RTEMS 6.1-rc2
Test context for spec:/rtems/ratemon/req/get-status test case. More...
rtems_id period_id
 This member contains a valid identifier of a period.
GetTimecountHandler previous_timecounter_handler
 This member contains the previous timecounter handler to restore.
rtems_rate_monotonic_period_status period_status
 This member is used to receive the rtems_rate_monotonic_period_status from the action.
rtems_id id_param
 This member specifies the id parameter for the action.
rtems_rate_monotonic_period_statusstatus_param
 This member specifies the status parameter for the action.
rtems_status_code status
 This member contains the returned status code of the action.
rtems_id task_id
 This member contains the task identifier of the owner task.
rtems_rate_monotonic_period_states previous_state
 This member contains the state before the action.
void(* do_reset )(void)
 If the rtems_cpu_usage_reset() directive should be called before rtems_rate_monotonic_get_status(), this member contains a pointer to it.
struct timespec elapsed
 This member contains the CLOCK_MONOTONIC time elapsed.
struct timespec consumed
 This member contains the CPU time consumed by the owner task.
uint32_t postponed_jobs_count
 This member contains the number of postponed jobs.
struct {
   size_t   pci [6]
 This member defines the pre-condition indices for the next action.
   size_t   pcs [6]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsRatemonReqGetStatus_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
