RTEMS 6.1-rc2
Test context for spec:/rtems/timer/req/server-fire-when test case. More...
rtems_id timer_id
 This member contains a valid id of a timer.
rtems_id id_param
 This member specifies the id parameter for the action.
const rtems_time_of_daywall_time_param
 This member specifies the wall_time parameter for the action.
rtems_timer_service_routine_entry routine_param
 This member specifies the routine parameter for the action.
rtems_status_code status
 This member contains the returned status code of the action.
int invocations
 This member contains a counter of invocations of the Timer Service Routine.
rtems_time_of_day tod_till_fire
 Function TriggerTimer() is used to figure out when the Timer Service Routine gets executed. This member contains the time-of-day when the Timer Service Routine fires (see fire).
void * routine_user_data
 This member contains the user data given to the Timer Service Routine when called.
PreConditionContext pre_cond_contex
 This member specifies which pre-condition context (none, interrupt context, server context) must be created before the rtems_timer_server_fire_when() action gets executed.
const rtems_time_of_daypre_cond_tod
 This member specifies the pre-condition state of the realtime clock. It should either be set to the value referenced by pre_cond_tod or if NULL, then the realtime clock should be not set.
Timer_Classes pre_class
 This member stores internal clock and context settings of the timer before the execution of the test action.
Timer_States pre_state
 This member stores the state of the timer before the execution of the test action.
Timer_States post_state
 This member stores the state of the timer after the execution of the test action.
Timer_Scheduling_Data pre_scheduling_data
 This member stores the scheduling data of the timer before the execution of the test action.
Timer_Scheduling_Data post_scheduling_data
 This member stores the scheduling data of the timer after the execution of the test action.
struct {
   size_t   pcs [8]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsTimerReqServerFireWhen_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
