RTEMS 6.1-rc2
ASR_Information Struct Reference
#include <asrdata.h>
bool is_enabled
rtems_asr_entry handler
rtems_mode mode_set
rtems_signal_set signals_pending
The following defines the control structure used to manage signals. Each thread has a copy of this record.
Field Documentation
◆ handler
rtems_asr_entry ASR_Information::handler
This field indicates if address of the signal handler function.
◆ is_enabled
bool ASR_Information::is_enabled
This field indicates if are ASRs enabled currently.
◆ mode_set
rtems_mode ASR_Information::mode_set
This field indicates if the task mode the signal will run with.
◆ signals_pending
rtems_signal_set ASR_Information::signals_pending
This field indicates the signal set that is pending.
