RTEMS 6.1-rc2
Test context for spec:/bsp/req/interrupt-handler-dispatch-unchecked test case. More...
rtems_interrupt_entryentry_to_restore
 This member references the interrupt entry to restore during test case teardown.
jmp_buf before_call
 This member provides a jump buffer to return from the fatal error.
rtems_interrupt_entry entry
 This member provides an interrupt entry to be dispatched.
volatile bool interrupt_occurred
 This member is true, then an interrupt occurred.
uint32_t entry_counter
 This member provides an entry dispatch counter.
uint32_t fatal_counter
 This member provides a fatal error counter.
rtems_fatal_source fatal_source
 This member contains the fatal source.
rtems_fatal_code fatal_code
 This member contains a fatal code.
rtems_vector_number test_vector
 This member contains the vector number of a testable interrupt.
rtems_interrupt_entry ** first
 This member references the pointer to the first entry of the interrupt vector.
rtems_interrupt_entryfirst_again
 This member references an interrupt entry for the first entry of the interrupt vector or is NULL.
struct {
   size_t   pci [2]
 This member defines the pre-condition indices for the next action.
   size_t   pcs [2]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   BspReqInterruptHandlerDispatchUnchecked_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
