RTEMS 6.1-rc2
Timer_Control Struct Reference
#include <timerdata.h>
Objects_Control Object
Watchdog_Control Ticker
Timer_Classes the_class
rtems_timer_service_routine_entry routine
void * user_data
Watchdog_Interval initial
Watchdog_Interval start_time
Watchdog_Interval stop_time
The following records define the control block used to manage each timer.
Field Documentation
◆ initial
Watchdog_Interval Timer_Control::initial
This field is the timer interval in ticks or seconds.
◆ Object
Objects_Control Timer_Control::Object
This field is the object management portion of a Timer instance.
◆ routine
rtems_timer_service_routine_entry Timer_Control::routine
This field is the timer service routine.
◆ start_time
Watchdog_Interval Timer_Control::start_time
This field is the timer start time point in ticks.
◆ stop_time
Watchdog_Interval Timer_Control::stop_time
This field is the timer stop time point in ticks.
◆ the_class
Timer_Classes Timer_Control::the_class
This field indicates what type of timer this currently is.
◆ Ticker
Watchdog_Control Timer_Control::Ticker
This field is the Watchdog instance which will be the scheduled.
◆ user_data
void* Timer_Control::user_data
This field is the timer service routine user data.
