RTEMS 6.1-rc2
ssc.h File Reference
#include "chip.h"
#include <stdint.h>
void SSC_Configure (Ssc *ssc, uint32_t bitRate, uint32_t masterClock)
 Configures a SSC peripheral.If the divided clock is not used, the master clock frequency can be set to 0.
void SSC_ConfigureTransmitter (Ssc *ssc, uint32_t tcmr, uint32_t tfmr)
 Configures the transmitter of a SSC peripheral.
void SSC_ConfigureReceiver (Ssc *ssc, uint32_t rcmr, uint32_t rfmr)
 Configures the receiver of a SSC peripheral.
void SSC_EnableTransmitter (Ssc *ssc)
 Enables the transmitter of a SSC peripheral.
void SSC_DisableTransmitter (Ssc *ssc)
 Disables the transmitter of a SSC peripheral.
void SSC_EnableReceiver (Ssc *ssc)
 Enables the receiver of a SSC peripheral.
void SSC_DisableReceiver (Ssc *ssc)
 Disables the receiver of a SSC peripheral.
void SSC_EnableInterrupts (Ssc *ssc, uint32_t sources)
 Enables one or more interrupt sources of a SSC peripheral.
void SSC_DisableInterrupts (Ssc *ssc, uint32_t sources)
 Disables one or more interrupt sources of a SSC peripheral.
void SSC_Write (Ssc *ssc, uint32_t frame)
 Sends one data frame through a SSC peripheral. If another frame is currently being sent, this function waits for the previous transfer to complete.
uint32_t SSC_Read (Ssc *ssc)
 Waits until one frame is received on a SSC peripheral, and returns it.
uint8_t SSC_IsRxReady (Ssc *ssc)
 Return 1 if one frame is received, 0 otherwise.
Interface for Synchronous Serial (SSC) controller.
◆ SSC_Configure()
void SSC_Configure ( Ssc ssc,
uint32_t  bitRate,
Note
The emitter and transmitter are disabled by this function.
Parameters
sscPointer to an SSC instance.
bitRatebit rate.
masterClockmaster clock.
◆ SSC_ConfigureReceiver()
void SSC_ConfigureReceiver ( Ssc ssc,
uint32_t  rcmr,
uint32_t  rfmr
Parameters
rcmrReceive Clock Mode Register value.
rfmrReceive Frame Mode Register value.
◆ SSC_ConfigureTransmitter()
void SSC_ConfigureTransmitter ( Ssc ssc,
uint32_t  tcmr,
uint32_t  tfmr
Parameters
tcmrTransmit Clock Mode Register value.
tfmrTransmit Frame Mode Register value.
◆ SSC_DisableInterrupts()
void SSC_DisableInterrupts ( Ssc ssc,
uint32_t  sources
Parameters
sourcesBitwise OR of selected interrupt sources.
◆ SSC_DisableReceiver()
void SSC_DisableReceiver ( Ssc ssc)
Parameters
◆ SSC_DisableTransmitter()
void SSC_DisableTransmitter ( Ssc ssc)
Parameters
◆ SSC_EnableInterrupts()
void SSC_EnableInterrupts ( Ssc ssc,
uint32_t  sources
Parameters
◆ SSC_EnableReceiver()
void SSC_EnableReceiver ( Ssc ssc)
Parameters
◆ SSC_EnableTransmitter()
void SSC_EnableTransmitter ( Ssc ssc)
Parameters
◆ SSC_IsRxReady()
uint8_t SSC_IsRxReady ( Ssc ssc)
Parameters
◆ SSC_Read()
uint32_t SSC_Read ( Ssc ssc)
Parameters
◆ SSC_Write()
void SSC_Write ( Ssc ssc,
uint32_t  frame
Parameters
frameData frame to send.
