RTEMS 6.1-rc2
Data Structures | Macros | Typedefs | Enumerations | Functions
stm32h7xx_hal_i2c.h File Reference
Header file of I2C HAL module. More...
#include "stm32h7xx_hal_def.h"
#include "stm32h7xx_hal_i2c_ex.h"
struct  I2C_InitTypeDef
struct  __I2C_HandleTypeDef
#define HAL_I2C_ERROR_NONE   (0x00000000U)
#define HAL_I2C_ERROR_BERR   (0x00000001U)
#define HAL_I2C_ERROR_ARLO   (0x00000002U)
#define HAL_I2C_ERROR_AF   (0x00000004U)
#define HAL_I2C_ERROR_OVR   (0x00000008U)
#define HAL_I2C_ERROR_DMA   (0x00000010U)
#define HAL_I2C_ERROR_TIMEOUT   (0x00000020U)
#define HAL_I2C_ERROR_SIZE   (0x00000040U)
#define HAL_I2C_ERROR_DMA_PARAM   (0x00000080U)
#define HAL_I2C_ERROR_INVALID_PARAM   (0x00000200U)
#define I2C_FIRST_FRAME   ((uint32_t)I2C_SOFTEND_MODE)
#define I2C_FIRST_AND_NEXT_FRAME   ((uint32_t)(I2C_RELOAD_MODE | I2C_SOFTEND_MODE))
#define I2C_NEXT_FRAME   ((uint32_t)(I2C_RELOAD_MODE | I2C_SOFTEND_MODE))
#define I2C_FIRST_AND_LAST_FRAME   ((uint32_t)I2C_AUTOEND_MODE)
#define I2C_LAST_FRAME   ((uint32_t)I2C_AUTOEND_MODE)
#define I2C_LAST_FRAME_NO_STOP   ((uint32_t)I2C_SOFTEND_MODE)
#define I2C_OTHER_FRAME   (0x000000AAU)
#define I2C_OTHER_AND_LAST_FRAME   (0x0000AA00U)
#define I2C_ADDRESSINGMODE_7BIT   (0x00000001U)
#define I2C_ADDRESSINGMODE_10BIT   (0x00000002U)
#define I2C_DUALADDRESS_DISABLE   (0x00000000U)
#define I2C_DUALADDRESS_ENABLE   I2C_OAR2_OA2EN
#define I2C_OA2_NOMASK   ((uint8_t)0x00U)
#define I2C_OA2_MASK01   ((uint8_t)0x01U)
#define I2C_OA2_MASK02   ((uint8_t)0x02U)
#define I2C_OA2_MASK03   ((uint8_t)0x03U)
#define I2C_OA2_MASK04   ((uint8_t)0x04U)
#define I2C_OA2_MASK05   ((uint8_t)0x05U)
#define I2C_OA2_MASK06   ((uint8_t)0x06U)
#define I2C_OA2_MASK07   ((uint8_t)0x07U)
#define I2C_GENERALCALL_DISABLE   (0x00000000U)
#define I2C_GENERALCALL_ENABLE   I2C_CR1_GCEN
#define I2C_NOSTRETCH_DISABLE   (0x00000000U)
#define I2C_NOSTRETCH_ENABLE   I2C_CR1_NOSTRETCH
#define I2C_MEMADD_SIZE_8BIT   (0x00000001U)
#define I2C_MEMADD_SIZE_16BIT   (0x00000002U)
#define I2C_DIRECTION_TRANSMIT   (0x00000000U)
#define I2C_DIRECTION_RECEIVE   (0x00000001U)
#define I2C_RELOAD_MODE   I2C_CR2_RELOAD
#define I2C_AUTOEND_MODE   I2C_CR2_AUTOEND
#define I2C_SOFTEND_MODE   (0x00000000U)
#define I2C_NO_STARTSTOP   (0x00000000U)
#define I2C_GENERATE_STOP   (uint32_t)(0x80000000U | I2C_CR2_STOP)
#define I2C_GENERATE_START_READ   (uint32_t)(0x80000000U | I2C_CR2_START | I2C_CR2_RD_WRN)
#define I2C_GENERATE_START_WRITE   (uint32_t)(0x80000000U | I2C_CR2_START)
#define I2C_IT_ERRI   I2C_CR1_ERRIE
#define I2C_IT_TCI   I2C_CR1_TCIE
#define I2C_IT_STOPI   I2C_CR1_STOPIE
#define I2C_IT_NACKI   I2C_CR1_NACKIE
#define I2C_IT_ADDRI   I2C_CR1_ADDRIE
#define I2C_IT_RXI   I2C_CR1_RXIE
#define I2C_IT_TXI   I2C_CR1_TXIE
#define I2C_FLAG_TXE   I2C_ISR_TXE
#define I2C_FLAG_TXIS   I2C_ISR_TXIS
#define I2C_FLAG_RXNE   I2C_ISR_RXNE
#define I2C_FLAG_ADDR   I2C_ISR_ADDR
#define I2C_FLAG_AF   I2C_ISR_NACKF
#define I2C_FLAG_STOPF   I2C_ISR_STOPF
#define I2C_FLAG_TC   I2C_ISR_TC
#define I2C_FLAG_TCR   I2C_ISR_TCR
#define I2C_FLAG_BERR   I2C_ISR_BERR
#define I2C_FLAG_ARLO   I2C_ISR_ARLO
#define I2C_FLAG_OVR   I2C_ISR_OVR
#define I2C_FLAG_PECERR   I2C_ISR_PECERR
#define I2C_FLAG_TIMEOUT   I2C_ISR_TIMEOUT
#define I2C_FLAG_ALERT   I2C_ISR_ALERT
#define I2C_FLAG_BUSY   I2C_ISR_BUSY
#define I2C_FLAG_DIR   I2C_ISR_DIR
#define __HAL_I2C_RESET_HANDLE_STATE(__HANDLE__)   ((__HANDLE__)->State = HAL_I2C_STATE_RESET)
 Reset I2C handle state.
#define __HAL_I2C_ENABLE_IT(__HANDLE__, __INTERRUPT__)   ((__HANDLE__)->Instance->CR1 |= (__INTERRUPT__))
 Enable the specified I2C interrupt.
#define __HAL_I2C_DISABLE_IT(__HANDLE__, __INTERRUPT__)   ((__HANDLE__)->Instance->CR1 &= (~(__INTERRUPT__)))
 Disable the specified I2C interrupt.
#define __HAL_I2C_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__)
 Check whether the specified I2C interrupt source is enabled or not.
#define I2C_FLAG_MASK   (0x0001FFFFU)
 Check whether the specified I2C flag is set or not.
#define __HAL_I2C_GET_FLAG(__HANDLE__, __FLAG__)
#define __HAL_I2C_CLEAR_FLAG(__HANDLE__, __FLAG__)
 Clear the I2C pending flags which are cleared by writing 1 in a specific bit.
#define __HAL_I2C_ENABLE(__HANDLE__)   (SET_BIT((__HANDLE__)->Instance->CR1, I2C_CR1_PE))
 Enable the specified I2C peripheral.
#define __HAL_I2C_DISABLE(__HANDLE__)   (CLEAR_BIT((__HANDLE__)->Instance->CR1, I2C_CR1_PE))
 Disable the specified I2C peripheral.
#define __HAL_I2C_GENERATE_NACK(__HANDLE__)   (SET_BIT((__HANDLE__)->Instance->CR2, I2C_CR2_NACK))
 Generate a Non-Acknowledge I2C peripheral in Slave mode.
#define IS_I2C_ADDRESSING_MODE(MODE)
#define IS_I2C_DUAL_ADDRESS(ADDRESS)
#define IS_I2C_OWN_ADDRESS2_MASK(MASK)
#define IS_I2C_GENERAL_CALL(CALL)
#define IS_I2C_NO_STRETCH(STRETCH)
#define IS_I2C_MEMADD_SIZE(SIZE)
#define IS_TRANSFER_MODE(MODE)
#define IS_TRANSFER_REQUEST(REQUEST)
#define IS_I2C_TRANSFER_OPTIONS_REQUEST(REQUEST)
#define IS_I2C_TRANSFER_OTHER_OPTIONS_REQUEST(REQUEST)
#define I2C_RESET_CR2(__HANDLE__)
#define I2C_GET_ADDR_MATCH(__HANDLE__)
#define I2C_GET_DIR(__HANDLE__)
#define I2C_GET_STOP_MODE(__HANDLE__)   ((__HANDLE__)->Instance->CR2 & I2C_CR2_AUTOEND)
#define I2C_GET_OWN_ADDRESS1(__HANDLE__)   ((uint16_t)((__HANDLE__)->Instance->OAR1 & I2C_OAR1_OA1))
#define I2C_GET_OWN_ADDRESS2(__HANDLE__)   ((uint16_t)((__HANDLE__)->Instance->OAR2 & I2C_OAR2_OA2))
#define IS_I2C_OWN_ADDRESS1(ADDRESS1)   ((ADDRESS1) <= 0x000003FFU)
#define IS_I2C_OWN_ADDRESS2(ADDRESS2)   ((ADDRESS2) <= (uint16_t)0x00FFU)
#define I2C_MEM_ADD_MSB(__ADDRESS__)
#define I2C_MEM_ADD_LSB(__ADDRESS__)   ((uint8_t)((uint16_t)((__ADDRESS__) & (uint16_t)(0x00FFU))))
#define I2C_GENERATE_START(__ADDMODE__, __ADDRESS__)
#define I2C_CHECK_FLAG(__ISR__, __FLAG__)
#define I2C_CHECK_IT_SOURCE(__CR1__, __IT__)   ((((__CR1__) & (__IT__)) == (__IT__)) ? SET : RESET)
typedef struct __I2C_HandleTypeDef I2C_HandleTypeDef
enum  HAL_I2C_StateTypeDef {
  HAL_I2C_STATE_RESET = 0x00U , HAL_I2C_STATE_READY = 0x20U , HAL_I2C_STATE_BUSY = 0x24U , HAL_I2C_STATE_BUSY_TX = 0x21U ,
  HAL_I2C_STATE_BUSY_RX = 0x22U , HAL_I2C_STATE_LISTEN = 0x28U , HAL_I2C_STATE_BUSY_TX_LISTEN = 0x29U , HAL_I2C_STATE_BUSY_RX_LISTEN = 0x2AU ,
  HAL_I2C_STATE_ABORT = 0x60U , HAL_I2C_STATE_TIMEOUT = 0xA0U , HAL_I2C_STATE_ERROR = 0xE0U
enum  HAL_I2C_ModeTypeDef { HAL_I2C_MODE_NONE = 0x00U , HAL_I2C_MODE_MASTER = 0x10U , HAL_I2C_MODE_SLAVE = 0x20U , HAL_I2C_MODE_MEM = 0x40U }
HAL_StatusTypeDef HAL_I2C_Init (I2C_HandleTypeDef *hi2c)
HAL_StatusTypeDef HAL_I2C_DeInit (I2C_HandleTypeDef *hi2c)
void HAL_I2C_MspInit (I2C_HandleTypeDef *hi2c)
void HAL_I2C_MspDeInit (I2C_HandleTypeDef *hi2c)
HAL_StatusTypeDef HAL_I2C_Master_Transmit (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size, uint32_t Timeout)
HAL_StatusTypeDef HAL_I2C_Master_Receive (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size, uint32_t Timeout)
HAL_StatusTypeDef HAL_I2C_Slave_Transmit (I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size, uint32_t Timeout)
HAL_StatusTypeDef HAL_I2C_Slave_Receive (I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size, uint32_t Timeout)
HAL_StatusTypeDef HAL_I2C_Mem_Write (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint16_t MemAddress, uint16_t MemAddSize, uint8_t *pData, uint16_t Size, uint32_t Timeout)
HAL_StatusTypeDef HAL_I2C_Mem_Read (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint16_t MemAddress, uint16_t MemAddSize, uint8_t *pData, uint16_t Size, uint32_t Timeout)
HAL_StatusTypeDef HAL_I2C_IsDeviceReady (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint32_t Trials, uint32_t Timeout)
HAL_StatusTypeDef HAL_I2C_Master_Transmit_IT (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_I2C_Master_Receive_IT (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_I2C_Slave_Transmit_IT (I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_I2C_Slave_Receive_IT (I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_I2C_Mem_Write_IT (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint16_t MemAddress, uint16_t MemAddSize, uint8_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_I2C_Mem_Read_IT (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint16_t MemAddress, uint16_t MemAddSize, uint8_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_I2C_Master_Seq_Transmit_IT (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size, uint32_t XferOptions)
HAL_StatusTypeDef HAL_I2C_Master_Seq_Receive_IT (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size, uint32_t XferOptions)
HAL_StatusTypeDef HAL_I2C_Slave_Seq_Transmit_IT (I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size, uint32_t XferOptions)
HAL_StatusTypeDef HAL_I2C_Slave_Seq_Receive_IT (I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size, uint32_t XferOptions)
HAL_StatusTypeDef HAL_I2C_EnableListen_IT (I2C_HandleTypeDef *hi2c)
HAL_StatusTypeDef HAL_I2C_DisableListen_IT (I2C_HandleTypeDef *hi2c)
HAL_StatusTypeDef HAL_I2C_Master_Abort_IT (I2C_HandleTypeDef *hi2c, uint16_t DevAddress)
HAL_StatusTypeDef HAL_I2C_Master_Transmit_DMA (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_I2C_Master_Receive_DMA (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_I2C_Slave_Transmit_DMA (I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_I2C_Slave_Receive_DMA (I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_I2C_Mem_Write_DMA (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint16_t MemAddress, uint16_t MemAddSize, uint8_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_I2C_Mem_Read_DMA (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint16_t MemAddress, uint16_t MemAddSize, uint8_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_I2C_Master_Seq_Transmit_DMA (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size, uint32_t XferOptions)
HAL_StatusTypeDef HAL_I2C_Master_Seq_Receive_DMA (I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size, uint32_t XferOptions)
HAL_StatusTypeDef HAL_I2C_Slave_Seq_Transmit_DMA (I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size, uint32_t XferOptions)
HAL_StatusTypeDef HAL_I2C_Slave_Seq_Receive_DMA (I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size, uint32_t XferOptions)
void HAL_I2C_EV_IRQHandler (I2C_HandleTypeDef *hi2c)
void HAL_I2C_ER_IRQHandler (I2C_HandleTypeDef *hi2c)
void HAL_I2C_MasterTxCpltCallback (I2C_HandleTypeDef *hi2c)
void HAL_I2C_MasterRxCpltCallback (I2C_HandleTypeDef *hi2c)
void HAL_I2C_SlaveTxCpltCallback (I2C_HandleTypeDef *hi2c)
void HAL_I2C_SlaveRxCpltCallback (I2C_HandleTypeDef *hi2c)
void HAL_I2C_AddrCallback (I2C_HandleTypeDef *hi2c, uint8_t TransferDirection, uint16_t AddrMatchCode)
void HAL_I2C_ListenCpltCallback (I2C_HandleTypeDef *hi2c)
void HAL_I2C_MemTxCpltCallback (I2C_HandleTypeDef *hi2c)
void HAL_I2C_MemRxCpltCallback (I2C_HandleTypeDef *hi2c)
void HAL_I2C_ErrorCallback (I2C_HandleTypeDef *hi2c)
void HAL_I2C_AbortCpltCallback (I2C_HandleTypeDef *hi2c)
HAL_I2C_StateTypeDef HAL_I2C_GetState (const I2C_HandleTypeDef *hi2c)
HAL_I2C_ModeTypeDef HAL_I2C_GetMode (const I2C_HandleTypeDef *hi2c)
uint32_t HAL_I2C_GetError (const I2C_HandleTypeDef *hi2c)
Author
MCD Application Team
Attention
