RTEMS 6.1-rc2
rtems_message_queue_config Struct Reference
This structure defines the configuration of a message queue constructed by rtems_message_queue_construct(). More...
#include <message.h>
rtems_name name
 This member defines the name of the message queue.
uint32_t maximum_pending_messages
 This member defines the maximum number of pending messages supported by the message queue.
size_t maximum_message_size
 This member defines the maximum message size supported by the message queue.
void * storage_area
 This member shall point to the message buffer storage area begin.
size_t storage_size
 This member defines size of the message buffer storage area in bytes.
void(* storage_free )(void *)
 This member defines the optional handler to free the message buffer storage area.
rtems_attribute attributes
 This member defines the attributes of the message queue.
Field Documentation
◆ storage_area
void* rtems_message_queue_config::storage_area
The message buffer storage area for the message queue shall be an array of the type defined by RTEMS_MESSAGE_QUEUE_BUFFER() with a maximum message size equal to the maximum message size of this configuration.
◆ storage_free
void(* rtems_message_queue_config::storage_free) (void *)
It is called when the message queue is deleted. It is called from task context under protection of the object allocator lock. It is allowed to call free() in this handler. If handler is NULL, then no action will be performed.
