RTEMS 6.1-rc2
Test context for spec:/rtems/intr/req/get-attributes test case. More...
Data Fields | |
rtems_interrupt_attributes | attributes_obj |
This member provides the rtems_interrupt_attributes object. | |
bool | valid_vector |
If this member is true, then the vector parameter shall be valid. | |
rtems_interrupt_attributes * | attributes |
This member specifies if the attributes parameter value. | |
rtems_status_code | status |
This member contains the return value of the rtems_interrupt_get_attributes() call. | |
struct { | |
size_t pcs [2] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
RtemsIntrReqGetAttributes_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
