RTEMS 6.1-rc2
Test context for spec:/rtems/message/req/construct test case. More...
Data Fields | |
rtems_status_code | status |
const rtems_message_queue_config * | config |
rtems_message_queue_config | config_obj |
rtems_id * | id |
rtems_id | id_obj |
void * | seized_objects |
uint32_t | storage_free_counter |
uint32_t | expected_storage_free_counter |
struct { | |
size_t pcs [9] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
RtemsMessageReqConstruct_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
