RTEMS 6.1-rc4
bsd-tree.h File Reference
This header file provides a red-black tree implementation. More...
#include <sys/cdefs.h>
#define RTEMS_SPLAY_HEAD(name, type)
#define RTEMS_SPLAY_INITIALIZER(root)    { NULL }
#define RTEMS_SPLAY_INIT(root)
#define RTEMS_SPLAY_ENTRY(type)
#define RTEMS_SPLAY_LEFT(elm, field)   (elm)->field.spe_left
#define RTEMS_SPLAY_RIGHT(elm, field)   (elm)->field.spe_right
#define RTEMS_SPLAY_ROOT(head)   (head)->sph_root
#define RTEMS_SPLAY_EMPTY(head)   (RTEMS_SPLAY_ROOT(head) == NULL)
#define RTEMS_SPLAY_ROTATE_RIGHT(head, tmp, field)
#define RTEMS_SPLAY_ROTATE_LEFT(head, tmp, field)
#define RTEMS_SPLAY_LINKLEFT(head, tmp, field)
#define RTEMS_SPLAY_LINKRIGHT(head, tmp, field)
#define RTEMS_SPLAY_ASSEMBLE(head, node, left, right, field)
#define RTEMS_SPLAY_PROTOTYPE(name, type, field, cmp)
#define RTEMS_SPLAY_GENERATE(name, type, field, cmp)
#define RTEMS_SPLAY_NEGINF   -1
#define RTEMS_SPLAY_INF   1
#define RTEMS_SPLAY_INSERT(name, x, y)   name##_RTEMS_SPLAY_INSERT(x, y)
#define RTEMS_SPLAY_REMOVE(name, x, y)   name##_RTEMS_SPLAY_REMOVE(x, y)
#define RTEMS_SPLAY_FIND(name, x, y)   name##_RTEMS_SPLAY_FIND(x, y)
#define RTEMS_SPLAY_NEXT(name, x, y)   name##_RTEMS_SPLAY_NEXT(x, y)
#define RTEMS_SPLAY_MIN(name, x)
#define RTEMS_SPLAY_MAX(name, x)
#define RTEMS_SPLAY_FOREACH(x, name, head)
#define RTEMS_RB_HEAD(name, type)
#define RTEMS_RB_INITIALIZER(root)    { NULL }
#define RTEMS_RB_INIT(root)
#define RTEMS_RB_BLACK   0
#define RTEMS_RB_RED   1
#define RTEMS_RB_ENTRY(type)
#define RTEMS_RB_LEFT(elm, field)   (elm)->field.rbe_left
#define RTEMS_RB_RIGHT(elm, field)   (elm)->field.rbe_right
#define RTEMS_RB_PARENT(elm, field)   (elm)->field.rbe_parent
#define RTEMS_RB_COLOR(elm, field)   (elm)->field.rbe_color
#define RTEMS_RB_ISRED(elm, field)   ((elm) != NULL && RTEMS_RB_COLOR(elm, field) == RTEMS_RB_RED)
#define RTEMS_RB_ROOT(head)   (head)->rbh_root
#define RTEMS_RB_EMPTY(head)   (RTEMS_RB_ROOT(head) == NULL)
#define RTEMS_RB_SET_PARENT(dst, src, field)
#define RTEMS_RB_SET(elm, parent, field)
#define RTEMS_RB_SET_BLACKRED(black, red, field)
#define RTEMS_RB_AUGMENT(x)   break
#define RTEMS_RB_SWAP_CHILD(head, out, in, field)
#define RTEMS_RB_ROTATE_LEFT(head, elm, tmp, field)
#define RTEMS_RB_ROTATE_RIGHT(head, elm, tmp, field)
#define RTEMS_RB_PARENT_ROTATE_LEFT(parent, left, tmp, field)
#define RTEMS_RB_PARENT_ROTATE_RIGHT(parent, right, tmp, field)
#define RTEMS_RB_RED_ROTATE_LEFT(head, elm, tmp, field)
#define RTEMS_RB_RED_ROTATE_RIGHT(head, elm, tmp, field)
#define RTEMS_RB_PROTOTYPE(name, type, field, cmp)    RTEMS_RB_PROTOTYPE_INTERNAL(name, type, field, cmp,)
#define RTEMS_RB_PROTOTYPE_STATIC(name, type, field, cmp)    RTEMS_RB_PROTOTYPE_INTERNAL(name, type, field, cmp, __unused static)
#define RTEMS_RB_PROTOTYPE_INTERNAL(name, type, field, cmp, attr)
#define RTEMS_RB_PROTOTYPE_INSERT_COLOR(name, type, attr)    attr void name##_RTEMS_RB_INSERT_COLOR(struct name *, struct type *)
#define RTEMS_RB_PROTOTYPE_REMOVE_COLOR(name, type, attr)    attr void name##_RTEMS_RB_REMOVE_COLOR(struct name *, struct type *)
#define RTEMS_RB_PROTOTYPE_REMOVE(name, type, attr)    attr struct type *name##_RTEMS_RB_REMOVE(struct name *, struct type *)
#define RTEMS_RB_PROTOTYPE_INSERT(name, type, attr)    attr struct type *name##_RTEMS_RB_INSERT(struct name *, struct type *)
#define RTEMS_RB_PROTOTYPE_FIND(name, type, attr)    attr struct type *name##_RTEMS_RB_FIND(struct name *, struct type *)
#define RTEMS_RB_PROTOTYPE_NFIND(name, type, attr)    attr struct type *name##_RTEMS_RB_NFIND(struct name *, struct type *)
#define RTEMS_RB_PROTOTYPE_NEXT(name, type, attr)    attr struct type *name##_RTEMS_RB_NEXT(struct type *)
#define RTEMS_RB_PROTOTYPE_PREV(name, type, attr)    attr struct type *name##_RTEMS_RB_PREV(struct type *)
#define RTEMS_RB_PROTOTYPE_MINMAX(name, type, attr)    attr struct type *name##_RTEMS_RB_MINMAX(struct name *, int)
#define RTEMS_RB_PROTOTYPE_REINSERT(name, type, attr)    attr struct type *name##_RTEMS_RB_REINSERT(struct name *, struct type *)
#define RTEMS_RB_GENERATE(name, type, field, cmp)    RTEMS_RB_GENERATE_INTERNAL(name, type, field, cmp,)
#define RTEMS_RB_GENERATE_STATIC(name, type, field, cmp)    RTEMS_RB_GENERATE_INTERNAL(name, type, field, cmp, __unused static)
#define RTEMS_RB_GENERATE_INTERNAL(name, type, field, cmp, attr)
#define RTEMS_RB_GENERATE_INSERT_COLOR(name, type, field, attr)
#define RTEMS_RB_GENERATE_REMOVE_COLOR(name, type, field, attr)
#define RTEMS_RB_GENERATE_REMOVE(name, type, field, attr)
#define RTEMS_RB_GENERATE_INSERT(name, type, field, cmp, attr)
#define RTEMS_RB_GENERATE_FIND(name, type, field, cmp, attr)
#define RTEMS_RB_GENERATE_NFIND(name, type, field, cmp, attr)
#define RTEMS_RB_GENERATE_NEXT(name, type, field, attr)
#define RTEMS_RB_GENERATE_PREV(name, type, field, attr)
#define RTEMS_RB_GENERATE_MINMAX(name, type, field, attr)
#define RTEMS_RB_GENERATE_REINSERT(name, type, field, cmp, attr)
#define RTEMS_RB_NEGINF   -1
#define RTEMS_RB_INF   1
#define RTEMS_RB_INSERT(name, x, y)   name##_RTEMS_RB_INSERT(x, y)
#define RTEMS_RB_REMOVE(name, x, y)   name##_RTEMS_RB_REMOVE(x, y)
#define RTEMS_RB_FIND(name, x, y)   name##_RTEMS_RB_FIND(x, y)
#define RTEMS_RB_NFIND(name, x, y)   name##_RTEMS_RB_NFIND(x, y)
#define RTEMS_RB_NEXT(name, x, y)   name##_RTEMS_RB_NEXT(y)
#define RTEMS_RB_PREV(name, x, y)   name##_RTEMS_RB_PREV(y)
#define RTEMS_RB_MIN(name, x)   name##_RTEMS_RB_MINMAX(x, RTEMS_RB_NEGINF)
#define RTEMS_RB_MAX(name, x)   name##_RTEMS_RB_MINMAX(x, RTEMS_RB_INF)
#define RTEMS_RB_REINSERT(name, x, y)   name##_RTEMS_RB_REINSERT(x, y)
#define RTEMS_RB_FOREACH(x, name, head)
#define RTEMS_RB_FOREACH_FROM(x, name, y)
#define RTEMS_RB_FOREACH_SAFE(x, name, head, y)
#define RTEMS_RB_FOREACH_REVERSE(x, name, head)
#define RTEMS_RB_FOREACH_REVERSE_FROM(x, name, y)
#define RTEMS_RB_FOREACH_REVERSE_SAFE(x, name, head, y)
The contents of this file come from the above version of FreeBSD with local changes applied in Newlib and then migrated to RTEMS. These changes lock RTEMS to a specific version of this file. As a result, the macros defined in this file have been scoped with an RTEMS_ namespace. This allows other versions of tree.h to be used by RTEMS libraries and applications without conflicts.
◆ RTEMS_RB_ENTRY
#define RTEMS_RB_ENTRY (   type)
Value:
struct { \
struct type *rbe_left; /* left element */ \
struct type *rbe_right; /* right element */ \
struct type *rbe_parent; /* parent element */ \
int rbe_color; /* node color */ \
◆ RTEMS_RB_FOREACH
#define RTEMS_RB_FOREACH (   x,
  name,
  head
Value:
for ((x) = RTEMS_RB_MIN(name, head); \
(x) != NULL; \
(x) = name##_RTEMS_RB_NEXT(x))
◆ RTEMS_RB_FOREACH_FROM
#define RTEMS_RB_FOREACH_FROM (   x,
  name,
Value:
for ((x) = (y); \
((x) != NULL) && ((y) = name##_RTEMS_RB_NEXT(x), (x) != NULL); \
(x) = (y))
◆ RTEMS_RB_FOREACH_REVERSE
#define RTEMS_RB_FOREACH_REVERSE (   x,
  name,
  head
Value:
for ((x) = RTEMS_RB_MAX(name, head); \
(x) != NULL; \
(x) = name##_RTEMS_RB_PREV(x))
◆ RTEMS_RB_FOREACH_REVERSE_FROM
#define RTEMS_RB_FOREACH_REVERSE_FROM (   x,
  name,
Value:
for ((x) = (y); \
((x) != NULL) && ((y) = name##_RTEMS_RB_PREV(x), (x) != NULL); \
(x) = (y))
◆ RTEMS_RB_FOREACH_REVERSE_SAFE
#define RTEMS_RB_FOREACH_REVERSE_SAFE (   x,
  name,
  head,
Value:
(x) = (y))
◆ RTEMS_RB_FOREACH_SAFE
#define RTEMS_RB_FOREACH_SAFE (   x,
  name,
  head,
Value:
(x) = (y))
◆ RTEMS_RB_GENERATE_FIND
#define RTEMS_RB_GENERATE_FIND (   name,
  type,
  field,
  cmp,
  attr
Value:
/* Finds the node with the same key as elm */ \
attr struct type * \
name##_RTEMS_RB_FIND(struct name *head, struct type *elm) \
struct type *tmp = RTEMS_RB_ROOT(head); \
int comp; \
while (tmp) { \
comp = cmp(elm, tmp); \
if (comp < 0) \
tmp = RTEMS_RB_LEFT(tmp, field); \
else if (comp > 0) \
tmp = RTEMS_RB_RIGHT(tmp, field); \
else \
return (tmp); \
return (NULL); \
◆ RTEMS_RB_GENERATE_INTERNAL
#define RTEMS_RB_GENERATE_INTERNAL (   name,
  type,
  field,
  cmp,
  attr
Value:
RTEMS_RB_GENERATE_INSERT_COLOR(name, type, field, attr) \
RTEMS_RB_GENERATE_REMOVE_COLOR(name, type, field, attr) \
RTEMS_RB_GENERATE_INSERT(name, type, field, cmp, attr) \
RTEMS_RB_GENERATE_REMOVE(name, type, field, attr) \
RTEMS_RB_GENERATE_FIND(name, type, field, cmp, attr) \
RTEMS_RB_GENERATE_NFIND(name, type, field, cmp, attr) \
RTEMS_RB_GENERATE_NEXT(name, type, field, attr) \
RTEMS_RB_GENERATE_PREV(name, type, field, attr) \
RTEMS_RB_GENERATE_MINMAX(name, type, field, attr) \
◆ RTEMS_RB_GENERATE_MINMAX
#define RTEMS_RB_GENERATE_MINMAX (   name,
  type,
  field,
  attr
Value:
name##_RTEMS_RB_MINMAX(struct name *head, int val) \
struct type *parent = NULL; \
while (tmp) { \
parent = tmp; \
if (val < 0) \
else \
return (parent); \
◆ RTEMS_RB_GENERATE_NEXT
#define RTEMS_RB_GENERATE_NEXT (   name,
  type,
  field,
  attr
Value:
/* ARGSUSED */ \
name##_RTEMS_RB_NEXT(struct type *elm) \
if (RTEMS_RB_RIGHT(elm, field)) { \
elm = RTEMS_RB_RIGHT(elm, field); \
while (RTEMS_RB_LEFT(elm, field)) \
elm = RTEMS_RB_LEFT(elm, field); \
} else { \
if (RTEMS_RB_PARENT(elm, field) && \
(elm == RTEMS_RB_LEFT(RTEMS_RB_PARENT(elm, field), field))) \
elm = RTEMS_RB_PARENT(elm, field); \
else { \
while (RTEMS_RB_PARENT(elm, field) && \
(elm == RTEMS_RB_RIGHT(RTEMS_RB_PARENT(elm, field), field)))\
return (elm); \
◆ RTEMS_RB_GENERATE_NFIND
#define RTEMS_RB_GENERATE_NFIND (   name,
  type,
  field,
  cmp,
  attr
Value:
/* Finds the first node greater than or equal to the search key */ \
name##_RTEMS_RB_NFIND(struct name *head, struct type *elm) \
struct type *res = NULL; \
int comp; \
while (tmp) { \
if (comp < 0) { \
res = tmp; \
else \
return (tmp); \
return (res); \
◆ RTEMS_RB_GENERATE_PREV
#define RTEMS_RB_GENERATE_PREV (   name,
  type,
  field,
  attr
Value:
/* ARGSUSED */ \
name##_RTEMS_RB_PREV(struct type *elm) \
if (RTEMS_RB_LEFT(elm, field)) { \
while (RTEMS_RB_RIGHT(elm, field)) \
} else { \
(elm == RTEMS_RB_RIGHT(RTEMS_RB_PARENT(elm, field), field))) \
else { \
(elm == RTEMS_RB_LEFT(RTEMS_RB_PARENT(elm, field), field)))\
return (elm); \
◆ RTEMS_RB_GENERATE_REINSERT
#define RTEMS_RB_GENERATE_REINSERT (   name,
  type,
  field,
  cmp,
  attr
Value:
name##_RTEMS_RB_REINSERT(struct name *head, struct type *elm) \
struct type *cmpelm; \
if (((cmpelm = RTEMS_RB_PREV(name, head, elm)) != NULL && \
cmp(cmpelm, elm) >= 0) || \
((cmpelm = RTEMS_RB_NEXT(name, head, elm)) != NULL && \
cmp(elm, cmpelm) >= 0)) { \
/* XXXLAS: Remove/insert is heavy handed. */ \
RTEMS_RB_REMOVE(name, head, elm); \
return (RTEMS_RB_INSERT(name, head, elm)); \
return (NULL); \
◆ RTEMS_RB_HEAD
#define RTEMS_RB_HEAD (   name,
  type
Value:
struct name { \
struct type *rbh_root; /* root of the tree */ \
◆ RTEMS_RB_INIT
#define RTEMS_RB_INIT (   root)
Value:
do { \
(root)->rbh_root = NULL; \
} while (/*CONSTCOND*/ 0)
◆ RTEMS_RB_PARENT_ROTATE_LEFT
#define RTEMS_RB_PARENT_ROTATE_LEFT (   parent,
  left,
  tmp,
  field
Value:
do { \
(tmp) = RTEMS_RB_RIGHT(left, field); \
if ((RTEMS_RB_RIGHT(left, field) = RTEMS_RB_LEFT(tmp, field)) != NULL) { \
RTEMS_RB_SET_PARENT(RTEMS_RB_RIGHT(left, field), left, field); \
RTEMS_RB_SET_PARENT(tmp, parent, field); \
RTEMS_RB_LEFT(parent, field) = (tmp); \
RTEMS_RB_LEFT(tmp, field) = (left); \
RTEMS_RB_SET_PARENT(left, tmp, field); \
RTEMS_RB_AUGMENT(left); \
◆ RTEMS_RB_PARENT_ROTATE_RIGHT
#define RTEMS_RB_PARENT_ROTATE_RIGHT (   parent,
  right,
  tmp,
  field
Value:
do { \
(tmp) = RTEMS_RB_LEFT(right, field); \
if ((RTEMS_RB_LEFT(right, field) = RTEMS_RB_RIGHT(tmp, field)) != NULL) { \
RTEMS_RB_SET_PARENT(RTEMS_RB_LEFT(right, field), right, field); \
RTEMS_RB_RIGHT(parent, field) = (tmp); \
RTEMS_RB_RIGHT(tmp, field) = (right); \
RTEMS_RB_SET_PARENT(right, tmp, field); \
RTEMS_RB_AUGMENT(right); \
◆ RTEMS_RB_PROTOTYPE_INTERNAL
#define RTEMS_RB_PROTOTYPE_INTERNAL (   name,
  type,
  field,
  cmp,
  attr
Value:
RTEMS_RB_PROTOTYPE_INSERT_COLOR(name, type, attr); \
RTEMS_RB_PROTOTYPE_REMOVE_COLOR(name, type, attr); \
RTEMS_RB_PROTOTYPE_INSERT(name, type, attr); \
RTEMS_RB_PROTOTYPE_REMOVE(name, type, attr); \
RTEMS_RB_PROTOTYPE_FIND(name, type, attr); \
RTEMS_RB_PROTOTYPE_NFIND(name, type, attr); \
RTEMS_RB_PROTOTYPE_NEXT(name, type, attr); \
RTEMS_RB_PROTOTYPE_PREV(name, type, attr); \
RTEMS_RB_PROTOTYPE_MINMAX(name, type, attr); \
RTEMS_RB_PROTOTYPE_REINSERT(name, type, attr);
◆ RTEMS_RB_RED_ROTATE_LEFT
#define RTEMS_RB_RED_ROTATE_LEFT (   head,
  elm,
  tmp,
  field
Value:
do { \
(tmp) = RTEMS_RB_RIGHT(elm, field); \
RTEMS_RB_RIGHT(elm, field) = RTEMS_RB_LEFT(tmp, field); \
RTEMS_RB_SET_PARENT(RTEMS_RB_RIGHT(elm, field), elm, field); \
RTEMS_RB_SET_PARENT(tmp, RTEMS_RB_PARENT(elm, field), field); \
RTEMS_RB_SWAP_CHILD(head, elm, tmp, field); \
RTEMS_RB_LEFT(tmp, field) = (elm); \
RTEMS_RB_SET_PARENT(elm, tmp, field); \
RTEMS_RB_AUGMENT(elm); \
◆ RTEMS_RB_RED_ROTATE_RIGHT
#define RTEMS_RB_RED_ROTATE_RIGHT (   head,
  elm,
  tmp,
  field
Value:
do { \
(tmp) = RTEMS_RB_LEFT(elm, field); \
RTEMS_RB_LEFT(elm, field) = RTEMS_RB_RIGHT(tmp, field); \
RTEMS_RB_SET_PARENT(RTEMS_RB_LEFT(elm, field), elm, field); \
RTEMS_RB_RIGHT(tmp, field) = (elm); \
◆ RTEMS_RB_ROTATE_LEFT
#define RTEMS_RB_ROTATE_LEFT (   head,
  elm,
  tmp,
  field
Value:
do { \
if ((RTEMS_RB_RIGHT(elm, field) = RTEMS_RB_LEFT(tmp, field)) != NULL) { \
◆ RTEMS_RB_ROTATE_RIGHT
#define RTEMS_RB_ROTATE_RIGHT (   head,
  elm,
  tmp,
  field
Value:
do { \
if ((RTEMS_RB_LEFT(elm, field) = RTEMS_RB_RIGHT(tmp, field)) != NULL) { \
◆ RTEMS_RB_SET
#define RTEMS_RB_SET (   elm,
  parent,
  field
Value:
do { \
RTEMS_RB_SET_PARENT(elm, parent, field); \
RTEMS_RB_LEFT(elm, field) = RTEMS_RB_RIGHT(elm, field) = NULL; \
RTEMS_RB_COLOR(elm, field) = RTEMS_RB_RED; \
◆ RTEMS_RB_SET_BLACKRED
#define RTEMS_RB_SET_BLACKRED (   black,
  red,
  field
Value:
do { \
RTEMS_RB_COLOR(black, field) = RTEMS_RB_BLACK; \
RTEMS_RB_COLOR(red, field) = RTEMS_RB_RED; \
◆ RTEMS_RB_SET_PARENT
#define RTEMS_RB_SET_PARENT (   dst,
  src,
  field
Value:
do { \
RTEMS_RB_PARENT(dst, field) = src; \
◆ RTEMS_RB_SWAP_CHILD
#define RTEMS_RB_SWAP_CHILD (   head,
  out,
  in,
  field
Value:
do { \
if (RTEMS_RB_PARENT(out, field) == NULL) \
RTEMS_RB_ROOT(head) = (in); \
else if ((out) == RTEMS_RB_LEFT(RTEMS_RB_PARENT(out, field), field)) \
RTEMS_RB_LEFT(RTEMS_RB_PARENT(out, field), field) = (in); \
else \
RTEMS_RB_RIGHT(RTEMS_RB_PARENT(out, field), field) = (in); \
◆ RTEMS_SPLAY_ASSEMBLE
#define RTEMS_SPLAY_ASSEMBLE (   head,
  node,
  left,
  right,
  field
Value:
do { \
RTEMS_SPLAY_RIGHT(left, field) = RTEMS_SPLAY_LEFT((head)->sph_root, field); \
RTEMS_SPLAY_LEFT(right, field) = RTEMS_SPLAY_RIGHT((head)->sph_root, field);\
RTEMS_SPLAY_LEFT((head)->sph_root, field) = RTEMS_SPLAY_RIGHT(node, field); \
RTEMS_SPLAY_RIGHT((head)->sph_root, field) = RTEMS_SPLAY_LEFT(node, field); \
◆ RTEMS_SPLAY_ENTRY
#define RTEMS_SPLAY_ENTRY (   type)
Value:
struct { \
struct type *spe_left; /* left element */ \
struct type *spe_right; /* right element */ \
◆ RTEMS_SPLAY_FOREACH
#define RTEMS_SPLAY_FOREACH (   x,
  name,
  head
Value:
for ((x) = RTEMS_SPLAY_MIN(name, head); \
(x) != NULL; \
(x) = RTEMS_SPLAY_NEXT(name, head, x))
◆ RTEMS_SPLAY_HEAD
#define RTEMS_SPLAY_HEAD (   name,
  type
Value:
struct name { \
struct type *sph_root; /* root of the tree */ \
◆ RTEMS_SPLAY_INIT
#define RTEMS_SPLAY_INIT (   root)
Value:
do { \
(root)->sph_root = NULL; \
◆ RTEMS_SPLAY_LINKLEFT
#define RTEMS_SPLAY_LINKLEFT (   head,
  tmp,
  field
Value:
do { \
RTEMS_SPLAY_LEFT(tmp, field) = (head)->sph_root; \
tmp = (head)->sph_root; \
(head)->sph_root = RTEMS_SPLAY_LEFT((head)->sph_root, field); \
◆ RTEMS_SPLAY_LINKRIGHT
#define RTEMS_SPLAY_LINKRIGHT (   head,
  tmp,
  field
Value:
do { \
RTEMS_SPLAY_RIGHT(tmp, field) = (head)->sph_root; \
(head)->sph_root = RTEMS_SPLAY_RIGHT((head)->sph_root, field); \
◆ RTEMS_SPLAY_MAX
#define RTEMS_SPLAY_MAX (   name,
Value:
(RTEMS_SPLAY_EMPTY(x) ? NULL \
: name##_RTEMS_SPLAY_MIN_MAX(x, RTEMS_SPLAY_INF))
◆ RTEMS_SPLAY_MIN
#define RTEMS_SPLAY_MIN (   name,
Value:
: name##_RTEMS_SPLAY_MIN_MAX(x, RTEMS_SPLAY_NEGINF))
◆ RTEMS_SPLAY_ROTATE_LEFT
#define RTEMS_SPLAY_ROTATE_LEFT (   head,
  tmp,
  field
Value:
do { \
RTEMS_SPLAY_RIGHT((head)->sph_root, field) = RTEMS_SPLAY_LEFT(tmp, field); \
(head)->sph_root = tmp; \
◆ RTEMS_SPLAY_ROTATE_RIGHT
#define RTEMS_SPLAY_ROTATE_RIGHT (   head,
  tmp,
  field
Value:
do { \
RTEMS_SPLAY_LEFT((head)->sph_root, field) = RTEMS_SPLAY_RIGHT(tmp, field); \
