RTEMS 6.1-rc2
rtems_filesystem_global_location_t Struct Reference
Global file system location. More...
#include <fs.h>
rtems_filesystem_location_info_t location
int reference_count
struct rtems_filesystem_global_location_tdeferred_released_next
int deferred_released_count
The global file system locations are used for
During the path evaluation global start locations are obtained to ensure that the current file system will be not unmounted in the meantime.
To support a release within critical sections of the operating system a deferred release is supported. This is similar to malloc() and free().
See also
rtems_filesystem_global_location_obtain() and rtems_filesystem_global_location_release().
Field Documentation
◆ deferred_released_count
int rtems_filesystem_global_location_t::deferred_released_count
A release within a critical section can happen multiple times. This field counts the deferred releases.
◆ deferred_released_next
struct rtems_filesystem_global_location_t* rtems_filesystem_global_location_t::deferred_released_next
A release within a critical section of the operating system will add this location to a list of deferred released locations. This list is processed in the next rtems_filesystem_global_location_obtain() in FIFO order.
