RTEMS 6.1-rc2
rtems_rtl_obj Struct Reference
#include <rtl-obj.h>
rtems_chain_node link
uint32_t flags
size_t users
size_t refs
int format
const char * fname
const char * oname
const char * aname
off_t ooffset
size_t fsize
rtems_chain_control sections
rtems_chain_control dependents
rtems_rtl_obj_symlocal_table
size_t local_syms
size_t local_size
rtems_rtl_obj_symglobal_table
size_t global_syms
size_t global_size
size_t unresolved
void * text_base
size_t text_size
void * const_base
size_t const_size
void * eh_base
size_t eh_size
void * data_base
size_t data_size
void * bss_base
size_t bss_size
size_t exec_size
void * entry
uint32_t checksum
uint32_t * sec_num
uint32_t obj_num
void * tramp_base
size_t tramp_size
size_t tramp_slots
size_t tramp_slot_size
void * tramp_brk
size_t tramp_relocs
struct link_maplinkmap
void * loader
RTL Object. There is one for each object module loaded plus one for the base kernel image.
Field Documentation
◆ aname
const char* rtems_rtl_obj::aname
The archive name containing the object. NULL means the object is not in a lib
◆ bss_base
void* rtems_rtl_obj::bss_base
The base address of the bss section in memory.
◆ bss_size
size_t rtems_rtl_obj::bss_size
The size of the bss section.
◆ checksum
uint32_t rtems_rtl_obj::checksum
The checksum of the text sections. A zero means do not checksum.
◆ const_base
void* rtems_rtl_obj::const_base
The base address of the const section in memory.
◆ const_size
size_t rtems_rtl_obj::const_size
The size of the const section.
◆ data_base
void* rtems_rtl_obj::data_base
The base address of the data section in memory.
◆ data_size
size_t rtems_rtl_obj::data_size
The size of the data section.
◆ dependents
rtems_chain_control rtems_rtl_obj::dependents
The dependent object files.
◆ eh_base
void* rtems_rtl_obj::eh_base
The base address of the eh section in memory.
◆ eh_size
size_t rtems_rtl_obj::eh_size
The size of the eh section.
◆ entry
void* rtems_rtl_obj::entry
The entry point of the module.
◆ exec_size
size_t rtems_rtl_obj::exec_size
The amount of executable memory allocated
◆ flags
uint32_t rtems_rtl_obj::flags
The status of the object file.
◆ fname
const char* rtems_rtl_obj::fname
The file name for the object.
◆ format
int rtems_rtl_obj::format
The format of the object file.
◆ fsize
size_t rtems_rtl_obj::fsize
Size of the object file.
◆ global_size
size_t rtems_rtl_obj::global_size
Global symbol memory usage.
◆ global_syms
size_t rtems_rtl_obj::global_syms
Global symbol count.
◆ global_table
rtems_rtl_obj_sym* rtems_rtl_obj::global_table
Global symbol table.
◆ link
rtems_chain_node rtems_rtl_obj::link
The node's link in the chain.
◆ linkmap
struct link_map* rtems_rtl_obj::linkmap
For GDB.
◆ loader
void* rtems_rtl_obj::loader
The file details specific to a loader.
◆ local_size
size_t rtems_rtl_obj::local_size
Local symbol memory usage.
◆ local_syms
size_t rtems_rtl_obj::local_syms
Local symbol count.
◆ local_table
rtems_rtl_obj_sym* rtems_rtl_obj::local_table
Local symbol table.
◆ obj_num
uint32_t rtems_rtl_obj::obj_num
The count of elf files in an rtl obj.
◆ oname
const char* rtems_rtl_obj::oname
The object file name. Can be relative.
◆ ooffset
off_t rtems_rtl_obj::ooffset
The object offset in the archive.
◆ refs
size_t rtems_rtl_obj::refs
References to the object file.
◆ sec_num
uint32_t* rtems_rtl_obj::sec_num
The sec nums of each obj.
◆ sections
rtems_chain_control rtems_rtl_obj::sections
The sections of interest in the object file.
◆ text_base
void* rtems_rtl_obj::text_base
The base address of the text section in memory.
◆ text_size
size_t rtems_rtl_obj::text_size
The size of the text section.
◆ tramp_base
void* rtems_rtl_obj::tramp_base
Trampoline memory. Used for fixups or veneers
◆ tramp_brk
void* rtems_rtl_obj::tramp_brk
Trampoline memory allocator. MD relocators can take memory from the break up to the size.
◆ tramp_relocs
size_t rtems_rtl_obj::tramp_relocs
Number of slots reserved for relocs. The remainder are for unresolved symbols.
◆ tramp_size
size_t rtems_rtl_obj::tramp_size
Size of a trampoline memory.
◆ tramp_slot_size
size_t rtems_rtl_obj::tramp_slot_size
The number of tampoline slots.
◆ tramp_slots
size_t rtems_rtl_obj::tramp_slots
◆ unresolved
size_t rtems_rtl_obj::unresolved
The number of unresolved relocations.
◆ users
size_t rtems_rtl_obj::users
Users of this object file, number of loads.
