RTEMS 6.1-rc2
Modules | Files | Macros | Variables
spec:/testsuites/validation-one-cpu-1
This general purpose validation test suite provides enough resources to run basic tests with exactly one processor and without a Clock Driver. More...
 spec:/acfg/val/scheduler-table-entries-one-cpu
 Tests the effect of CONFIGURE_SCHEDULER_TABLE_ENTRIES the application configuration options in a configuration with only one processor.
 spec:/rtems/task/req/construct
file  ts-validation-one-cpu-1.c
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
#define CONFIGURE_MAXIMUM_PROCESSORS   1
#define CONFIGURE_SCHEDULER_TABLE_ENTRIES    RTEMS_SCHEDULER_TABLE_PRIORITY( a, TEST_SCHEDULER_A_NAME )
const char rtems_test_name [] = "TestsuitesValidationOneCpu1"
 Each test must define a test name string.
Two test suites of this configuration are provided to limit test run duration.
