RTEMS 6.1-rc2
This validation test suite provides enough resources to run tests for the interrupt controller related directives of the Interrupt Manager. More...
Files | |
file | ts-validation-intr.c |
#define | CONFIGURE_MAXIMUM_PROCESSORS 5 |
#define | CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER |
const char | rtems_test_name [] = "TestsuitesValidationIntr" |
Each test must define a test name string. | |
In SMP configurations, up to three scheduler instances using the SMP EDF scheduler are provided using up to four processors.
