RTEMS 6.1-rc2
HAL State structure definition. More...
enum  HAL_I2C_StateTypeDef {
  HAL_I2C_STATE_RESET = 0x00U , HAL_I2C_STATE_READY = 0x20U , HAL_I2C_STATE_BUSY = 0x24U , HAL_I2C_STATE_BUSY_TX = 0x21U ,
  HAL_I2C_STATE_BUSY_RX = 0x22U , HAL_I2C_STATE_LISTEN = 0x28U , HAL_I2C_STATE_BUSY_TX_LISTEN = 0x29U , HAL_I2C_STATE_BUSY_RX_LISTEN = 0x2AU ,
  HAL_I2C_STATE_ABORT = 0x60U , HAL_I2C_STATE_TIMEOUT = 0xA0U , HAL_I2C_STATE_ERROR = 0xE0U
Note
HAL I2C State value coding follow below described bitmap :
b7-b6 Error information
00 : No Error
01 : Abort (Abort user request on going)
10 : Timeout
11 : Error
b5 Peripheral initialization status
0 : Reset (peripheral not initialized)
1 : Init done (peripheral initialized and ready to use. HAL I2C Init function called)
b4 (not used)
x : Should be set to 0
b3
0 : Ready or Busy (No Listen mode ongoing)
1 : Listen (peripheral in Address Listen Mode)
b2 Intrinsic process state
0 : Ready
1 : Busy (peripheral busy with some configuration or internal operations)
b1 Rx state
0 : Ready (no Rx operation ongoing)
1 : Busy (Rx operation ongoing)
b0 Tx state
0 : Ready (no Tx operation ongoing)
1 : Busy (Tx operation ongoing)
◆ HAL_I2C_StateTypeDef
HAL_I2C_STATE_RESET
Peripheral is not yet Initialized
HAL_I2C_STATE_READY
Peripheral Initialized and ready for use
HAL_I2C_STATE_BUSY
An internal process is ongoing
Data Transmission process is ongoing
Data Reception process is ongoing
Address Listen Mode is ongoing
Address Listen Mode and Data Transmission process is ongoing
Address Listen Mode and Data Reception process is ongoing
HAL_I2C_STATE_ABORT
Abort user request ongoing
Timeout state
HAL_I2C_STATE_ERROR
Error
