RTEMS 6.1-rc2
telnetd.c File Reference
The telnet DAEMON. More...
#include <sys/queue.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <arpa/inet.h>
#include <inttypes.h>
#include <unistd.h>
#include <syslog.h>
#include <rtems/pty.h>
#include <rtems/shell.h>
#include <rtems/telnetd.h>
#include <rtems/thread.h>
#include <rtems/userenv.h>
struct  telnetd_session
struct  telnetd_context
union  telnetd_address
#define TELNETD_EVENT_SUCCESS   RTEMS_EVENT_0
#define TELNETD_EVENT_ERROR   RTEMS_EVENT_1
typedef struct telnetd_context telnetd_context
typedef struct telnetd_session telnetd_session
rtems_status_code rtems_telnetd_start (const rtems_telnetd_config_table *config)
 Starts the Telnet server using the provided configuration.
The telnet DAEMON.
After start the net you can start this daemon. It uses the previously inited pseudo-terminales (pty.c) getting a new terminal with getpty(). This function gives a terminal name passing a opened socket like parameter.
With register_telnetd() you add a new command in the shell to start this daemon interactively. (Login in /dev/console of course)
Sorry but OOB is not still implemented. (This is the first version)
◆ rtems_telnetd_start()
rtems_status_code rtems_telnetd_start ( const rtems_telnetd_config_table config)
Return values
RTEMS_SUCCESSFULSuccessful operation.
RTEMS_INVALID_ADDRESSThe command function in the configuration is NULL.
RTEMS_RESOURCE_IN_USEThe server port is already in use.
RTEMS_NOT_IMPLEMENTEDThe keep stdio configuration option is true.
RTEMS_UNSATISFIEDNot enough resources to start the Telnet server or task priority in configuration is invalid.
