RTEMS 6.1-rc2
HAL Mode structure definition. More...
enum  HAL_I2C_ModeTypeDef { HAL_I2C_MODE_NONE = 0x00U , HAL_I2C_MODE_MASTER = 0x10U , HAL_I2C_MODE_SLAVE = 0x20U , HAL_I2C_MODE_MEM = 0x40U }
Note
HAL I2C Mode value coding follow below described bitmap :
b7 (not used)
x : Should be set to 0
b6
0 : None
1 : Memory (HAL I2C communication is in Memory Mode)
b5
0 : None
1 : Slave (HAL I2C communication is in Slave Mode)
b4
0 : None
1 : Master (HAL I2C communication is in Master Mode)
b3-b2-b1-b0 (not used)
xxxx : Should be set to 0000
◆ HAL_I2C_ModeTypeDef
HAL_I2C_MODE_NONE
No I2C communication on going
HAL_I2C_MODE_MASTER
HAL_I2C_MODE_SLAVE
HAL_I2C_MODE_MEM
