RTEMS 6.1-rc2
rtems-debugger-block.h
1/*
2 * Copyright (c) 2016 Chris Johns <chrisj@rtems.org>.
3 * All rights reserved.
4 *
5 * Redistribution and use in source and binary forms, with or without
6 * modification, are permitted provided that the following conditions
7 * are met:
8 * 1. Redistributions of source code must retain the above copyright
9 * notice, this list of conditions and the following disclaimer.
10 * 2. Redistributions in binary form must reproduce the above copyright
11 * notice, this list of conditions and the following disclaimer in the
12 * documentation and/or other materials provided with the distribution.
13 *
14 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
15 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
16 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
17 * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
18 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
19 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
20 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
21 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
22 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
23 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
24 * SUCH DAMAGE.
25 */
26
27/*
28 * Debugger for RTEMS.
29 */
30
31#ifndef _RTEMS_DEBUGGER_BLOCK_h
32#define _RTEMS_DEBUGGER_BLOCK_h
33
34#include <rtems/rtems-debugger.h>
35
36#ifdef __cplusplus
37extern "C" {
38#endif /* __cplusplus */
39
46{
47 void* block;
48 size_t step;
49 size_t size;
50 size_t count;
51 size_t level;
53
57extern int rtems_debugger_block_create(rtems_debugger_block* block,
58 size_t step,
59 size_t size);
60
64extern int rtems_debugger_block_destroy(rtems_debugger_block* block);
65
69extern int rtems_debugger_block_resize(rtems_debugger_block* block);
70
71#ifdef __cplusplus
72}
73#endif /* __cplusplus */
74
75
76#endif
Definition: rtems-debugger-block.h:46
void * block
Definition: rtems-debugger-block.h:47
size_t size
Definition: rtems-debugger-block.h:49
size_t count
Definition: rtems-debugger-block.h:50
size_t level
Definition: rtems-debugger-block.h:51
size_t step
Definition: rtems-debugger-block.h:48
