RTEMS 6.1-rc2
Data Structures | Macros | Typedefs | Enumerations | Functions
rtl-elf.h File Reference
RTEMS Run-Time Linker ELF Headers. More...
#include <rtems/rtl/rtl-fwd.h>
#include <rtems/rtl/rtl-obj-fwd.h>
#include <rtems/rtl/rtl-sym.h>
#include <sys/cdefs.h>
#include <sys/exec_elf.h>
struct  rtems_rtl_mdreloc_trmap
#define ELFSIZE   32
#define _STANDALONE   1
#define RTEMS_RTL_ELF_STRING_MAX   (256)
typedef enum rtems_rtl_elf_rel_status rtems_rtl_elf_rel_status
typedef struct rtems_rtl_mdreloc_trmap rtems_rtl_mdreloc_tramp
enum  rtems_rtl_elf_rel_status { rtems_rtl_elf_rel_no_error , rtems_rtl_elf_rel_failure , rtems_rtl_elf_rel_tramp_cache , rtems_rtl_elf_rel_tramp_add }
uint32_t rtems_rtl_elf_section_flags (const rtems_rtl_obj *obj, const Elf_Shdr *shdr)
uint32_t rtems_rtl_elf_arch_parse_section (const rtems_rtl_obj *obj, int section, const char *name, const Elf_Shdr *shdr, const uint32_t flags)
bool rtems_rtl_elf_arch_section_alloc (const rtems_rtl_obj *obj, rtems_rtl_obj_sect *sect)
bool rtems_rtl_elf_arch_section_free (const rtems_rtl_obj *obj, rtems_rtl_obj_sect *sect)
bool rtems_rtl_elf_rel_resolve_sym (Elf_Word type)
size_t rtems_rtl_elf_relocate_tramp_max_size (void)
rtems_rtl_elf_rel_status rtems_rtl_elf_relocate_rel_tramp (rtems_rtl_obj *obj, const Elf_Rel *rel, const rtems_rtl_obj_sect *sect, const char *symname, const Elf_Byte syminfo, const Elf_Word symvalue)
rtems_rtl_elf_rel_status rtems_rtl_elf_relocate_rela_tramp (rtems_rtl_obj *obj, const Elf_Rela *rela, const rtems_rtl_obj_sect *sect, const char *symname, const Elf_Byte syminfo, const Elf_Word symvalue)
rtems_rtl_elf_rel_status rtems_rtl_elf_relocate_rel (rtems_rtl_obj *obj, const Elf_Rel *rel, const rtems_rtl_obj_sect *sect, const char *symname, const Elf_Byte syminfo, const Elf_Word symvalue)
rtems_rtl_elf_rel_status rtems_rtl_elf_relocate_rela (rtems_rtl_obj *obj, const Elf_Rela *rela, const rtems_rtl_obj_sect *sect, const char *symname, const Elf_Byte syminfo, const Elf_Word symvalue)
bool rtems_rtl_elf_file_check (rtems_rtl_obj *obj, int fd)
bool rtems_rtl_elf_file_load (rtems_rtl_obj *obj, int fd)
bool rtems_rtl_elf_file_unload (rtems_rtl_obj *obj)
rtems_rtl_loader_formatrtems_rtl_elf_file_sig (void)
◆ ELFSIZE
#define ELFSIZE   32
Imported NetBSD ELF Specifics Start.
◆ RTEMS_RTL_ELF_STRING_MAX
Maximum string length. This a read buffering limit rather than a specific ELF length. I hope this is ok as I am concerned about some C++ symbol lengths.
Typedef Documentation
◆ rtems_rtl_elf_rel_status
Imported NetBSD ELF Specifics End. ELF Relocation status codes.
◆ rtems_rtl_mdreloc_tramp
Relocation trampoline relocation data.
There is no error processing the record.
There was a failure processing the record.
The reloc record may need a trampoliine.
Add a trampoliine.
◆ rtems_rtl_elf_arch_parse_section()
uint32_t rtems_rtl_elf_arch_parse_section ( const rtems_rtl_obj obj,
int  section,
const char *  name,
const Elf_Shdr *  shdr,
Architecture specific handler to parse the section and add any flags that may be need to handle the section.
Parameters
objThe object file being relocated.
secitonThe section index.
nameThe name of the section
shdrThe ELF section header.
flagsThe standard ELF parsed flags.
Return values
uint32_tExtra RTL object file flags.
◆ rtems_rtl_elf_arch_section_alloc()
bool rtems_rtl_elf_arch_section_alloc ( const rtems_rtl_obj obj,
rtems_rtl_obj_sect sect
Architecture specific handler to allocate a section. Some sections are specific to an architecture and need special allocators.
Parameters
sectThe section data.
Return values
trueThe allocator was successful.
◆ rtems_rtl_elf_arch_section_free()
bool rtems_rtl_elf_arch_section_free ( const rtems_rtl_obj obj,
Architecture specific handler to free a section. Some sections are specific to an architecture and need special allocators.
Parameters
Return values
◆ rtems_rtl_elf_file_check()
bool rtems_rtl_elf_file_check ( rtems_rtl_obj obj,
int  fd
The ELF format check handler.
Parameters
objThe object being checked.
fdThe file descriptor.
◆ rtems_rtl_elf_file_load()
bool rtems_rtl_elf_file_load ( rtems_rtl_obj obj,
int  fd
The ELF format load handler.
Parameters
objThe object to load.
◆ rtems_rtl_elf_file_sig()
rtems_rtl_loader_format * rtems_rtl_elf_file_sig ( void  )
The ELF format signature handler.
Returns
rtems_rtl_loader_format* The format's signature.
◆ rtems_rtl_elf_file_unload()
bool rtems_rtl_elf_file_unload ( rtems_rtl_obj obj)
The ELF format unload handler.
Parameters
objThe object to unload.
◆ rtems_rtl_elf_rel_resolve_sym()
bool rtems_rtl_elf_rel_resolve_sym ( Elf_Word  type)
Architecture specific handler to check is a relocation record's type is required to resolve a symbol.
Parameters
typeThe type field in the relocation record.
Return values
trueThe relocation record require symbol resolution.
falseThe relocation record does not require symbol resolution.
◆ rtems_rtl_elf_relocate_rel()
rtems_rtl_elf_rel_status rtems_rtl_elf_relocate_rel ( rtems_rtl_obj obj,
const Elf_Rel *  rel,
const rtems_rtl_obj_sect sect,
const char *  symname,
Architecture specific relocation handler compiled in for a specific architecture by the build system. The handler applies the relocation to the target.
Parameters
relThe ELF relocation record.
sectThe section of the object file the relocation is for.
symnameThe symbol's name.
syminfoThe ELF symbol info field.
symvalueIf a symbol is referenced, this is the symbols value.
Return values
rtems_rtl_elf_rel_statusThe result of the trampoline parsing.
◆ rtems_rtl_elf_relocate_rel_tramp()
rtems_rtl_elf_rel_status rtems_rtl_elf_relocate_rel_tramp ( rtems_rtl_obj obj,
Architecture specific relocation trampoline handler compiled in for a specific architecture by the build system. The handler determines if the relocation record requires a trampoline.
Parameters
relaThe ELF relocation record.
Return values
◆ rtems_rtl_elf_relocate_rela()
rtems_rtl_elf_rel_status rtems_rtl_elf_relocate_rela ( rtems_rtl_obj obj,
const Elf_Rela *  rela,
Parameters
relaThe ELF addend relocation record.
Return values
◆ rtems_rtl_elf_relocate_rela_tramp()
rtems_rtl_elf_rel_status rtems_rtl_elf_relocate_rela_tramp ( rtems_rtl_obj obj,
Parameters
Return values
◆ rtems_rtl_elf_relocate_tramp_max_size()
size_t rtems_rtl_elf_relocate_tramp_max_size ( void  )
Architecture specific relocation maximum trampoline size. A trampoline entry of this size is allocated for each unresolved external.
Returns
size_t The maximum size of a trampoline for this architecture.
◆ rtems_rtl_elf_section_flags()
uint32_t rtems_rtl_elf_section_flags ( const rtems_rtl_obj obj,
Architecture specific handler to translate unknown section flags to RTL section flags. If this function returns 0 an error is raised.
Parameters
Return values
0Unknown or unsupported flags.
uint32_tRTL object file flags.
