RTEMS 6.1-rc2
ssc.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
37#ifndef _SSC_
38#define _SSC_
39
40/*----------------------------------------------------------------------------
41 * Headers
42 *----------------------------------------------------------------------------*/
43#include "chip.h"
44
45#include <stdint.h>
46
47#ifdef __cplusplus
48extern "C" {
49#endif
50
51/*----------------------------------------------------------------------------
52 * Exported functions
53 *----------------------------------------------------------------------------*/
54extern void SSC_Configure(Ssc *ssc, uint32_t bitRate, uint32_t masterClock);
55extern void SSC_ConfigureTransmitter(Ssc *ssc, uint32_t tcmr, uint32_t tfmr);
56extern void SSC_ConfigureReceiver(Ssc *ssc, uint32_t rcmr, uint32_t rfmr);
57extern void SSC_EnableTransmitter(Ssc *ssc);
58extern void SSC_DisableTransmitter(Ssc *ssc);
59extern void SSC_EnableReceiver(Ssc *ssc);
60extern void SSC_DisableReceiver(Ssc *ssc);
61extern void SSC_EnableInterrupts(Ssc *ssc, uint32_t sources);
62extern void SSC_DisableInterrupts(Ssc *ssc, uint32_t sources);
63extern void SSC_Write(Ssc *ssc, uint32_t frame);
64extern uint32_t SSC_Read(Ssc *ssc);
65extern uint8_t SSC_IsRxReady(Ssc *ssc);
66
67#ifdef __cplusplus
68}
69#endif
70
71#endif /* #ifndef _SSC_ */
72
Enables one or more interrupt sources of a SSC peripheral.
Definition: ssc.c:172
Configures the transmitter of a SSC peripheral.
Definition: ssc.c:113
Enables the transmitter of a SSC peripheral.
Definition: ssc.c:135
Waits until one frame is received on a SSC peripheral, and returns it.
Definition: ssc.c:204
Sends one data frame through a SSC peripheral. If another frame is currently being sent,...
Definition: ssc.c:193
Return 1 if one frame is received, 0 otherwise.
Definition: ssc.c:215
Enables the receiver of a SSC peripheral.
Definition: ssc.c:153
Configures a SSC peripheral.If the divided clock is not used, the master clock frequency can be set t...
Definition: ssc.c:87
Configures the receiver of a SSC peripheral.
Definition: ssc.c:125
Disables one or more interrupt sources of a SSC peripheral.
Definition: ssc.c:182
Disables the receiver of a SSC peripheral.
Definition: ssc.c:162
Disables the transmitter of a SSC peripheral.
Definition: ssc.c:144
Ssc hardware registers.
Definition: component_ssc.h:41
