_SEL_MASK)
#define PMU_MISC1_CLR_LVDS2_CLK_SEL_MASK   (0x3E0U)
#define PMU_MISC1_CLR_LVDS2_CLK_SEL_SHIFT   (5U)
#define PMU_MISC1_CLR_LVDS2_CLK_SEL(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_CLR_LVDS2_CLK_SEL_SHIFT)) & PMU_MISC1_CLR_LVDS2_CLK_SEL_MASK)
#define PMU_MISC1_CLR_LVDSCLK1_OBEN_MASK   (0x400U)
#define PMU_MISC1_CLR_LVDSCLK1_OBEN_SHIFT   (10U)
#define PMU_MISC1_CLR_LVDSCLK1_OBEN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_CLR_LVDSCLK1_OBEN_SHIFT)) & PMU_MISC1_CLR_LVDSCLK1_OBEN_MASK)
#define PMU_MISC1_CLR_LVDSCLK2_OBEN_MASK   (0x800U)
#define PMU_MISC1_CLR_LVDSCLK2_OBEN_SHIFT   (11U)
#define PMU_MISC1_CLR_LVDSCLK2_OBEN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_CLR_LVDSCLK2_OBEN_SHIFT)) & PMU_MISC1_CLR_LVDSCLK2_OBEN_MASK)
#define PMU_MISC1_CLR_LVDSCLK1_IBEN_MASK   (0x1000U)
#define PMU_MISC1_CLR_LVDSCLK1_IBEN_SHIFT   (12U)
#define PMU_MISC1_CLR_LVDSCLK1_IBEN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_CLR_LVDSCLK1_IBEN_SHIFT)) & PMU_MISC1_CLR_LVDSCLK1_IBEN_MASK)
#define PMU_MISC1_CLR_LVDSCLK2_IBEN_MASK   (0x2000U)
#define PMU_MISC1_CLR_LVDSCLK2_IBEN_SHIFT   (13U)
#define PMU_MISC1_CLR_LVDSCLK2_IBEN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_CLR_LVDSCLK2_IBEN_SHIFT)) & PMU_MISC1_CLR_LVDSCLK2_IBEN_MASK)
#define PMU_MISC1_CLR_PFD_480_AUTOGATE_EN_MASK   (0x10000U)
#define PMU_MISC1_CLR_PFD_480_AUTOGATE_EN_SHIFT   (16U)
#define PMU_MISC1_CLR_PFD_480_AUTOGATE_EN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_CLR_PFD_480_AUTOGATE_EN_SHIFT)) & PMU_MISC1_CLR_PFD_480_AUTOGATE_EN_MASK)
#define PMU_MISC1_CLR_PFD_528_AUTOGATE_EN_MASK   (0x20000U)
#define PMU_MISC1_CLR_PFD_528_AUTOGATE_EN_SHIFT   (17U)
#define PMU_MISC1_CLR_PFD_528_AUTOGATE_EN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_CLR_PFD_528_AUTOGATE_EN_SHIFT)) & PMU_MISC1_CLR_PFD_528_AUTOGATE_EN_MASK)
#define PMU_MISC1_CLR_IRQ_TEMPPANIC_MASK   (0x8000000U)
#define PMU_MISC1_CLR_IRQ_TEMPPANIC_SHIFT   (27U)
#define PMU_MISC1_CLR_IRQ_TEMPPANIC(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_CLR_IRQ_TEMPPANIC_SHIFT)) & PMU_MISC1_CLR_IRQ_TEMPPANIC_MASK)
#define PMU_MISC1_CLR_IRQ_TEMPLOW_MASK   (0x10000000U)
#define PMU_MISC1_CLR_IRQ_TEMPLOW_SHIFT   (28U)
#define PMU_MISC1_CLR_IRQ_TEMPLOW(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_CLR_IRQ_TEMPLOW_SHIFT)) & PMU_MISC1_CLR_IRQ_TEMPLOW_MASK)
#define PMU_MISC1_CLR_IRQ_TEMPHIGH_MASK   (0x20000000U)
#define PMU_MISC1_CLR_IRQ_TEMPHIGH_SHIFT   (29U)
#define PMU_MISC1_CLR_IRQ_TEMPHIGH(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_CLR_IRQ_TEMPHIGH_SHIFT)) & PMU_MISC1_CLR_IRQ_TEMPHIGH_MASK)
#define PMU_MISC1_CLR_IRQ_ANA_BO_MASK   (0x40000000U)
#define PMU_MISC1_CLR_IRQ_ANA_BO_SHIFT   (30U)
#define PMU_MISC1_CLR_IRQ_ANA_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_CLR_IRQ_ANA_BO_SHIFT)) & PMU_MISC1_CLR_IRQ_ANA_BO_MASK)
#define PMU_MISC1_CLR_IRQ_DIG_BO_MASK   (0x80000000U)
#define PMU_MISC1_CLR_IRQ_DIG_BO_SHIFT   (31U)
#define PMU_MISC1_CLR_IRQ_DIG_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_CLR_IRQ_DIG_BO_SHIFT)) & PMU_MISC1_CLR_IRQ_DIG_BO_MASK)
MISC1_TOG - Miscellaneous Register 1
#define PMU_MISC1_TOG_LVDS1_CLK_SEL_MASK   (0x1FU)
#define PMU_MISC1_TOG_LVDS1_CLK_SEL_SHIFT   (0U)
#define PMU_MISC1_TOG_LVDS1_CLK_SEL(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_TOG_LVDS1_CLK_SEL_SHIFT)) & PMU_MISC1_TOG_LVDS1_CLK_SEL_MASK)
#define PMU_MISC1_TOG_LVDS2_CLK_SEL_MASK   (0x3E0U)
#define PMU_MISC1_TOG_LVDS2_CLK_SEL_SHIFT   (5U)
#define PMU_MISC1_TOG_LVDS2_CLK_SEL(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_TOG_LVDS2_CLK_SEL_SHIFT)) & PMU_MISC1_TOG_LVDS2_CLK_SEL_MASK)
#define PMU_MISC1_TOG_LVDSCLK1_OBEN_MASK   (0x400U)
#define PMU_MISC1_TOG_LVDSCLK1_OBEN_SHIFT   (10U)
#define PMU_MISC1_TOG_LVDSCLK1_OBEN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_TOG_LVDSCLK1_OBEN_SHIFT)) & PMU_MISC1_TOG_LVDSCLK1_OBEN_MASK)
#define PMU_MISC1_TOG_LVDSCLK2_OBEN_MASK   (0x800U)
#define PMU_MISC1_TOG_LVDSCLK2_OBEN_SHIFT   (11U)
#define PMU_MISC1_TOG_LVDSCLK2_OBEN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_TOG_LVDSCLK2_OBEN_SHIFT)) & PMU_MISC1_TOG_LVDSCLK2_OBEN_MASK)
#define PMU_MISC1_TOG_LVDSCLK1_IBEN_MASK   (0x1000U)
#define PMU_MISC1_TOG_LVDSCLK1_IBEN_SHIFT   (12U)
#define PMU_MISC1_TOG_LVDSCLK1_IBEN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_TOG_LVDSCLK1_IBEN_SHIFT)) & PMU_MISC1_TOG_LVDSCLK1_IBEN_MASK)
#define PMU_MISC1_TOG_LVDSCLK2_IBEN_MASK   (0x2000U)
#define PMU_MISC1_TOG_LVDSCLK2_IBEN_SHIFT   (13U)
#define PMU_MISC1_TOG_LVDSCLK2_IBEN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_TOG_LVDSCLK2_IBEN_SHIFT)) & PMU_MISC1_TOG_LVDSCLK2_IBEN_MASK)
#define PMU_MISC1_TOG_PFD_480_AUTOGATE_EN_MASK   (0x10000U)
#define PMU_MISC1_TOG_PFD_480_AUTOGATE_EN_SHIFT   (16U)
#define PMU_MISC1_TOG_PFD_480_AUTOGATE_EN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_TOG_PFD_480_AUTOGATE_EN_SHIFT)) & PMU_MISC1_TOG_PFD_480_AUTOGATE_EN_MASK)
#define PMU_MISC1_TOG_PFD_528_AUTOGATE_EN_MASK   (0x20000U)
#define PMU_MISC1_TOG_PFD_528_AUTOGATE_EN_SHIFT   (17U)
#define PMU_MISC1_TOG_PFD_528_AUTOGATE_EN(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_TOG_PFD_528_AUTOGATE_EN_SHIFT)) & PMU_MISC1_TOG_PFD_528_AUTOGATE_EN_MASK)
#define PMU_MISC1_TOG_IRQ_TEMPPANIC_MASK   (0x8000000U)
#define PMU_MISC1_TOG_IRQ_TEMPPANIC_SHIFT   (27U)
#define PMU_MISC1_TOG_IRQ_TEMPPANIC(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_TOG_IRQ_TEMPPANIC_SHIFT)) & PMU_MISC1_TOG_IRQ_TEMPPANIC_MASK)
#define PMU_MISC1_TOG_IRQ_TEMPLOW_MASK   (0x10000000U)
#define PMU_MISC1_TOG_IRQ_TEMPLOW_SHIFT   (28U)
#define PMU_MISC1_TOG_IRQ_TEMPLOW(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_TOG_IRQ_TEMPLOW_SHIFT)) & PMU_MISC1_TOG_IRQ_TEMPLOW_MASK)
#define PMU_MISC1_TOG_IRQ_TEMPHIGH_MASK   (0x20000000U)
#define PMU_MISC1_TOG_IRQ_TEMPHIGH_SHIFT   (29U)
#define PMU_MISC1_TOG_IRQ_TEMPHIGH(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_TOG_IRQ_TEMPHIGH_SHIFT)) & PMU_MISC1_TOG_IRQ_TEMPHIGH_MASK)
#define PMU_MISC1_TOG_IRQ_ANA_BO_MASK   (0x40000000U)
#define PMU_MISC1_TOG_IRQ_ANA_BO_SHIFT   (30U)
#define PMU_MISC1_TOG_IRQ_ANA_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_TOG_IRQ_ANA_BO_SHIFT)) & PMU_MISC1_TOG_IRQ_ANA_BO_MASK)
#define PMU_MISC1_TOG_IRQ_DIG_BO_MASK   (0x80000000U)
#define PMU_MISC1_TOG_IRQ_DIG_BO_SHIFT   (31U)
#define PMU_MISC1_TOG_IRQ_DIG_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_TOG_IRQ_DIG_BO_SHIFT)) & PMU_MISC1_TOG_IRQ_DIG_BO_MASK)
MISC2 - Miscellaneous Control Register
#define PMU_MISC2_REG0_BO_OFFSET_MASK   (0x7U)
#define PMU_MISC2_REG0_BO_OFFSET_SHIFT   (0U)
#define PMU_MISC2_REG0_BO_OFFSET(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_REG0_BO_OFFSET_SHIFT)) & PMU_MISC2_REG0_BO_OFFSET_MASK)
#define PMU_MISC2_REG0_BO_STATUS_MASK   (0x8U)
#define PMU_MISC2_REG0_BO_STATUS_SHIFT   (3U)
#define PMU_MISC2_REG0_BO_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_REG0_BO_STATUS_SHIFT)) & PMU_MISC2_REG0_BO_STATUS_MASK)
#define PMU_MISC2_REG0_ENABLE_BO_MASK   (0x20U)
#define PMU_MISC2_REG0_ENABLE_BO_SHIFT   (5U)
#define PMU_MISC2_REG0_ENABLE_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_REG0_ENABLE_BO_SHIFT)) & PMU_MISC2_REG0_ENABLE_BO_MASK)
#define PMU_MISC2_PLL3_disable_MASK   (0x80U)
#define PMU_MISC2_PLL3_disable_SHIFT   (7U)
#define PMU_MISC2_PLL3_disable(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_PLL3_disable_SHIFT)) & PMU_MISC2_PLL3_disable_MASK)
#define PMU_MISC2_REG1_BO_OFFSET_MASK   (0x700U)
#define PMU_MISC2_REG1_BO_OFFSET_SHIFT   (8U)
#define PMU_MISC2_REG1_BO_OFFSET(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_REG1_BO_OFFSET_SHIFT)) & PMU_MISC2_REG1_BO_OFFSET_MASK)
#define PMU_MISC2_REG1_BO_STATUS_MASK   (0x800U)
#define PMU_MISC2_REG1_BO_STATUS_SHIFT   (11U)
#define PMU_MISC2_REG1_BO_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_REG1_BO_STATUS_SHIFT)) & PMU_MISC2_REG1_BO_STATUS_MASK)
#define PMU_MISC2_REG1_ENABLE_BO_MASK   (0x2000U)
#define PMU_MISC2_REG1_ENABLE_BO_SHIFT   (13U)
#define PMU_MISC2_REG1_ENABLE_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_REG1_ENABLE_BO_SHIFT)) & PMU_MISC2_REG1_ENABLE_BO_MASK)
#define PMU_MISC2_AUDIO_DIV_LSB_MASK   (0x8000U)
#define PMU_MISC2_AUDIO_DIV_LSB_SHIFT   (15U)
#define PMU_MISC2_AUDIO_DIV_LSB(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_AUDIO_DIV_LSB_SHIFT)) & PMU_MISC2_AUDIO_DIV_LSB_MASK)
#define PMU_MISC2_REG2_BO_OFFSET_MASK   (0x70000U)
#define PMU_MISC2_REG2_BO_OFFSET_SHIFT   (16U)
#define PMU_MISC2_REG2_BO_OFFSET(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_REG2_BO_OFFSET_SHIFT)) & PMU_MISC2_REG2_BO_OFFSET_MASK)
#define PMU_MISC2_REG2_BO_STATUS_MASK   (0x80000U)
#define PMU_MISC2_REG2_BO_STATUS_SHIFT   (19U)
#define PMU_MISC2_REG2_BO_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_REG2_BO_STATUS_SHIFT)) & PMU_MISC2_REG2_BO_STATUS_MASK)
#define PMU_MISC2_REG2_ENABLE_BO_MASK   (0x200000U)
#define PMU_MISC2_REG2_ENABLE_BO_SHIFT   (21U)
#define PMU_MISC2_REG2_ENABLE_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_REG2_ENABLE_BO_SHIFT)) & PMU_MISC2_REG2_ENABLE_BO_MASK)
#define PMU_MISC2_REG2_OK_MASK   (0x400000U)
#define PMU_MISC2_REG2_OK_SHIFT   (22U)
#define PMU_MISC2_REG2_OK(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_REG2_OK_SHIFT)) & PMU_MISC2_REG2_OK_MASK)
#define PMU_MISC2_AUDIO_DIV_MSB_MASK   (0x800000U)
#define PMU_MISC2_AUDIO_DIV_MSB_SHIFT   (23U)
#define PMU_MISC2_AUDIO_DIV_MSB(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_AUDIO_DIV_MSB_SHIFT)) & PMU_MISC2_AUDIO_DIV_MSB_MASK)
#define PMU_MISC2_REG0_STEP_TIME_MASK   (0x3000000U)
#define PMU_MISC2_REG0_STEP_TIME_SHIFT   (24U)
#define PMU_MISC2_REG0_STEP_TIME(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_REG0_STEP_TIME_SHIFT)) & PMU_MISC2_REG0_STEP_TIME_MASK)
#define PMU_MISC2_REG1_STEP_TIME_MASK   (0xC000000U)
#define PMU_MISC2_REG1_STEP_TIME_SHIFT   (26U)
#define PMU_MISC2_REG1_STEP_TIME(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_REG1_STEP_TIME_SHIFT)) & PMU_MISC2_REG1_STEP_TIME_MASK)
#define PMU_MISC2_REG2_STEP_TIME_MASK   (0x30000000U)
#define PMU_MISC2_REG2_STEP_TIME_SHIFT   (28U)
#define PMU_MISC2_REG2_STEP_TIME(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_REG2_STEP_TIME_SHIFT)) & PMU_MISC2_REG2_STEP_TIME_MASK)
#define PMU_MISC2_VIDEO_DIV_MASK   (0xC0000000U)
#define PMU_MISC2_VIDEO_DIV_SHIFT   (30U)
#define PMU_MISC2_VIDEO_DIV(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_VIDEO_DIV_SHIFT)) & PMU_MISC2_VIDEO_DIV_MASK)
MISC2_SET - Miscellaneous Control Register
#define PMU_MISC2_SET_REG0_BO_OFFSET_MASK   (0x7U)
#define PMU_MISC2_SET_REG0_BO_OFFSET_SHIFT   (0U)
#define PMU_MISC2_SET_REG0_BO_OFFSET(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_REG0_BO_OFFSET_SHIFT)) & PMU_MISC2_SET_REG0_BO_OFFSET_MASK)
#define PMU_MISC2_SET_REG0_BO_STATUS_MASK   (0x8U)
#define PMU_MISC2_SET_REG0_BO_STATUS_SHIFT   (3U)
#define PMU_MISC2_SET_REG0_BO_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_REG0_BO_STATUS_SHIFT)) & PMU_MISC2_SET_REG0_BO_STATUS_MASK)
#define PMU_MISC2_SET_REG0_ENABLE_BO_MASK   (0x20U)
#define PMU_MISC2_SET_REG0_ENABLE_BO_SHIFT   (5U)
#define PMU_MISC2_SET_REG0_ENABLE_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_REG0_ENABLE_BO_SHIFT)) & PMU_MISC2_SET_REG0_ENABLE_BO_MASK)
#define PMU_MISC2_SET_PLL3_disable_MASK   (0x80U)
#define PMU_MISC2_SET_PLL3_disable_SHIFT   (7U)
#define PMU_MISC2_SET_PLL3_disable(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_PLL3_disable_SHIFT)) & PMU_MISC2_SET_PLL3_disable_MASK)
#define PMU_MISC2_SET_REG1_BO_OFFSET_MASK   (0x700U)
#define PMU_MISC2_SET_REG1_BO_OFFSET_SHIFT   (8U)
#define PMU_MISC2_SET_REG1_BO_OFFSET(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_REG1_BO_OFFSET_SHIFT)) & PMU_MISC2_SET_REG1_BO_OFFSET_MASK)
#define PMU_MISC2_SET_REG1_BO_STATUS_MASK   (0x800U)
#define PMU_MISC2_SET_REG1_BO_STATUS_SHIFT   (11U)
#define PMU_MISC2_SET_REG1_BO_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_REG1_BO_STATUS_SHIFT)) & PMU_MISC2_SET_REG1_BO_STATUS_MASK)
#define PMU_MISC2_SET_REG1_ENABLE_BO_MASK   (0x2000U)
#define PMU_MISC2_SET_REG1_ENABLE_BO_SHIFT   (13U)
#define PMU_MISC2_SET_REG1_ENABLE_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_REG1_ENABLE_BO_SHIFT)) & PMU_MISC2_SET_REG1_ENABLE_BO_MASK)
#define PMU_MISC2_SET_AUDIO_DIV_LSB_MASK   (0x8000U)
#define PMU_MISC2_SET_AUDIO_DIV_LSB_SHIFT   (15U)
#define PMU_MISC2_SET_AUDIO_DIV_LSB(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_AUDIO_DIV_LSB_SHIFT)) & PMU_MISC2_SET_AUDIO_DIV_LSB_MASK)
#define PMU_MISC2_SET_REG2_BO_OFFSET_MASK   (0x70000U)
#define PMU_MISC2_SET_REG2_BO_OFFSET_SHIFT   (16U)
#define PMU_MISC2_SET_REG2_BO_OFFSET(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_REG2_BO_OFFSET_SHIFT)) & PMU_MISC2_SET_REG2_BO_OFFSET_MASK)
#define PMU_MISC2_SET_REG2_BO_STATUS_MASK   (0x80000U)
#define PMU_MISC2_SET_REG2_BO_STATUS_SHIFT   (19U)
#define PMU_MISC2_SET_REG2_BO_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_REG2_BO_STATUS_SHIFT)) & PMU_MISC2_SET_REG2_BO_STATUS_MASK)
#define PMU_MISC2_SET_REG2_ENABLE_BO_MASK   (0x200000U)
#define PMU_MISC2_SET_REG2_ENABLE_BO_SHIFT   (21U)
#define PMU_MISC2_SET_REG2_ENABLE_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_REG2_ENABLE_BO_SHIFT)) & PMU_MISC2_SET_REG2_ENABLE_BO_MASK)
#define PMU_MISC2_SET_REG2_OK_MASK   (0x400000U)
#define PMU_MISC2_SET_REG2_OK_SHIFT   (22U)
#define PMU_MISC2_SET_REG2_OK(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_REG2_OK_SHIFT)) & PMU_MISC2_SET_REG2_OK_MASK)
#define PMU_MISC2_SET_AUDIO_DIV_MSB_MASK   (0x800000U)
#define PMU_MISC2_SET_AUDIO_DIV_MSB_SHIFT   (23U)
#define PMU_MISC2_SET_AUDIO_DIV_MSB(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_AUDIO_DIV_MSB_SHIFT)) & PMU_MISC2_SET_AUDIO_DIV_MSB_MASK)
#define PMU_MISC2_SET_REG0_STEP_TIME_MASK   (0x3000000U)
#define PMU_MISC2_SET_REG0_STEP_TIME_SHIFT   (24U)
#define PMU_MISC2_SET_REG0_STEP_TIME(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_REG0_STEP_TIME_SHIFT)) & PMU_MISC2_SET_REG0_STEP_TIME_MASK)
#define PMU_MISC2_SET_REG1_STEP_TIME_MASK   (0xC000000U)
#define PMU_MISC2_SET_REG1_STEP_TIME_SHIFT   (26U)
#define PMU_MISC2_SET_REG1_STEP_TIME(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_REG1_STEP_TIME_SHIFT)) & PMU_MISC2_SET_REG1_STEP_TIME_MASK)
#define PMU_MISC2_SET_REG2_STEP_TIME_MASK   (0x30000000U)
#define PMU_MISC2_SET_REG2_STEP_TIME_SHIFT   (28U)
#define PMU_MISC2_SET_REG2_STEP_TIME(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_REG2_STEP_TIME_SHIFT)) & PMU_MISC2_SET_REG2_STEP_TIME_MASK)
#define PMU_MISC2_SET_VIDEO_DIV_MASK   (0xC0000000U)
#define PMU_MISC2_SET_VIDEO_DIV_SHIFT   (30U)
#define PMU_MISC2_SET_VIDEO_DIV(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_VIDEO_DIV_SHIFT)) & PMU_MISC2_SET_VIDEO_DIV_MASK)
MISC2_CLR - Miscellaneous Control Register
#define PMU_MISC2_CLR_REG0_BO_OFFSET_MASK   (0x7U)
#define PMU_MISC2_CLR_REG0_BO_OFFSET_SHIFT   (0U)
#define PMU_MISC2_CLR_REG0_BO_OFFSET(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_REG0_BO_OFFSET_SHIFT)) & PMU_MISC2_CLR_REG0_BO_OFFSET_MASK)
#define PMU_MISC2_CLR_REG0_BO_STATUS_MASK   (0x8U)
#define PMU_MISC2_CLR_REG0_BO_STATUS_SHIFT   (3U)
#define PMU_MISC2_CLR_REG0_BO_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_REG0_BO_STATUS_SHIFT)) & PMU_MISC2_CLR_REG0_BO_STATUS_MASK)
#define PMU_MISC2_CLR_REG0_ENABLE_BO_MASK   (0x20U)
#define PMU_MISC2_CLR_REG0_ENABLE_BO_SHIFT   (5U)
#define PMU_MISC2_CLR_REG0_ENABLE_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_REG0_ENABLE_BO_SHIFT)) & PMU_MISC2_CLR_REG0_ENABLE_BO_MASK)
#define PMU_MISC2_CLR_PLL3_disable_MASK   (0x80U)
#define PMU_MISC2_CLR_PLL3_disable_SHIFT   (7U)
#define PMU_MISC2_CLR_PLL3_disable(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_PLL3_disable_SHIFT)) & PMU_MISC2_CLR_PLL3_disable_MASK)
#define PMU_MISC2_CLR_REG1_BO_OFFSET_MASK   (0x700U)
#define PMU_MISC2_CLR_REG1_BO_OFFSET_SHIFT   (8U)
#define PMU_MISC2_CLR_REG1_BO_OFFSET(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_REG1_BO_OFFSET_SHIFT)) & PMU_MISC2_CLR_REG1_BO_OFFSET_MASK)
#define PMU_MISC2_CLR_REG1_BO_STATUS_MASK   (0x800U)
#define PMU_MISC2_CLR_REG1_BO_STATUS_SHIFT   (11U)
#define PMU_MISC2_CLR_REG1_BO_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_REG1_BO_STATUS_SHIFT)) & PMU_MISC2_CLR_REG1_BO_STATUS_MASK)
#define PMU_MISC2_CLR_REG1_ENABLE_BO_MASK   (0x2000U)
#define PMU_MISC2_CLR_REG1_ENABLE_BO_SHIFT   (13U)
#define PMU_MISC2_CLR_REG1_ENABLE_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_REG1_ENABLE_BO_SHIFT)) & PMU_MISC2_CLR_REG1_ENABLE_BO_MASK)
#define PMU_MISC2_CLR_AUDIO_DIV_LSB_MASK   (0x8000U)
#define PMU_MISC2_CLR_AUDIO_DIV_LSB_SHIFT   (15U)
#define PMU_MISC2_CLR_AUDIO_DIV_LSB(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_AUDIO_DIV_LSB_SHIFT)) & PMU_MISC2_CLR_AUDIO_DIV_LSB_MASK)
#define PMU_MISC2_CLR_REG2_BO_OFFSET_MASK   (0x70000U)
#define PMU_MISC2_CLR_REG2_BO_OFFSET_SHIFT   (16U)
#define PMU_MISC2_CLR_REG2_BO_OFFSET(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_REG2_BO_OFFSET_SHIFT)) & PMU_MISC2_CLR_REG2_BO_OFFSET_MASK)
#define PMU_MISC2_CLR_REG2_BO_STATUS_MASK   (0x80000U)
#define PMU_MISC2_CLR_REG2_BO_STATUS_SHIFT   (19U)
#define PMU_MISC2_CLR_REG2_BO_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_REG2_BO_STATUS_SHIFT)) & PMU_MISC2_CLR_REG2_BO_STATUS_MASK)
#define PMU_MISC2_CLR_REG2_ENABLE_BO_MASK   (0x200000U)
#define PMU_MISC2_CLR_REG2_ENABLE_BO_SHIFT   (21U)
#define PMU_MISC2_CLR_REG2_ENABLE_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_REG2_ENABLE_BO_SHIFT)) & PMU_MISC2_CLR_REG2_ENABLE_BO_MASK)
#define PMU_MISC2_CLR_REG2_OK_MASK   (0x400000U)
#define PMU_MISC2_CLR_REG2_OK_SHIFT   (22U)
#define PMU_MISC2_CLR_REG2_OK(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_REG2_OK_SHIFT)) & PMU_MISC2_CLR_REG2_OK_MASK)
#define PMU_MISC2_CLR_AUDIO_DIV_MSB_MASK   (0x800000U)
#define PMU_MISC2_CLR_AUDIO_DIV_MSB_SHIFT   (23U)
#define PMU_MISC2_CLR_AUDIO_DIV_MSB(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_AUDIO_DIV_MSB_SHIFT)) & PMU_MISC2_CLR_AUDIO_DIV_MSB_MASK)
#define PMU_MISC2_CLR_REG0_STEP_TIME_MASK   (0x3000000U)
#define PMU_MISC2_CLR_REG0_STEP_TIME_SHIFT   (24U)
#define PMU_MISC2_CLR_REG0_STEP_TIME(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_REG0_STEP_TIME_SHIFT)) & PMU_MISC2_CLR_REG0_STEP_TIME_MASK)
#define PMU_MISC2_CLR_REG1_STEP_TIME_MASK   (0xC000000U)
#define PMU_MISC2_CLR_REG1_STEP_TIME_SHIFT   (26U)
#define PMU_MISC2_CLR_REG1_STEP_TIME(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_REG1_STEP_TIME_SHIFT)) & PMU_MISC2_CLR_REG1_STEP_TIME_MASK)
#define PMU_MISC2_CLR_REG2_STEP_TIME_MASK   (0x30000000U)
#define PMU_MISC2_CLR_REG2_STEP_TIME_SHIFT   (28U)
#define PMU_MISC2_CLR_REG2_STEP_TIME(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_REG2_STEP_TIME_SHIFT)) & PMU_MISC2_CLR_REG2_STEP_TIME_MASK)
#define PMU_MISC2_CLR_VIDEO_DIV_MASK   (0xC0000000U)
#define PMU_MISC2_CLR_VIDEO_DIV_SHIFT   (30U)
#define PMU_MISC2_CLR_VIDEO_DIV(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_VIDEO_DIV_SHIFT)) & PMU_MISC2_CLR_VIDEO_DIV_MASK)
MISC2_TOG - Miscellaneous Control Register
#define PMU_MISC2_TOG_REG0_BO_OFFSET_MASK   (0x7U)
#define PMU_MISC2_TOG_REG0_BO_OFFSET_SHIFT   (0U)
#define PMU_MISC2_TOG_REG0_BO_OFFSET(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_REG0_BO_OFFSET_SHIFT)) & PMU_MISC2_TOG_REG0_BO_OFFSET_MASK)
#define PMU_MISC2_TOG_REG0_BO_STATUS_MASK   (0x8U)
#define PMU_MISC2_TOG_REG0_BO_STATUS_SHIFT   (3U)
#define PMU_MISC2_TOG_REG0_BO_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_REG0_BO_STATUS_SHIFT)) & PMU_MISC2_TOG_REG0_BO_STATUS_MASK)
#define PMU_MISC2_TOG_REG0_ENABLE_BO_MASK   (0x20U)
#define PMU_MISC2_TOG_REG0_ENABLE_BO_SHIFT   (5U)
#define PMU_MISC2_TOG_REG0_ENABLE_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_REG0_ENABLE_BO_SHIFT)) & PMU_MISC2_TOG_REG0_ENABLE_BO_MASK)
#define PMU_MISC2_TOG_PLL3_disable_MASK   (0x80U)
#define PMU_MISC2_TOG_PLL3_disable_SHIFT   (7U)
#define PMU_MISC2_TOG_PLL3_disable(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_PLL3_disable_SHIFT)) & PMU_MISC2_TOG_PLL3_disable_MASK)
#define PMU_MISC2_TOG_REG1_BO_OFFSET_MASK   (0x700U)
#define PMU_MISC2_TOG_REG1_BO_OFFSET_SHIFT   (8U)
#define PMU_MISC2_TOG_REG1_BO_OFFSET(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_REG1_BO_OFFSET_SHIFT)) & PMU_MISC2_TOG_REG1_BO_OFFSET_MASK)
#define PMU_MISC2_TOG_REG1_BO_STATUS_MASK   (0x800U)
#define PMU_MISC2_TOG_REG1_BO_STATUS_SHIFT   (11U)
#define PMU_MISC2_TOG_REG1_BO_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_REG1_BO_STATUS_SHIFT)) & PMU_MISC2_TOG_REG1_BO_STATUS_MASK)
#define PMU_MISC2_TOG_REG1_ENABLE_BO_MASK   (0x2000U)
#define PMU_MISC2_TOG_REG1_ENABLE_BO_SHIFT   (13U)
#define PMU_MISC2_TOG_REG1_ENABLE_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_REG1_ENABLE_BO_SHIFT)) & PMU_MISC2_TOG_REG1_ENABLE_BO_MASK)
#define PMU_MISC2_TOG_AUDIO_DIV_LSB_MASK   (0x8000U)
#define PMU_MISC2_TOG_AUDIO_DIV_LSB_SHIFT   (15U)
#define PMU_MISC2_TOG_AUDIO_DIV_LSB(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_AUDIO_DIV_LSB_SHIFT)) & PMU_MISC2_TOG_AUDIO_DIV_LSB_MASK)
#define PMU_MISC2_TOG_REG2_BO_OFFSET_MASK   (0x70000U)
#define PMU_MISC2_TOG_REG2_BO_OFFSET_SHIFT   (16U)
#define PMU_MISC2_TOG_REG2_BO_OFFSET(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_REG2_BO_OFFSET_SHIFT)) & PMU_MISC2_TOG_REG2_BO_OFFSET_MASK)
#define PMU_MISC2_TOG_REG2_BO_STATUS_MASK   (0x80000U)
#define PMU_MISC2_TOG_REG2_BO_STATUS_SHIFT   (19U)
#define PMU_MISC2_TOG_REG2_BO_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_REG2_BO_STATUS_SHIFT)) & PMU_MISC2_TOG_REG2_BO_STATUS_MASK)
#define PMU_MISC2_TOG_REG2_ENABLE_BO_MASK   (0x200000U)
#define PMU_MISC2_TOG_REG2_ENABLE_BO_SHIFT   (21U)
#define PMU_MISC2_TOG_REG2_ENABLE_BO(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_REG2_ENABLE_BO_SHIFT)) & PMU_MISC2_TOG_REG2_ENABLE_BO_MASK)
#define PMU_MISC2_TOG_REG2_OK_MASK   (0x400000U)
#define PMU_MISC2_TOG_REG2_OK_SHIFT   (22U)
#define PMU_MISC2_TOG_REG2_OK(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_REG2_OK_SHIFT)) & PMU_MISC2_TOG_REG2_OK_MASK)
#define PMU_MISC2_TOG_AUDIO_DIV_MSB_MASK   (0x800000U)
#define PMU_MISC2_TOG_AUDIO_DIV_MSB_SHIFT   (23U)
#define PMU_MISC2_TOG_AUDIO_DIV_MSB(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_AUDIO_DIV_MSB_SHIFT)) & PMU_MISC2_TOG_AUDIO_DIV_MSB_MASK)
#define PMU_MISC2_TOG_REG0_STEP_TIME_MASK   (0x3000000U)
#define PMU_MISC2_TOG_REG0_STEP_TIME_SHIFT   (24U)
#define PMU_MISC2_TOG_REG0_STEP_TIME(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_REG0_STEP_TIME_SHIFT)) & PMU_MISC2_TOG_REG0_STEP_TIME_MASK)
#define PMU_MISC2_TOG_REG1_STEP_TIME_MASK   (0xC000000U)
#define PMU_MISC2_TOG_REG1_STEP_TIME_SHIFT   (26U)
#define PMU_MISC2_TOG_REG1_STEP_TIME(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_REG1_STEP_TIME_SHIFT)) & PMU_MISC2_TOG_REG1_STEP_TIME_MASK)
#define PMU_MISC2_TOG_REG2_STEP_TIME_MASK   (0x30000000U)
#define PMU_MISC2_TOG_REG2_STEP_TIME_SHIFT   (28U)
#define PMU_MISC2_TOG_REG2_STEP_TIME(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_REG2_STEP_TIME_SHIFT)) & PMU_MISC2_TOG_REG2_STEP_TIME_MASK)
#define PMU_MISC2_TOG_VIDEO_DIV_MASK   (0xC0000000U)
#define PMU_MISC2_TOG_VIDEO_DIV_SHIFT   (30U)
#define PMU_MISC2_TOG_VIDEO_DIV(x)   (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_VIDEO_DIV_SHIFT)) & PMU_MISC2_TOG_VIDEO_DIV_MASK)
◆ PMU_MISC0_CLKGATE_CTRL
#define PMU_MISC0_CLKGATE_CTRL (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLKGATE_CTRL_SHIFT)) & PMU_MISC0_CLKGATE_CTRL_MASK)
CLKGATE_CTRL 0b0..Allow the logic to automatically gate the clock when the XTAL is powered down. 0b1..Prevent the logic from ever gating off the clock.
◆ PMU_MISC0_CLKGATE_DELAY
#define PMU_MISC0_CLKGATE_DELAY (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLKGATE_DELAY_SHIFT)) & PMU_MISC0_CLKGATE_DELAY_MASK)
CLKGATE_DELAY 0b000..0.5ms 0b001..1.0ms 0b010..2.0ms 0b011..3.0ms 0b100..4.0ms 0b101..5.0ms 0b110..6.0ms 0b111..7.0ms
◆ PMU_MISC0_CLR_CLKGATE_CTRL
#define PMU_MISC0_CLR_CLKGATE_CTRL (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLR_CLKGATE_CTRL_SHIFT)) & PMU_MISC0_CLR_CLKGATE_CTRL_MASK)
◆ PMU_MISC0_CLR_CLKGATE_DELAY
#define PMU_MISC0_CLR_CLKGATE_DELAY (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLR_CLKGATE_DELAY_SHIFT)) & PMU_MISC0_CLR_CLKGATE_DELAY_MASK)
◆ PMU_MISC0_CLR_DISCON_HIGH_SNVS
#define PMU_MISC0_CLR_DISCON_HIGH_SNVS (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLR_DISCON_HIGH_SNVS_SHIFT)) & PMU_MISC0_CLR_DISCON_HIGH_SNVS_MASK)
DISCON_HIGH_SNVS 0b0..Turn on the switch 0b1..Turn off the switch
◆ PMU_MISC0_CLR_OSC_I
#define PMU_MISC0_CLR_OSC_I (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLR_OSC_I_SHIFT)) & PMU_MISC0_CLR_OSC_I_MASK)
OSC_I 0b00..Nominal 0b01..Decrease current by 12.5% 0b10..Decrease current by 25.0% 0b11..Decrease current by 37.5%
◆ PMU_MISC0_CLR_REFTOP_SELFBIASOFF
#define PMU_MISC0_CLR_REFTOP_SELFBIASOFF (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLR_REFTOP_SELFBIASOFF_SHIFT)) & PMU_MISC0_CLR_REFTOP_SELFBIASOFF_MASK)
REFTOP_SELFBIASOFF 0b0..Uses coarse bias currents for startup 0b1..Uses bandgap-based bias currents for best performance.
◆ PMU_MISC0_CLR_REFTOP_VBGADJ
#define PMU_MISC0_CLR_REFTOP_VBGADJ (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLR_REFTOP_VBGADJ_SHIFT)) & PMU_MISC0_CLR_REFTOP_VBGADJ_MASK)
REFTOP_VBGADJ 0b000..Nominal VBG 0b001..VBG+0.78% 0b010..VBG+1.56% 0b011..VBG+2.34% 0b100..VBG-0.78% 0b101..VBG-1.56% 0b110..VBG-2.34% 0b111..VBG-3.12%
◆ PMU_MISC0_CLR_RTC_XTAL_SOURCE
#define PMU_MISC0_CLR_RTC_XTAL_SOURCE (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLR_RTC_XTAL_SOURCE_SHIFT)) & PMU_MISC0_CLR_RTC_XTAL_SOURCE_MASK)
RTC_XTAL_SOURCE 0b0..Internal ring oscillator 0b1..RTC_XTAL
◆ PMU_MISC0_CLR_STOP_MODE_CONFIG
#define PMU_MISC0_CLR_STOP_MODE_CONFIG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLR_STOP_MODE_CONFIG_SHIFT)) & PMU_MISC0_CLR_STOP_MODE_CONFIG_MASK)
STOP_MODE_CONFIG 0b00..SUSPEND (DSM) 0b01..Analog regulators are ON. 0b10..STOP (lower power) 0b11..STOP (very lower power)
◆ PMU_MISC0_CLR_VID_PLL_PREDIV
#define PMU_MISC0_CLR_VID_PLL_PREDIV (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_CLR_VID_PLL_PREDIV_SHIFT)) & PMU_MISC0_CLR_VID_PLL_PREDIV_MASK)
VID_PLL_PREDIV 0b0..Divide by 1 0b1..Divide by 2
◆ PMU_MISC0_DISCON_HIGH_SNVS
#define PMU_MISC0_DISCON_HIGH_SNVS (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_DISCON_HIGH_SNVS_SHIFT)) & PMU_MISC0_DISCON_HIGH_SNVS_MASK)
◆ PMU_MISC0_OSC_I
#define PMU_MISC0_OSC_I (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_OSC_I_SHIFT)) & PMU_MISC0_OSC_I_MASK)
◆ PMU_MISC0_REFTOP_SELFBIASOFF
#define PMU_MISC0_REFTOP_SELFBIASOFF (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_REFTOP_SELFBIASOFF_SHIFT)) & PMU_MISC0_REFTOP_SELFBIASOFF_MASK)
◆ PMU_MISC0_REFTOP_VBGADJ
#define PMU_MISC0_REFTOP_VBGADJ (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_REFTOP_VBGADJ_SHIFT)) & PMU_MISC0_REFTOP_VBGADJ_MASK)
◆ PMU_MISC0_RTC_XTAL_SOURCE
#define PMU_MISC0_RTC_XTAL_SOURCE (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_RTC_XTAL_SOURCE_SHIFT)) & PMU_MISC0_RTC_XTAL_SOURCE_MASK)
◆ PMU_MISC0_SET_CLKGATE_CTRL
#define PMU_MISC0_SET_CLKGATE_CTRL (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_SET_CLKGATE_CTRL_SHIFT)) & PMU_MISC0_SET_CLKGATE_CTRL_MASK)
◆ PMU_MISC0_SET_CLKGATE_DELAY
#define PMU_MISC0_SET_CLKGATE_DELAY (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_SET_CLKGATE_DELAY_SHIFT)) & PMU_MISC0_SET_CLKGATE_DELAY_MASK)
◆ PMU_MISC0_SET_DISCON_HIGH_SNVS
#define PMU_MISC0_SET_DISCON_HIGH_SNVS (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_SET_DISCON_HIGH_SNVS_SHIFT)) & PMU_MISC0_SET_DISCON_HIGH_SNVS_MASK)
◆ PMU_MISC0_SET_OSC_I
#define PMU_MISC0_SET_OSC_I (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_SET_OSC_I_SHIFT)) & PMU_MISC0_SET_OSC_I_MASK)
◆ PMU_MISC0_SET_REFTOP_SELFBIASOFF
#define PMU_MISC0_SET_REFTOP_SELFBIASOFF (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_SET_REFTOP_SELFBIASOFF_SHIFT)) & PMU_MISC0_SET_REFTOP_SELFBIASOFF_MASK)
◆ PMU_MISC0_SET_REFTOP_VBGADJ
#define PMU_MISC0_SET_REFTOP_VBGADJ (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_SET_REFTOP_VBGADJ_SHIFT)) & PMU_MISC0_SET_REFTOP_VBGADJ_MASK)
◆ PMU_MISC0_SET_RTC_XTAL_SOURCE
#define PMU_MISC0_SET_RTC_XTAL_SOURCE (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_SET_RTC_XTAL_SOURCE_SHIFT)) & PMU_MISC0_SET_RTC_XTAL_SOURCE_MASK)
◆ PMU_MISC0_SET_STOP_MODE_CONFIG
#define PMU_MISC0_SET_STOP_MODE_CONFIG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_SET_STOP_MODE_CONFIG_SHIFT)) & PMU_MISC0_SET_STOP_MODE_CONFIG_MASK)
◆ PMU_MISC0_SET_VID_PLL_PREDIV
#define PMU_MISC0_SET_VID_PLL_PREDIV (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_SET_VID_PLL_PREDIV_SHIFT)) & PMU_MISC0_SET_VID_PLL_PREDIV_MASK)
◆ PMU_MISC0_STOP_MODE_CONFIG
#define PMU_MISC0_STOP_MODE_CONFIG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_STOP_MODE_CONFIG_SHIFT)) & PMU_MISC0_STOP_MODE_CONFIG_MASK)
◆ PMU_MISC0_TOG_CLKGATE_CTRL
#define PMU_MISC0_TOG_CLKGATE_CTRL (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_TOG_CLKGATE_CTRL_SHIFT)) & PMU_MISC0_TOG_CLKGATE_CTRL_MASK)
◆ PMU_MISC0_TOG_CLKGATE_DELAY
#define PMU_MISC0_TOG_CLKGATE_DELAY (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_TOG_CLKGATE_DELAY_SHIFT)) & PMU_MISC0_TOG_CLKGATE_DELAY_MASK)
◆ PMU_MISC0_TOG_DISCON_HIGH_SNVS
#define PMU_MISC0_TOG_DISCON_HIGH_SNVS (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_TOG_DISCON_HIGH_SNVS_SHIFT)) & PMU_MISC0_TOG_DISCON_HIGH_SNVS_MASK)
◆ PMU_MISC0_TOG_OSC_I
#define PMU_MISC0_TOG_OSC_I (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_TOG_OSC_I_SHIFT)) & PMU_MISC0_TOG_OSC_I_MASK)
◆ PMU_MISC0_TOG_REFTOP_SELFBIASOFF
#define PMU_MISC0_TOG_REFTOP_SELFBIASOFF (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_TOG_REFTOP_SELFBIASOFF_SHIFT)) & PMU_MISC0_TOG_REFTOP_SELFBIASOFF_MASK)
◆ PMU_MISC0_TOG_REFTOP_VBGADJ
#define PMU_MISC0_TOG_REFTOP_VBGADJ (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_TOG_REFTOP_VBGADJ_SHIFT)) & PMU_MISC0_TOG_REFTOP_VBGADJ_MASK)
◆ PMU_MISC0_TOG_RTC_XTAL_SOURCE
#define PMU_MISC0_TOG_RTC_XTAL_SOURCE (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_TOG_RTC_XTAL_SOURCE_SHIFT)) & PMU_MISC0_TOG_RTC_XTAL_SOURCE_MASK)
◆ PMU_MISC0_TOG_STOP_MODE_CONFIG
#define PMU_MISC0_TOG_STOP_MODE_CONFIG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_TOG_STOP_MODE_CONFIG_SHIFT)) & PMU_MISC0_TOG_STOP_MODE_CONFIG_MASK)
◆ PMU_MISC0_TOG_VID_PLL_PREDIV
#define PMU_MISC0_TOG_VID_PLL_PREDIV (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_TOG_VID_PLL_PREDIV_SHIFT)) & PMU_MISC0_TOG_VID_PLL_PREDIV_MASK)
◆ PMU_MISC0_VID_PLL_PREDIV
#define PMU_MISC0_VID_PLL_PREDIV (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC0_VID_PLL_PREDIV_SHIFT)) & PMU_MISC0_VID_PLL_PREDIV_MASK)
◆ PMU_MISC1_CLR_LVDS1_CLK_SEL
#define PMU_MISC1_CLR_LVDS1_CLK_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_CLR_LVDS1_CLK_SEL_SHIFT)) & PMU_MISC1_CLR_LVDS1_CLK_SEL_MASK)
LVDS1_CLK_SEL 0b00000..ARM PLL 0b00001..System PLL 0b00010..ref_pfd4_clk == pll2_pfd0_clk 0b00011..ref_pfd5_clk == pll2_pfd1_clk 0b00100..ref_pfd6_clk == pll2_pfd2_clk 0b00101..ref_pfd7_clk == pll2_pfd3_clk 0b00110..Audio PLL 0b00111..Video PLL 0b01001..ethernet ref clock (ENET_PLL) 0b01100..USB1 PLL clock 0b01101..USB2 PLL clock 0b01110..ref_pfd0_clk == pll3_pfd0_clk 0b01111..ref_pfd1_clk == pll3_pfd1_clk 0b10000..ref_pfd2_clk == pll3_pfd2_clk 0b10001..ref_pfd3_clk == pll3_pfd3_clk 0b10010..xtal (24M)
◆ PMU_MISC1_CLR_LVDS2_CLK_SEL
#define PMU_MISC1_CLR_LVDS2_CLK_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_CLR_LVDS2_CLK_SEL_SHIFT)) & PMU_MISC1_CLR_LVDS2_CLK_SEL_MASK)
LVDS2_CLK_SEL 0b00000..ARM PLL 0b00001..System PLL 0b00010..ref_pfd4_clk == pll2_pfd0_clk 0b00011..ref_pfd5_clk == pll2_pfd1_clk 0b00100..ref_pfd6_clk == pll2_pfd2_clk 0b00101..ref_pfd7_clk == pll2_pfd3_clk 0b00110..Audio PLL 0b00111..Video PLL 0b01000..MLB PLL 0b01001..ethernet ref clock (ENET_PLL) 0b01010..PCIe ref clock (125M) 0b01011..SATA ref clock (100M) 0b01100..USB1 PLL clock 0b01101..USB2 PLL clock 0b01110..ref_pfd0_clk == pll3_pfd0_clk 0b01111..ref_pfd1_clk == pll3_pfd1_clk 0b10000..ref_pfd2_clk == pll3_pfd2_clk 0b10001..ref_pfd3_clk == pll3_pfd3_clk 0b10010..xtal (24M) 0b10011..LVDS1 (loopback) 0b10100..LVDS2 (not useful)
◆ PMU_MISC1_LVDS1_CLK_SEL
#define PMU_MISC1_LVDS1_CLK_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_LVDS1_CLK_SEL_SHIFT)) & PMU_MISC1_LVDS1_CLK_SEL_MASK)
◆ PMU_MISC1_LVDS2_CLK_SEL
#define PMU_MISC1_LVDS2_CLK_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_LVDS2_CLK_SEL_SHIFT)) & PMU_MISC1_LVDS2_CLK_SEL_MASK)
◆ PMU_MISC1_SET_LVDS1_CLK_SEL
#define PMU_MISC1_SET_LVDS1_CLK_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_SET_LVDS1_CLK_SEL_SHIFT)) & PMU_MISC1_SET_LVDS1_CLK_SEL_MASK)
◆ PMU_MISC1_SET_LVDS2_CLK_SEL
#define PMU_MISC1_SET_LVDS2_CLK_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_SET_LVDS2_CLK_SEL_SHIFT)) & PMU_MISC1_SET_LVDS2_CLK_SEL_MASK)
◆ PMU_MISC1_TOG_LVDS1_CLK_SEL
#define PMU_MISC1_TOG_LVDS1_CLK_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_TOG_LVDS1_CLK_SEL_SHIFT)) & PMU_MISC1_TOG_LVDS1_CLK_SEL_MASK)
◆ PMU_MISC1_TOG_LVDS2_CLK_SEL
#define PMU_MISC1_TOG_LVDS2_CLK_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC1_TOG_LVDS2_CLK_SEL_SHIFT)) & PMU_MISC1_TOG_LVDS2_CLK_SEL_MASK)
◆ PMU_MISC2_AUDIO_DIV_LSB
#define PMU_MISC2_AUDIO_DIV_LSB (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_AUDIO_DIV_LSB_SHIFT)) & PMU_MISC2_AUDIO_DIV_LSB_MASK)
AUDIO_DIV_LSB 0b0..divide by 1 (Default) 0b1..divide by 2
◆ PMU_MISC2_AUDIO_DIV_MSB
#define PMU_MISC2_AUDIO_DIV_MSB (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_AUDIO_DIV_MSB_SHIFT)) & PMU_MISC2_AUDIO_DIV_MSB_MASK)
AUDIO_DIV_MSB 0b0..divide by 1 (Default) 0b1..divide by 2
◆ PMU_MISC2_CLR_AUDIO_DIV_LSB
#define PMU_MISC2_CLR_AUDIO_DIV_LSB (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_AUDIO_DIV_LSB_SHIFT)) & PMU_MISC2_CLR_AUDIO_DIV_LSB_MASK)
◆ PMU_MISC2_CLR_AUDIO_DIV_MSB
#define PMU_MISC2_CLR_AUDIO_DIV_MSB (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_AUDIO_DIV_MSB_SHIFT)) & PMU_MISC2_CLR_AUDIO_DIV_MSB_MASK)
◆ PMU_MISC2_CLR_REG0_BO_OFFSET
#define PMU_MISC2_CLR_REG0_BO_OFFSET (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_REG0_BO_OFFSET_SHIFT)) & PMU_MISC2_CLR_REG0_BO_OFFSET_MASK)
REG0_BO_OFFSET 0b100..Brownout offset = 0.100V 0b111..Brownout offset = 0.175V
◆ PMU_MISC2_CLR_REG0_BO_STATUS
#define PMU_MISC2_CLR_REG0_BO_STATUS (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_REG0_BO_STATUS_SHIFT)) & PMU_MISC2_CLR_REG0_BO_STATUS_MASK)
REG0_BO_STATUS 0b1..Brownout, supply is below target minus brownout offset.
◆ PMU_MISC2_CLR_REG0_STEP_TIME
#define PMU_MISC2_CLR_REG0_STEP_TIME (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_REG0_STEP_TIME_SHIFT)) & PMU_MISC2_CLR_REG0_STEP_TIME_MASK)
REG0_STEP_TIME 0b00..64 0b01..128 0b10..256 0b11..512
◆ PMU_MISC2_CLR_REG1_BO_OFFSET
#define PMU_MISC2_CLR_REG1_BO_OFFSET (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_REG1_BO_OFFSET_SHIFT)) & PMU_MISC2_CLR_REG1_BO_OFFSET_MASK)
REG1_BO_OFFSET 0b100..Brownout offset = 0.100V 0b111..Brownout offset = 0.175V
◆ PMU_MISC2_CLR_REG1_BO_STATUS
#define PMU_MISC2_CLR_REG1_BO_STATUS (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_REG1_BO_STATUS_SHIFT)) & PMU_MISC2_CLR_REG1_BO_STATUS_MASK)
REG1_BO_STATUS 0b1..Brownout, supply is below target minus brownout offset.
◆ PMU_MISC2_CLR_REG1_STEP_TIME
#define PMU_MISC2_CLR_REG1_STEP_TIME (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_REG1_STEP_TIME_SHIFT)) & PMU_MISC2_CLR_REG1_STEP_TIME_MASK)
REG1_STEP_TIME 0b00..64 0b01..128 0b10..256 0b11..512
◆ PMU_MISC2_CLR_REG2_BO_OFFSET
#define PMU_MISC2_CLR_REG2_BO_OFFSET (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_REG2_BO_OFFSET_SHIFT)) & PMU_MISC2_CLR_REG2_BO_OFFSET_MASK)
REG2_BO_OFFSET 0b100..Brownout offset = 0.100V 0b111..Brownout offset = 0.175V
◆ PMU_MISC2_CLR_REG2_STEP_TIME
#define PMU_MISC2_CLR_REG2_STEP_TIME (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_REG2_STEP_TIME_SHIFT)) & PMU_MISC2_CLR_REG2_STEP_TIME_MASK)
REG2_STEP_TIME 0b00..64 0b01..128 0b10..256 0b11..512
◆ PMU_MISC2_CLR_VIDEO_DIV
#define PMU_MISC2_CLR_VIDEO_DIV (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_CLR_VIDEO_DIV_SHIFT)) & PMU_MISC2_CLR_VIDEO_DIV_MASK)
VIDEO_DIV 0b00..divide by 1 (Default) 0b01..divide by 2 0b10..divide by 1 0b11..divide by 4
◆ PMU_MISC2_REG0_BO_OFFSET
#define PMU_MISC2_REG0_BO_OFFSET (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_REG0_BO_OFFSET_SHIFT)) & PMU_MISC2_REG0_BO_OFFSET_MASK)
◆ PMU_MISC2_REG0_BO_STATUS
#define PMU_MISC2_REG0_BO_STATUS (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_REG0_BO_STATUS_SHIFT)) & PMU_MISC2_REG0_BO_STATUS_MASK)
◆ PMU_MISC2_REG0_STEP_TIME
#define PMU_MISC2_REG0_STEP_TIME (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_REG0_STEP_TIME_SHIFT)) & PMU_MISC2_REG0_STEP_TIME_MASK)
◆ PMU_MISC2_REG1_BO_OFFSET
#define PMU_MISC2_REG1_BO_OFFSET (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_REG1_BO_OFFSET_SHIFT)) & PMU_MISC2_REG1_BO_OFFSET_MASK)
◆ PMU_MISC2_REG1_BO_STATUS
#define PMU_MISC2_REG1_BO_STATUS (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_REG1_BO_STATUS_SHIFT)) & PMU_MISC2_REG1_BO_STATUS_MASK)
◆ PMU_MISC2_REG1_STEP_TIME
#define PMU_MISC2_REG1_STEP_TIME (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_REG1_STEP_TIME_SHIFT)) & PMU_MISC2_REG1_STEP_TIME_MASK)
◆ PMU_MISC2_REG2_BO_OFFSET
#define PMU_MISC2_REG2_BO_OFFSET (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_REG2_BO_OFFSET_SHIFT)) & PMU_MISC2_REG2_BO_OFFSET_MASK)
◆ PMU_MISC2_REG2_STEP_TIME
#define PMU_MISC2_REG2_STEP_TIME (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_REG2_STEP_TIME_SHIFT)) & PMU_MISC2_REG2_STEP_TIME_MASK)
◆ PMU_MISC2_SET_AUDIO_DIV_LSB
#define PMU_MISC2_SET_AUDIO_DIV_LSB (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_AUDIO_DIV_LSB_SHIFT)) & PMU_MISC2_SET_AUDIO_DIV_LSB_MASK)
◆ PMU_MISC2_SET_AUDIO_DIV_MSB
#define PMU_MISC2_SET_AUDIO_DIV_MSB (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_AUDIO_DIV_MSB_SHIFT)) & PMU_MISC2_SET_AUDIO_DIV_MSB_MASK)
◆ PMU_MISC2_SET_REG0_BO_OFFSET
#define PMU_MISC2_SET_REG0_BO_OFFSET (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_REG0_BO_OFFSET_SHIFT)) & PMU_MISC2_SET_REG0_BO_OFFSET_MASK)
◆ PMU_MISC2_SET_REG0_BO_STATUS
#define PMU_MISC2_SET_REG0_BO_STATUS (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_REG0_BO_STATUS_SHIFT)) & PMU_MISC2_SET_REG0_BO_STATUS_MASK)
◆ PMU_MISC2_SET_REG0_STEP_TIME
#define PMU_MISC2_SET_REG0_STEP_TIME (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_REG0_STEP_TIME_SHIFT)) & PMU_MISC2_SET_REG0_STEP_TIME_MASK)
◆ PMU_MISC2_SET_REG1_BO_OFFSET
#define PMU_MISC2_SET_REG1_BO_OFFSET (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_REG1_BO_OFFSET_SHIFT)) & PMU_MISC2_SET_REG1_BO_OFFSET_MASK)
◆ PMU_MISC2_SET_REG1_BO_STATUS
#define PMU_MISC2_SET_REG1_BO_STATUS (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_REG1_BO_STATUS_SHIFT)) & PMU_MISC2_SET_REG1_BO_STATUS_MASK)
◆ PMU_MISC2_SET_REG1_STEP_TIME
#define PMU_MISC2_SET_REG1_STEP_TIME (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_REG1_STEP_TIME_SHIFT)) & PMU_MISC2_SET_REG1_STEP_TIME_MASK)
◆ PMU_MISC2_SET_REG2_BO_OFFSET
#define PMU_MISC2_SET_REG2_BO_OFFSET (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_REG2_BO_OFFSET_SHIFT)) & PMU_MISC2_SET_REG2_BO_OFFSET_MASK)
◆ PMU_MISC2_SET_REG2_STEP_TIME
#define PMU_MISC2_SET_REG2_STEP_TIME (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_REG2_STEP_TIME_SHIFT)) & PMU_MISC2_SET_REG2_STEP_TIME_MASK)
◆ PMU_MISC2_SET_VIDEO_DIV
#define PMU_MISC2_SET_VIDEO_DIV (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_SET_VIDEO_DIV_SHIFT)) & PMU_MISC2_SET_VIDEO_DIV_MASK)
◆ PMU_MISC2_TOG_AUDIO_DIV_LSB
#define PMU_MISC2_TOG_AUDIO_DIV_LSB (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_AUDIO_DIV_LSB_SHIFT)) & PMU_MISC2_TOG_AUDIO_DIV_LSB_MASK)
◆ PMU_MISC2_TOG_AUDIO_DIV_MSB
#define PMU_MISC2_TOG_AUDIO_DIV_MSB (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_AUDIO_DIV_MSB_SHIFT)) & PMU_MISC2_TOG_AUDIO_DIV_MSB_MASK)
◆ PMU_MISC2_TOG_REG0_BO_OFFSET
#define PMU_MISC2_TOG_REG0_BO_OFFSET (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_REG0_BO_OFFSET_SHIFT)) & PMU_MISC2_TOG_REG0_BO_OFFSET_MASK)
◆ PMU_MISC2_TOG_REG0_BO_STATUS
#define PMU_MISC2_TOG_REG0_BO_STATUS (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_REG0_BO_STATUS_SHIFT)) & PMU_MISC2_TOG_REG0_BO_STATUS_MASK)
◆ PMU_MISC2_TOG_REG0_STEP_TIME
#define PMU_MISC2_TOG_REG0_STEP_TIME (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_REG0_STEP_TIME_SHIFT)) & PMU_MISC2_TOG_REG0_STEP_TIME_MASK)
◆ PMU_MISC2_TOG_REG1_BO_OFFSET
#define PMU_MISC2_TOG_REG1_BO_OFFSET (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_REG1_BO_OFFSET_SHIFT)) & PMU_MISC2_TOG_REG1_BO_OFFSET_MASK)
◆ PMU_MISC2_TOG_REG1_BO_STATUS
#define PMU_MISC2_TOG_REG1_BO_STATUS (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_REG1_BO_STATUS_SHIFT)) & PMU_MISC2_TOG_REG1_BO_STATUS_MASK)
◆ PMU_MISC2_TOG_REG1_STEP_TIME
#define PMU_MISC2_TOG_REG1_STEP_TIME (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_REG1_STEP_TIME_SHIFT)) & PMU_MISC2_TOG_REG1_STEP_TIME_MASK)
◆ PMU_MISC2_TOG_REG2_BO_OFFSET
#define PMU_MISC2_TOG_REG2_BO_OFFSET (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_REG2_BO_OFFSET_SHIFT)) & PMU_MISC2_TOG_REG2_BO_OFFSET_MASK)
◆ PMU_MISC2_TOG_REG2_STEP_TIME
#define PMU_MISC2_TOG_REG2_STEP_TIME (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_REG2_STEP_TIME_SHIFT)) & PMU_MISC2_TOG_REG2_STEP_TIME_MASK)
◆ PMU_MISC2_TOG_VIDEO_DIV
#define PMU_MISC2_TOG_VIDEO_DIV (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_TOG_VIDEO_DIV_SHIFT)) & PMU_MISC2_TOG_VIDEO_DIV_MASK)
◆ PMU_MISC2_VIDEO_DIV
#define PMU_MISC2_VIDEO_DIV (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_MISC2_VIDEO_DIV_SHIFT)) & PMU_MISC2_VIDEO_DIV_MASK)
◆ PMU_REG_1P1_CLR_OUTPUT_TRG
#define PMU_REG_1P1_CLR_OUTPUT_TRG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_CLR_OUTPUT_TRG_SHIFT)) & PMU_REG_1P1_CLR_OUTPUT_TRG_MASK)
OUTPUT_TRG 0b00100..0.8V 0b10000..1.1V 0b000x1..1.375V
◆ PMU_REG_1P1_CLR_SELREF_WEAK_LINREG
#define PMU_REG_1P1_CLR_SELREF_WEAK_LINREG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_CLR_SELREF_WEAK_LINREG_SHIFT)) & PMU_REG_1P1_CLR_SELREF_WEAK_LINREG_MASK)
SELREF_WEAK_LINREG 0b0..Weak-linreg output tracks low-power-bandgap voltage 0b1..Weak-linreg output tracks VDD_SOC_IN voltage
◆ PMU_REG_1P1_OUTPUT_TRG
#define PMU_REG_1P1_OUTPUT_TRG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_OUTPUT_TRG_SHIFT)) & PMU_REG_1P1_OUTPUT_TRG_MASK)
◆ PMU_REG_1P1_SELREF_WEAK_LINREG
#define PMU_REG_1P1_SELREF_WEAK_LINREG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_SELREF_WEAK_LINREG_SHIFT)) & PMU_REG_1P1_SELREF_WEAK_LINREG_MASK)
◆ PMU_REG_1P1_SET_OUTPUT_TRG
#define PMU_REG_1P1_SET_OUTPUT_TRG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_SET_OUTPUT_TRG_SHIFT)) & PMU_REG_1P1_SET_OUTPUT_TRG_MASK)
◆ PMU_REG_1P1_SET_SELREF_WEAK_LINREG
#define PMU_REG_1P1_SET_SELREF_WEAK_LINREG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_SET_SELREF_WEAK_LINREG_SHIFT)) & PMU_REG_1P1_SET_SELREF_WEAK_LINREG_MASK)
◆ PMU_REG_1P1_TOG_OUTPUT_TRG
#define PMU_REG_1P1_TOG_OUTPUT_TRG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_TOG_OUTPUT_TRG_SHIFT)) & PMU_REG_1P1_TOG_OUTPUT_TRG_MASK)
◆ PMU_REG_1P1_TOG_SELREF_WEAK_LINREG
#define PMU_REG_1P1_TOG_SELREF_WEAK_LINREG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_1P1_TOG_SELREF_WEAK_LINREG_SHIFT)) & PMU_REG_1P1_TOG_SELREF_WEAK_LINREG_MASK)
◆ PMU_REG_2P5_CLR_OUTPUT_TRG
#define PMU_REG_2P5_CLR_OUTPUT_TRG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_CLR_OUTPUT_TRG_SHIFT)) & PMU_REG_2P5_CLR_OUTPUT_TRG_MASK)
OUTPUT_TRG 0b00000..2.10V 0b10000..2.50V 0b11111..2.875V
◆ PMU_REG_2P5_OUTPUT_TRG
#define PMU_REG_2P5_OUTPUT_TRG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_OUTPUT_TRG_SHIFT)) & PMU_REG_2P5_OUTPUT_TRG_MASK)
◆ PMU_REG_2P5_SET_OUTPUT_TRG
#define PMU_REG_2P5_SET_OUTPUT_TRG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_SET_OUTPUT_TRG_SHIFT)) & PMU_REG_2P5_SET_OUTPUT_TRG_MASK)
◆ PMU_REG_2P5_TOG_OUTPUT_TRG
#define PMU_REG_2P5_TOG_OUTPUT_TRG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_2P5_TOG_OUTPUT_TRG_SHIFT)) & PMU_REG_2P5_TOG_OUTPUT_TRG_MASK)
◆ PMU_REG_3P0_CLR_OUTPUT_TRG
#define PMU_REG_3P0_CLR_OUTPUT_TRG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_CLR_OUTPUT_TRG_SHIFT)) & PMU_REG_3P0_CLR_OUTPUT_TRG_MASK)
OUTPUT_TRG 0b00000..2.625V 0b01111..3.000V 0b11111..3.400V
◆ PMU_REG_3P0_CLR_VBUS_SEL
#define PMU_REG_3P0_CLR_VBUS_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_CLR_VBUS_SEL_SHIFT)) & PMU_REG_3P0_CLR_VBUS_SEL_MASK)
VBUS_SEL 0b1..Utilize VBUS OTG1 power 0b0..Utilize VBUS OTG2 power
◆ PMU_REG_3P0_OUTPUT_TRG
#define PMU_REG_3P0_OUTPUT_TRG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_OUTPUT_TRG_SHIFT)) & PMU_REG_3P0_OUTPUT_TRG_MASK)
◆ PMU_REG_3P0_SET_OUTPUT_TRG
#define PMU_REG_3P0_SET_OUTPUT_TRG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_SET_OUTPUT_TRG_SHIFT)) & PMU_REG_3P0_SET_OUTPUT_TRG_MASK)
◆ PMU_REG_3P0_SET_VBUS_SEL
#define PMU_REG_3P0_SET_VBUS_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_SET_VBUS_SEL_SHIFT)) & PMU_REG_3P0_SET_VBUS_SEL_MASK)
◆ PMU_REG_3P0_TOG_OUTPUT_TRG
#define PMU_REG_3P0_TOG_OUTPUT_TRG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_TOG_OUTPUT_TRG_SHIFT)) & PMU_REG_3P0_TOG_OUTPUT_TRG_MASK)
◆ PMU_REG_3P0_TOG_VBUS_SEL
#define PMU_REG_3P0_TOG_VBUS_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_TOG_VBUS_SEL_SHIFT)) & PMU_REG_3P0_TOG_VBUS_SEL_MASK)
◆ PMU_REG_3P0_VBUS_SEL
#define PMU_REG_3P0_VBUS_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_3P0_VBUS_SEL_SHIFT)) & PMU_REG_3P0_VBUS_SEL_MASK)
◆ PMU_REG_CORE_CLR_RAMP_RATE
#define PMU_REG_CORE_CLR_RAMP_RATE (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_CLR_RAMP_RATE_SHIFT)) & PMU_REG_CORE_CLR_RAMP_RATE_MASK)
RAMP_RATE 0b00..Fast 0b01..Medium Fast 0b10..Medium Slow 0b11..Slow
◆ PMU_REG_CORE_CLR_REG0_ADJ
#define PMU_REG_CORE_CLR_REG0_ADJ (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_CLR_REG0_ADJ_SHIFT)) & PMU_REG_CORE_CLR_REG0_ADJ_MASK)
REG0_ADJ - This bit field defines the adjustment bits to calibrate the target value of Reg0. The adjustment is applied on top on any adjustment applied to the global reference in the misc0 register. 0b0000..No adjustment 0b0001..+ 0.25% 0b0010..+ 0.50% 0b0011..+ 0.75% 0b0100..+ 1.00% 0b0101..+ 1.25% 0b0110..+ 1.50% 0b0111..+ 1.75% 0b1000..- 0.25% 0b1001..- 0.50% 0b1010..- 0.75% 0b1011..- 1.00% 0b1100..- 1.25% 0b1101..- 1.50% 0b1110..- 1.75% 0b1111..- 2.00%
◆ PMU_REG_CORE_CLR_REG0_TARG
#define PMU_REG_CORE_CLR_REG0_TARG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_CLR_REG0_TARG_SHIFT)) & PMU_REG_CORE_CLR_REG0_TARG_MASK)
REG0_TARG 0b00000..Power gated off 0b00001..Target core voltage = 0.725V 0b00010..Target core voltage = 0.750V 0b00011..Target core voltage = 0.775V 0b10000..Target core voltage = 1.100V 0b11110..Target core voltage = 1.450V 0b11111..Power FET switched full on. No regulation.
◆ PMU_REG_CORE_CLR_REG1_ADJ
#define PMU_REG_CORE_CLR_REG1_ADJ (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_CLR_REG1_ADJ_SHIFT)) & PMU_REG_CORE_CLR_REG1_ADJ_MASK)
REG1_ADJ - This bit field defines the adjustment bits to calibrate the target value of Reg1. The adjustment is applied on top on any adjustment applied to the global reference in the misc0 register. 0b0000..No adjustment 0b0001..+ 0.25% 0b0010..+ 0.50% 0b0011..+ 0.75% 0b0100..+ 1.00% 0b0101..+ 1.25% 0b0110..+ 1.50% 0b0111..+ 1.75% 0b1000..- 0.25% 0b1001..- 0.50% 0b1010..- 0.75% 0b1011..- 1.00% 0b1100..- 1.25% 0b1101..- 1.50% 0b1110..- 1.75% 0b1111..- 2.00%
◆ PMU_REG_CORE_CLR_REG1_TARG
#define PMU_REG_CORE_CLR_REG1_TARG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_CLR_REG1_TARG_SHIFT)) & PMU_REG_CORE_CLR_REG1_TARG_MASK)
REG1_TARG - This bit field defines the target voltage for the vpu/gpu power domain. Single bit increments reflect 25mV core voltage steps. Not all steps will make sense to use either because of input supply limitations or load operation. 0b00000..Power gated off 0b00001..Target core voltage = 0.725V 0b00010..Target core voltage = 0.750V 0b00011..Target core voltage = 0.775V 0b10000..Target core voltage = 1.100V 0b11110..Target core voltage = 1.450V 0b11111..Power FET switched full on. No regulation.
◆ PMU_REG_CORE_CLR_REG2_ADJ
#define PMU_REG_CORE_CLR_REG2_ADJ (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_CLR_REG2_ADJ_SHIFT)) & PMU_REG_CORE_CLR_REG2_ADJ_MASK)
REG2_ADJ - This bit field defines the adjustment bits to calibrate the target value of Reg2. The adjustment is applied on top on any adjustment applied to the global reference in the misc0 register. 0b0000..No adjustment 0b0001..+ 0.25% 0b0010..+ 0.50% 0b0011..+ 0.75% 0b0100..+ 1.00% 0b0101..+ 1.25% 0b0110..+ 1.50% 0b0111..+ 1.75% 0b1000..- 0.25% 0b1001..- 0.50% 0b1010..- 0.75% 0b1011..- 1.00% 0b1100..- 1.25% 0b1101..- 1.50% 0b1110..- 1.75% 0b1111..- 2.00%
◆ PMU_REG_CORE_CLR_REG2_TARG
#define PMU_REG_CORE_CLR_REG2_TARG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_CLR_REG2_TARG_SHIFT)) & PMU_REG_CORE_CLR_REG2_TARG_MASK)
REG2_TARG 0b00000..Power gated off 0b00001..Target core voltage = 0.725V 0b00010..Target core voltage = 0.750V 0b00011..Target core voltage = 0.775V 0b10000..Target core voltage = 1.100V 0b11110..Target core voltage = 1.450V 0b11111..Power FET switched full on. No regulation.
◆ PMU_REG_CORE_RAMP_RATE
#define PMU_REG_CORE_RAMP_RATE (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_RAMP_RATE_SHIFT)) & PMU_REG_CORE_RAMP_RATE_MASK)
◆ PMU_REG_CORE_REG0_ADJ
#define PMU_REG_CORE_REG0_ADJ (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_REG0_ADJ_SHIFT)) & PMU_REG_CORE_REG0_ADJ_MASK)
◆ PMU_REG_CORE_REG0_TARG
#define PMU_REG_CORE_REG0_TARG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_REG0_TARG_SHIFT)) & PMU_REG_CORE_REG0_TARG_MASK)
◆ PMU_REG_CORE_REG1_ADJ
#define PMU_REG_CORE_REG1_ADJ (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_REG1_ADJ_SHIFT)) & PMU_REG_CORE_REG1_ADJ_MASK)
◆ PMU_REG_CORE_REG1_TARG
#define PMU_REG_CORE_REG1_TARG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_REG1_TARG_SHIFT)) & PMU_REG_CORE_REG1_TARG_MASK)
◆ PMU_REG_CORE_REG2_ADJ
#define PMU_REG_CORE_REG2_ADJ (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_REG2_ADJ_SHIFT)) & PMU_REG_CORE_REG2_ADJ_MASK)
◆ PMU_REG_CORE_REG2_TARG
#define PMU_REG_CORE_REG2_TARG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_REG2_TARG_SHIFT)) & PMU_REG_CORE_REG2_TARG_MASK)
◆ PMU_REG_CORE_SET_RAMP_RATE
#define PMU_REG_CORE_SET_RAMP_RATE (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_SET_RAMP_RATE_SHIFT)) & PMU_REG_CORE_SET_RAMP_RATE_MASK)
◆ PMU_REG_CORE_SET_REG0_ADJ
#define PMU_REG_CORE_SET_REG0_ADJ (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_SET_REG0_ADJ_SHIFT)) & PMU_REG_CORE_SET_REG0_ADJ_MASK)
◆ PMU_REG_CORE_SET_REG0_TARG
#define PMU_REG_CORE_SET_REG0_TARG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_SET_REG0_TARG_SHIFT)) & PMU_REG_CORE_SET_REG0_TARG_MASK)
◆ PMU_REG_CORE_SET_REG1_ADJ
#define PMU_REG_CORE_SET_REG1_ADJ (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_SET_REG1_ADJ_SHIFT)) & PMU_REG_CORE_SET_REG1_ADJ_MASK)
◆ PMU_REG_CORE_SET_REG1_TARG
#define PMU_REG_CORE_SET_REG1_TARG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_SET_REG1_TARG_SHIFT)) & PMU_REG_CORE_SET_REG1_TARG_MASK)
◆ PMU_REG_CORE_SET_REG2_ADJ
#define PMU_REG_CORE_SET_REG2_ADJ (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_SET_REG2_ADJ_SHIFT)) & PMU_REG_CORE_SET_REG2_ADJ_MASK)
◆ PMU_REG_CORE_SET_REG2_TARG
#define PMU_REG_CORE_SET_REG2_TARG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_SET_REG2_TARG_SHIFT)) & PMU_REG_CORE_SET_REG2_TARG_MASK)
◆ PMU_REG_CORE_TOG_RAMP_RATE
#define PMU_REG_CORE_TOG_RAMP_RATE (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_TOG_RAMP_RATE_SHIFT)) & PMU_REG_CORE_TOG_RAMP_RATE_MASK)
◆ PMU_REG_CORE_TOG_REG0_ADJ
#define PMU_REG_CORE_TOG_REG0_ADJ (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_TOG_REG0_ADJ_SHIFT)) & PMU_REG_CORE_TOG_REG0_ADJ_MASK)
◆ PMU_REG_CORE_TOG_REG0_TARG
#define PMU_REG_CORE_TOG_REG0_TARG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_TOG_REG0_TARG_SHIFT)) & PMU_REG_CORE_TOG_REG0_TARG_MASK)
◆ PMU_REG_CORE_TOG_REG1_ADJ
#define PMU_REG_CORE_TOG_REG1_ADJ (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_TOG_REG1_ADJ_SHIFT)) & PMU_REG_CORE_TOG_REG1_ADJ_MASK)
◆ PMU_REG_CORE_TOG_REG1_TARG
#define PMU_REG_CORE_TOG_REG1_TARG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_TOG_REG1_TARG_SHIFT)) & PMU_REG_CORE_TOG_REG1_TARG_MASK)
◆ PMU_REG_CORE_TOG_REG2_ADJ
#define PMU_REG_CORE_TOG_REG2_ADJ (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_TOG_REG2_ADJ_SHIFT)) & PMU_REG_CORE_TOG_REG2_ADJ_MASK)
◆ PMU_REG_CORE_TOG_REG2_TARG
#define PMU_REG_CORE_TOG_REG2_TARG (   x)    (((uint32_t)(((uint32_t)(x)) << PMU_REG_CORE_TOG_REG2_TARG_SHIFT)) & PMU_REG_CORE_TOG_REG2_TARG_MASK)
