RTEMS 6.1-rc2
rtems_debugger_block Struct Reference
#include <rtems-debugger-block.h>
void * block
size_t step
size_t size
size_t count
size_t level
DB server block manages a block of re-sizable memory. The block only grows. As more threads enter the system the block becomes the peak and then sits at that level.
Field Documentation
◆ block
void* rtems_debugger_block::block
The block of memory.
◆ count
size_t rtems_debugger_block::count
The number of elements in the block.
◆ level
size_t rtems_debugger_block::level
The usage level in the block.
◆ size
size_t rtems_debugger_block::size
The size of the elements in the block.
◆ step
size_t rtems_debugger_block::step
The step size the block is increased by.
