RTEMS 6.1-rc2
#include <stdbool.h>
#include <stdint.h>
#include <rtems/rfs/rtems-rfs-inode.h>
#include <rtems/rfs/rtems-rfs-mutex.h>
#include <rtems/libio_.h>
#include <rtems/fs.h>
struct  rtems_rfs_rtems_private
#define RTEMS_RFS_RTEMS_ERROR   0
#define RTEMS_RFS_RTEMS_TRACE   0
#define rtems_rfs_rtems_error(_m, _e)    (((errno = (_e)) == 0) ? 0 : -1)
#define RTEMS_RFS_RTEMS_DEBUG_ALL   (0xffffffff)
#define RTEMS_RFS_RTEMS_DEBUG_ERROR_MSGS   (1 << 0)
#define RTEMS_RFS_RTEMS_DEBUG_EVAL_PATH   (1 << 1)
#define RTEMS_RFS_RTEMS_DEBUG_EVAL_FOR_MAKE   (1 << 2)
#define RTEMS_RFS_RTEMS_DEBUG_EVAL_PERMS   (1 << 3)
#define RTEMS_RFS_RTEMS_DEBUG_MKNOD   (1 << 4)
#define RTEMS_RFS_RTEMS_DEBUG_RMNOD   (1 << 5)
#define RTEMS_RFS_RTEMS_DEBUG_LINK   (1 << 6)
#define RTEMS_RFS_RTEMS_DEBUG_UNLINK   (1 << 7)
#define RTEMS_RFS_RTEMS_DEBUG_CHOWN   (1 << 8)
#define RTEMS_RFS_RTEMS_DEBUG_READLINK   (1 << 9)
#define RTEMS_RFS_RTEMS_DEBUG_FCHMOD   (1 << 10)
#define RTEMS_RFS_RTEMS_DEBUG_STAT   (1 << 11)
#define RTEMS_RFS_RTEMS_DEBUG_RENAME   (1 << 12)
#define RTEMS_RFS_RTEMS_DEBUG_DIR_RMNOD   (1 << 13)
#define RTEMS_RFS_RTEMS_DEBUG_FILE_OPEN   (1 << 14)
#define RTEMS_RFS_RTEMS_DEBUG_FILE_CLOSE   (1 << 15)
#define RTEMS_RFS_RTEMS_DEBUG_FILE_READ   (1 << 16)
#define RTEMS_RFS_RTEMS_DEBUG_FILE_WRITE   (1 << 17)
#define RTEMS_RFS_RTEMS_DEBUG_FILE_LSEEK   (1 << 18)
#define RTEMS_RFS_RTEMS_DEBUG_FILE_FTRUNC   (1 << 19)
#define rtems_rfs_rtems_trace(_m)   (0)
#define rtems_rfs_rtems_trace_set_mask(_m)
#define rtems_rfs_rtems_trace_clear_mask(_m)
#define rtems_rfs_rtems_pathloc_dev(_loc)    ((rtems_rfs_file_system*)((_loc)->mt_entry->fs_info))
#define rtems_rfs_rtems_set_pathloc_ino(_loc, _ino)    (_loc)->node_access = (void*)((intptr_t)(_ino))
#define rtems_rfs_rtems_get_pathloc_ino(_loc)    ((rtems_rfs_ino) (intptr_t)((_loc)->node_access))
#define rtems_rfs_rtems_set_pathloc_doff(_loc, _doff)    (_loc)->node_access_2 = (void*)((intptr_t)(_doff))
#define rtems_rfs_rtems_get_pathloc_doff(_loc)    ((uint32_t) (intptr_t)((_loc)->node_access_2))
#define rtems_rfs_rtems_get_iop_ino(_iop)    ((intptr_t)(_iop)->pathinfo.node_access)
#define rtems_rfs_rtems_get_iop_file_handle(_iop)    ((rtems_rfs_file_handle*)(_iop)->pathinfo.node_access_2)
#define rtems_rfs_rtems_set_iop_file_handle(_iop, _fh)    (_iop)->pathinfo.node_access_2 = (_fh)
#define rtems_rfs_rtems_handlers(_h)    &rtems_rfs_rtems_ ## _h ## _handlers
typedef struct rtems_rfs_rtems_private rtems_rfs_rtems_private
bool rtems_rfs_rtems_set_handlers (rtems_filesystem_location_info_t *pathloc, rtems_rfs_inode_handle *inode)
uint16_t rtems_rfs_rtems_imode (mode_t mode)
mode_t rtems_rfs_rtems_mode (int imode)
int rtems_rfs_rtems_fstat (const rtems_filesystem_location_info_t *pathloc, struct stat *buf)
int rtems_rfs_rtems_rmnod (const rtems_filesystem_location_info_t *parent_pathloc, const rtems_filesystem_location_info_t *pathloc)
int rtems_rfs_rtems_fdatasync (rtems_libio_t *iop)
const rtems_filesystem_file_handlers_r rtems_rfs_rtems_dir_handlers
const rtems_filesystem_file_handlers_r rtems_rfs_rtems_device_handlers
const rtems_filesystem_file_handlers_r rtems_rfs_rtems_link_handlers
const rtems_filesystem_file_handlers_r rtems_rfs_rtems_file_handlers
RTEMS File System RTEMS Header file.
This file is not to be installed. It binds the RFS file system to RTEMS.
◆ RTEMS_RFS_RTEMS_DEBUG_ALL
Trace message defines the RTEMS bindings of the RTEMS RFS. This is a development tool where can edit the values below to control the various trace output.
◆ RTEMS_RFS_RTEMS_ERROR
RTEMS RFS RTEMS Error Enable. Set to 1 for printing of errors. Default is off.
◆ rtems_rfs_rtems_error
#define rtems_rfs_rtems_error (   _m,
  _e
If we are not handling errors provide a define that removes the strings from the code.
◆ rtems_rfs_rtems_get_iop_file_handle
#define rtems_rfs_rtems_get_iop_file_handle (   _iop)     ((rtems_rfs_file_handle*)(_iop)->pathinfo.node_access_2)
Get the file handle from the I/O pointer.
Parameters
_iopThe I/O pointer.
Returns
filehandle The file handle
◆ rtems_rfs_rtems_get_iop_ino
#define rtems_rfs_rtems_get_iop_ino (   _iop)     ((intptr_t)(_iop)->pathinfo.node_access)
Get the ino from the I/O pointer.
Parameters
[in]_iopis the I/O pointer.
Returns
ino
◆ rtems_rfs_rtems_get_pathloc_doff
#define rtems_rfs_rtems_get_pathloc_doff (   _loc)     ((uint32_t) (intptr_t)((_loc)->node_access_2))
Get the directory offset (doff) given a path location.
Parameters
[in]_locis a pointer to the path location.
Returns
uin32_t The doff in the path location.
◆ rtems_rfs_rtems_get_pathloc_ino
#define rtems_rfs_rtems_get_pathloc_ino (   _loc)     ((rtems_rfs_ino) (intptr_t)((_loc)->node_access))
Get the inode number (ino) given a path location.
Parameters
Returns
rtems_rfs_ino The inode number in the path location.
◆ rtems_rfs_rtems_handlers
#define rtems_rfs_rtems_handlers (   _h)     &rtems_rfs_rtems_ ## _h ## _handlers
Create the name of the handler's table given the type of handlers.
Parameters
[in]_his the name of the handlers.
Returns
label The name of the handler's table.
◆ rtems_rfs_rtems_pathloc_dev
#define rtems_rfs_rtems_pathloc_dev (   _loc)     ((rtems_rfs_file_system*)((_loc)->mt_entry->fs_info))
Return the file system structure given a path location.
Parameters
Returns
◆ rtems_rfs_rtems_set_iop_file_handle
#define rtems_rfs_rtems_set_iop_file_handle (   _iop,
  _fh
Set the file handle in the I/O pointer.
Parameters
[in]_fhis the file handle.
◆ rtems_rfs_rtems_set_pathloc_doff
#define rtems_rfs_rtems_set_pathloc_doff (   _loc,
  _doff
Set the directory offset (doff) into the path location.
Parameters
[in]_doffis the doff to set in the path location.
◆ rtems_rfs_rtems_set_pathloc_ino
#define rtems_rfs_rtems_set_pathloc_ino (   _loc,
  _ino
Set the inode number (ino) into the path location.
Parameters
[in]_inois the ino to set in the path location.
◆ RTEMS_RFS_RTEMS_TRACE
RTEMS RFS RTEMS Trace Enable. Set to 1 for printing of errors. Default is off.
◆ rtems_rfs_rtems_trace
#define rtems_rfs_rtems_trace (   _m)    (0)
Call to check if this part is bring traced. If RTEMS_RFS_RTEMS_TRACE is defined to 0 the code is dead code elminiated when built with -Os, -O2, or higher.
Parameters
[in]maskis the part of the API to trace.
Return values
trueTracing is active for the mask.
falseDo not trace.
◆ rtems_rfs_rtems_trace_clear_mask
#define rtems_rfs_rtems_trace_clear_mask (   _m)
Clear the mask.
Parameters
[in]maskis the mask bits to clear.
Return values
maskThe previous mask.
◆ rtems_rfs_rtems_trace_set_mask
#define rtems_rfs_rtems_trace_set_mask (   _m)
Set the mask.
Parameters
[in]maskis the mask bits to set.
Return values
Typedef Documentation
◆ rtems_rfs_rtems_private
Add shell trace shell command. Private RFS RTEMS Port data.
◆ rtems_rfs_rtems_fdatasync()
int rtems_rfs_rtems_fdatasync ( rtems_libio_t iop)
The following routine does a sync on an inode node. Currently it flushes everything related to this device.
Parameters
iop
Parameters
iop
Returns
int
◆ rtems_rfs_rtems_fstat()
int rtems_rfs_rtems_fstat ( const rtems_filesystem_location_info_t pathloc,
struct stat *  buf
The following routine does a stat on a node.
◆ rtems_rfs_rtems_imode()
uint16_t rtems_rfs_rtems_imode ( mode_t  mode)
Convert the system mode flags to inode mode flags.
Parameters
[in]modeis the system mode flags.
Returns
uint16_t The inode mode flags.
◆ rtems_rfs_rtems_mode()
mode_t rtems_rfs_rtems_mode ( int  imode)
Convert the inode mode flags to system mode flags.
Parameters
[in]imodeis the inode mode flags
Returns
mode_t The system mode flags.
◆ rtems_rfs_rtems_rmnod()
int rtems_rfs_rtems_rmnod ( const rtems_filesystem_location_info_t parent_pathloc,
Routine to remove a node from the RFS file system.
Parameters
parent_pathloc
pathloc
Parameters
parent_pathloc
pathloc
Returns
int
◆ rtems_rfs_rtems_set_handlers()
bool rtems_rfs_rtems_set_handlers ( rtems_filesystem_location_info_t pathloc,
rtems_rfs_inode_handle inode
Set the handlers in the path location based on the mode of the inode.
Parameters
[in]locis a pointer to the path location to set the handlers in.
[in]inodeis the inode handle to check the mode of for the type of handlers.
Return values
trueThe handlers have been set.
falseThere are no handlers for the mode.
Variable Documentation
◆ rtems_rfs_rtems_dir_handlers
extern
The handlers.
◆ rtems_rfs_rtems_link_handlers
extern
Handler table for RFS link nodes
