RTEMS 6.1-rc2
Lpspi_driver
struct  _lpspi_master_config
 LPSPI master configuration structure. More...
struct  _lpspi_slave_config
 LPSPI slave configuration structure. More...
struct  _lpspi_transfer
 LPSPI master/slave transfer structure. More...
struct  _lpspi_master_handle
 LPSPI master transfer handle structure used for transactional API. More...
struct  _lpspi_slave_handle
 LPSPI slave transfer handle structure used for transactional API. More...
Driver version
enum  {
  kStatus_LPSPI_Busy = MAKE_STATUS(kStatusGroup_LPSPI, 0) , kStatus_LPSPI_Error = MAKE_STATUS(kStatusGroup_LPSPI, 1) , kStatus_LPSPI_Idle = MAKE_STATUS(kStatusGroup_LPSPI, 2) , kStatus_LPSPI_OutOfRange = MAKE_STATUS(kStatusGroup_LPSPI, 3) ,
  kStatus_LPSPI_Timeout = MAKE_STATUS(kStatusGroup_LPSPI, 4)
 Status for the LPSPI driver. More...
enum  _lpspi_flags {
  kLPSPI_TxDataRequestFlag = LPSPI_SR_TDF_MASK , kLPSPI_RxDataReadyFlag = LPSPI_SR_RDF_MASK , kLPSPI_WordCompleteFlag = LPSPI_SR_WCF_MASK , kLPSPI_FrameCompleteFlag = LPSPI_SR_FCF_MASK ,
  kLPSPI_TransferCompleteFlag = LPSPI_SR_TCF_MASK , kLPSPI_TransmitErrorFlag = LPSPI_SR_TEF_MASK , kLPSPI_ReceiveErrorFlag = LPSPI_SR_REF_MASK , kLPSPI_DataMatchFlag = LPSPI_SR_DMF_MASK ,
  kLPSPI_ModuleBusyFlag = LPSPI_SR_MBF_MASK , kLPSPI_AllStatusFlag
 LPSPI status flags in SPIx_SR register. More...
enum  _lpspi_interrupt_enable {
  kLPSPI_TxInterruptEnable = LPSPI_IER_TDIE_MASK , kLPSPI_RxInterruptEnable = LPSPI_IER_RDIE_MASK , kLPSPI_WordCompleteInterruptEnable = LPSPI_IER_WCIE_MASK , kLPSPI_FrameCompleteInterruptEnable = LPSPI_IER_FCIE_MASK ,
  kLPSPI_TransferCompleteInterruptEnable = LPSPI_IER_TCIE_MASK , kLPSPI_TransmitErrorInterruptEnable = LPSPI_IER_TEIE_MASK , kLPSPI_ReceiveErrorInterruptEnable = LPSPI_IER_REIE_MASK , kLPSPI_DataMatchInterruptEnable = LPSPI_IER_DMIE_MASK ,
  kLPSPI_AllInterruptEnable
 LPSPI interrupt source. More...
enum  _lpspi_dma_enable { kLPSPI_TxDmaEnable = LPSPI_DER_TDDE_MASK , kLPSPI_RxDmaEnable = LPSPI_DER_RDDE_MASK }
 LPSPI DMA source. More...
enum  _lpspi_master_slave_mode { kLPSPI_Master = 1U , kLPSPI_Slave = 0U }
 LPSPI master or slave mode configuration. More...
enum  _lpspi_which_pcs_config { kLPSPI_Pcs0 = 0U , kLPSPI_Pcs1 = 1U , kLPSPI_Pcs2 = 2U , kLPSPI_Pcs3 = 3U }
 LPSPI Peripheral Chip Select (PCS) configuration (which PCS to configure). More...
enum  _lpspi_pcs_polarity_config { kLPSPI_PcsActiveHigh = 1U , kLPSPI_PcsActiveLow = 0U }
 LPSPI Peripheral Chip Select (PCS) Polarity configuration. More...
enum  _lpspi_pcs_polarity {
  kLPSPI_Pcs0ActiveLow = 1U << 0 , kLPSPI_Pcs1ActiveLow = 1U << 1 , kLPSPI_Pcs2ActiveLow = 1U << 2 , kLPSPI_Pcs3ActiveLow = 1U << 3 ,
  kLPSPI_PcsAllActiveLow = 0xFU
 LPSPI Peripheral Chip Select (PCS) Polarity. More...
enum  _lpspi_clock_polarity { kLPSPI_ClockPolarityActiveHigh = 0U , kLPSPI_ClockPolarityActiveLow = 1U }
 LPSPI clock polarity configuration. More...
enum  _lpspi_clock_phase { kLPSPI_ClockPhaseFirstEdge = 0U , kLPSPI_ClockPhaseSecondEdge = 1U }
 LPSPI clock phase configuration. More...
enum  _lpspi_shift_direction { kLPSPI_MsbFirst = 0U , kLPSPI_LsbFirst = 1U }
 LPSPI data shifter direction options. More...
enum  _lpspi_host_request_select { kLPSPI_HostReqExtPin = 0U , kLPSPI_HostReqInternalTrigger = 1U }
 LPSPI Host Request select configuration. More...
enum  _lpspi_match_config {
  kLPSI_MatchDisabled = 0x0U , kLPSI_1stWordEqualsM0orM1 = 0x2U , kLPSI_AnyWordEqualsM0orM1 = 0x3U , kLPSI_1stWordEqualsM0and2ndWordEqualsM1 = 0x4U ,
  kLPSI_AnyWordEqualsM0andNxtWordEqualsM1 = 0x5U , kLPSI_1stWordAndM1EqualsM0andM1 = 0x6U , kLPSI_AnyWordAndM1EqualsM0andM1 = 0x7U
 LPSPI Match configuration options. More...
enum  _lpspi_pin_config { kLPSPI_SdiInSdoOut = 0U , kLPSPI_SdiInSdiOut = 1U , kLPSPI_SdoInSdoOut = 2U , kLPSPI_SdoInSdiOut = 3U }
 LPSPI pin (SDO and SDI) configuration. More...
enum  _lpspi_data_out_config { kLpspiDataOutRetained = 0U , kLpspiDataOutTristate = 1U }
 LPSPI data output configuration. More...
enum  _lpspi_transfer_width { kLPSPI_SingleBitXfer = 0U , kLPSPI_TwoBitXfer = 1U , kLPSPI_FourBitXfer = 2U }
 LPSPI transfer width configuration. More...
enum  _lpspi_delay_type { kLPSPI_PcsToSck = 1U , kLPSPI_LastSckToPcs , kLPSPI_BetweenTransfer }
 LPSPI delay type selection. More...
enum  _lpspi_transfer_config_flag_for_master {
  kLPSPI_MasterPcs0 = 0U << LPSPI_MASTER_PCS_SHIFT , kLPSPI_MasterPcs1 = 1U << LPSPI_MASTER_PCS_SHIFT , kLPSPI_MasterPcs2 = 2U << LPSPI_MASTER_PCS_SHIFT , kLPSPI_MasterPcs3 = 3U << LPSPI_MASTER_PCS_SHIFT ,
  kLPSPI_MasterPcsContinuous = 1U << 20 , kLPSPI_MasterByteSwap
 Use this enumeration for LPSPI master transfer configFlags. More...
enum  _lpspi_transfer_config_flag_for_slave {
  kLPSPI_SlavePcs0 = 0U << LPSPI_SLAVE_PCS_SHIFT , kLPSPI_SlavePcs1 = 1U << LPSPI_SLAVE_PCS_SHIFT , kLPSPI_SlavePcs2 = 2U << LPSPI_SLAVE_PCS_SHIFT , kLPSPI_SlavePcs3 = 3U << LPSPI_SLAVE_PCS_SHIFT ,
  kLPSPI_SlaveByteSwap
 Use this enumeration for LPSPI slave transfer configFlags. More...
enum  _lpspi_transfer_state { kLPSPI_Idle = 0x0U , kLPSPI_Busy , kLPSPI_Error }
 LPSPI transfer state, which is used for LPSPI transactional API state machine. More...
typedef enum _lpspi_master_slave_mode lpspi_master_slave_mode_t
typedef enum _lpspi_which_pcs_config lpspi_which_pcs_t
typedef enum _lpspi_pcs_polarity_config lpspi_pcs_polarity_config_t
typedef enum _lpspi_clock_polarity lpspi_clock_polarity_t
typedef enum _lpspi_clock_phase lpspi_clock_phase_t
typedef enum _lpspi_shift_direction lpspi_shift_direction_t
typedef enum _lpspi_host_request_select lpspi_host_request_select_t
typedef enum _lpspi_match_config lpspi_match_config_t
typedef enum _lpspi_pin_config lpspi_pin_config_t
typedef enum _lpspi_data_out_config lpspi_data_out_config_t
typedef enum _lpspi_transfer_width lpspi_transfer_width_t
typedef enum _lpspi_delay_type lpspi_delay_type_t
typedef struct _lpspi_master_config lpspi_master_config_t
typedef struct _lpspi_slave_config lpspi_slave_config_t
typedef struct _lpspi_master_handle lpspi_master_handle_t
 Forward declaration of the _lpspi_master_handle typedefs.
typedef struct _lpspi_slave_handle lpspi_slave_handle_t
 Forward declaration of the _lpspi_slave_handle typedefs.
typedef void(* lpspi_master_transfer_callback_t) (LPSPI_Type *base, lpspi_master_handle_t *handle, status_t status, void *userData)
 Master completion callback function pointer type.
typedef void(* lpspi_slave_transfer_callback_t) (LPSPI_Type *base, lpspi_slave_handle_t *handle, status_t status, void *userData)
 Slave completion callback function pointer type.
typedef struct _lpspi_transfer lpspi_transfer_t
volatile uint8_t g_lpspiDummyData []
 Global variable for dummy data value setting.
#define FSL_LPSPI_DRIVER_VERSION   (MAKE_VERSION(2, 4, 0))
 LPSPI driver version.
#define LPSPI_DUMMY_DATA   (0x00U)
 LPSPI dummy data if no Tx data.
#define SPI_RETRY_TIMES   0U /* Define to zero means keep waiting until the flag is assert/deassert. */
 Retry times for waiting flag.
#define LPSPI_MASTER_PCS_SHIFT   (4U)
#define LPSPI_MASTER_PCS_MASK   (0xF0U)
#define LPSPI_SLAVE_PCS_SHIFT   (4U)
#define LPSPI_SLAVE_PCS_MASK   (0xF0U)
Initialization and deinitialization
void LPSPI_MasterInit (LPSPI_Type *base, const lpspi_master_config_t *masterConfig, uint32_t srcClock_Hz)
 Initializes the LPSPI master.
void LPSPI_MasterGetDefaultConfig (lpspi_master_config_t *masterConfig)
 Sets the lpspi_master_config_t structure to default values.
void LPSPI_SlaveInit (LPSPI_Type *base, const lpspi_slave_config_t *slaveConfig)
 LPSPI slave configuration.
void LPSPI_SlaveGetDefaultConfig (lpspi_slave_config_t *slaveConfig)
 Sets the lpspi_slave_config_t structure to default values.
void LPSPI_Deinit (LPSPI_Type *base)
 De-initializes the LPSPI peripheral. Call this API to disable the LPSPI clock.
void LPSPI_Reset (LPSPI_Type *base)
 Restores the LPSPI peripheral to reset state. Note that this function sets all registers to reset state. As a result, the LPSPI module can't work after calling this API.
uint32_t LPSPI_GetInstance (LPSPI_Type *base)
 Get the LPSPI instance from peripheral base address.
Bus Operations
bool LPSPI_CheckTransferArgument (LPSPI_Type *base, lpspi_transfer_t *transfer, bool isEdma)
 Check the argument for transfer .
uint32_t LPSPI_MasterSetBaudRate (LPSPI_Type *base, uint32_t baudRate_Bps, uint32_t srcClock_Hz, uint32_t *tcrPrescaleValue)
 Sets the LPSPI baud rate in bits per second.
void LPSPI_MasterSetDelayScaler (LPSPI_Type *base, uint32_t scaler, lpspi_delay_type_t whichDelay)
 Manually configures a specific LPSPI delay parameter (module must be disabled to change the delay values).
uint32_t LPSPI_MasterSetDelayTimes (LPSPI_Type *base, uint32_t delayTimeInNanoSec, lpspi_delay_type_t whichDelay, uint32_t srcClock_Hz)
 Calculates the delay based on the desired delay input in nanoseconds (module must be disabled to change the delay values).
void LPSPI_SetDummyData (LPSPI_Type *base, uint8_t dummyData)
 Set up the dummy data.
Transactional
void LPSPI_MasterTransferCreateHandle (LPSPI_Type *base, lpspi_master_handle_t *handle, lpspi_master_transfer_callback_t callback, void *userData)
 Initializes the LPSPI master handle.
status_t LPSPI_MasterTransferBlocking (LPSPI_Type *base, lpspi_transfer_t *transfer)
 LPSPI master transfer data using a polling method.
status_t LPSPI_MasterTransferNonBlocking (LPSPI_Type *base, lpspi_master_handle_t *handle, lpspi_transfer_t *transfer)
 LPSPI master transfer data using an interrupt method.
status_t LPSPI_MasterTransferGetCount (LPSPI_Type *base, lpspi_master_handle_t *handle, size_t *count)
 Gets the master transfer remaining bytes.
void LPSPI_MasterTransferAbort (LPSPI_Type *base, lpspi_master_handle_t *handle)
 LPSPI master abort transfer which uses an interrupt method.
void LPSPI_MasterTransferHandleIRQ (LPSPI_Type *base, lpspi_master_handle_t *handle)
 LPSPI Master IRQ handler function.
void LPSPI_SlaveTransferCreateHandle (LPSPI_Type *base, lpspi_slave_handle_t *handle, lpspi_slave_transfer_callback_t callback, void *userData)
 Initializes the LPSPI slave handle.
status_t LPSPI_SlaveTransferNonBlocking (LPSPI_Type *base, lpspi_slave_handle_t *handle, lpspi_transfer_t *transfer)
 LPSPI slave transfer data using an interrupt method.
status_t LPSPI_SlaveTransferGetCount (LPSPI_Type *base, lpspi_slave_handle_t *handle, size_t *count)
 Gets the slave transfer remaining bytes.
void LPSPI_SlaveTransferAbort (LPSPI_Type *base, lpspi_slave_handle_t *handle)
 LPSPI slave aborts a transfer which uses an interrupt method.
void LPSPI_SlaveTransferHandleIRQ (LPSPI_Type *base, lpspi_slave_handle_t *handle)
 LPSPI Slave IRQ handler function.
◆ LPSPI_DUMMY_DATA
Dummy data used for tx if there is not txData.
◆ LPSPI_MASTER_PCS_MASK
LPSPI master PCS shift macro , internal used.
◆ LPSPI_MASTER_PCS_SHIFT
◆ LPSPI_SLAVE_PCS_MASK
LPSPI slave PCS shift macro , internal used.
◆ LPSPI_SLAVE_PCS_SHIFT
Typedef Documentation
◆ lpspi_master_transfer_callback_t
Parameters
baseLPSPI peripheral address.
handlePointer to the handle for the LPSPI master.
statusSuccess or error code describing whether the transfer is completed.
userDataArbitrary pointer-dataSized value passed from the application.
◆ lpspi_slave_transfer_callback_t
Parameters
handlePointer to the handle for the LPSPI slave.
◆ anonymous enum
anonymous enum
kStatus_LPSPI_Busy
LPSPI transfer is busy.
kStatus_LPSPI_Error
LPSPI driver error.
kStatus_LPSPI_Idle
LPSPI is idle.
LPSPI transfer out Of range.
LPSPI timeout polling status flags.
◆ _lpspi_clock_phase
CPHA=0. Data is captured on the leading edge of the SCK and changed on the following edge.
CPHA=1. Data is changed on the leading edge of the SCK and captured on the following edge.
◆ _lpspi_clock_polarity
CPOL=0. Active-high LPSPI clock (idles low)
CPOL=1. Active-low LPSPI clock (idles high)
◆ _lpspi_data_out_config
Data out retains last value when chip select is de-asserted
Data out is tristated when chip select is de-asserted
◆ _lpspi_delay_type
kLPSPI_PcsToSck
PCS-to-SCK delay.
kLPSPI_LastSckToPcs
Last SCK edge to PCS delay.
Delay between transfers.
◆ _lpspi_dma_enable
LPSPI DMA source.
kLPSPI_TxDmaEnable
Transmit data DMA enable
kLPSPI_RxDmaEnable
Receive data DMA enable
◆ _lpspi_flags
Transmit data flag
Receive data flag
Word Complete flag
Frame Complete flag
Transfer Complete flag
Transmit Error flag (FIFO underrun)
Receive Error flag (FIFO overrun)
Data Match flag
Module Busy flag
Used for clearing all w1c status flags
◆ _lpspi_host_request_select
Host Request is an ext pin.
Host Request is an internal trigger.
◆ _lpspi_interrupt_enable
Transmit data interrupt enable
Receive data interrupt enable
Word complete interrupt enable
Frame complete interrupt enable
Transfer complete interrupt enable
Transmit error interrupt enable(FIFO underrun)
Receive Error interrupt enable (FIFO overrun)
Data Match interrupt enable
All above interrupts enable.
◆ _lpspi_master_slave_mode
kLPSPI_Master
LPSPI peripheral operates in master mode.
kLPSPI_Slave
LPSPI peripheral operates in slave mode.
◆ _lpspi_match_config
kLPSI_MatchDisabled
LPSPI Match Disabled.
LPSPI Match Enabled.
◆ _lpspi_pcs_polarity
Pcs0 Active Low (idles high).
Pcs1 Active Low (idles high).
Pcs2 Active Low (idles high).
Pcs3 Active Low (idles high).
Pcs0 to Pcs5 Active Low (idles high).
◆ _lpspi_pcs_polarity_config
PCS Active High (idles low)
kLPSPI_PcsActiveLow
PCS Active Low (idles high)
◆ _lpspi_pin_config
kLPSPI_SdiInSdoOut
LPSPI SDI input, SDO output.
kLPSPI_SdiInSdiOut
LPSPI SDI input, SDI output.
kLPSPI_SdoInSdoOut
LPSPI SDO input, SDO output.
kLPSPI_SdoInSdiOut
LPSPI SDO input, SDI output.
◆ _lpspi_shift_direction
kLPSPI_MsbFirst
Data transfers start with most significant bit.
kLPSPI_LsbFirst
Data transfers start with least significant bit.
◆ _lpspi_transfer_config_flag_for_master
kLPSPI_MasterPcs0
LPSPI master transfer use PCS0 signal
kLPSPI_MasterPcs1
LPSPI master transfer use PCS1 signal
kLPSPI_MasterPcs2
LPSPI master transfer use PCS2 signal
kLPSPI_MasterPcs3
LPSPI master transfer use PCS3 signal
Is PCS signal continuous
Is master swap the byte. For example, when want to send data 1 2 3 4 5 6 7 8 (suppose you set lpspi_shift_direction_t to MSB).
  1. If you set bitPerFrame = 8 , no matter the kLPSPI_MasterByteSwapyou flag is used or not, the waveform is 1 2 3 4 5 6 7 8.
  2. If you set bitPerFrame = 16 : (1) the waveform is 2 1 4 3 6 5 8 7 if you do not use the kLPSPI_MasterByteSwap flag. (2) the waveform is 1 2 3 4 5 6 7 8 if you use the kLPSPI_MasterByteSwap flag.
  3. If you set bitPerFrame = 32 : (1) the waveform is 4 3 2 1 8 7 6 5 if you do not use the kLPSPI_MasterByteSwap flag. (2) the waveform is 1 2 3 4 5 6 7 8 if you use the kLPSPI_MasterByteSwap flag.
◆ _lpspi_transfer_config_flag_for_slave
kLPSPI_SlavePcs0
LPSPI slave transfer use PCS0 signal
kLPSPI_SlavePcs1
LPSPI slave transfer use PCS1 signal
kLPSPI_SlavePcs2
LPSPI slave transfer use PCS2 signal
kLPSPI_SlavePcs3
LPSPI slave transfer use PCS3 signal
Is slave swap the byte. For example, when want to send data 1 2 3 4 5 6 7 8 (suppose you set lpspi_shift_direction_t to MSB).
  1. If you set bitPerFrame = 8 , no matter the kLPSPI_SlaveByteSwap flag is used or not, the waveform is 1 2 3 4 5 6 7 8.
  2. If you set bitPerFrame = 16 : (1) the waveform is 2 1 4 3 6 5 8 7 if you do not use the kLPSPI_SlaveByteSwap flag. (2) the waveform is 1 2 3 4 5 6 7 8 if you use the kLPSPI_SlaveByteSwap flag.
  3. If you set bitPerFrame = 32 : (1) the waveform is 4 3 2 1 8 7 6 5 if you do not use the kLPSPI_SlaveByteSwap flag. (2) the waveform is 1 2 3 4 5 6 7 8 if you use the kLPSPI_SlaveByteSwap flag.
◆ _lpspi_transfer_state
kLPSPI_Idle
Nothing in the transmitter/receiver.
kLPSPI_Busy
Transfer queue is not finished.
kLPSPI_Error
Transfer error.
◆ _lpspi_transfer_width
1-bit shift at a time, data out on SDO, in on SDI (normal mode)
kLPSPI_TwoBitXfer
2-bits shift out on SDO/SDI and in on SDO/SDI
kLPSPI_FourBitXfer
4-bits shift out on SDO/SDI/PCS[3:2] and in on SDO/SDI/PCS[3:2]
◆ _lpspi_which_pcs_config
kLPSPI_Pcs0
PCS[0]
kLPSPI_Pcs1
PCS[1]
kLPSPI_Pcs2
PCS[2]
kLPSPI_Pcs3
PCS[3]
◆ LPSPI_CheckTransferArgument()
bool LPSPI_CheckTransferArgument ( LPSPI_Type base,
lpspi_transfer_t transfer,
bool  isEdma
Parameters
transferthe transfer struct to be used.
isEdmaTrue to check for EDMA transfer, false to check interrupt non-blocking transfer
Returns
Return true for right and false for wrong.
brief Check the argument for transfer .
param base LPSPI peripheral address. param transfer the transfer struct to be used. param isEdma True to check for EDMA transfer, false to check interrupt non-blocking transfer return Return true for right and false for wrong.
◆ LPSPI_Deinit()
void LPSPI_Deinit ( LPSPI_Type base)
Parameters
brief De-initializes the LPSPI peripheral. Call this API to disable the LPSPI clock. param base LPSPI peripheral address.
◆ LPSPI_GetInstance()
uint32_t LPSPI_GetInstance ( LPSPI_Type base)
Parameters
baseLPSPI peripheral base address.
Returns
LPSPI instance.
brief Get the LPSPI instance from peripheral base address.
param base LPSPI peripheral base address. return LPSPI instance.
◆ LPSPI_MasterGetDefaultConfig()
void LPSPI_MasterGetDefaultConfig ( lpspi_master_config_t masterConfig)
This API initializes the configuration structure for LPSPI_MasterInit(). The initialized structure can remain unchanged in LPSPI_MasterInit(), or can be modified before calling the LPSPI_MasterInit(). Example:
lpspi_master_config_t masterConfig;
void LPSPI_MasterGetDefaultConfig(lpspi_master_config_t *masterConfig)
Definition: fsl_lpspi.c:323
Definition: fsl_lpspi.h:262
Parameters
masterConfigpointer to lpspi_master_config_t structure
brief Sets the lpspi_master_config_t structure to default values.
This API initializes the configuration structure for LPSPI_MasterInit(). The initialized structure can remain unchanged in LPSPI_MasterInit(), or can be modified before calling the LPSPI_MasterInit(). Example: code lpspi_master_config_t masterConfig; LPSPI_MasterGetDefaultConfig(&masterConfig); endcode param masterConfig pointer to lpspi_master_config_t structure
◆ LPSPI_MasterInit()
void LPSPI_MasterInit ( LPSPI_Type base,
const lpspi_master_config_t masterConfig,
Parameters
masterConfigPointer to structure lpspi_master_config_t.
srcClock_HzModule source input clock in Hertz
brief Initializes the LPSPI master.
param base LPSPI peripheral address. param masterConfig Pointer to structure lpspi_master_config_t. param srcClock_Hz Module source input clock in Hertz
◆ LPSPI_MasterSetBaudRate()
uint32_t LPSPI_MasterSetBaudRate ( LPSPI_Type base,
uint32_t *  tcrPrescaleValue
This function takes in the desired bitsPerSec (baud rate) and calculates the nearest possible baud rate without exceeding the desired baud rate and returns the calculated baud rate in bits-per-second. It requires the caller to provide the frequency of the module source clock (in Hertz). Note that the baud rate does not go into effect until the Transmit Control Register (TCR) is programmed with the prescale value. Hence, this function returns the prescale tcrPrescaleValue parameter for later programming in the TCR. The higher level peripheral driver should alert the user of an out of range baud rate input.
Note that the LPSPI module must first be disabled before configuring this. Note that the LPSPI module must be configured for master mode before configuring this.
Parameters
baudRate_BpsThe desired baud rate in bits per second.
srcClock_HzModule source input clock in Hertz.
tcrPrescaleValueThe TCR prescale value needed to program the TCR.
Returns
The actual calculated baud rate. This function may also return a "0" if the LPSPI is not configured for master mode or if the LPSPI module is not disabled.
brief Sets the LPSPI baud rate in bits per second.
param base LPSPI peripheral address. param baudRate_Bps The desired baud rate in bits per second. param srcClock_Hz Module source input clock in Hertz. param tcrPrescaleValue The TCR prescale value needed to program the TCR. return The actual calculated baud rate. This function may also return a "0" if the LPSPI is not configured for master mode or if the LPSPI module is not disabled.
◆ LPSPI_MasterSetDelayScaler()
void LPSPI_MasterSetDelayScaler ( LPSPI_Type base,
uint32_t  scaler,
This function configures the following: SCK to PCS delay, or PCS to SCK delay, or The configurations must occur between the transfer delay.
The delay names are available in type lpspi_delay_type_t.
The user passes the desired delay along with the delay value. This allows the user to directly set the delay values if they have pre-calculated them or if they simply wish to manually increment the value.
Parameters
scalerThe 8-bit delay value 0x00 to 0xFF (255).
whichDelayThe desired delay to configure, must be of type lpspi_delay_type_t.
brief Manually configures a specific LPSPI delay parameter (module must be disabled to change the delay values).
param base LPSPI peripheral address. param scaler The 8-bit delay value 0x00 to 0xFF (255). param whichDelay The desired delay to configure, must be of type lpspi_delay_type_t.
◆ LPSPI_MasterSetDelayTimes()
uint32_t LPSPI_MasterSetDelayTimes ( LPSPI_Type base,
This function calculates the values for the following: SCK to PCS delay, or PCS to SCK delay, or The configurations must occur between the transfer delay.
The user passes the desired delay and the desired delay value in nano-seconds. The function calculates the value needed for the desired delay parameter and returns the actual calculated delay because an exact delay match may not be possible. In this case, the closest match is calculated without going below the desired delay value input. It is possible to input a very large delay value that exceeds the capability of the part, in which case the maximum supported delay is returned. It is up to the higher level peripheral driver to alert the user of an out of range delay input.
Note that the LPSPI module must be configured for master mode before configuring this. And note that the delayTime = LPSPI_clockSource / (PRESCALE * Delay_scaler).
Parameters
delayTimeInNanoSecThe desired delay value in nano-seconds.
whichDelayThe desired delay to configuration, which must be of type lpspi_delay_type_t.
Returns
actual Calculated delay value in nano-seconds.
brief Calculates the delay based on the desired delay input in nanoseconds (module must be disabled to change the delay values).
param base LPSPI peripheral address. param delayTimeInNanoSec The desired delay value in nano-seconds. param whichDelay The desired delay to configuration, which must be of type lpspi_delay_type_t. param srcClock_Hz Module source input clock in Hertz. return actual Calculated delay value in nano-seconds.
◆ LPSPI_MasterTransferAbort()
void LPSPI_MasterTransferAbort ( LPSPI_Type base,
lpspi_master_handle_t handle
This function aborts a transfer which uses an interrupt method.
Parameters
handlepointer to lpspi_master_handle_t structure which stores the transfer state.
brief LPSPI master abort transfer which uses an interrupt method.
param base LPSPI peripheral address. param handle pointer to lpspi_master_handle_t structure which stores the transfer state.
◆ LPSPI_MasterTransferBlocking()
status_t LPSPI_MasterTransferBlocking ( LPSPI_Type base,
This function transfers data using a polling method. This is a blocking function, which does not return until all transfers have been completed.
Note: The transfer data size should be integer multiples of bytesPerFrame if bytesPerFrame is less than or equal to 4. For bytesPerFrame greater than 4: The transfer data size should be equal to bytesPerFrame if the bytesPerFrame is not integer multiples of 4. Otherwise, the transfer data size can be an integer multiple of bytesPerFrame.
Parameters
transferpointer to lpspi_transfer_t structure.
Returns
status of status_t.
brief LPSPI master transfer data using a polling method.
param base LPSPI peripheral address. param transfer pointer to lpspi_transfer_t structure. return status of status_t.
◆ LPSPI_MasterTransferCreateHandle()
void LPSPI_MasterTransferCreateHandle ( LPSPI_Type base,
lpspi_master_handle_t handle,
void *  userData
This function initializes the LPSPI handle, which can be used for other LPSPI transactional APIs. Usually, for a specified LPSPI instance, call this API once to get the initialized handle.
Parameters
handleLPSPI handle pointer to lpspi_master_handle_t.
callbackDSPI callback.
userDatacallback function parameter.
brief Initializes the LPSPI master handle.
param base LPSPI peripheral address. param handle LPSPI handle pointer to lpspi_master_handle_t. param callback DSPI callback. param userData callback function parameter.
◆ LPSPI_MasterTransferGetCount()
status_t LPSPI_MasterTransferGetCount ( LPSPI_Type base,
size_t *  count
This function gets the master transfer remaining bytes.
Parameters
countNumber of bytes transferred so far by the non-blocking transaction.
Returns
status of status_t.
brief Gets the master transfer remaining bytes.
param base LPSPI peripheral address. param handle pointer to lpspi_master_handle_t structure which stores the transfer state. param count Number of bytes transferred so far by the non-blocking transaction. return status of status_t.
◆ LPSPI_MasterTransferHandleIRQ()
void LPSPI_MasterTransferHandleIRQ ( LPSPI_Type base,
This function processes the LPSPI transmit and receive IRQ.
Parameters
brief LPSPI Master IRQ handler function.
◆ LPSPI_MasterTransferNonBlocking()
status_t LPSPI_MasterTransferNonBlocking ( LPSPI_Type base,
This function transfers data using an interrupt method. This is a non-blocking function, which returns right away. When all data is transferred, the callback function is called.
Parameters
Returns
status of status_t.
brief LPSPI master transfer data using an interrupt method.
param base LPSPI peripheral address. param handle pointer to lpspi_master_handle_t structure which stores the transfer state. param transfer pointer to lpspi_transfer_t structure. return status of status_t.
◆ LPSPI_Reset()
void LPSPI_Reset ( LPSPI_Type base)
Parameters
brief Restores the LPSPI peripheral to reset state. Note that this function sets all registers to reset state. As a result, the LPSPI module can't work after calling this API. param base LPSPI peripheral address.
◆ LPSPI_SetDummyData()
void LPSPI_SetDummyData ( LPSPI_Type base,
uint8_t  dummyData
Parameters
dummyDataData to be transferred when tx buffer is NULL. Note: This API has no effect when LPSPI in slave interrupt mode, because driver will set the TXMSK bit to 1 if txData is NULL, no data is loaded from transmit FIFO and output pin is tristated.
brief Set up the dummy data.
param base LPSPI peripheral address. param dummyData Data to be transferred when tx buffer is NULL. Note: This API has no effect when LPSPI in slave interrupt mode, because driver will set the TXMSK bit to 1 if txData is NULL, no data is loaded from transmit FIFO and output pin is tristated.
◆ LPSPI_SlaveGetDefaultConfig()
void LPSPI_SlaveGetDefaultConfig ( lpspi_slave_config_t slaveConfig)
This API initializes the configuration structure for LPSPI_SlaveInit(). The initialized structure can remain unchanged in LPSPI_SlaveInit() or can be modified before calling the LPSPI_SlaveInit(). Example:
void LPSPI_SlaveGetDefaultConfig(lpspi_slave_config_t *slaveConfig)
Definition: fsl_lpspi.c:402
Definition: fsl_lpspi.h:290
Parameters
slaveConfigpointer to lpspi_slave_config_t structure.
brief Sets the lpspi_slave_config_t structure to default values.
This API initializes the configuration structure for LPSPI_SlaveInit(). The initialized structure can remain unchanged in LPSPI_SlaveInit() or can be modified before calling the LPSPI_SlaveInit(). Example: code lpspi_slave_config_t slaveConfig; LPSPI_SlaveGetDefaultConfig(&slaveConfig); endcode param slaveConfig pointer to lpspi_slave_config_t structure.
< Bits per frame, minimum 8, maximum 4096.
< Clock polarity.
< Clock phase.
< MSB or LSB data shift direction.
< Desired Peripheral Chip Select (pcs)
< Desired PCS active high or low
◆ LPSPI_SlaveInit()
void LPSPI_SlaveInit ( LPSPI_Type base,
const lpspi_slave_config_t slaveConfig
Parameters
slaveConfigPointer to a structure lpspi_slave_config_t.
brief LPSPI slave configuration.
param base LPSPI peripheral address. param slaveConfig Pointer to a structure lpspi_slave_config_t.
◆ LPSPI_SlaveTransferAbort()
void LPSPI_SlaveTransferAbort ( LPSPI_Type base,
lpspi_slave_handle_t handle
Parameters
handlepointer to lpspi_slave_handle_t structure which stores the transfer state.
brief LPSPI slave aborts a transfer which uses an interrupt method.
param base LPSPI peripheral address. param handle pointer to lpspi_slave_handle_t structure which stores the transfer state.
◆ LPSPI_SlaveTransferCreateHandle()
void LPSPI_SlaveTransferCreateHandle ( LPSPI_Type base,
lpspi_slave_handle_t handle,
void *  userData
Parameters
handleLPSPI handle pointer to lpspi_slave_handle_t.
brief Initializes the LPSPI slave handle.
param base LPSPI peripheral address. param handle LPSPI handle pointer to lpspi_slave_handle_t. param callback DSPI callback. param userData callback function parameter.
◆ LPSPI_SlaveTransferGetCount()
status_t LPSPI_SlaveTransferGetCount ( LPSPI_Type base,
size_t *  count
This function gets the slave transfer remaining bytes.
Parameters
Returns
status of status_t.
brief Gets the slave transfer remaining bytes.
param base LPSPI peripheral address. param handle pointer to lpspi_slave_handle_t structure which stores the transfer state. param count Number of bytes transferred so far by the non-blocking transaction. return status of status_t.
◆ LPSPI_SlaveTransferHandleIRQ()
void LPSPI_SlaveTransferHandleIRQ ( LPSPI_Type base,
This function processes the LPSPI transmit and receives an IRQ.
Parameters
brief LPSPI Slave IRQ handler function.
◆ LPSPI_SlaveTransferNonBlocking()
status_t LPSPI_SlaveTransferNonBlocking ( LPSPI_Type base,
This function transfer data using an interrupt method. This is a non-blocking function, which returns right away. When all data is transferred, the callback function is called.
Note: The transfer data size should be integer multiples of bytesPerFrame if bytesPerFrame is less than or equal to 4. For bytesPerFrame greater than 4: The transfer data size should be equal to bytesPerFrame if the bytesPerFrame is not an integer multiple of 4. Otherwise, the transfer data size can be an integer multiple of bytesPerFrame.
Parameters
Returns
status of status_t.
brief LPSPI slave transfer data using an interrupt method.
param base LPSPI peripheral address. param handle pointer to lpspi_slave_handle_t structure which stores the transfer state. param transfer pointer to lpspi_transfer_t structure. return status of status_t.
