macros to handle SDRAM interrupts
More...
#define | __FMC_SDRAM_ENABLE_IT(__INSTANCE__, __INTERRUPT__) ((__INSTANCE__)->SDRTR |= (__INTERRUPT__)) |
| Enable the SDRAM device interrupt.
#define | __FMC_SDRAM_DISABLE_IT(__INSTANCE__, __INTERRUPT__) ((__INSTANCE__)->SDRTR &= ~(__INTERRUPT__)) |
| Disable the SDRAM device interrupt.
#define | __FMC_SDRAM_GET_FLAG(__INSTANCE__, __FLAG__) (((__INSTANCE__)->SDSR &(__FLAG__)) == (__FLAG__)) |
| Get flag status of the SDRAM device.
#define | __FMC_SDRAM_CLEAR_FLAG(__INSTANCE__, __FLAG__) ((__INSTANCE__)->SDRTR |= (__FLAG__)) |
| Clear flag status of the SDRAM device.
◆ __FMC_SDRAM_CLEAR_FLAG
#define __FMC_SDRAM_CLEAR_FLAG |
__INSTANCE__, |
__FLAG__ |
- Parameters
__INSTANCE__ | FMC_SDRAM instance |
__FLAG__ | FMC_SDRAM flag This parameter can be any combination of the following values:
- FMC_SDRAM_FLAG_REFRESH_ERROR
- Return values
◆ __FMC_SDRAM_DISABLE_IT
#define __FMC_SDRAM_DISABLE_IT |
__INSTANCE__, |
__INTERRUPT__ |
- Parameters
__INTERRUPT__ | FMC_SDRAM interrupt This parameter can be any combination of the following values:
- FMC_IT_REFRESH_ERROR: Interrupt refresh error
- Return values
◆ __FMC_SDRAM_ENABLE_IT
#define __FMC_SDRAM_ENABLE_IT |
__INSTANCE__, |
__INTERRUPT__ |
- Parameters
- Return values
◆ __FMC_SDRAM_GET_FLAG
#define __FMC_SDRAM_GET_FLAG |
__INSTANCE__, |
__FLAG__ |
- Parameters
- FMC_SDRAM_FLAG_REFRESH_IT: Interrupt refresh error.
- FMC_SDRAM_FLAG_BUSY: SDRAM busy flag.
- FMC_SDRAM_FLAG_REFRESH_ERROR: Refresh error flag.
- Return values
The | state of FLAG (SET or RESET). |
