RTEMS 6.1-rc2
Test context for spec:/rtems/intr/req/clear test case. More...
volatile uint32_t interrupt_count
 This member contains the count of serviced interrupts.
bool do_clear
 If this member is true, then the interrupt shall be cleared.
rtems_vector_number vector
 This member contains the current vector number.
bool valid_vector
 If this member is true, then the vector parameter shall be valid.
rtems_status_code status
 This member contains the return value of the rtems_interrupt_clear() call.
struct {
   size_t   pci [2]
 This member defines the pre-condition indices for the next action.
   size_t   pcs [2]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsIntrReqClear_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
