RTEMS 6.1-rc4
Data Structures | Macros
This header file provides interfaces of the ARM Generic Interrupt Controller (GIC) memory-mapped registers. More...
#include <bsp/utility.h>
struct  gic_cpuif
struct  gic_dist
struct  gic_redist
struct  gic_sgi_ppi
#define GIC_CPUIF_ICCICR_CBPR   BSP_BIT32(4)
#define GIC_CPUIF_ICCICR_FIQ_EN   BSP_BIT32(3)
#define GIC_CPUIF_ICCICR_ACK_CTL   BSP_BIT32(2)
#define GIC_CPUIF_ICCICR_ENABLE_GRP_1   BSP_BIT32(1)
#define GIC_CPUIF_ICCICR_ENABLE   BSP_BIT32(0)
#define GIC_CPUIF_ICCPMR_PRIORITY(val)   BSP_FLD32(val, 0, 7)
#define GIC_CPUIF_ICCPMR_PRIORITY_GET(reg)   BSP_FLD32GET(reg, 0, 7)
#define GIC_CPUIF_ICCPMR_PRIORITY_SET(reg, val)   BSP_FLD32SET(reg, val, 0, 7)
#define GIC_CPUIF_ICCBPR_BINARY_POINT(val)   BSP_FLD32(val, 0, 2)
#define GIC_CPUIF_ICCBPR_BINARY_POINT_GET(reg)   BSP_FLD32GET(reg, 0, 2)
#define GIC_CPUIF_ICCBPR_BINARY_POINT_SET(reg, val)   BSP_FLD32SET(reg, val, 0, 2)
#define GIC_CPUIF_ICCIAR_CPUID(val)   BSP_FLD32(val, 10, 12)
#define GIC_CPUIF_ICCIAR_CPUID_GET(reg)   BSP_FLD32GET(reg, 10, 12)
#define GIC_CPUIF_ICCIAR_CPUID_SET(reg, val)   BSP_FLD32SET(reg, val, 10, 12)
#define GIC_CPUIF_ICCIAR_ACKINTID(val)   BSP_FLD32(val, 0, 9)
#define GIC_CPUIF_ICCIAR_ACKINTID_GET(reg)   BSP_FLD32GET(reg, 0, 9)
#define GIC_CPUIF_ICCIAR_ACKINTID_SET(reg, val)   BSP_FLD32SET(reg, val, 0, 9)
#define GIC_CPUIF_ICCEOIR_CPUID(val)   BSP_FLD32(val, 10, 12)
#define GIC_CPUIF_ICCEOIR_CPUID_GET(reg)   BSP_FLD32GET(reg, 10, 12)
#define GIC_CPUIF_ICCEOIR_CPUID_SET(reg, val)   BSP_FLD32SET(reg, val, 10, 12)
#define GIC_CPUIF_ICCEOIR_EOIINTID(val)   BSP_FLD32(val, 0, 9)
#define GIC_CPUIF_ICCEOIR_EOIINTID_GET(reg)   BSP_FLD32GET(reg, 0, 9)
#define GIC_CPUIF_ICCEOIR_EOIINTID_SET(reg, val)   BSP_FLD32SET(reg, val, 0, 9)
#define GIC_CPUIF_ICCRPR_PRIORITY(val)   BSP_FLD32(val, 0, 7)
#define GIC_CPUIF_ICCRPR_PRIORITY_GET(reg)   BSP_FLD32GET(reg, 0, 7)
#define GIC_CPUIF_ICCRPR_PRIORITY_SET(reg, val)   BSP_FLD32SET(reg, val, 0, 7)
#define GIC_CPUIF_ICCHPIR_CPUID(val)   BSP_FLD32(val, 10, 12)
#define GIC_CPUIF_ICCHPIR_CPUID_GET(reg)   BSP_FLD32GET(reg, 10, 12)
#define GIC_CPUIF_ICCHPIR_CPUID_SET(reg, val)   BSP_FLD32SET(reg, val, 10, 12)
#define GIC_CPUIF_ICCHPIR_PENDINTID(val)   BSP_FLD32(val, 0, 9)
#define GIC_CPUIF_ICCHPIR_PENDINTID_GET(reg)   BSP_FLD32GET(reg, 0, 9)
#define GIC_CPUIF_ICCHPIR_PENDINTID_SET(reg, val)   BSP_FLD32SET(reg, val, 0, 9)
#define GIC_CPUIF_ICCABPR_BINARY_POINT(val)   BSP_FLD32(val, 0, 2)
#define GIC_CPUIF_ICCABPR_BINARY_POINT_GET(reg)   BSP_FLD32GET(reg, 0, 2)
#define GIC_CPUIF_ICCABPR_BINARY_POINT_SET(reg, val)   BSP_FLD32SET(reg, val, 0, 2)
#define GIC_CPUIF_ICCIIDR_PRODUCT_ID(val)   BSP_FLD32(val, 24, 31)
#define GIC_CPUIF_ICCIIDR_PRODUCT_ID_GET(reg)   BSP_FLD32GET(reg, 24, 31)
#define GIC_CPUIF_ICCIIDR_PRODUCT_ID_SET(reg, val)   BSP_FLD32SET(reg, val, 24, 31)
#define GIC_CPUIF_ICCIIDR_ARCH_VERSION(val)   BSP_FLD32(val, 16, 19)
#define GIC_CPUIF_ICCIIDR_ARCH_VERSION_GET(reg)   BSP_FLD32GET(reg, 16, 19)
#define GIC_CPUIF_ICCIIDR_ARCH_VERSION_SET(reg, val)   BSP_FLD32SET(reg, val, 16, 19)
#define GIC_CPUIF_ICCIIDR_REVISION(val)   BSP_FLD32(val, 12, 15)
#define GIC_CPUIF_ICCIIDR_REVISION_GET(reg)   BSP_FLD32GET(reg, 12, 15)
#define GIC_CPUIF_ICCIIDR_REVISION_SET(reg, val)   BSP_FLD32SET(reg, val, 12, 15)
#define GIC_CPUIF_ICCIIDR_IMPLEMENTER(val)   BSP_FLD32(val, 0, 11)
#define GIC_CPUIF_ICCIIDR_IMPLEMENTER_GET(reg)   BSP_FLD32GET(reg, 0, 11)
#define GIC_CPUIF_ICCIIDR_IMPLEMENTER_SET(reg, val)   BSP_FLD32SET(reg, val, 0, 11)
#define GIC_DIST_ICDDCR_RWP   BSP_BIT32(31)
#define GIC_DIST_ICDDCR_E1NWF   BSP_BIT32(7)
#define GIC_DIST_ICDDCR_DS   BSP_BIT32(6)
#define GIC_DIST_ICDDCR_ARE_NS   BSP_BIT32(5)
#define GIC_DIST_ICDDCR_ARE_S   BSP_BIT32(4)
#define GIC_DIST_ICDDCR_ENABLE_GRP1S   BSP_BIT32(2)
#define GIC_DIST_ICDDCR_ENABLE_GRP1NS   BSP_BIT32(1)
#define GIC_DIST_ICDDCR_ENABLE_GRP0   BSP_BIT32(0)
#define GIC_DIST_ICDDCR_ENABLE_GRP_1   BSP_BIT32(1)
#define GIC_DIST_ICDDCR_ENABLE   BSP_BIT32(0)
#define GIC_DIST_ICDICTR_LSPI(val)   BSP_FLD32(val, 11, 15)
#define GIC_DIST_ICDICTR_LSPI_GET(reg)   BSP_FLD32GET(reg, 11, 15)
#define GIC_DIST_ICDICTR_LSPI_SET(reg, val)   BSP_FLD32SET(reg, val, 11, 15)
#define GIC_DIST_ICDICTR_SECURITY_EXTN   BSP_BIT32(10)
#define GIC_DIST_ICDICTR_CPU_NUMBER(val)   BSP_FLD32(val, 5, 7)
#define GIC_DIST_ICDICTR_CPU_NUMBER_GET(reg)   BSP_FLD32GET(reg, 5, 7)
#define GIC_DIST_ICDICTR_CPU_NUMBER_SET(reg, val)   BSP_FLD32SET(reg, val, 5, 7)
#define GIC_DIST_ICDICTR_IT_LINES_NUMBER(val)   BSP_FLD32(val, 0, 4)
#define GIC_DIST_ICDICTR_IT_LINES_NUMBER_GET(reg)   BSP_FLD32GET(reg, 0, 4)
#define GIC_DIST_ICDICTR_IT_LINES_NUMBER_SET(reg, val)   BSP_FLD32SET(reg, val, 0, 4)
#define GIC_DIST_ICDIIDR_PRODUCT_ID(val)   BSP_FLD32(val, 24, 31)
#define GIC_DIST_ICDIIDR_PRODUCT_ID_GET(reg)   BSP_FLD32GET(reg, 24, 31)
#define GIC_DIST_ICDIIDR_PRODUCT_ID_SET(reg, val)   BSP_FLD32SET(reg, val, 24, 31)
#define GIC_DIST_ICDIIDR_VARIANT(val)   BSP_FLD32(val, 16, 19)
#define GIC_DIST_ICDIIDR_VARIANT_GET(reg)   BSP_FLD32GET(reg, 16, 19)
#define GIC_DIST_ICDIIDR_VARIANT_SET(reg, val)   BSP_FLD32SET(reg, val, 16, 19)
#define GIC_DIST_ICDIIDR_REVISION(val)   BSP_FLD32(val, 12, 15)
#define GIC_DIST_ICDIIDR_REVISION_GET(reg)   BSP_FLD32GET(reg, 12, 15)
#define GIC_DIST_ICDIIDR_REVISION_SET(reg, val)   BSP_FLD32SET(reg, val, 12, 15)
#define GIC_DIST_ICDIIDR_IMPLEMENTER(val)   BSP_FLD32(val, 0, 11)
#define GIC_DIST_ICDIIDR_IMPLEMENTER_GET(reg)   BSP_FLD32GET(reg, 0, 11)
#define GIC_DIST_ICDIIDR_IMPLEMENTER_SET(reg, val)   BSP_FLD32SET(reg, val, 0, 11)
#define GIC_DIST_ICDSGIR_TARGET_LIST_FILTER(val)   BSP_FLD32(val, 24, 25)
#define GIC_DIST_ICDSGIR_TARGET_LIST_FILTER_GET(reg)   BSP_FLD32GET(reg, 24, 25)
#define GIC_DIST_ICDSGIR_TARGET_LIST_FILTER_SET(reg, val)   BSP_FLD32SET(reg, val, 24, 25)
#define GIC_DIST_ICDSGIR_CPU_TARGET_LIST(val)   BSP_FLD32(val, 16, 23)
#define GIC_DIST_ICDSGIR_CPU_TARGET_LIST_GET(reg)   BSP_FLD32GET(reg, 16, 23)
#define GIC_DIST_ICDSGIR_CPU_TARGET_LIST_SET(reg, val)   BSP_FLD32SET(reg, val, 16, 23)
#define GIC_DIST_ICDSGIR_NSATT   BSP_BIT32(15)
#define GIC_DIST_ICDSGIR_SGIINTID(val)   BSP_FLD32(val, 0, 3)
#define GIC_DIST_ICDSGIR_SGIINTID_GET(reg)   BSP_FLD32GET(reg, 0, 3)
#define GIC_DIST_ICDSGIR_SGIINTID_SET(reg, val)   BSP_FLD32SET(reg, val, 0, 3)
#define GIC_REDIST_ICRRCR_UWP   BSP_BIT32(31)
#define GIC_REDIST_ICRRCR_DPG1S   BSP_BIT32(26)
#define GIC_REDIST_ICRRCR_DPG1NS   BSP_BIT32(25)
#define GIC_REDIST_ICRRCR_DPG0   BSP_BIT32(24)
#define GIC_REDIST_ICRRCR_RWP   BSP_BIT32(4)
#define GIC_REDIST_ICRRCR_ENABLE_LPI   BSP_BIT32(0)
#define GIC_REDIST_ICRTYPER_AFFINITY_VALUE(val)   BSP_FLD64(val, 32, 63)
#define GIC_REDIST_ICRTYPER_AFFINITY_VALUE_GET(reg)   BSP_FLD64GET(reg, 32, 63)
#define GIC_REDIST_ICRTYPER_AFFINITY_VALUE_SET(reg, val)   BSP_FLD64SET(reg, val, 32, 63)
#define GIC_REDIST_ICRTYPER_COMMON_LPI_AFFINITY(val)   BSP_FLD64(val, 24, 25)
#define GIC_REDIST_ICRTYPER_COMMON_LPI_AFFINITY_GET(reg)   BSP_FLD64GET(reg, 24, 25)
#define GIC_REDIST_ICRTYPER_COMMON_LPI_AFFINITY_SET(reg, val)   BSP_FLD64SET(reg, val, 24, 25)
#define GIC_REDIST_ICRTYPER_CPU_NUMBER(val)   BSP_FLD64(val, 8, 23)
#define GIC_REDIST_ICRTYPER_CPU_NUMBER_GET(reg)   BSP_FLD64GET(reg, 8, 23)
#define GIC_REDIST_ICRTYPER_CPU_NUMBER_SET(reg, val)   BSP_FLD64SET(reg, val, 8, 23)
#define GIC_REDIST_ICRTYPER_DPGS   BSP_BIT64(5)
#define GIC_REDIST_ICRTYPER_LAST   BSP_BIT64(4)
#define GIC_REDIST_ICRTYPER_DIRECT_LPI   BSP_BIT64(3)
#define GIC_REDIST_ICRTYPER_VLPIS   BSP_BIT64(1)
#define GIC_REDIST_ICRTYPER_PLPIS   BSP_BIT64(0)
#define GIC_REDIST_ICRWAKER_CHILDREN_ASLEEP   BSP_BIT32(2)
#define GIC_REDIST_ICRWAKER_PROCESSOR_SLEEP   BSP_BIT32(1)
