RTEMS 6.1-rc2
Test context for spec:/rtems/intr/req/handler-iterate test case. More...
bool initialized_during_setup
 If this member is true, then the service was initialized during setup.
rtems_vector_number test_vector
 This member provides the vector number of a testable interrupt vector.
bool test_vector_was_enabled
 If this member is true, then the testable interrupt vector was enabled at the test case begin.
bool initialized
 If this member is true, then the service shall be initialized.
bool isr
 If this member is true, then rtems_interrupt_handler_iterate() shall be called from within interrupt context.
uint32_t visited_entries
 This member provides the count of visited entries.
rtems_interrupt_entry entry
 This member provides an rtems_interrupt_entry object.
rtems_vector_number vector
 This member specifies if the vector parameter value.
rtems_interrupt_per_handler_routine routine
 This member specifies if the routine parameter value.
rtems_status_code status
 This member contains the return value of the rtems_interrupt_handler_iterate() call.
struct {
   size_t   pcs [4]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsIntrReqHandlerIterate_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
