RTEMS 6.1-rc2
rtl-find-file.h
2
11/*
12 * COPYRIGHT (c) 2012-2013 Chris Johns <chrisj@rtems.org>
13 *
16 * are met:
22 *
34 */
35
36#if !defined (_RTEMS_RTL_FIND_FILE_H_)
37#define _RTEMS_RTL_FIND_FILE_H_
38
39#include <rtems.h>
40#include <rtems/chain.h>
41
42#ifdef __cplusplus
43extern "C" {
44#endif /* __cplusplus */
45
56bool rtems_rtl_find_file (const char* name,
57 const char* paths,
58 const char** file_name,
59 size_t* size);
60
61#ifdef __cplusplus
62}
63#endif /* __cplusplus */
64
65#endif
This header file provides the Chains API.
bool rtems_rtl_find_file(const char *name, const char *paths, const char **file_name, size_t *size)
Definition: rtl-find-file.c:61
