RTEMS 6.1-rc2
This source file contains the SPARC-specific implementation of _CPU_ISR_install_raw_handler() and _CPU_ISR_install_vector(). More...
#define | HIGH_BITS_MASK 0xFFFFFC00 |
#define | HIGH_BITS_SHIFT 10 |
#define | LOW_BITS_MASK 0x000003FF |
void | _CPU_ISR_install_raw_handler (uint32_t vector, CPU_ISR_raw_handler new_handler, CPU_ISR_raw_handler *old_handler) |
SPARC specific raw ISR installer. | |
void | _CPU_ISR_install_vector (uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler) |
SPARC specific RTEMS ISR installer. | |
const CPU_Trap_table_entry | _CPU_Trap_slot_template |
void _CPU_ISR_install_raw_handler | ( | uint32_t | vector, |
CPU_ISR_raw_handler | new_handler, | ||
CPU_ISR_raw_handler * | old_handler | ||
This routine installs new_handler to be directly called from the trap table.
[in] | vector | is the vector number |
[in] | new_handler | is the new ISR handler |
[in] | old_handler | will contain the old ISR handler |
const CPU_Trap_table_entry _CPU_Trap_slot_template |
This is the set of opcodes for the instructions loaded into a trap table entry. The routine which installs a handler is responsible for filling in the fields for the _handler address and the _vector trap type.
The constants following this structure are masks for the fields which must be filled in when the handler is installed.
