RTEMS 6.1-rc2
_lpspi_master_handle Struct Reference
LPSPI master transfer handle structure used for transactional API. More...
#include <fsl_lpspi.h>
volatile bool isPcsContinuous
volatile bool writeTcrInIsr
volatile bool isByteSwap
volatile bool isTxMask
volatile uint16_t bytesPerFrame
volatile uint8_t fifoSize
volatile uint8_t rxWatermark
volatile uint8_t bytesEachWrite
volatile uint8_t bytesEachRead
uint8_t *volatile txData
uint8_t *volatile rxData
volatile size_t txRemainingByteCount
volatile size_t rxRemainingByteCount
volatile uint32_t writeRegRemainingTimes
volatile uint32_t readRegRemainingTimes
uint32_t totalByteCount
uint32_t txBuffIfNull
volatile uint8_t state
lpspi_master_transfer_callback_t callback
void * userData
Field Documentation
◆ bytesEachRead
volatile uint8_t _lpspi_master_handle::bytesEachRead
Bytes for each read RDR.
◆ bytesEachWrite
volatile uint8_t _lpspi_master_handle::bytesEachWrite
Bytes for each write TDR.
◆ bytesPerFrame
volatile uint16_t _lpspi_master_handle::bytesPerFrame
Number of bytes in each frame
◆ callback
lpspi_master_transfer_callback_t _lpspi_master_handle::callback
Completion callback.
◆ fifoSize
volatile uint8_t _lpspi_master_handle::fifoSize
FIFO dataSize.
◆ isByteSwap
volatile bool _lpspi_master_handle::isByteSwap
A flag that whether should byte swap.
◆ isPcsContinuous
volatile bool _lpspi_master_handle::isPcsContinuous
Is PCS continuous in transfer.
◆ isTxMask
volatile bool _lpspi_master_handle::isTxMask
A flag that whether TCR[TXMSK] is set.
◆ readRegRemainingTimes
volatile uint32_t _lpspi_master_handle::readRegRemainingTimes
Read RDR register remaining times.
◆ rxData
uint8_t* volatile _lpspi_master_handle::rxData
Receive buffer.
◆ rxRemainingByteCount
volatile size_t _lpspi_master_handle::rxRemainingByteCount
Number of bytes remaining to receive.
◆ rxWatermark
volatile uint8_t _lpspi_master_handle::rxWatermark
Rx watermark.
◆ state
volatile uint8_t _lpspi_master_handle::state
LPSPI transfer state , _lpspi_transfer_state.
◆ totalByteCount
uint32_t _lpspi_master_handle::totalByteCount
Number of transfer bytes
◆ txBuffIfNull
uint32_t _lpspi_master_handle::txBuffIfNull
Used if the txData is NULL.
◆ txData
uint8_t* volatile _lpspi_master_handle::txData
Send buffer.
◆ txRemainingByteCount
volatile size_t _lpspi_master_handle::txRemainingByteCount
Number of bytes remaining to send.
◆ userData
void* _lpspi_master_handle::userData
Callback user data.
◆ writeRegRemainingTimes
volatile uint32_t _lpspi_master_handle::writeRegRemainingTimes
Write TDR register remaining times.
◆ writeTcrInIsr
volatile bool _lpspi_master_handle::writeTcrInIsr
A flag that whether should write TCR in ISR.
