RTEMS 6.1-rc2
Data Structures | Typedefs
userext.h File Reference
This header file provides interfaces of the User Extensions Handler which are used by the implementation and the Application Configuration. More...
#include <rtems/score/interr.h>
struct  User_extensions_Table
 User extension table. More...
typedef bool(* User_extensions_thread_create_extension) (struct _Thread_Control *executing, struct _Thread_Control *created)
 Task create extension.
typedef void(* User_extensions_thread_delete_extension) (struct _Thread_Control *executing, struct _Thread_Control *deleted)
 Task delete extension.
typedef void(* User_extensions_thread_start_extension) (struct _Thread_Control *executing, struct _Thread_Control *started)
 Task start extension.
typedef void(* User_extensions_thread_restart_extension) (struct _Thread_Control *executing, struct _Thread_Control *restarted)
 Task restart extension.
typedef void(* User_extensions_thread_switch_extension) (struct _Thread_Control *executing, struct _Thread_Control *heir)
 Task switch extension.
typedef void(* User_extensions_thread_begin_extension) (struct _Thread_Control *executing)
 Task begin extension.
typedef void(* User_extensions_thread_exitted_extension) (struct _Thread_Control *executing)
 Task exitted extension.
typedef void(* User_extensions_fatal_extension) (Internal_errors_Source source, bool always_set_to_false, Internal_errors_t code)
 Fatal error extension.
typedef void(* User_extensions_thread_terminate_extension) (struct _Thread_Control *terminated)
 Task termination extension.
