RTEMS 6.1-rc2
Test context for spec:/rtems/task/req/construct test case. More...
Data Fields | |
rtems_id | scheduler_b_id |
This member contains the scheduler B identifier. | |
unsigned int | thread_zombie_ticket |
This member contains the thread zombie registry ticket right before the task exit of the zombie task. | |
volatile bool | zombie_ready |
If this member is true, then the zombie thread is ready to get killed. | |
rtems_mode | actual_modes |
This member contains the actual modes of the constructed task. | |
rtems_status_code | status |
const rtems_task_config * | config |
rtems_task_config | config_obj |
rtems_id | zombie_id |
rtems_id * | id |
rtems_id | id_obj |
bool | create_extension_status |
uint32_t | create_extension_calls |
uint32_t | delete_extension_calls |
uint32_t | delete_zombie_extension_calls |
uint32_t | storage_free_calls |
size_t | stack_size |
rtems_id | extension_ids [2] |
void * | seized_objects |
struct { | |
size_t pcs [15] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
RtemsTaskReqConstruct_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
