RTEMS 6.1-rc4
Files | Data Structures | Macros | Enumerations | Enumerator | Functions
ARM Generic Interrupt Controller (GIC) Support
This group contains the Interrupt Manager implementation parts specific to the ARM Generic Interrupt Controller. More...
file  arm-gic-arch.h
 This header file provides interfaces of the ARM Generic Interrupt Controller (GIC) support specific to the AArch64 architecture.
file  arm-gic-arch.h
 This header file provides interfaces of the ARM Generic Interrupt Controller (GIC) support specific to the Arm architecture.
file  arm-gic-irq.h
 This header file provides interfaces of the ARM Generic Interrupt Controller (GIC) support.
file  arm-gic-regs.h
 This header file provides interfaces of the ARM Generic Interrupt Controller (GIC) memory-mapped registers.
file  arm-gic-tm27.h
 This header file provides the TM27 support for the ARM Generic Interrupt Controller (GIC).
file  arm-gic.h
file  arm-gicv3.h
 This header file provides interfaces of the ARM Generic Interrupt Controller (GIC) support specific to the GICv3.
file  arm-gicv2-get-attributes.c
 This source file contains the implementation of bsp_interrupt_get_attributes() for the GICv2.
file  arm-gicv2-zynqmp.c
 This source file contains the implementation of bsp_interrupt_get_attributes() for the GICv2 of Xilinx Zynq UltraScale+ MPSoC and RFSoC devices.
file  arm-gicv2.c
 This source file contains the implementation of the generic GICv2 support.
file  arm-gicv3.c
 This source file contains the implementation of the generic GICv3 support.
struct  gic_cpuif
struct  gic_dist
struct  gic_redist
struct  gic_sgi_ppi
#define ARM_GIC_IRQ_SGI_0   0
#define ARM_GIC_IRQ_SGI_1   1
#define ARM_GIC_IRQ_SGI_2   2
#define ARM_GIC_IRQ_SGI_3   3
#define ARM_GIC_IRQ_SGI_5   5
#define ARM_GIC_IRQ_SGI_6   6
#define ARM_GIC_IRQ_SGI_7   7
#define ARM_GIC_IRQ_SGI_8   8
#define ARM_GIC_IRQ_SGI_9   9
#define ARM_GIC_IRQ_SGI_10   10
#define ARM_GIC_IRQ_SGI_11   11
#define ARM_GIC_IRQ_SGI_12   12
#define ARM_GIC_IRQ_SGI_13   13
#define ARM_GIC_IRQ_SGI_14   14
#define ARM_GIC_IRQ_SGI_15   15
#define ARM_GIC_IRQ_SGI_LAST   15
#define ARM_GIC_IRQ_PPI_LAST   31
#define ARM_GIC_DIST   ((volatile gic_dist *) BSP_ARM_GIC_DIST_BASE)
#define GIC_ID_TO_ONE_BIT_REG_INDEX(id)   ((id) >> 5)
#define GIC_ID_TO_ONE_BIT_REG_BIT(id)   (1U << ((id) & 0x1fU))
#define GIC_ID_TO_TWO_BITS_REG_INDEX(id)   ((id) >> 4)
#define GIC_ID_TO_TWO_BITS_REG_OFFSET(id)   (((id) & 0xfU) << 1)
#define PRIORITY_DEFAULT   127
#define MPIDR_AFFINITY2(val)   BSP_FLD64(val, 16, 23)
#define MPIDR_AFFINITY2_GET(reg)   BSP_FLD64GET(reg, 16, 23)
#define MPIDR_AFFINITY2_SET(reg, val)   BSP_FLD64SET(reg, val, 16, 23)
#define MPIDR_AFFINITY1(val)   BSP_FLD64(val, 8, 15)
#define MPIDR_AFFINITY1_GET(reg)   BSP_FLD64GET(reg, 8, 15)
#define MPIDR_AFFINITY1_SET(reg, val)   BSP_FLD64SET(reg, val, 8, 15)
#define MPIDR_AFFINITY0(val)   BSP_FLD64(val, 0, 7)
#define MPIDR_AFFINITY0_GET(reg)   BSP_FLD64GET(reg, 0, 7)
#define MPIDR_AFFINITY0_SET(reg, val)   BSP_FLD64SET(reg, val, 0, 7)
#define ICC_SGIR_AFFINITY3(val)   BSP_FLD64(val, 48, 55)
#define ICC_SGIR_AFFINITY3_GET(reg)   BSP_FLD64GET(reg, 48, 55)
#define ICC_SGIR_AFFINITY3_SET(reg, val)   BSP_FLD64SET(reg, val, 48, 55)
#define ICC_SGIR_IRM   BSP_BIT32(40)
#define ICC_SGIR_AFFINITY2(val)   BSP_FLD64(val, 32, 39)
#define ICC_SGIR_AFFINITY2_GET(reg)   BSP_FLD64GET(reg, 32, 39)
#define ICC_SGIR_AFFINITY2_SET(reg, val)   BSP_FLD64SET(reg, val, 32, 39)
#define ICC_SGIR_INTID(val)   BSP_FLD64(val, 24, 27)
#define ICC_SGIR_INTID_GET(reg)   BSP_FLD64GET(reg, 24, 27)
#define ICC_SGIR_INTID_SET(reg, val)   BSP_FLD64SET(reg, val, 24, 27)
#define ICC_SGIR_AFFINITY1(val)   BSP_FLD64(val, 16, 23)
#define ICC_SGIR_AFFINITY1_GET(reg)   BSP_FLD64GET(reg, 16, 23)
#define ICC_SGIR_AFFINITY1_SET(reg, val)   BSP_FLD64SET(reg, val, 16, 23)
#define ICC_SGIR_CPU_TARGET_LIST(val)   BSP_FLD64(val, 0, 15)
#define ICC_SGIR_CPU_TARGET_LIST_GET(reg)   BSP_FLD64GET(reg, 0, 15)
#define ICC_SGIR_CPU_TARGET_LIST_SET(reg, val)   BSP_FLD64SET(reg, val, 0, 15)
#define ICC_IGRPEN0_EL1   "S3_0_C12_C12_6, %0"
#define ICC_IGRPEN1_EL1   "S3_0_C12_C12_7, %0"
#define ICC_IGRPEN1_EL3   "S3_6_C12_C12_7, %0"
#define ICC_IGRPEN0   ICC_IGRPEN0_EL1
#define ICC_IGRPEN1   ICC_IGRPEN1_EL1
#define ICC_PMR   "S3_0_C4_C6_0, %0"
#define ICC_EOIR1   "S3_0_C12_C12_1, %0"
#define ICC_SRE   "S3_0_C12_C12_5, %0"
#define ICC_BPR0   "S3_0_C12_C8_3, %0"
#define ICC_BPR1   "S3_0_C12_C12_3, %0"
#define ICC_CTLR   "S3_0_C12_C12_4, %0"
#define ICC_IAR1   "%0, S3_0_C12_C12_0"
#define MPIDR   "%0, mpidr_el1"
#define MPIDR_AFFINITY3(val)   BSP_FLD64(val, 32, 39)
#define MPIDR_AFFINITY3_GET(reg)   BSP_FLD64GET(reg, 32, 39)
#define MPIDR_AFFINITY3_SET(reg, val)   BSP_FLD64SET(reg, val, 32, 39)
#define ICC_SGI1   "S3_0_C12_C11_5, %0"
#define WRITE64_SR(SR_NAME, VALUE)    __asm__ volatile("msr " SR_NAME " \n" : : "r" (VALUE) );
#define WRITE_SR(SR_NAME, VALUE)   WRITE64_SR(SR_NAME, VALUE)
#define READ_SR(SR_NAME)
enum  gic_group { GIC_GROUP_0 , GIC_GROUP_1 }
enum  gic_trigger_mode { GIC_LEVEL_SENSITIVE , GIC_EDGE_TRIGGERED }
enum  gic_handling_model { GIC_N_TO_N , GIC_1_TO_N }
rtems_status_code arm_gic_irq_set_group (rtems_vector_number vector, gic_group group)
rtems_status_code arm_gic_irq_get_group (rtems_vector_number vector, gic_group *group)
void arm_gic_trigger_sgi (rtems_vector_number vector, uint32_t targets)
◆ READ_SR
#define READ_SR (   SR_NAME)
Value:
uint64_t value; \
__asm__ volatile("mrs " SR_NAME : "=&r" (value) ); \
value; \
