RTEMS 6.1-rc2
rap.c File Reference
RTEMS Application Loader. More...
#include <pthread.h>
#include <stdarg.h>
#include <rtems/libio_.h>
#include <dlfcn.h>
#include <rtems/rtl/rap.h>
#include <rtems/rtl/rtl.h>
#include "rtl-find-file.h"
struct  rtems_rap_data_s
struct  rtems_rap_app
#define RTL_ENTRY_POINT   "_rtems"
typedef struct rtems_rap_data_s rtems_rap_data
typedef struct rtems_rap_app rtems_rap_app
typedef int(* rtems_rap_entry) (int argc, const char *argv[])
bool rtems_rap_load (const char *name, int mode, int argc, const char *argv[])
bool rtems_rap_unload (const char *name)
void * rtems_rap_find (const char *name)
bool rtems_rap_iterate (rtems_rap_iterator iterator)
const char * rtems_rap_name (void *handle)
void * rtems_rap_dl_handle (void *handle)
int rtems_rap_get_error (char *message, size_t max_message)
This is the RAP implementation.
◆ RTL_ENTRY_POINT
RTL entry.
Typedef Documentation
◆ rtems_rap_app
The RAP file data. This structure is allocated on the heap when a file is loaded.
◆ rtems_rap_data
The global RAP data. This structure is allocated on the heap when the first call to location an application and is never released.
◆ rtems_rap_entry
RAP entry call signature.
◆ rtems_rap_dl_handle()
void * rtems_rap_dl_handle ( void *  handle)
Return the DL handle used to load the module given the RAP handle.
Parameters
handleThe module handle.
Returns
void* The DL handle returned by the dlopen call.
◆ rtems_rap_find()
void * rtems_rap_find ( const char *  name)
Find the application handle given a file name.
Parameters
nameThe name of the application file. It can be absolute or relative. Relative names can the basename with an extension.
Return values
NULLNo application file with that name found.
Returns
void* The application descriptor.
◆ rtems_rap_get_error()
int rtems_rap_get_error ( char *  message,
size_t  max_message
Get the last error message clearing it. This call is not thread safe is multiple threads are loading object files at the same time. This call follows the model provided by the dlopen family of calls.
Parameters
messagePointer to a buffer to copy the message into.
max_messageThe maximum message that can be copied.
Returns
int The last error number.
◆ rtems_rap_iterate()
bool rtems_rap_iterate ( rtems_rap_iterator  iterator)
Run an iterator over the modules calling the iterator function.
Parameters
iteratorThe iterator function.
Return values
trueThe iterator function returned did not return false.
falseThe iterator function returned false..
◆ rtems_rap_load()
bool rtems_rap_load ( const char *  name,
int  mode,
int  argc,
const char *  argv[]
Load an application.
Parameters
Returns
bool True if the module loads else an error.
◆ rtems_rap_name()
const char * rtems_rap_name ( void *  handle)
Return the name of the module given a handle.
Parameters
Returns
const char* The name of the module if the handle is valid else it is NULL.
◆ rtems_rap_unload()
bool rtems_rap_unload ( const char *  name)
Unload an application.
Parameters
objThe application descriptor.
Return values
trueThe application file has been unloaded.
falseThe application could not be unloaded.
