RTEMS 6.1-rc2
Files | Data Structures | Functions
spec:/acfg/val/fatal-init-task-construct-failed
Tests a fatal error caused by an invalid application configuration. More...
file  tr-fatal-init-task-construct-failed.c
file  tr-fatal-init-task-construct-failed.h
struct  AcfgValFatalInitTaskConstructFailed_Context
 Test context for spec:/acfg/val/fatal-init-task-construct-failed test case. More...
void AcfgValFatalInitTaskConstructFailed_Run (rtems_fatal_source source, rtems_fatal_code code)
 Runs the parameterized test case.
This test case performs the following actions:
◆ AcfgValFatalInitTaskConstructFailed_Run()
void AcfgValFatalInitTaskConstructFailed_Run ( rtems_fatal_source  source,
Parameters
sourceis fatal source.
codeis fatal code.
