RTEMS 6.1-rc2
Test context for spec:/acfg/val/fatal-init-task-construct-failed test case. More...
rtems_fatal_source source
 This member contains a copy of the corresponding AcfgValFatalInitTaskConstructFailed_Run() parameter.
rtems_fatal_code code
