RTEMS 6.1-rc2
Test context for spec:/rtems/intr/req/entry-remove test case. More...
bool initialized_during_setup
 If this member is true, then the service was initialized during setup.
bool interrupt_occurred
 If this member is true, then an interrupt occurred.
uint32_t entry_counter
 This member provides a counter incremented by EntryRoutine().
rtems_interrupt_entry other_entry
 This member provides another rtems_interrupt_entry object.
bool other_installed
 If this member is true, then another entry was installed.
rtems_interrupt_entry third_entry
 This member provides a third rtems_interrupt_entry object.
bool third_installed
 If this member is true, then a third entry was installed.
bool installed
 If this member is true, then the entry is installed.
bool first
 If this member is true, then the entry is installed as the first entry.
bool last
 If this member is true, then the entry is installed as the last entry.
bool match
 If this member is true, then the entry matches with another installed entry.
rtems_vector_number test_vector
 This member provides the vector number of a testable interrupt vector.
bool test_vector_was_enabled
 If this member is true, then the testable interrupt vector was enabled at the test case begin.
rtems_interrupt_attributes attributes
 This member provides the attributes of the testable interrupt vector.
bool initialized
 If this member is true, then the service shall be initialized.
bool isr
 If this member is true, then rtems_interrupt_entry_remove() shall be called from within interrupt context.
bool enabled_before
 This member contains the enabled status before the rtems_interrupt_entry_remove() call.
bool enabled_after
 This member contains the enabled status after the rtems_interrupt_entry_remove() call.
uint32_t visited_entries
 This member provides the count of visited entries.
rtems_interrupt_entry entry_obj
 This member provides the rtems_interrupt_entry object.
rtems_vector_number vector
 This member specifies if the vector parameter value.
rtems_interrupt_entryentry
 This member specifies if the entry parameter value.
rtems_status_code status
 This member contains the return value of the rtems_interrupt_entry_remove() call.
struct {
   size_t   pci [9]
 This member defines the pre-condition indices for the next action.
   size_t   pcs [9]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsIntrReqEntryRemove_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
