RTEMS 6.1-rc2
Files | Data Structures | Enumerations | Functions
file  tc-timer-server-fire-when.c
struct  RtemsTimerReqServerFireWhen_Entry
struct  RtemsTimerReqServerFireWhen_Context
 Test context for spec:/rtems/timer/req/server-fire-when test case. More...
enum  RtemsTimerReqServerFireWhen_Pre_Server { RtemsTimerReqServerFireWhen_Pre_Server_Init , RtemsTimerReqServerFireWhen_Pre_Server_NotInit , RtemsTimerReqServerFireWhen_Pre_Server_NA }
enum  RtemsTimerReqServerFireWhen_Pre_RtClock { RtemsTimerReqServerFireWhen_Pre_RtClock_Set , RtemsTimerReqServerFireWhen_Pre_RtClock_Unset , RtemsTimerReqServerFireWhen_Pre_RtClock_NA }
enum  RtemsTimerReqServerFireWhen_Pre_Routine { RtemsTimerReqServerFireWhen_Pre_Routine_Valid , RtemsTimerReqServerFireWhen_Pre_Routine_Null , RtemsTimerReqServerFireWhen_Pre_Routine_NA }
enum  RtemsTimerReqServerFireWhen_Pre_WallTime {
  RtemsTimerReqServerFireWhen_Pre_WallTime_Valid , RtemsTimerReqServerFireWhen_Pre_WallTime_Invalid , RtemsTimerReqServerFireWhen_Pre_WallTime_Past , RtemsTimerReqServerFireWhen_Pre_WallTime_Null ,
  RtemsTimerReqServerFireWhen_Pre_WallTime_NA
enum  RtemsTimerReqServerFireWhen_Pre_Id { RtemsTimerReqServerFireWhen_Pre_Id_Valid , RtemsTimerReqServerFireWhen_Pre_Id_Invalid , RtemsTimerReqServerFireWhen_Pre_Id_NA }
enum  RtemsTimerReqServerFireWhen_Pre_Context { RtemsTimerReqServerFireWhen_Pre_Context_None , RtemsTimerReqServerFireWhen_Pre_Context_Interrupt , RtemsTimerReqServerFireWhen_Pre_Context_Server , RtemsTimerReqServerFireWhen_Pre_Context_NA }
enum  RtemsTimerReqServerFireWhen_Pre_Clock { RtemsTimerReqServerFireWhen_Pre_Clock_None , RtemsTimerReqServerFireWhen_Pre_Clock_Ticks , RtemsTimerReqServerFireWhen_Pre_Clock_Realtime , RtemsTimerReqServerFireWhen_Pre_Clock_NA }
enum  RtemsTimerReqServerFireWhen_Pre_State { RtemsTimerReqServerFireWhen_Pre_State_Inactive , RtemsTimerReqServerFireWhen_Pre_State_Scheduled , RtemsTimerReqServerFireWhen_Pre_State_Pending , RtemsTimerReqServerFireWhen_Pre_State_NA }
enum  RtemsTimerReqServerFireWhen_Post_Status {
  RtemsTimerReqServerFireWhen_Post_Status_Ok , RtemsTimerReqServerFireWhen_Post_Status_NotDef , RtemsTimerReqServerFireWhen_Post_Status_InvId , RtemsTimerReqServerFireWhen_Post_Status_InvAddr ,
  RtemsTimerReqServerFireWhen_Post_Status_InvClock , RtemsTimerReqServerFireWhen_Post_Status_IncStat , RtemsTimerReqServerFireWhen_Post_Status_NA
enum  RtemsTimerReqServerFireWhen_Post_Context {
  RtemsTimerReqServerFireWhen_Post_Context_None , RtemsTimerReqServerFireWhen_Post_Context_Interrupt , RtemsTimerReqServerFireWhen_Post_Context_Server , RtemsTimerReqServerFireWhen_Post_Context_Nop ,
  RtemsTimerReqServerFireWhen_Post_Context_NA
enum  RtemsTimerReqServerFireWhen_Post_Clock {
  RtemsTimerReqServerFireWhen_Post_Clock_None , RtemsTimerReqServerFireWhen_Post_Clock_Ticks , RtemsTimerReqServerFireWhen_Post_Clock_Realtime , RtemsTimerReqServerFireWhen_Post_Clock_Nop ,
  RtemsTimerReqServerFireWhen_Post_Clock_NA
enum  RtemsTimerReqServerFireWhen_Post_State { RtemsTimerReqServerFireWhen_Post_State_Scheduled , RtemsTimerReqServerFireWhen_Post_State_Nop , RtemsTimerReqServerFireWhen_Post_State_NA }
enum  RtemsTimerReqServerFireWhen_Post_WallTime { RtemsTimerReqServerFireWhen_Post_WallTime_Param , RtemsTimerReqServerFireWhen_Post_WallTime_Nop , RtemsTimerReqServerFireWhen_Post_WallTime_NA }
enum  RtemsTimerReqServerFireWhen_Post_Routine { RtemsTimerReqServerFireWhen_Post_Routine_Param , RtemsTimerReqServerFireWhen_Post_Routine_Nop , RtemsTimerReqServerFireWhen_Post_Routine_NA }
enum  RtemsTimerReqServerFireWhen_Post_UserData { RtemsTimerReqServerFireWhen_Post_UserData_Param , RtemsTimerReqServerFireWhen_Post_UserData_Nop , RtemsTimerReqServerFireWhen_Post_UserData_NA }
enum  PreConditionContext {
  PRE_NONE = 0 , PRE_INTERRUPT = 1 , PRE_SERVER = 2 , PRE_NONE = 0 ,
  PRE_INTERRUPT = 1 , PRE_SERVER = 2 , PRE_NONE = 0 , PRE_INTERRUPT = 1 ,
  PRE_SERVER = 2 , PRE_NONE = 0 , PRE_INTERRUPT = 1 , PRE_SERVER = 2 ,
enum  Scheduling_Ticks {
  SCHEDULE_NONE = 0 , SCHEDULE_SOON = 1 , SCHEDULE_LATER = 2 , SCHEDULE_MAX = 5 ,
  SCHEDULE_NONE = 0 , SCHEDULE_SOON = 1 , SCHEDULE_MAX = 5 , SCHEDULE_NONE = 0 ,
  SCHEDULE_SOON = 1 , SCHEDULE_LATER = 2 , SCHEDULE_MAX = 5 , SCHEDULE_NONE = 0 ,
  SCHEDULE_VERY_SOON = 1 , SCHEDULE_SOON = 2 , SCHEDULE_LATER = 3 , SCHEDULE_MAX = 5 ,
 T_TEST_CASE_FIXTURE (RtemsTimerReqServerFireWhen, &RtemsTimerReqServerFireWhen_Fixture)
